    Delta printing height map diagnostics help
    439
    • sneakyferretundefined
      sneakyferret
      You guys have been helping me so much, again, I cannot thank you enough! I am back for another question. I have been recently doing bed leveling and find that my height map matches an example in delta calibration that reads, "One of the most common errors would be tower endstop settings. When these are in error, the primary effect is to product a tilt to the bed scan." Tutorial_example.png
      Mine seems to match the description but I cannot for the life of me figure it out. heightmap.png
      Below is my config if there's anything else I can show I will gladly!
      ; generated by RepRapFirmware Configuration Tool v2.0.3 on Thu Sep 05 2019 15:50:44 GMT-0400 (Eastern Daylight Time)
      G90                                         ; send absolute coordinates...
      M83                                         ; ...but relative extruder moves
      M550 P"Tall Printer"                        ; set printer name
      M665 R180 L160 B130 H580                    ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0                               ; put your endstop adjustments here, or let auto calibration find them
      M552 S1                                     ; enable network
      M586 P0 S1                                  ; enable HTTP
      M586 P1 S0                                  ; disable FTP
      M586 P2 S0                                  ; disable Telnet
      M569 P0 S0                                  ; physical drive 0 goes backwards
      M569 P1 S0                                  ; physical drive 1 goes backwards
      M569 P2 S0                                  ; physical drive 2 goes backwards
      M569 P3 S1                                  ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                            ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                     ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z80.00 E500.00            ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00    ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00    ; set accelerations (mm/s^2)
      M906 X1100 Y1100 Z1100 E900 I60            ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                     ; Set idle timeout
      M208 Z0 S1                                  ; set minimum Z
      M574 X2 S1 P"!xstop"                         ; X active low and disabled endstop
      M574 Y2 S1 P"!ystop"                         ; Y active low and disabled endstop
      M574 Z2 S1 P"!zstop"                         ; Z active low and disabled endstop
      M558 P8 C"zprobe.in+zprobe.mod" R0.4 H10 F1200 T6000   ; set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z-.22                        ; set Z probe trigger value, offset and trigger height
      M557 R85 S20                                ; define mesh grid
      ; Temperature Sensors
      M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 ; define bed temperature sensor
      M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.06e-8 ; define E0 temperature sensor
      M950 H0 C"bed_heat" T0 ; heater 0 uses the bedheat pin, sensor 0
      M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1
      M307 H0 B0 S1.00
      M140 H0
      M950 F1 C"fan1" Q500
      M106 P1 S1 H1 T45
      M950 F0 C"fan0" Q500                     ; Part Cooling fan
      M106 C"PartFan" P0 S0 H-1 B1
      M307 H0 ; report the process parameters for heater 0
      M307 H0 R2.186 K0.17:0.11 D5.67 S1.00 V24.0 ; set the process parameters for heater 0
      M563 P0 H1 F0 D0 T0                           ; define tool 0
      G10 P0 X0 Y0 Z0                             ; set tool 0 axis offsets
      G10 P0 R0 S0                                ; set initial tool 0 active and standby temperatures to 0C
      M501 ; recall last used parameters
        sneakyferret
        More clarification: I have ran automatic calibration using my duet3d smart effector on a duet3d wifi 2 controller. This is the height map that is generated after running mesh compensation.
        • alankilianundefined
          alankilian @sneakyferret
          @sneakyferret posting your bed.g will help people determine how many "types" of calibration you are doing.
          This will help understand if you are doing home-switch-height calibration or not.
          The bed.g file defines the points that will be probed, and the number of factors that will be calibrated. RepRapFirmware supports the following calibration schemes:
              3-factor: Adjusts the endstop switch position corrections (M666 XYZ parameters).
              4-factor: Similar to traditional manual delta calibration, but much faster. Adjusts the endstop switch position corrections (M666 XYZ parameters) and the delta radius (M665 R parameter).
              6-factor: as 4-factor but also adjusts the X and Y tower position corrections.
              7-factor: as 6-factor but also adjusts the diagonal rod length (M665 L parameter).
