    Warning: Lost connection to Duet - help needed
    1.1k
    • KCMARINEundefined
      KCMARINE
      M115
      FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.5beta1 ELECTRONICS: Duet 3 MB6HC v1.01 FIRMWARE_DATE: 2022-12-23 18:27:08
      • KCMARINEundefined
        KCMARINE
        When I try to do a calibration print I immediately get a Timeout while waiting for macro ?
        M32 "0:/gcodes/First layer calibration.gcode"
        File 0:/gcodes/First layer calibration.gcode selected for printing
        Error: Timeout while waiting for macro file start.g (channel File2)
        gloomyandyundefined 1 Reply Last reply Reply Quote 0
        • gloomyandyundefined
          gloomyandy @KCMARINE
          @KCMARINE You may want to try the stable release version (3.4.5) to see if you have the same problems. If things work with 3.4.5 then it would probably be a good idea to report the above in the beta section of the forum.
            droftarts administrators @KCMARINE
            @KCMARINE in your M122 I see
            === Storage ===
            Free file entries: 10
            SD card not detected. Check your SD card.
            Scratch that, SBC mode.
            • KCMARINEundefined
              KCMARINE
              Thanks - what's the process to roll back the firmware - I tried to do this by uploading 3.4.5 to DWC, and it did not work - so I am guessing I have to reset and erase and reinstall with BOSSA
                @KCMARINE Are you using an SBC setup? Can you still talk to the board using DWC after you tried to install 3.4.5?
                It looks like you are still on DSF 3.4.5
                @KCMARINE said in Warning: Lost connection to Duet - help needed:
                Duet Control Server v3.4.5
                So you had a mixture of 3.4.5 on the SBC and 3.5beta1 on your Duet board. That's probably not a good idea. Did you deliberately install the beta? What steps did you use to do that?
                This is probably not good:
                TfrRdy pin glitches: 298
                But it may be a side effect of mixing different versions.
                KCMARINEundefined 1 Reply Last reply Reply Quote 1
                • KCMARINEundefined
                  KCMARINE @gloomyandy
                  @gloomyandy, thanks for catching that, mate.
                  A question, please, Can you advise if the MB6HC running 3.4.5 and EXP3HC running 3.4.4 will work?
                  What I did is keep the SBC on 3.4.5 - no change.
                  I removed the Duet 3 MB6HC board from the machine - erased the firmware, and reinstalled it with BOSSA version 3.4.5.
                  I also erased the Duet EXP3HC board and used DWC to load version 3.4.4 as I do not see a later version in the git repo - 3.4.4 was the last release.
                  Confirming:
                  M115
                  FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.5 ELECTRONICS: Duet 3 MB6HC v1.01 FIRMWARE_DATE: 2022-11-30 19:35:23
                  M115 B1
                  Duet EXP3HC rev 1.01 or earlier firmware version 3.4.4 (2022-10-14 11:45:56)
                  M122
                  RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.01 (SBC mode)
                  Board ID: 08DJM-9P63L-DJ3T8-6J9DD-3SJ6N-9B7ZA
                  Used output buffers: 1 of 40 (20 max)
                  Static ram: 152760
                  Dynamic ram: 67576 of which 16 recycled
                  Never used RAM 130320, free system stack 192 words
                  Tasks: SBC(ready,0.6%,473) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,799) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,339) TMC(notifyWait,7.7%,91) MAIN(running,91.4%,923) IDLE(ready,0.4%,30), total 100.0%
                  Owned mutexes: HTTP(MAIN)
                  Last reset 00:02:37 ago, cause: software
                  Last software reset at 2023-01-22 04:24, reason: User, GCodes spinning, available RAM 130276, slot 0
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043c000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                  Error status: 0x00
                  Aux0 errors 0,0,0
                  Step timer max interval 134
                  MCU temperature: min 42.3, current 42.6, max 44.8
                  Supply voltage: min 24.3, current 24.4, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                  12V rail voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0
                  Events: 0 queued, 0 completed
                  Driver 0: standstill, SG min 0, mspos 8, reads 27109, writes 14 timeouts 0
