    My Pi Zero 2W Adapter for Duet 3 | Duet 3 Mini 5+
    664
    • PCRundefined
      PCR
      Tested the PCB today. Works great.
      Have 2 more of the Prototypen!
      Will give it away for shipping. You only need the Pi. I will include connectors
      Best
      And yes i knew the CSI connector... Next Revision will fix it.
      PCRundefined o_lampeundefined Rushmere3Dundefined Nurgelrotundefined 4 Replies Last reply Reply Quote 4
      • PCRundefined
        PCR @PCR
        • o_lampeundefined
          o_lampe @PCR
          @pcr Is there enough clearance for a mini-HDMI_to_HDMI adapter, when the Duet3 header is soldered? The adapter I have is pretty big...
          PCRundefined 1 Reply Last reply Reply Quote 0
          • PCRundefined
            PCR @o_lampe
            @o_lampe If you using a header.for mounting the Pi then yes. I solderd Mine directly on it
            • Rushmere3Dundefined
              Rushmere3D @PCR
              @pcr This might be a stupid question but what does the adaptor do? Can't you just attach a duet3 to the zero with a ribbon cable?
              Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
              • PCRundefined
                PCR @Rushmere3D
                @rushmere3d you could. But with that the Signal way is shorter. You get a USB A Port. And in the next Revision a Buck comverter
                gloomyandyundefined 1 Reply Last reply Reply Quote 0
                • gloomyandyundefined
                  gloomyandy @PCR
                  @pcr Can you post a picture showing how it mounts on the board?
                  • Nurgelrotundefined
                    Nurgelrot @PCR
                    @pcr Amazing work. Please be sure to post when/if your have a production version.
                    • 0nn0undefined
                      0nn0
                      So, did this board ever make it to production? (or is there a schematic which I could use to have it made at a PCB proto fab?)
                      • PCRundefined
                        PCR @0nn0
                        @0nn0 sent PM
