    Hollow shaft extruder
    345
    41.2k
    • JoergS5undefined
      JoergS5 @o_lampe
      @o_lampe there is a Nema 8 here https://www.reichelt.de/hohlwellen-schrittmotor-nema-08-1-8-0-6-a-3-9-v-nema08-05hs-p335320.html?PROVID=2788&gclid=Cj0KCQjwwISlBhD6ARIsAESAmp5SVBd28tYQEtsDZDv-4GQtwyN0WT3fD8lBi6a7V1rBr5Z6D26vTaUaAkYVEALw_wcB
      I don't think you can bore a hore through the steel shaft. Possible would be to disassemble the stepper and replace the shaft. Then you could use aluminium instead of steel, this spares weight (but I don't know whether the stepper's magnets need the steel as core).
      • o_lampeundefined
        o_lampe @JoergS5
        @JoergS5 Good find! The actual weight is nowhere stated, but they mention package weight of 67grams..
        Drilling through the shaft is mentioned a few times in the Schnekenstruder thread. Usually the shaft already has a center-drill and they are not hardened.
        • JoergS5undefined
          JoergS5 @o_lampe
          @o_lampe I see no problem to bore the shaft, but disassembled from the stepper and using a lathe, boring half way from both sides. Rotating the shaft and using the drill non-rotating. With good cooling.
          I have a lathe, I could try it for you, but I need multiple shafts because the first tries will probably fail *). 8mm would be much easier than 5 mm.
          *) thinking about it, this doesn't need to be a stepper shaft. I have enough steel shafts...
          Another idea, buy a normal nema 17 with hollow shaft and exchange the shafts
          with a light stepper.
          deckingmanundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
            deckingman @JoergS5
            @JoergS5 Another idea - clamp the motor in a drill dress press then rotate the shaft by driving the motor against a non-rotating drill bit 🙂 (That wasn't really a serious idea but it would save disassembling the motor ..........).
            dc42undefined o_lampeundefined 2 Replies Last reply Reply Quote 1
              dc42 administrators @deckingman
              Hollow shaft stepper motors are commonly used in open source pick-and-place machines, with the suction to pick up the part fed through the shaft. You may be able to find out more about hollow shaft motors by asking at https://groups.google.com/g/openpnp.
              • o_lampeundefined
                o_lampe @deckingman
                @deckingman Let's see if a rotary axis limited to 2^31 angle degrees will be enough to drill through 13mm steel 😉
                • o_lampeundefined
                  o_lampe @JoergS5
                  @JoergS5 Don't waste your time with these experiments.
                  I disassembled a N17 pancake and the shaft is only pressfit into the rotor. Easy job to drill it hollow with a lathe. The hole doesn't have to be super centric. 2.5mm will do for sure.
                  • o_lampeundefined
                    o_lampe
                    I played around with the beveled gear design and tried to figure out what gear ratio I could achieve.
                    The BMG dual drive gears are a real spoilsport, because the distance between the hobbed gear and the spur gear doubles up when mounted as shown.
                    The blue bevel gears can't be much larger, and the 2nd stage straight gear much smaller.
                    The estimated teethcount now is:
                    orange gear 64T
                    blue bevel 48T
                    blue spur 12T
                    BMG spur 17T
                    That sums up to a gear ratio of 1:4, that's less than any other geared extruder has. 😞 (unless I miscalculated, which is possible)
                    Q: why is the gap between hobbed and spur gear so big? Isn't there a better way to make them?
                      droftarts administrators @o_lampe
                      @o_lampe I was thinking more along the lines of the image below, using a hypoid gear.
                      The gear ratio is about 2:1. There's just about enough space between the larger gear and the driven hobbed insert (about 4mm) for the second hobbed insert to be in a lever housing, like in most other extruders. But you could increase the size of the gear on the motor shaft, and reduce the size of the large gear, all the way down to 1:1 (assuming the motor is strong enough for direct drive) if you needed more space. Or increase the distance between the motor and the hobbed inserts for a higher gear ratio and smaller, lighter motor.
                      droftartsundefined nikschaundefined 2 Replies Last reply Reply Quote 0
                        droftarts administrators @droftarts
                        Turns out my idea is pretty much the same as this one that @T3P3Tony posted about in the other thread, which looks pretty neat: https://youtu.be/eI0tD69wD18
                        That one uses a NEMA14. I saw pictures of it and assumed it was a NEMA17, so perhaps wouldn't be too top heavy.
                        I think it would be worth contacting Jason at LDO to see if they have/can make any lighter pancake or round stepper motors with hollow shafts, for either the hypoid version or the Archimedes screw version.
                        I'd say the Archimedes screw version wins on compactness, at the expense of some concerns about the filament spinning and extrusion inconsistency, though these might be avoided with more refinement of the design and manufacturing process. Alternatively, fitting something like a filament monitor, but with a shaft encoder on it, and running the extruder in closed loop mode would help.