                  Driver 1: standstill, SG min 0, mspos 8, reads 27110, writes 14 timeouts 0
                  Driver 2: standstill, SG min 0, mspos 8, reads 27110, writes 14 timeouts 0
                  Driver 3: standstill, SG min 0, mspos 8, reads 27110, writes 14 timeouts 0
                  Driver 4: standstill, SG min 0, mspos 8, reads 27110, writes 14 timeouts 0
                  Driver 5: standstill, SG min 0, mspos 8, reads 27110, writes 14 timeouts 0
                  Date/time: 2023-01-22 04:27:32
                  Slowest loop: 1.27ms; fastest: 0.05ms
                  === Storage ===
                  DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                  === MainDDARing ===
                  === AuxDDARing ===
                  Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                  Heater 1 is on, I-accum = 0.0
                  Segments left: 0
                  Movement lock held by null
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  SBC is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Aux2 is idle in state(s) 0
                  Code queue is empty
                  === CAN ===
                  Messages queued 1408, received 1267, lost 0, boc 0
                  Longest wait 1ms for reply type 6042, peak Tx sync delay 290, free buffers 50 (min 49), ts 788/787/0
                  Tx timeouts 0,0,0,0,0,0
                  === SBC interface ===
                  Transfer state: 5, failed transfers: 0, checksum errors: 1
                  RX/TX seq numbers: 6088/6088
                  SPI underruns 1, overruns 0
                  State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2ad48
                  Buffer RX/TX: 0/0-0, open files: 0
                  === Duet Control Server ===
                  Code buffer space: 4096
                  Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 5
                  Full transfers per second: 39.44, max time between full transfers: 102.9ms, max pin wait times: 59.0ms/14.9ms
                  Codes per second: 0.48
                  Maximum length of RX/TX data transfers: 2988/904
                  • KCMARINEundefined
                    KCMARINE
                    Still happening - Restarted and tried to run bed leveling - immediately getting
                    Connection to Duet established
                    1/22/2023, 12:45:13 PM	Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
                    1/22/2023, 12:45:04 PM	Connection to Duet established
                    1/22/2023, 12:45:04 PM	Warning: Lost connection to Duet (SPI connection reset because the number of maximum retries has been exceeded)
                    1/22/2023, 12:44:57 PM	Connection to Duet established
                    1/22/2023, 12:44:57 PM	Warning: Lost connection to Duet (SPI connection reset because the number of maximum retries has been exceeded)
                    1/22/2023, 12:44:54 PM	Warning: SPI connection has been reset
                    1/22/2023, 12:44:47 PM	Connection to Duet established
                    1/22/2023, 12:44:47 PM	Warning: Lost connection to Duet (SPI connection reset because the number of maximum retries has been exceeded)
                    1/22/2023, 12:44:17 PM	Warning: M307: Heater 1 predicted maximum temperature at full power is 450°C
                    1/22/2023, 12:44:16 PM	Connection established
                    I am at a loss now what can be wrong
                    KCMARINEundefined 1 Reply Last reply Reply Quote 0
                    • KCMARINEundefined
                      KCMARINE @KCMARINE
                      @KCMARINE - TfrRdy Pin glitches: 5
                      • KCMARINEundefined
                        KCMARINE @KCMARINE
                        @gloomyandy - recap to answer your questions
                        Yes, I downloaded https://pkg.duet3d.com/DuetPi.zip and flashed the SD card.
                        Yes, did make the upgrade
                        I made the upgrade by downloading the 3.5 beta from the git repo and uploaded to DWC then installed it unknowingly that it may conflict with the SBC 3.4.5
                        .Yes, however SPI connection reset and timeouts are still happening
                        Yes, now I have downgraded all firmware to match the Pi SBC and problems still remain
                          @KCMARINE So you are now on 3.4.5 on for both DSF and RRF (at least that is what your last posted M122 shows). Can you post another one just so we can be sure. What SBC are you using? Is it a raspberry Pi (which model) or something else?
