    Your start.g
    886
    • Exerqtorundefined
      Exerqtor
      In the lack of anything nifty to put in start.g myself , what do you got in yours?
      • Proschi3Dundefined
        Proschi3D
        I would be interested in idex start codes
        Love my Duet 3 Mini.
        https://www.instagram.com/proschi3d
        https://youtube.com/@proschi3d
        https://www.proschi3d.de
        • jens55undefined
          jens55
          Can't help you with strat.g but here is my very blah start.g for my jubilee tool changer:
          ; This file is called before any print job
          T-1
          if !move.axes[0].homed || !move.axes[1].homed|| !move.axes[2].homed ; If the printer hasn't been homed, home it
          My start.g file for a creality printer .... doesn't exist.
          Exerqtorundefined 1 Reply Last reply Reply Quote 1
          • Exerqtorundefined
            Exerqtor @jens55
            @jens55 said in Your strart.g:
            Fixed! 😂
            T-1
            Yeah i guess the homing could live there.
              ; start.g - run before slicer gcode at start of print
              M140 S65		; set heated bed to 65 and release
              T0			; Select Tool 0
              M291 P"Print Started. Preheating and Homing." T10
              G4 S1
              M98 P"0:/macros/Musical Tunes/LuckyTune.g" ; Lucky tune to start print off on the right foot
              G4 S1
              M220 S100		; Set speed factor back to 100% in case it was changed
              M221 S100		; Set extrusion factor back to 100% in case it was changed
              M290 R0 S0		; clear babystepping
              M106 S0			; Turn part cooling blower off if it is on
              G10 P0 R0 S80		; Set extruder to 80 and release
              M190 S65		; set heated bed to 65 and wait
              G28			; home XYZ
              G29 S1			; load heightmap
              G10 P0 R80 S180	; Set extruder to 180 and release
              M98 P"0:/sys/ZSpeedsPrint.g"	; Load Z speeds for printing
              M98 P"0:/sys/CurrentsPrint.g"	; Load print motor currents
              M566 P1 ; jerk between all moves
              ; Slicer Start Gcode begins.
              Exerqtorundefined 1 Reply Last reply Reply Quote 0
              • Exerqtorundefined Exerqtor marked this topic as a regular topic
              • mikeabuilderundefined
                mikeabuilder
                I wrote these when I was beginning to learn coding on the Duet, so there may be a better way to do this, but...
                I collect the time (state.time) in one global variable and the print file name (job.file.name) in another.
                Then in stop.g, I collect the time again so I have the elapsed print time. I append the start time, elapsed time, and job name into a file so I can create print statistics.
                When I did this, I thought the data I wanted would be deleted from the object model before stop.g would run.
                And since writing the macro over a year ago, I've never looked at the file once.
                But I'm going to add some of the things from Phaedrux's file, and the checking for homing.
                • Exerqtorundefined
                  Exerqtor @Phaedrux
                  @Phaedrux
                  Got som ideas there! Care to share that lucky tune btw? Just for shits and giggles? 😂
                    Phaedrux Moderator @Exerqtor
                    @Exerqtor Sure, here's a link to all the midi files and converted gcodes I have messed around with.
                    https://artisanalrobotics.ca:22597/d/s/rqPGN0DTNtMvhiQuNXmH3PeHZiEEaQyH/RKWWWVJzciWvzL6y177wNDdw4OZqZWCc-nbqgzzmaHQo
                    And here's the ones that actually ended up working well, including the ones I made myself.
                    https://artisanalrobotics.ca:22597/d/s/rqPKR4rm5OSxkYIFSIrHQ08H5HR5Cir7/CajwpV2Tbtc7FCBjge8daO01bFGstcGA-JbzA8WqaHQo
                    It's a bit hit or miss these days whether the PanelDue will play them smoothly as things have gotten more complex.
                    And here's the original thead with a link to the tool to convert midi to gcode tone.
                    https://forum.duet3d.com/topic/15722/turn-your-printer-into-a-juke-box
                    • Exerqtorundefined
                      Exerqtor @Phaedrux
                      @Phaedrux said in Your start.g:
                      Thanks! Looks like it might be some weirdness happening in RRF 3.5.0b1+ though 🤔 I uploaded luckytune.g and ran it to listen to what it sound like, and each time i excecute the file it plays off in a different pitch/tune lol.
                      On another note (pun intended), I've slapped together something based on your start.g and my excisting print start routine:
                      start.g:
                      ; /sys/lib/print/print_start.g  v2.0
                      ; Called when starting a print (after start.g) at the end of your slicers start code
                      ; Used to configure print parameters
                      M140 S{global.bed_temp}                                                        ; Set bed temperature
                      if exists(global.sb_leds)
                        set global.sb_leds = "heating"                                               ; StealthBurner LED status
                      M116 H0 S5        ; Wait for the bed to reach its temperature +/-5°C
                      M98 "/sys/lib/print/print_probe.g/"                                            ; Pre print mesh macro, if it will probe a mesh or not i controlled by global.Print_Probe(true=on, false=off) and select a mesh accordinlgy
                      M376 H5        ; Set bed compensation taper to 5mm
                      G10 P{global.initial_extruder} R{global.hotend_temp} S{global.hotend_temp}     ; Set active and standby temps for the initial tool
                      M116 H1        ; Wait hotend to reach it's temperature
                      M42 P0 S0.3        ; Turn on chamber lights to 30%
                      G0 Z{(global.first_layer_height + 5)} F3000                                    ; Drop bed to first layer height + 5mm to reduce pucker factor
                      M98 P"/sys/lib/print/print_purge.g"                                            ; Purge the nozzle before starting print
                      M400        ; Wait for moves to finish
                        set global.sb_leds = "printing"                                              ; StealthBurner LED status
                      if exists(global.RunDaemon)
                        set global.RunDaemon = false                                                 ; Disable daemon.g while printing because of bug in RRF 3.5.0b1+
                      OwenDundefined 1 Reply Last reply Reply Quote 0
                      • OwenDundefined
                        OwenD @Exerqtor
                        @Exerqtor
                        If you have daemon.g running it tends to interrupt these "music" macros.
                        I see you have a global runDaemon
                        I use that at the start and finish of the tunes to disable the daemon for the duration of the tune.
                        It depends where the daemon is in terms of its process cycle as to whether the tune ends up unhindered.
                        You may need a G4 at the start of the tune.
                        • Exerqtorundefined
                          Exerqtor @OwenD
                          @OwenD said in Your start.g:
                          @Exerqtor
                          Noted, thx!
                          Proschi3Dundefined 1 Reply Last reply Reply Quote 0
                            Proschi3D @Exerqtor
                            M291 P"Start.g wird ausgeführt" S0
                            M98 P"/Macros/SUB/CheckDoor"          ;Door open or closed
                            M561
                            M106 P3 S0
                            G4 S1
                            M106 P3 S25
                            G4 S1
                            M106 P3 S0
                            G4 S1
                            M106 P3 S25                          ;dimme LED for IR Probe
                            M98 P"/Macros/SUB/Preheat"           ;Preheat for Loaded Filament
                            if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                              G28
                            G28 Z0
                            M98 P"/Macros/Buildplate"            ;Load Hightmap for Buildplate and Filament
                            M98 P"config_probe.g"
                            • apakundefined
                              apak
                              here are some of my start.g
                              https://github.com/macasero/Hbot-3d-Campy/blob/main/MORAN/sys/start.g
                              https://github.com/macasero/Bear-mk3s-duet2/blob/main/sys/start.g
                              https://github.com/macasero/Predator-Duet3mini-smarteffector-REPRAP/blob/main/sys/start.g
