    Hollow shaft extruder
    345
    41.1k
      droftarts administrators @droftarts
      Turns out my idea is pretty much the same as this one that @T3P3Tony posted about in the other thread, which looks pretty neat: https://youtu.be/eI0tD69wD18
      That one uses a NEMA14. I saw pictures of it and assumed it was a NEMA17, so perhaps wouldn't be too top heavy.
      I think it would be worth contacting Jason at LDO to see if they have/can make any lighter pancake or round stepper motors with hollow shafts, for either the hypoid version or the Archimedes screw version.
      I'd say the Archimedes screw version wins on compactness, at the expense of some concerns about the filament spinning and extrusion inconsistency, though these might be avoided with more refinement of the design and manufacturing process. Alternatively, fitting something like a filament monitor, but with a shaft encoder on it, and running the extruder in closed loop mode would help.
      • o_lampeundefined
        o_lampe @droftarts
        @droftarts I'm not happy with the dual drive gears somewhere in the middle of the assembly. They should be lowest as possible (e.g. for flexible filament)
        That's why I didn't increase the blue bevel gears in my sketch.
        The ingenius extruder is quite impressive, but top heavy IMHO.
        A two stage gearing would make it more compact, I guess.
        Those square NEMA14 motors are so heavy compared to the round ones, I'm surprised, he picked one of these...
        The hypoid drive reminded me a bit of a worm drive, which might be an option, too?
        Which CAD system can calculate them? (hypoid)
        droftartsundefined nikschaundefined 2 Replies Last reply Reply Quote 0
          droftarts administrators @o_lampe
          @o_lampe said in Hollow shaft extruder:
          @droftarts I'm not happy with the dual drive gears somewhere in the middle of the assembly. They should be lowest as possible (e.g. for flexible filament). That's why I didn't increase the blue bevel gears in my sketch.
          Good point. A smaller second gear would bring it closer, at the expense of gear ratio.
          The ingenius extruder is quite impressive, but top heavy IMHO. ... Those square NEMA14 motors are so heavy compared to the round ones, I'm surprised, he picked one of these...
          Yes, that was my initial thought, too.
          But more backlash/complexity/cost?
          It's kind of a cross between a spiral bevel gear and a worm drive. See https://en.wikipedia.org/wiki/Spiral_bevel_gear#Hypoid_gears
          The advantage is that it can transmit more torque than a spiral bevel gear, but, like a worm drive, they also have some sliding action along the teeth.
          This is about the only CAD tutorial I could find for making hypoid gears, though uses Blender, I'm sure it could be done in Fusion 360 or OpenSCAD: https://youtu.be/wWn9gYwnONk
          There's a calculator here http://www.otvinta.com/hypoid.html (they also have calculators and videos for other gears
          Also, if it helps your design, Orbiter v2.0 uses shorter drive gears; 11mm vs 15mm. You could reduce the size of the motor gear, then.
          • nikschaundefined
            nikscha @droftarts
            @droftarts Way ahead of you 😉
            https://www.youtube.com/watch?v=eI0tD69wD18
            Stay in school
            droftartsundefined 1 Reply Last reply Reply Quote 1
              droftarts administrators @nikscha
              @nikscha I saw... I give up! Yours is very nice, I like how you're trying to squeeze the filament sensor in there too. How did you model the hypoid gear? I saw from your videos you're using Fusion 360.
              nikschaundefined 1 Reply Last reply Reply Quote 0
              • nikschaundefined
                nikscha @o_lampe
                *Ingenuity Extruder 😛
                I actually ordered a round one from LDO, and torque per weight seemed to be much better for the square one. Obviously this is only in the prototype stage (I am actually looking for beta testers right now), and any help with the motor design would be appreciated!
                I used a blender tutorial to model the hypoid bevel gears. Rest is done in fusion. But there are also proper calculators (MIT calculator) for hypoid bevel gears.
                Stay in school
                • nikschaundefined
                  nikscha @droftarts
                  @droftarts I followed a blender tutorial hahaha. The math is done here for you: http://www.otvinta.com/hypoid.html
                  I want to open source this design under Creative Commons, so any help is appreciated!
                  I'm actually looking for beta testers, and maybe we can make this a kit!
                  Stay in school
                  • nikschaundefined
                    nikscha
                    Damn I wanted to wait a bit longer with posting about the Ingenuity extruder on the forum but I guess it's too late now 😅
                    It's a direct drive extruder which features a hollow-shaft Nema-14 stepper motor, Bondtech LGX drive gear, an eccentric breach which is self-locking, an idler wheel where the spokes act as a tensioning spring and a hypoid bevel gear pair, archiving a gear ratio of 37:7.
                    The whole mechanism features only 4 moving parts: two gears, the idler wheel and the breach-lever. Weight is 229g.
                    https://www.thingiverse.com/thing:6056191
                    Stay in school
                      @nikscha Do you think there's any way you can reduce the diameter of the large gear? My first impression was that it would be a bit top heavy, though a lighter motor would help with that. @o_lampe 's point about it being a long way from the drive gear to the hot end, particularly for flexible filaments, could also be problematic.
                      What is your view on the Archimedes screw extruder?
                      • nikschaundefined
                        nikscha
                        Sorry for highjacking this post by the way, I made a separate one here:
                        https://forum.duet3d.com/topic/32876/ingenuity-extruder-for-smart-effector
                        Stay in school
                          @nikscha said in Hollow shaft extruder:
                          No worries, after all your extruder is a hollow shaft extruder, and that's what this thread is about!
