    3.5 B3 Toolboard stepper intermittently running backwards
    Beta Firmware
    12
    83
    4.5k
    • Argoundefined
      Argo @Exerqtor
      @Exerqtor
      It seems it only temporarily fixed the issue. I just startet my printer for the first time since I was able to successfully print a Voron test cube and when inserting filament via PanelDue the extruder runs backwards at 5mm/s and forward at 10 mm/s when commanding it to extrude. With other words the bug came back 😞
      Exerqtorundefined 1 Reply Last reply Reply Quote 0
      • Exerqtorundefined
        Exerqtor @Argo
        @Argo
        Ah ok, lets hope @dc42 has time to look into this soon.
        • oliofundefined
          oliof
          and another 12h print completed without issue. Really weird.
          • Exerqtorundefined
            Exerqtor @oliof
            @oliof
            Yeah like i said in my thread, it seems totally sporadic.
            • oliofundefined
              oliof @Exerqtor
              @Exerqtor well, I have one gcode file now that seems to stop at a certain point to just extrude, and another that runs for 12 hours. On monday I will have a couple hours to try and find a reproducer.
              Out of interest, are you using slicer or firmware retract?
              • Exerqtorundefined
                Exerqtor @oliof
                @oliof
                I'm using FW ✌
                • muleundefined
                  mule
                  I am having the same issue withe B3: When trying to print a test for measuring pressure advance the filament gets retracted so far that it even leaves the extruder gears after printing some lines. It is always happening at the same position when trying to print the following gcode:pa_pattern.gcode
                  gloomyandyundefined 1 Reply Last reply Reply Quote 0
                  • gloomyandyundefined
                    gloomyandy @mule
                    @mule Can you identify at which point it goes into reverse? Layer height or whatever? Having your config.g file would also be good if anyone needs to reproduce this.
                    ctilley79undefined muleundefined 2 Replies Last reply Reply Quote 0
                    • ctilley79undefined
                      ctilley79 @gloomyandy
                      @gloomyandy You don't need to be in a print for the problem to occur. You can just manually extrude from the DWC console or the extrude buttons on the DWC dashboard page. I thought the the threshold was F254 but now it seems to vary.
                      • muleundefined
                        mule @gloomyandy
                        @gloomyandy
                        Some of my findings:
                        Nr. 1: The purge line is not being completed because the extruder runs backwards after printing about half of the line
                        Nr. 2: Line is not being printed because the extruder runs backwards
                        Nr. 3: The extruder motor stands still and neither moves forward nor backwards. Therefore no filament is being extruded until the end of the whole print job.
                        Findings: There is not only an issue with retracting instead of extruding but also with a complete stop of the extruder motor. Looking at Nr. 1 and Nr.2 it seems to me that the extruder runs backwards whenever the y axis is moving from the front to the back (Y increases).
                        Hopefully this helps.
                        gloomyandyundefined 1 Reply Last reply Reply Quote 1
                          gloomyandy @mule
                          @mule That's very useful, but anyone trying to reproduce it really needs to see how you have things configured, so please post your config.g file (or whatever you use to setup things).
                          muleundefined ctilley79undefined 2 Replies Last reply Reply Quote 0
                          • muleundefined
                            mule @gloomyandy
                            @gloomyandy Sorry, of course you're right. Please find attached the the config.g and the macro (PrintStart.txt) including the code for printing the purge line:
                            config.g
                            PrintStart.txt
                            OwenDundefined 1 Reply Last reply Reply Quote 1
                            • OwenDundefined
                              OwenD @mule
                              @mule
                              Is there any way you can try your extruder on a different driver?
                              I only say because I have had a driver fail that was randomly missing steps and only running in one direction
                              https://forum.duet3d.com/topic/28666/motor-travels-in-one-direction-regardless-of-command/4?_=1682994512366
                              oliofundefined muleundefined ctilley79undefined 3 Replies Last reply Reply Quote 0
                              • oliofundefined
                                oliof @OwenD
                                @OwenD I like your thinking but its quite unlikely that we are seeing a mass death of drivers on various toolboards of different makes and models.
                                • muleundefined
                                  mule @OwenD
                                  @OwenD It is not a defective driver, because if downgrading the firmware to v3.4 everything is working fine again.
                                  1 Reply Last reply Reply Quote 4
                                    ctilley79 @OwenD
                                    @OwenD It's not a failure of a driver because rolling back to 3.4 fixes the issue
                                      @gloomyandy I'm not trying to bug you but I'm just curious. Have you been able to reproduce the issue?
                                        gloomyandy @ctilley79
                                        @ctilley79 Not exactly, I've been running a lot of general extrusion tests on my e3d toolchanger comparing two different toolboards (a 1LC and a prototype rp2040 based one) against a tool driven directly from the main board. I've seen some extrusion issues with both the toolboard based tools and with the directly driven tool, though they seem to be slightly different. In both cases I have only seen a problem when using both PA and IS at the same time. I've passed on my results to DC42 and hopefully he will be able to investigate further. I don't think I've seen the extruder running backwards in any of those tests.
                                        • Exerqtorundefined
                                          Exerqtor @gloomyandy
                                          @gloomyandy Not running backwards is one thing, but have you gotten it to just stop? The extruder i mean, Intermittently and then start again by itself?
                                            We are aware of and looking into this issue. I'll create a github issue for it today hopefully.
                                            And many thanks to those doing the excellent testing and reporting here.
                                            tasundefined 1 Reply Last reply Reply Quote 3
