    Pattern Pressure Advance Calibration
    66
    8.7k
      jay_s_uk @Alex9779
      @Alex9779 I hadn't noticed your PR. Doesn't matter though as yours was more elegant than mine anyway. Plus I need to coding practice.
      Next up is adding RRF commands to Andrews guide where required.
      Alex9779undefined 1 Reply Last reply Reply Quote 0
      • Alex9779undefined
        Alex9779 @jay_s_uk
        @jay_s_uk 👍 like it, his guide is so good, I got so good initial results after I built my Voron just by adapting his profiles.
        I hope his PA calibration will spread, with that generator it is so much easier to do.
        Maybe someone can put that into the Duet docs too? https://docs.duet3d.com/en/User_manual/Tuning/Pressure_advance
          jay_s_uk
          @droftarts is the man to add it to the docs
          • CCS86undefined
            CCS86
            Is anyone else seeing an over extrusion in the label area infill?
            My perimeters and test lines are extruding perfectly. But that small pane of solid significantly over-extrudes the infill.
            I double checked and compared to the perimeters, the line spacing and extrusion rates match. My best guess is that there is too much overlap between infill and perimeters.
            :edit:
            That seems to be the issue. And possibly a doubled up infill line as well. Plus too much overlap with the perimeter of the main anchor:
            I'm also wondering why the test lines seem under-extruded on the first layer. Are they being extruded at a rate for the nominal layer thickness, not the first layer thickness?
            Ellisundefined 1 Reply Last reply Reply Quote 0
            • Ellisundefined
              Ellis @CCS86
              @CCS86
              Hey guys.
              • The first layer can look a bit overextruded partly because it uses your starting PA (often 0).
              • The infill/perimeter overlap should be 25% but I will verify that is working properly
              • The doubled-up infill line is a bug I just fixed today actually, will be pushing that up soon
              • The extra overlap for the number tab is on purpose, but even with that extra overlap I'm seeing people with the tab not sticking, hah. It was meant to help it be more likely to stick for folks whose squish isn't quite enough. Ideally it would slice it all as one object rather than two rectangles overlapping, but coding is hard, so just two rectangles for now, heh.
              • I'll also check the extrusion rates for first layer vs other layers
              CCS86undefined 1 Reply Last reply Reply Quote 1
              • CCS86undefined
                CCS86 @Ellis
                @Ellis said in Pattern Pressure Advance Calibration:
                @CCS86
                Hey guys.
                Maybe you could add a parameter that people could use to assist in first layer adhesion.
                I have mine dialed in and don't need the extra overlap:
                You can see that my first attempt had great perimeter extrusion, very over-extruded in the tab, and under-extrusion on the test lines.
                • Ellisundefined
                  Ellis @CCS86
                  @CCS86 I don't think it's worth adding more setting clutter for the tab overlap. It's not causing any actual issues, is it?
                  The tab isn't usually that bad. When I said it looks a little overextruded, I meant more like this:
                  https://photos.app.goo.gl/4HSMCC2aQ2mmb7pWA
                  I think something else may be contributing there. Your pattern ends are very blobby at 0 PA so that's likely also reflecting in the tab. And the perimeters there don't show minor over-squish nearly as much as the tab does
                  140% default anchor line width is also fairly fat, which may contribute
                  For now try the anchor layer rather than the anchor frame to get the patterns to stick - I will look at first layer flow there later today
                  Also please share your gcode file
                  CCS86undefined 1 Reply Last reply Reply Quote 0
                  • CCS86undefined
                    CCS86 @Ellis
                    @Ellis
                    Here is the gcode file:
                    pa_pattern.gcode
                    I am using 118% for both line widths, and a 0.25mm first layer height in that photo.
                    My pattern ends at PA0 look less blobby than your IMO, but my tab is more over-extruded:
                    I think it's an issue. Even a 0.1mm Z hop can't clear it, and you can see the nozzle has smeared right through a lot of plastic. Overpressuring the nozzle and smearing through extra plastic isn't the best way to start a precision calibration. There are like 43 settings in the script. If adding 1 more can prevent such bad over-extrusion, that seems well worth it to me.
                    mrehorstdmdundefined Ellisundefined 3 Replies Last reply Reply Quote 0
                    • mrehorstdmdundefined
                      mrehorstdmd @CCS86
                      I've been running some tests using this pattern on my printer with a 1mm nozzle. I set all line widths to 1mm and everything sticks fine (230C PETG at 30 mm/sec on 70C PEI).
