Hollow shaft extruder
345
40.2k
    o_lampe @tombrazier
    @tombrazier I guess your Dremel will be pretty busy for a while. Here's the first print of the double roller VDE-100
    Some artifacts I've noticed when I converted to .obj. They actually show in the print..
    undefined 1 Reply Last reply 17 Aug 2023, 15:50 Reply Quote 2
      tombrazier
      @o_lampe said in Hollow shaft extruder:
      It get's tricky when mm/s was the toolhead speed.
      Sorry I might not have been clear. It was filament speed. Multiple by 1.75^2 * pi / 4 to get volumetric speed.
        tombrazier @o_lampe
        Fab, thanks.
        The hole is intended. It marks bearing number 1. In this case that's not really relevant. But when there were different kinds of bearings or (because I ran out of bearings to grind!) different diameter bearings in different positions, I needed the marker.
        The bits in the middle are fine. If they printed really well and are strong enough, they can act as an extra guide for the filament. Otherwise they can be broken or cut off easily enough.
        undefined 1 Reply Last reply 17 Aug 2023, 19:28 Reply Quote 0
          o_lampe @tombrazier
          @tombrazier How do you mount it on the stepper? There is no radial hole for a grub screw.
          undefined 1 Reply Last reply 17 Aug 2023, 19:40 Reply Quote 0
            tombrazier @o_lampe
            @o_lampe I press it onto the shaft. It holds with friction. The torque is so low that a grub screw is not necessary.
            undefined 1 Reply Last reply 20 Aug 2023, 07:16 Reply Quote 0
            • undefined o_lampe referenced this topic 19 Aug 2023, 06:43
              breed @tombrazier
              @tombrazier is there a link to the double roller version? I want to look at it in cad.
              undefined undefined 2 Replies Last reply 21 Aug 2023, 10:23 Reply Quote 0
                oliof @breed
                due to the continued interest in hollow shaft extruders, @tombrazier and I had a chat with Jason from LDO about a ready made hollow shaft extruder for VDE. We are currently gauging interest in production of some samples.
                These are the planned motor specs. The weight is with a 1m wire, actual motor weight is closer to 50g as far as I understand
                If anyone is interested in getting one or two, please get in touch with me so we can organize a group order.
                undefined undefined undefined 3 Replies Last reply 22 Aug 2023, 06:06 Reply Quote 0
                  tombrazier @breed
                  @breed VDE-Tom-9.1mm_backtoback.step
                  And the FreeCAD parametric model (well, several models including the back to back one): VDE-Tom.FCStd
                  undefined 1 Reply Last reply 22 Aug 2023, 04:31 Reply Quote 0
                    tombrazier
                    This post is deleted!
                      breed @tombrazier
                      @tombrazier alt text
                      undefined 1 Reply Last reply 22 Aug 2023, 10:47 Reply Quote 0
                        o_lampe @oliof
                        @oliof I figured out, that my NEMA14 steppers have a thicker middle part on the shaft. So it isn't possible to replace the shaft with a 5x1mm stainless tube.
                        OTOH I'm so happy with my BLDC extruder, that I won't spend money on a LDO stepper.
                        I'm happy to supply resin printed carriers, unless @tombrazier has also found a better source in UK?
                        The bearings didn't arrive yet, so I can't tell if the carrier needs subtile changes.
                        undefined 1 Reply Last reply 22 Aug 2023, 10:49 Reply Quote 0
                          CNCModeller @oliof
                          @oliof said in Hollow shaft extruder:
                          I'd be interested, I need a compact extrusion solution that I can embed in a much more complex print head. I have a hollow shaft stepper I've been playing with, but I'm guessing a closed loop brush less solution will have better performance.
                          I've only been following the thread superficially so I'd really appreciate if someone in the know could pull together a summary of relevant resources e.g. any cad for printed parts etc, hopefully the resources are Fusion 360 compatible so I can integrate them into my larger assembly.
                          I have both FDM and resin printers so should be ok to pull something together, albeit I'm maxed out on the day job at the moment so any progress at my end will be relatively slow.
                          Any thoughts would be much appreciated 👍
                          All the best.
                          Barry M
                          Polar Duet3 Mini + 1HCL
                          https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                          Wanhao D4S: Duet2
                          https://forum.duet3d.com/post/296755
                          K40 Laser, Duet2
                          https://forum.duet3d.com/post/312082
                          Wanhao D5S
                          https://www.youtube.com/CNCModellerUK
                          undefined undefined 2 Replies Last reply 22 Aug 2023, 11:23 Reply Quote 0
                            tombrazier @breed
                            @breed Cool. Are you Adam, then?
                            undefined 1 Reply Last reply 22 Aug 2023, 15:58 Reply Quote 0
                              tombrazier @o_lampe
                              @o_lampe You're my only source at the moment. I am interested to see the difference between SLA and FDM. I find the latter works really well but it looks like the SLA print has higher resolution.
                                o_lampe @CNCModeller
                                @CNCModeller said in Hollow shaft extruder:
                                The BLDC version is not as compact and lightweight as the stepper because it needs a sensor and separate MCU&driver. I have a working unit with a Waveshare rp2040-zero and sFOC-mini. But the magnetic sensor doesn't work with the hollow shaft concept.
                                The AMT103-V is expensive and heavy. There is a lighter AMT102-V which could be interesting. But there is yet no design that fits the VDE-100 extruder.
                                I haven't bought any of these, because the 20€ shipping fee puts me off.
                                There are optical encoders too, but they need an enclosure...
                                The dice are still rolling
                                If you don't want to wait, you should go for a LDO hollow shaft stepper.
                                undefined 1 Reply Last reply 22 Aug 2023, 11:58 Reply Quote 0
                                  CNCModeller @o_lampe
                                  @o_lampe thanks for the feedback, I'll stick with the stepper for now then.
                                  I have ring based (CNC lathe spindle) magnetic encoders working on other prototypes but you are correct in that the additional mass for the sensor changes the equation.
                                  Will keep an eye on what's happening here all the same.
                                  I'm not timescale sensitive as the day job is really demanding at the moment, just trying to keep up with relevant community developments. 👍
                                  Many thanks
                                  Barry M
                                  Wanhao D4S: Duet2
                                  K40 Laser, Duet2
                                  Wanhao D5S
                                    o_lampe
                                    I pushed myself over the edge and ordered an PD30 optical disk encoder with 512ppr.
                                    The wiring and tech-specs are a bit confusing as usual. I hope it's an ABI type...
                                      breed @tombrazier
                                      @tombrazier Yep. I don't think I linked that correctly.
                                        o_lampe
                                        The bearings arrived and I made a big batch of both carrier versions.
                                        It works nice and smooth spinning it by hand.
                                        It's too early to review the threeBB. I'll let him do some weightlifting soon.
                                        The carriers in the background are freebies for guinee pigs (a small donation for stamps and envelops is welcome) . They come without bearings tho.
                                        PM me for details
                                        I'll send five of each to @tombrazier, so users in UK may ask him...unless he wants to keep them all for himself 😉
                                        He might also be able to tell us more about the grinding process.
                                        undefined undefined undefined undefined 4 Replies Last reply 23 Aug 2023, 02:24 Reply Quote 1
                                          breed @o_lampe
                                          @o_lampe What did the weight end up?
                                          undefined 1 Reply Last reply 23 Aug 2023, 06:39 Reply Quote 0
                                          181 out of 345