                          • KCMARINEundefined
                            @gloomyandy thanks. I can confirm the following:
                            SBC is Raspberry Pi 4 Model B
                            and M122
                            1/22/2023, 5:53:12 PM	m122
                            Used output buffers: 1 of 40 (19 max)
                            Static ram: 152760
                            Never used RAM 130320, free system stack 200 words
                            Tasks: SBC(ready,0.6%,461) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,339) TMC(notifyWait,7.6%,91) MAIN(running,90.9%,923) IDLE(ready,0.9%,30), total 100.0%
                            Last reset 00:04:22 ago, cause: power up
                            Last software reset time unknown, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 132888, slot 0
                            Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00400804 BFAR 0x0000633a SP 0x2041b450 Task MAIN Freestk 1628 ok
                            Stack: 2042a370 00000000 20418198 0000632e 00000000 00489db5 00489de6 21030000 2042c550 00000000 00000000 0048922f 00000000 00000000 00000000 0000000a 00000000 2042c550 20419a84 2042d1ac 00000000 00000001 00000000 00488ee7 00000001 00489db5 00000000
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            Step timer max interval 135
                            MCU temperature: min 35.9, current 44.9, max 44.9
                            Supply voltage: min 24.3, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                            Driver 0: standstill, SG min 0, mspos 8, reads 22115, writes 14 timeouts 0
                            Driver 1: standstill, SG min 0, mspos 8, reads 22115, writes 14 timeouts 0
                            Driver 2: standstill, SG min 0, mspos 8, reads 22115, writes 14 timeouts 0
                            Driver 3: standstill, SG min 0, mspos 8, reads 22115, writes 14 timeouts 0
                            Driver 4: standstill, SG min 0, mspos 8, reads 22115, writes 14 timeouts 0
                            Driver 5: standstill, SG min 0, mspos 8, reads 22115, writes 14 timeouts 0
                            Date/time: 2023-01-22 09:53:11
                            Slowest loop: 2.22ms; fastest: 0.03ms
                            === Storage ===
                            === MainDDARing ===
                            === AuxDDARing ===
                            Segments left: 0
                            Code queue is empty
                            === CAN ===
                            Messages queued 2265, received 2101, lost 0, boc 0
                            Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 50 (min 49), ts 1311/1310/0
                            Transfer state: 5, failed transfers: 0, checksum errors: 0
                            RX/TX seq numbers: 11230/11230
                            SPI underruns 0, overruns 0
                            Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                            Full transfers per second: 0.61, max time between full transfers: 425.3ms, max pin wait times: 44.1ms/51.4ms
                            Codes per second: 0.00
                            Maximum length of RX/TX data transfers: 6196/836
                            jay_s_ukundefined KCMARINEundefined gloomyandyundefined 3 Replies Last reply Reply Quote 0
                              jay_s_uk @KCMARINE
                              @KCMARINE are you using the supplied cable between the pi and the duet? Can you post a photo of it's routing so we can see what's near it etc?
                              • KCMARINEundefined
                                KCMARINE @KCMARINE
                                @gloomyandy
                                  @KCMARINE Yep both versions match. Could you also post a picture showing how the two boards are connected. After that I think this is one for @chrishamm
                                  gloomyandyundefined KCMARINEundefined 2 Replies Last reply Reply Quote 0
                                    gloomyandy @gloomyandy
                                    @gloomyandy Ha Jay got there first!
                                    • KCMARINEundefined
                                      @gloomyandy
                                      • KCMARINEundefined
                                        KCMARINE @KCMARINE
                                        @gloomyandy
                                        Thanks for the help - I appreciate all that you do
                                        I am out of ideas.
                                        My last attempt/thought is to flash another SD card with a new copy of DuetPi.zip and see what happens!
                                        • KCMARINEundefined
                                          KCMARINE @KCMARINE
                                          @gloomyandy @droftarts @jay_s_uk
                                          Success - after flashing a new SD card with DuetPi.zip I am happy to report that I have no more communication errors and I can print my first calibration cube.
                                          I believe that the issue may have been caused by the additional motion installation for the Logitech webcam
                                          https://www.instructables.com/How-to-Make-Raspberry-Pi-Webcam-Server-and-Stream-/
                                          The strange thing is I have this running on another SBC Pi 4 and MB6HC running 3.4.5 on a delta with no issues, guessing it could be a compatibility issue with 3.5 upgrades and then a downgrade, just a stab in the dark.
                                          Thanks again for your support gents - very much appreciated.
                                          jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                                            jay_s_uk @KCMARINE
                                            @KCMARINE glad you got sorted. I was going to suggest that running all those cables next to the ribbon may be the cause but as you've fixed it I wouldn't worry. If it does however happen again I would consider revisiting your cable routing
                                            • Phaedruxundefined Phaedrux has marked this topic as solved