              8-factor: as 6-factor but also adjusts the X and Y tilt angles (M666 A and B parameters).
              9-factor: as 8-factor but also adjusts the diagonal rod length (M665 L parameter).
          sneakyferretundefined 1 Reply Last reply Reply Quote 1
            sneakyferret @alankilian
            @alankilian Here it is!
            ; bed.g
            ; called to perform automatic delta calibration via G32
            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Feb 02 2020 21:40:17 GMT-0500 (Eastern Standard Time)
            ; 13 points, 7 factors, probing radius: 138, probe offset (0, 0)
            G28
            G30 P0 X0.00 Y130.00 Z-99999 H-1.06
            G30 P1 X83.56 Y99.59 Z-99999 H-1.25
            G30 P2 X128.03 Y22.57 Z-99999 H-1.34
            G30 P3 X112.58 Y-65.00 Z-99999 H-0.49
            G30 P4 X44.46 Y-122.16 Z-99999 H0.59
            G30 P5 X-44.46 Y-122.16 Z-99999 H1.47
            G30 P6 X-112.58 Y-65.00 Z-99999 H2.07
            G30 P7 X-128.03 Y22.57 Z-99999 H1.28
            G30 P8 X-83.56 Y99.59 Z-99999 H-0.08
            G30 P9 X0.00 Y65.00 Z-99999 H-0.66
            G30 P10 X56.29 Y-32.50 Z-99999 H-0.22
            G30 P11 X-56.29 Y-32.50 Z-99999 H0.95
            G30 P12 X0 Y0 Z-99999 S6
            M500 ; I believe this saves the mesh to EPROM
            sneakyferretundefined 1 Reply Last reply Reply Quote 0
              sneakyferret @sneakyferret
              I am hoping its just something simple I am missing. You guys are great for everything!
                I'd give it a good mechanical check over. See if anything is cracked, or loose, or wiggles.
                  sneakyferret @Phaedrux
                  @Phaedrux Have been going over it with a fine tooth comb and so far nothing stands out.
                    @sneakyferret I've checked everything mechanical from tower bolts to stepper motor set screws on my delta printer. The only thing I really notice that's suspicious is that my belt tensions may could be tightened further but its not like they're floppy loose.
                    Anything else come to mind?
                      Generate a new bed.g file? I'm not a delta user, so my help is pretty limited.
                      When in doubt though it's good to go back to basics
                      https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_linear_delta
                      https://docs.duet3d.com/en/User_manual/Tuning/Delta_calibration
                        @Phaedrux Appreciate the reply, but I have been over the initial calibration and mesh compensations step by step repeatedly, making sure to follow each step and the result is the same. 😞
                          @sneakyferret Ok, update! I was following this instructional here and placed trigger height corrections at each of my bed.g points.
                          After this, this resulted in the above SUPER skewed height map. I got curious and removed those Hxxx corrections at the end of my bed.g points. Lo and behold:
                          A much more reasonable looking height map!
                          I followed the instructional by measuring trigger height at each of the coordinates and taking that value, subtracting it from the center point trigger height, and placed those values in bed.g. Only problem is I didn't see that it says to place them in G31 commands.. My bed file doesn't contain any G31 commands! 😄
                          I appreciate no one being impatient with me during this. What exactly is G31 used for? I don't understand what everyone says about it.
                            G31 defines the offset between the nozzle and probe.
                            https://docs.duet3d.com/en/User_manual/Reference/Gcodes#g31-set-or-report-current-probe-status
                              dc42 administrators @sneakyferret
                              @sneakyferret you should not need to use trigger height corrections when using a Smart Effector. The trigger height should be much the same all over the bed, typically about -0.1mm. What range of trigger heights did you measure, and how did you measure them?
                              When you run auto calibration what results does it report?
                                sneakyferret @dc42
                                @dc42 not too bad. Max deviations are -.148 and .154 at the low and high end. I measured the trigger heights by taking my bed.g coordinates, driving the nozzle to each point, use G30 S-1 to do a single probe and have it display the trigger height. I'll have to re run auto cal to see what it reads out but my bed leveling looks much better now.
