    M308 add a new sensor
    766
    • moth4017undefined
      moth4017
      @dc42 , BME 280 ordered to try when the v3.5 is out..
      • moth4017undefined
        moth4017
        @dc42 is there any info on how to connect and setup the BME280?
        Exerqtorundefined dc42undefined 2 Replies Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @moth4017
          @moth4017 said in M308 add a new sensor:
          It's been added to M308 for RRF3.5 and later at least.
          Reguarding how to connect it i would guess you do it just like you would with a DHT sensor.
          moth4017undefined 1 Reply Last reply Reply Quote 0
          • moth4017undefined
            moth4017 @Exerqtor
            @Exerqtor Hi the NME280 is an SPI device , so im guessing there is more to set up and im not sure which chip select pin is used.
              dc42 administrators @moth4017
              @moth4017 the BME280 can be connected to the SPI daughter board connector. You can use any one of the CS pins on that connector.
              • moth4017undefined
                moth4017 @dc42
                @dc42 Thanks, do you have to define the CS pin like this?
                if i was to use spi2 CS2
                M308 S1 P"spi2.cs2" Y"BME280" A"BME280"
                  @moth4017 yes it's the same as how you would define the CS pin for a PT100 or thermocouple board.
                  Accessing the 2 additional sensors in the BME280 is similar to how you access humidity on a DHT22. Here's how I configured a BME280 on a Duet 3 Mini:
                  m308 s11 y"bme280" p"spi.cs1" a"Ambient temp"
                  m308 s12 y"bmepressure" p"s11.1" a"Pressure[hPa]"
                  m308 s13 y"bmehumidity" p"s11.2" a"Humidity[%]"
                  Exerqtorundefined 1 Reply Last reply Reply Quote 1
                  • Exerqtorundefined
                    Exerqtor @dc42
                    I assume we don't connect/use the clock pin on the BME280 ?
                      dc42 administrators @Exerqtor
                      @Exerqtor you need to connect the SDI, SDO and SCK pins of the BME280 to MOSI, MISO and SCLK respectively. And of course also connect CS, 3.3V power and ground.
                      • moth4017undefined
                        moth4017
                        BME connected and working , i have used spi.cs2
                        M308 s11 y"bme280" p"spi.cs2" A"Ambient temp"
                        M308 s12 y"bmepressure" p"s11.1" A"Pressure[hPa]"
                        M308 s13 y"bmehumidity" p"s11.2" A"Humidity[%]"
                        A bit of info as the Pin out description on the BME not the same as Duet board
                        Duet Temp Daughter Board to BME 280
                        pin 1 .................................................. CSB
                        pin2 ................................................... GND
                        pin3
                        pin4.................................................... SCL
                        pin5 ................................................... SDA
                        pin6.................................................... SDO
                        pin7
                        pin8................................................... VCC
                        pin9
                        pin10
                        • moth4017undefined moth4017 referenced this topic
                        • dc42undefined dc42 marked this topic as a question
                        • dc42undefined dc42 has marked this topic as solved
                        • Tinchusundefined
                          Tinchus
                          Hello all. Just to confirm: using the BME280 is not possible yet on version 3.4 versions of firmware?
                            jay_s_uk @Tinchus
                            @Tinchus correct. its part of 3.5
                            Tinchusundefined 1 Reply Last reply Reply Quote 0
                            • Tinchusundefined
                              Tinchus @jay_s_uk
                              @jay_s_uk Hello Thanks for the answer, then I should update to 3.5 beta to test this.
                              Docs talk about connecting the BME280 to the temperature daughter board. I have a thermocouple doughter board, it will work?
                                jay_s_uk @Tinchus
                                @Tinchus depending on which board you have. best off opening a new thread
