M308 add a new sensor
@Exerqtor Hi the NME280 is an SPI device , so im guessing there is more to set up and im not sure which chip select pin is used.
@moth4017 the BME280 can be connected to the SPI daughter board connector. You can use any one of the CS pins on that connector.
@dc42 Thanks, do you have to define the CS pin like this?
if i was to use spi2 CS2
M308 S1 P"spi2.cs2" Y"BME280" A"BME280"
@moth4017 yes it's the same as how you would define the CS pin for a PT100 or thermocouple board.
Accessing the 2 additional sensors in the BME280 is similar to how you access humidity on a DHT22. Here's how I configured a BME280 on a Duet 3 Mini:
m308 s11 y"bme280" p"spi.cs1" a"Ambient temp"
m308 s12 y"bmepressure" p"s11.1" a"Pressure[hPa]"
m308 s13 y"bmehumidity" p"s11.2" a"Humidity[%]" -
I assume we don't connect/use the clock pin on the BME280 ?
@Exerqtor you need to connect the SDI, SDO and SCK pins of the BME280 to MOSI, MISO and SCLK respectively. And of course also connect CS, 3.3V power and ground.
BME connected and working , i have used spi.cs2
M308 s11 y"bme280" p"spi.cs2" A"Ambient temp"
M308 s12 y"bmepressure" p"s11.1" A"Pressure[hPa]"
M308 s13 y"bmehumidity" p"s11.2" A"Humidity[%]"A bit of info as the Pin out description on the BME not the same as Duet board
Duet Temp Daughter Board to BME 280
pin 1 .................................................. CSB
pin2 ................................................... GND
pin3
pin4.................................................... SCL
pin5 ................................................... SDA
pin6.................................................... SDO
pin7
pin8................................................... VCC
pin9
pin10 -
undefined moth4017 referenced this topic
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
Hello all. Just to confirm: using the BME280 is not possible yet on version 3.4 versions of firmware?
@Tinchus correct. its part of 3.5
@jay_s_uk Hello Thanks for the answer, then I should update to 3.5 beta to test this.
Docs talk about connecting the BME280 to the temperature daughter board. I have a thermocouple doughter board, it will work?
@Tinchus depending on which board you have. best off opening a new thread