                      I'm not entirely sure what I should be looking for in the resulting print- the corners should be sharp and not blobby or gapped, but should I also be looking at the ends of the test lines that print on the anchoring border, or is that more of a retraction tuning issue? I am using the default 0.5 mm retraction...
                      My initial test with the PA at the default range had all the test corners looking identical. I tried again going from 0.1 to 0.5 and finally started to see some gaps in the corners.
                      Ellisundefined 2 Replies Last reply Reply Quote 0
                      • Ellisundefined
                        Ellis @CCS86
                        @CCS86
                        Yes, but you are comparing 30mm/s first layer to my 150mm/s top layers
                        My bottom layers are not as blobby, though you can't see it in that photo
                        • Ellisundefined
                          Ellis @mrehorstdmd
                          @mrehorstdmd Did you see the guide link up top, next to the 3d preview? Has an example in there showing what to look for
                          • Ellisundefined
                            Ellis @CCS86
                            @CCS86 Also just to be clear, I don't mean to hand wave your issues here, just comparing with others
                            • I think the overlap is too much in places as you said, that spot included, so I may reduce that.
                              • Maybe it should also just print the first layer at your current PA, and not set PA until second layer+? Might also help
                            • I am wondering if the overextrusion would be less with 120% first layer width, maybe the default of 140% is just a bit aggressive.
                            • I have pushed a fix for the doubling-up infill line, at least I think so, can you please see if it's still occurring for you?
                            • I think I see a flow issue with the first layer of the pattern itself (not the perims/anchor/tab), working on that bit. Thanks for spotting that. Not 100% sure yet, though, so I'll update here soon
                            • Ellisundefined
                              Ellis @mrehorstdmd
                              @mrehorstdmd I am curious to see some photos with 1mm nozzle, largest nozzle I have seen used so far is 0.8mm
                                mrehorstdmd @Ellis
                                @Ellis I'll print some new tests tonight and shoot some photos and post them. The 1 mm nozzle has been a b**** to print with for everything except single wall vases for a long time. I suspect there's not a lot of pressure in the hot end, and the viscosity of the molten filament probably has less effect on extrusion.
                                • Ellisundefined
                                  Ellis @mrehorstdmd
                                  @mrehorstdmd Found some small errors in the flow math, hold off for now
                                  • Ellisundefined
                                    Ellis @mrehorstdmd
                                    @mrehorstdmd Ok just pushed a bunch of fixes, all clear 🙂
                                    @CCS86 I fixed the flow and overlap issues. The tab seems to print a lot better now. Give it a whirl.
                                    mrehorstdmdundefined CCS86undefined 2 Replies Last reply Reply Quote 1
                                      mrehorstdmd @Ellis
                                      @Ellis Thanks. I didn't get to it last night anyway, so I'll try it tonight.
                                      • CCS86undefined
                                        CCS86 @Ellis
                                        Looks soooo much better in the gcode viewer! I'll try it tonight.
                                        Thanks!
                                        • oliofundefined
                                          oliof
                                          I took the liberty to submit a feature request (firmware retract) and a small bug report (missing unretract length setting).
                                          Ellisundefined 1 Reply Last reply Reply Quote 2
                                          • Ellisundefined
                                            Ellis @oliof
                                            @oliof I don't quite follow the logic behind having a different unretract length. Is that a common thing? Always seemed... bodgy to me. I don't print with large nozzles very often, though, so maybe that's part of it. PA is supposed to help with what you mentioned (needing extra pressure to start), or is that not typically enough?
                                            I think at a certain point it becomes too many settings & too much clutter - it actually had firmware retract and I removed it (and a few other things) to make it leaner. Software retract works for everyone.
                                            Once it starts becoming a wall of settings, it starts to become really overwhelming for new folks.
                                            It's meant to be a quick test with only the features necessary to get it printed, not a full web based slicer with all the same features as your desktop one, y'know?
                                            Hell, I've even thought about getting rid of the Z hop settings and just baking in the 0.1mm z-hop.
                                            mrehorstdmdundefined oliofundefined 2 Replies Last reply Reply Quote 1
