    M308 add a new sensor
    767
    • moth4017undefined
      moth4017 @jay_s_uk
      @jay_s_uk
      http://www.aosong.com/en/products-61.html
      Ive been using it with a esp32 and th btncmd pulgin with the duet3 Mini 5 , but would be nice to attach it direct .
      The BME280 looks like it was designed to operate up to 65C although it is rated to 85C , this should be ok for our application.
      • moth4017undefined
        moth4017 @gloomyandy
        @gloomyandy
        The DHT does not seem to be very accurate at low humidity values
        • moth4017undefined
          moth4017
          @dc42 , BME 280 ordered to try when the v3.5 is out..
          • moth4017undefined
            moth4017
            @dc42 is there any info on how to connect and setup the BME280?
            Exerqtorundefined dc42undefined 2 Replies Last reply Reply Quote 0
            • Exerqtorundefined
              Exerqtor @moth4017
              @moth4017 said in M308 add a new sensor:
              It's been added to M308 for RRF3.5 and later at least.
              Reguarding how to connect it i would guess you do it just like you would with a DHT sensor.
              moth4017undefined 1 Reply Last reply Reply Quote 0
              • moth4017undefined
                moth4017 @Exerqtor
                @Exerqtor Hi the NME280 is an SPI device , so im guessing there is more to set up and im not sure which chip select pin is used.
                  dc42 administrators @moth4017
                  @moth4017 the BME280 can be connected to the SPI daughter board connector. You can use any one of the CS pins on that connector.
                  • moth4017undefined
                    moth4017 @dc42
                    @dc42 Thanks, do you have to define the CS pin like this?
                    if i was to use spi2 CS2
                    M308 S1 P"spi2.cs2" Y"BME280" A"BME280"
                      @moth4017 yes it's the same as how you would define the CS pin for a PT100 or thermocouple board.
                      Accessing the 2 additional sensors in the BME280 is similar to how you access humidity on a DHT22. Here's how I configured a BME280 on a Duet 3 Mini:
                      m308 s11 y"bme280" p"spi.cs1" a"Ambient temp"
                      m308 s12 y"bmepressure" p"s11.1" a"Pressure[hPa]"
                      m308 s13 y"bmehumidity" p"s11.2" a"Humidity[%]"
                      Exerqtorundefined 1 Reply Last reply Reply Quote 1
                      • Exerqtorundefined
                        Exerqtor @dc42
                        I assume we don't connect/use the clock pin on the BME280 ?
                          dc42 administrators @Exerqtor
                          @Exerqtor you need to connect the SDI, SDO and SCK pins of the BME280 to MOSI, MISO and SCLK respectively. And of course also connect CS, 3.3V power and ground.
                          • moth4017undefined
                            moth4017
                            BME connected and working , i have used spi.cs2
                            M308 s11 y"bme280" p"spi.cs2" A"Ambient temp"
                            M308 s12 y"bmepressure" p"s11.1" A"Pressure[hPa]"
                            M308 s13 y"bmehumidity" p"s11.2" A"Humidity[%]"
                            A bit of info as the Pin out description on the BME not the same as Duet board
                            Duet Temp Daughter Board to BME 280
                            pin 1 .................................................. CSB
                            pin2 ................................................... GND
                            pin3
                            pin4.................................................... SCL
                            pin5 ................................................... SDA
                            pin6.................................................... SDO
                            pin7
                            pin8................................................... VCC
                            pin9
                            pin10
                            • moth4017undefined moth4017 referenced this topic
                            • dc42undefined dc42 marked this topic as a question
                            • dc42undefined dc42 has marked this topic as solved
                            • Tinchusundefined
                              Tinchus
                              Hello all. Just to confirm: using the BME280 is not possible yet on version 3.4 versions of firmware?
                                jay_s_uk @Tinchus
                                @Tinchus correct. its part of 3.5
                                Tinchusundefined 1 Reply Last reply Reply Quote 0
                                • Tinchusundefined
                                  Tinchus @jay_s_uk
                                  @jay_s_uk Hello Thanks for the answer, then I should update to 3.5 beta to test this.
                                  Docs talk about connecting the BME280 to the temperature daughter board. I have a thermocouple doughter board, it will work?
                                    jay_s_uk @Tinchus
                                    @Tinchus depending on which board you have. best off opening a new thread
