    Your start.g
    888
    • jens55undefined
      jens55
      Can't help you with strat.g but here is my very blah start.g for my jubilee tool changer:
      ; This file is called before any print job
      T-1
      if !move.axes[0].homed || !move.axes[1].homed|| !move.axes[2].homed ; If the printer hasn't been homed, home it
      My start.g file for a creality printer .... doesn't exist.
      Exerqtorundefined 1 Reply Last reply Reply Quote 1
      • Exerqtorundefined
        Exerqtor @jens55
        @jens55 said in Your strart.g:
        Fixed! 😂
        T-1
        Yeah i guess the homing could live there.
          ; start.g - run before slicer gcode at start of print
          M140 S65		; set heated bed to 65 and release
          T0			; Select Tool 0
          M291 P"Print Started. Preheating and Homing." T10
          G4 S1
          M98 P"0:/macros/Musical Tunes/LuckyTune.g" ; Lucky tune to start print off on the right foot
          G4 S1
          M220 S100		; Set speed factor back to 100% in case it was changed
          M221 S100		; Set extrusion factor back to 100% in case it was changed
          M290 R0 S0		; clear babystepping
          M106 S0			; Turn part cooling blower off if it is on
          G10 P0 R0 S80		; Set extruder to 80 and release
          M190 S65		; set heated bed to 65 and wait
          G28			; home XYZ
          G29 S1			; load heightmap
          G10 P0 R80 S180	; Set extruder to 180 and release
          M98 P"0:/sys/ZSpeedsPrint.g"	; Load Z speeds for printing
          M98 P"0:/sys/CurrentsPrint.g"	; Load print motor currents
          M566 P1 ; jerk between all moves
          ; Slicer Start Gcode begins.
          Exerqtorundefined 1 Reply Last reply Reply Quote 0
          • Exerqtorundefined Exerqtor marked this topic as a regular topic
          • mikeabuilderundefined
            mikeabuilder
            I wrote these when I was beginning to learn coding on the Duet, so there may be a better way to do this, but...
            I collect the time (state.time) in one global variable and the print file name (job.file.name) in another.
            Then in stop.g, I collect the time again so I have the elapsed print time. I append the start time, elapsed time, and job name into a file so I can create print statistics.
            When I did this, I thought the data I wanted would be deleted from the object model before stop.g would run.
            And since writing the macro over a year ago, I've never looked at the file once.
            But I'm going to add some of the things from Phaedrux's file, and the checking for homing.
            • Exerqtorundefined
              Exerqtor @Phaedrux
              @Phaedrux
              Got som ideas there! Care to share that lucky tune btw? Just for shits and giggles? 😂
                Phaedrux Moderator @Exerqtor
                @Exerqtor Sure, here's a link to all the midi files and converted gcodes I have messed around with.
                https://artisanalrobotics.ca:22597/d/s/rqPGN0DTNtMvhiQuNXmH3PeHZiEEaQyH/RKWWWVJzciWvzL6y177wNDdw4OZqZWCc-nbqgzzmaHQo
                And here's the ones that actually ended up working well, including the ones I made myself.
                https://artisanalrobotics.ca:22597/d/s/rqPKR4rm5OSxkYIFSIrHQ08H5HR5Cir7/CajwpV2Tbtc7FCBjge8daO01bFGstcGA-JbzA8WqaHQo
                It's a bit hit or miss these days whether the PanelDue will play them smoothly as things have gotten more complex.
                And here's the original thead with a link to the tool to convert midi to gcode tone.
                https://forum.duet3d.com/topic/15722/turn-your-printer-into-a-juke-box
                • Exerqtorundefined
                  Exerqtor @Phaedrux
                  @Phaedrux said in Your start.g:
                  Thanks! Looks like it might be some weirdness happening in RRF 3.5.0b1+ though 🤔 I uploaded luckytune.g and ran it to listen to what it sound like, and each time i excecute the file it plays off in a different pitch/tune lol.
                  On another note (pun intended), I've slapped together something based on your start.g and my excisting print start routine:
                  start.g:
                  ; /sys/lib/print/print_start.g  v2.0
                  ; Called when starting a print (after start.g) at the end of your slicers start code
                  ; Used to configure print parameters
                  M140 S{global.bed_temp}                                                        ; Set bed temperature
                  if exists(global.sb_leds)
                    set global.sb_leds = "heating"                                               ; StealthBurner LED status
                  M116 H0 S5        ; Wait for the bed to reach its temperature +/-5°C
                  M98 "/sys/lib/print/print_probe.g/"                                            ; Pre print mesh macro, if it will probe a mesh or not i controlled by global.Print_Probe(true=on, false=off) and select a mesh accordinlgy
                  M376 H5        ; Set bed compensation taper to 5mm
                  G10 P{global.initial_extruder} R{global.hotend_temp} S{global.hotend_temp}     ; Set active and standby temps for the initial tool
                  M116 H1        ; Wait hotend to reach it's temperature
                  M42 P0 S0.3        ; Turn on chamber lights to 30%
                  G0 Z{(global.first_layer_height + 5)} F3000                                    ; Drop bed to first layer height + 5mm to reduce pucker factor
                  M98 P"/sys/lib/print/print_purge.g"                                            ; Purge the nozzle before starting print
                  M400        ; Wait for moves to finish
                    set global.sb_leds = "printing"                                              ; StealthBurner LED status
                  if exists(global.RunDaemon)
                    set global.RunDaemon = false                                                 ; Disable daemon.g while printing because of bug in RRF 3.5.0b1+
                  OwenDundefined 1 Reply Last reply Reply Quote 0
                  • OwenDundefined
                    OwenD @Exerqtor
                    @Exerqtor
                    If you have daemon.g running it tends to interrupt these "music" macros.
                    I see you have a global runDaemon
                    I use that at the start and finish of the tunes to disable the daemon for the duration of the tune.
                    It depends where the daemon is in terms of its process cycle as to whether the tune ends up unhindered.
                    You may need a G4 at the start of the tune.
                    • Exerqtorundefined
                      Exerqtor @OwenD
                      @OwenD said in Your start.g:
                      @Exerqtor
                      Noted, thx!
                      Proschi3Dundefined 1 Reply Last reply Reply Quote 0
                      • Proschi3Dundefined
                        Proschi3D @Exerqtor
                        M291 P"Start.g wird ausgeführt" S0
                        M98 P"/Macros/SUB/CheckDoor"          ;Door open or closed
                        M561
                        M106 P3 S0
                        G4 S1
                        M106 P3 S25
                        G4 S1
                        M106 P3 S0
                        G4 S1
                        M106 P3 S25                          ;dimme LED for IR Probe
                        M98 P"/Macros/SUB/Preheat"           ;Preheat for Loaded Filament
                        if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                          G28
                        G28 Z0
                        M98 P"/Macros/Buildplate"            ;Load Hightmap for Buildplate and Filament
                        M98 P"config_probe.g"
                        Love my Duet 3 Mini.
                        https://www.instagram.com/proschi3d
                        https://youtube.com/@proschi3d
                        https://www.proschi3d.de
                        • apakundefined
                          apak
                          here are some of my start.g
                          https://github.com/macasero/Hbot-3d-Campy/blob/main/MORAN/sys/start.g
                          https://github.com/macasero/Bear-mk3s-duet2/blob/main/sys/start.g
                          https://github.com/macasero/Predator-Duet3mini-smarteffector-REPRAP/blob/main/sys/start.g
