    Warning: Driver 1 warning: over temperature warning
    382
    • moth4017undefined
      moth4017 @SonnyD1
      @SonnyD1 did you feel the stepper driver heat sink to see if it was hot?
      SonnyD1undefined 1 Reply Last reply Reply Quote 0
      • SonnyD1undefined
        SonnyD1 @moth4017
        @moth4017 Yes and it did not feel hot to me.
        moth4017undefined 1 Reply Last reply Reply Quote 0
        • moth4017undefined
          moth4017 @SonnyD1
          @SonnyD1 post your config
          • SonnyD1undefined
            SonnyD1 @moth4017
            @moth4017
            ; Configuration file for Duet WiFi (firmware version 3.4.5)
            ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Feb 19 2023 17:01:06 GMT-0500 (Eastern Standard Time)
            G21 ; work in milimeters
            M550 P"IDEX" ; set printer name
            M111 S0 ; debug off
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S1 ; enable FTP
            M586 P2 S0 ; disable Telnet
            M575 P1 B57600 S1 ; enable support for PanelDue
            M569 P0 S1 ; physical drive 0 goes forwards - X stepper
            M569 P1 S1 ; physical drive 1 goes forwards - Z stepper (left)
            M569 P2 S1 ; physical drive 2 goes forwards - Z stepper (right)
            M569 P3 S1 ; physical drive 3 goes forwards - E0 stepper
            M569 P6 S1 ; physical drive 6 goes forwards - Y stepper (left)
            M569 P7 S0 ; physical drive 7 goes backwards - Y stepper (right)
            M569 P8 S1 ; physical drive 8 gows forwards - U stepper
            M569 P9 S1 ; physical drive 9 goes forwards - E1 stepper
            M584 X0 Y6:7 Z1:2 U8 E3:9 ; set drive mapping
            M350 X16 Y16 Z16 U16 E16:16 I1 ; configure microstepping with interpolation
            M92 X80.00 Y80.00 Z800.00 U80.00 E400.00:400.00 ; set steps per mm
            M566 X900.00 Y900.00 Z60.00 U900.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) - jerk
            M203 X6000.00 Y6000.00 Z180.00 U6000.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z20.00 U500.00 E250.00:250.00 ; set accelerations (mm/s^2)
            M906 X2300 Y2300 Z2300 U2300 E600:600 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X-26 Y0 U10 Z0 S1 ; set axis minima
            M208 X290 Y300 U330 Z300 S0 ; set axis maxima
            M574 X1 S1 P"e1stop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin e1stop
            M574 U1 S1 P"duex.e6stop" ; configure switch-type (e.g. microswitch) endstop for high end on U via pin exp.e6stop
            M574 Y1 S1 P"duex.e5stop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin exp.e5stop
            M591 D0 P1 C"xstop" S0 ; configure filament monitor (simple switch) for E0
            M591 D1 P1 C"duex.e4stop" S0 ; configure filament monitor (simple switch) for E1
            ; Emergency Stop
            ; M950 J1 C"e0stop" ; identify pin number for emergency stop
            ; M581 T2 P1 S1 R1 ; invoke trigger 2 when an inactive-to-active edge is detected on input 0 or input 3 and a file is being printed from SD card
            ; BLTouch
            M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch
            M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch, connected to zprobe.in and the dive height + speeds
            G31 P500 X-31 Y-14.5 Z2.5 ; set Z probe trigger value, offset and trigger height
            M557 X20:270 Y20:280 S50 ; define mesh grid
            M308 S0 P"duex.e4temp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin duex.e4temp
            M307 H0 R0.889 K0.214:0.000 D1.95 E1.35 S1.00 B0 ; enable bang-bang mode for the bed heater and set PWM limit
            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
            M307 H1 R4.899 K0.886:0.346 D1.80 E1.35 S1.00 B0 V24.0 ; disable bang-bang mode for heater and set PWM limit
            M143 H1 S300 ; set temperature limit for heater 1 to 300C
            M308 S2 P"duex.e3temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin duex.e3temp
            M950 H2 C"duex.e6heat" T2 ; create nozzle heater output on duex.e6heat and map it to sensor 2
            M307 H2 R4.493 K0.675:0.344 D2.01 E1.35 S1.00 B0 V24.1 ; disable bang-bang mode for heater and set PWM limit
            M143 H2 S300 ; set temperature limit for heater 2 to 300C
            M950 F0 C"fan2" Q500 ; create fan 0 on pin fan0 and set its frequency
            M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on at 45c
            M950 F2 C"duex.fan3" Q500 ; create fan 2 on pin duex.fan3 and set its frequency
            M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off
            M950 F3 C"duex.fan4" Q500 ; create fan 3 on pin duex.fan4 and set its frequency
            M106 P3 S1 H2 T45 ; set fan 3 value. Thermostatic control is turned on at 45c
            M563 P0 D0 H1 F0 ; define tool 0 that used low end X carriage
            G10 P0 X-26 Y0 Z0 ; set tool 0 axis offsets
            M563 P1 D1 H2 F2 ; define tool 1 that used high end U carriage
            G10 P1 X359 Y0 Z0 ; set tool 1 axis offsets
            ; IDEX
            ; Create a tool that prints 2 copies of the object using both carriages
            ;M563 P1 D0:1 H1:2 X0:3 F0:2 ; tool 2 uses both extruders, hot end heaters and fans, and maps X to both X and U
            ;G10 P1 X50 Y0 U-50 S0 R0 ; set tool offsets and temperatures
            ;M567 P1 E1:1 ; set mix ratio 100% on both extruders
            T0 ; select first tool
            • moth4017undefined
              moth4017 @SonnyD1
              @SonnyD1 what stepper motors are you using the current looks high , try dropping t0 1200 ma
              • SonnyD1undefined
                SonnyD1 @moth4017
                @moth4017 It's the LDO-42STH47-2504AC rated at 2.5a max current. The 2300 your seeing is around 80% of that. 1200 would be less than 50% max current. Should I go that low? The driver is rated for 3a right?
                • sebkritikelundefined
                  sebkritikel @SonnyD1
                  @SonnyD1 Do you have any 'active cooling' for the stepper drivers on your Duet 2 Wifi? typically with motors that use higher currents (like the motors you have) it is recommended to have fans blowing air over the Duet boards to cool the stepper drivers/chips. The TMC2660 chips heatsink to the board itself.
                  Large(ish?) IDEX - 6HC, 1HCL
                  Stratasys Dimension 1200es to 6HC Conversion
                  SonnyD1undefined 1 Reply Last reply Reply Quote 1
                  • SonnyD1undefined
                    SonnyD1 @sebkritikel
                    @sebkritikel No I don't. Ive never needed it on other builds. Is that the only thing that will resolve my issue?
                    • moth4017undefined
                      moth4017 @SonnyD1
                      @SonnyD1 i think the drivers are rated at 2.4A peak not continuous ,
                      SonnyD1undefined 2 Replies Last reply Reply Quote 1
                      • SonnyD1undefined
                        SonnyD1 @moth4017
                        @moth4017 Based on 2.4a peak what % would you recommend. Usually its between 60-85%. I can drop em all down I think. Especially since its not a speed printer. I'll give 75% a try.
                        • SonnyD1undefined
                          SonnyD1 @moth4017
                          @moth4017 so I lowered it to 1900. Repeated the G32 that was triggering the error and it completed this time. I'm pretty sure that will be enough current. If not, now I know I will have to add additional cooling to the boards. I may end up doing that anyway. Thank you for the help but I think you've solved my issue for now.
                          • SonnyD1undefined SonnyD1 has marked this topic as solved