                        • o_lampeundefined
                          o_lampe @droftarts
                          @droftarts I'm not happy with the dual drive gears somewhere in the middle of the assembly. They should be lowest as possible (e.g. for flexible filament)
                          That's why I didn't increase the blue bevel gears in my sketch.
                          The ingenius extruder is quite impressive, but top heavy IMHO.
                          A two stage gearing would make it more compact, I guess.
                          Those square NEMA14 motors are so heavy compared to the round ones, I'm surprised, he picked one of these...
                          The hypoid drive reminded me a bit of a worm drive, which might be an option, too?
                          Which CAD system can calculate them? (hypoid)
                            @o_lampe said in Hollow shaft extruder:
                            @droftarts I'm not happy with the dual drive gears somewhere in the middle of the assembly. They should be lowest as possible (e.g. for flexible filament). That's why I didn't increase the blue bevel gears in my sketch.
                            Good point. A smaller second gear would bring it closer, at the expense of gear ratio.
                            The ingenius extruder is quite impressive, but top heavy IMHO. ... Those square NEMA14 motors are so heavy compared to the round ones, I'm surprised, he picked one of these...
                            Yes, that was my initial thought, too.
                            But more backlash/complexity/cost?
                            It's kind of a cross between a spiral bevel gear and a worm drive. See https://en.wikipedia.org/wiki/Spiral_bevel_gear#Hypoid_gears
                            The advantage is that it can transmit more torque than a spiral bevel gear, but, like a worm drive, they also have some sliding action along the teeth.
                            This is about the only CAD tutorial I could find for making hypoid gears, though uses Blender, I'm sure it could be done in Fusion 360 or OpenSCAD: https://youtu.be/wWn9gYwnONk
                            There's a calculator here http://www.otvinta.com/hypoid.html (they also have calculators and videos for other gears
                            Also, if it helps your design, Orbiter v2.0 uses shorter drive gears; 11mm vs 15mm. You could reduce the size of the motor gear, then.
                            • nikschaundefined
                              nikscha @droftarts
                              @droftarts Way ahead of you 😉
                              https://www.youtube.com/watch?v=eI0tD69wD18
                              Stay in school
                              droftartsundefined 1 Reply Last reply Reply Quote 1
                                droftarts administrators @nikscha
                                @nikscha I saw... I give up! Yours is very nice, I like how you're trying to squeeze the filament sensor in there too. How did you model the hypoid gear? I saw from your videos you're using Fusion 360.
                                nikschaundefined 1 Reply Last reply Reply Quote 0
                                • nikschaundefined
                                  nikscha @o_lampe
                                  *Ingenuity Extruder 😛
                                  I actually ordered a round one from LDO, and torque per weight seemed to be much better for the square one. Obviously this is only in the prototype stage (I am actually looking for beta testers right now), and any help with the motor design would be appreciated!
                                  I used a blender tutorial to model the hypoid bevel gears. Rest is done in fusion. But there are also proper calculators (MIT calculator) for hypoid bevel gears.
                                  Stay in school
                                  • nikschaundefined
                                    nikscha @droftarts
                                    @droftarts I followed a blender tutorial hahaha. The math is done here for you: http://www.otvinta.com/hypoid.html
                                    I want to open source this design under Creative Commons, so any help is appreciated!
                                    I'm actually looking for beta testers, and maybe we can make this a kit!
                                    Stay in school
                                    • nikschaundefined
                                      nikscha
                                      Damn I wanted to wait a bit longer with posting about the Ingenuity extruder on the forum but I guess it's too late now 😅
                                      It's a direct drive extruder which features a hollow-shaft Nema-14 stepper motor, Bondtech LGX drive gear, an eccentric breach which is self-locking, an idler wheel where the spokes act as a tensioning spring and a hypoid bevel gear pair, archiving a gear ratio of 37:7.
                                      The whole mechanism features only 4 moving parts: two gears, the idler wheel and the breach-lever. Weight is 229g.
                                      https://www.thingiverse.com/thing:6056191
                                      Stay in school
                                        @nikscha Do you think there's any way you can reduce the diameter of the large gear? My first impression was that it would be a bit top heavy, though a lighter motor would help with that. @o_lampe 's point about it being a long way from the drive gear to the hot end, particularly for flexible filaments, could also be problematic.
                                        What is your view on the Archimedes screw extruder?
                                        • nikschaundefined
                                          nikscha
                                          Sorry for highjacking this post by the way, I made a separate one here:
                                          https://forum.duet3d.com/topic/32876/ingenuity-extruder-for-smart-effector
                                          Stay in school
                                            @nikscha said in Hollow shaft extruder:
                                            No worries, after all your extruder is a hollow shaft extruder, and that's what this thread is about!