                          • nikschaundefined
                            nikscha @droftarts
                            @droftarts said in Hollow shaft extruder:
                            Well the diameter of the "wheel" depends on multiple factors, like hypoid offset, gear ratio and number of teeth.
                            The hypoid offset is limited by the diameter of the drive wheel, which is the bondtech LGX in my case. gear ratio is aimed at 1:7, and tooth size is limited by the material properties.
                            I made all my prototypes from resin gears (Sirayatech white mecha), which were quite brittle, but I've since moved to gears made from IGUS SLS plastics. They're much stronger and more durable, and with them it might be possible to have a smaller wheel and/or a higher reduction ratio.
                            While testing I found that the "top heaviness" isn't that much of a problem, I'll post my input shaping results later for proof 😉
                            About the Archimedes screw extruder:
                            Very neat! And so light! I am jealous!
                            But there's no way of tensioning the filament, and loading/unloading can only be done electronically.
                            A harder filament will also provide more resistance to deformation which might stall the extruder. A softer filament might slip. There's also only one "teeth" engaging with the filament, so it might slip easier, especially considering that there's no way of tensioning it.
                            Abrasive filament will also dull the knife edge.
                            Edit:
                            A quick calculation shows that at 15degree pitch one revolution of the screw will advance the filament by about 1.5mm (tan15 * 1.75 *pi), the archimedes extruder has (360/1.8)= 200 steps per revolution, so about 133.33 steps per mm, which is not that much.
                            Edit2: judging from this: https://youtu.be/YTADdWiFQnI?t=238 my math is wrong, and the archimedes extruder needs about two revolutions to advance the filament by 1.75mm, which implies 1.14 revolutions for 1mm. This is equal to 228 steps/mm
                            Stay in school
                            • nikschaundefined nikscha referenced this topic
                            • o_lampeundefined
                              o_lampe @nikscha
                              @nikscha Thanks for joining the conversation.
                              I've made some small gears with ABS-like resin and also Anycubics tough resin.
                              Especially the latter is promising for testing gears. Could you achieve the same ratio with a smaller module? Your hypoid wheel looks like it can lift a car...but there is not much torque to deal with.
                              • nikschaundefined
                                nikscha @o_lampe
                                @o_lampe
                                I don't think resin gears are the way forward. You want something abrasion resistant because hypoid bevel gears slightly rub against each other, it's not a pure rolling motion like spur gears for example.
                                Instead I'm using SLS printed gears (IGUS).
                                One BIG problem that needs solving is the stepper getting hot. Usually this isn't a problem, but with a hollow shaft extruder the filament going through the shaft will get hot. Pla especially will soften quickly. Resin printed pinions that sit on the shaft will soften as well.
                                I had to run my old stepper at 600mA, while it's rated at 800, just to prevent overheating. I remedy this by counterboring the shaft from the top, and inserting a thin-walled ptfe tube for insulation.
                                The new stepper that has the ptfe tube and Igus gears can run hotter (obviously), but I haven't tested it enough yet.
                                If you have a delta printer and a smart effector and want to help me test, please hit me up, I'll gladly sent you a gear pair and custom stepper motor.
                                Stay in school
                                • nikschaundefined
                                  nikscha @o_lampe
                                  @o_lampe
                                  You definitely could archive the same ratio with a smaller module.
                                  Don't overestimate the hypoid gears tho, the ratio is only about 1:7, and the stepper is a nema 14, so not much torque here either.
                                  I should also state again that the diameter of the bigger gear is a function of hypoid shift. Hypoid shift is among other determined by the diameter of the drive wheel, in my case an LGX hardened drive wheel by bondtech. You could use a smaller one, maybe something that's used in the orbiter which is using 12mm diameter drive wheels instead of the LGX 18mm, which makes the hypoid shift 6mm instead of 9mm.
                                  But this now means that the pinion is so small that you can't have it sit on a stepper motor shaft, it's diameter is now only 4mm instead of the 5.7mm I get with the LGX gears. This means that the red section will be too thin: 131d5f24-8951-4b7b-93f1-248d6200a972-image.png
                                  Stay in school
                                  • OwenDundefined
                                    OwenD
                                    Interesting concept.
                                    I'll be interested to see if the resonant frequencies common in hypoid gears have an effect on extrusion.
                                    • nikschaundefined
                                      nikscha @OwenD
                                      @OwenD Could you elaborate? I haven't heard of those resonant frequencies
                                      Stay in school
                                      OwenDundefined 1 Reply Last reply Reply Quote 0
                                      • OwenDundefined
                                        OwenD @nikscha
                                        My experience with regards to printing has only been with the Zesty nimble.
                                        If you search you should find plenty of examples of the artifacts.
                                        The V2 version is supposed to have fixed this, but I'd given up by then.
                                        Hence my interest to see if this implementation of similar gears will present with the same issues.
                                        The older of us would be well familiar with these frequencies on car differentials.
                                        There is plenty of research on how these frequencies occur, but the math is well over my head.
                                        • nikschaundefined
                                          nikscha @OwenD
                                          @OwenD
                                          I printed @MIHAIDESIGNS extruder test piece and it looks very smooth.
                                          Does that answer your question?
                                          Stay in school
                                          • OwenDundefined
                                            OwenD @nikscha
                                            @OwenD
                                            I don't see the same patterns, but there does seem to be some irregular extrusion in places.
                                            It probably looks worse in the photo than in person and is way less than the issue I had.
                                            Not trying to hose down the idea, just interested from a mechanics point of view.
