Duet 2 Wifi 3 Heater control using bed output + messed up tools
1.4k
    mikep91
    Hey everyone.
    I have tried setting up a hotend with 3 heaters - I am getting some messed up tools it seems.
    When i PID Tune heater 1, it turns on heater 2.
    It doesnt show heater/tool 3 on my display but shows it in DWC - However i have multiple tools for some of the heaters.....
    Config:config.g
    undefined 1 Reply Last reply 7 Oct 2023, 14:54 Reply Quote 0
      mikep91 @mikep91
      @mikep91
      I am beaten - no matter what i change my heaters and sensors does not match up.
      Also after switching to 3.4.6 i cannot even heat up my 3rd heater - it heats too slowly...
      I tried doing the aututune - but then figured my heaters and sensors doesnt match up...
      Anyone?
      undefined 1 Reply Last reply 7 Oct 2023, 14:55 Reply Quote 0
        DIY-O-Sphere @mikep91
        @mikep91
        M140 H1 ; disable heated bed (overrides default heater mapping)
        should be
        M140 H-1
        (UTC+1)
          mikep91 @DIY-O-Sphere
          @DIY-O-Sphere
          Yeah i enabled it to check if my 3rd heater shows up in that spot - that happens some times... :S
          undefined 1 Reply Last reply 7 Oct 2023, 14:56 Reply Quote 0
            @mikep91
            You are mapping heater1 to the bed....
            (UTC+1)
            undefined 1 Reply Last reply 7 Oct 2023, 14:57 Reply Quote 0
              Yes I need to use the "bedheat" output to heat up my 3rd heater as the two other heater outputs is used.
              However I am mismatching sensors, tools and heaters somehow in my config, so nothing aligns up :(!
              undefined 1 Reply Last reply 7 Oct 2023, 14:59 Reply Quote 0
                mikep91 @mikep91
                @mikep91
                This one bedheater shows 101c but that doesnt show anywhere in my DWC - vise versa
                undefined 1 Reply Last reply 7 Oct 2023, 15:23 Reply Quote 0
                  @mikep91
                  M140 H-1 ; disable heated bed (overrides default heater mapping)
                  M308 S0 P"spi.cs3" Y"rtd-max31865" ; configure sensor 0 as PT100 on pin spi.cs3
                  M950 H0 C"bedheat" T0 ; create nozzle heater output on bedheat and map it to sensor 0
                  M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                  M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
                  M308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 2 as thermocouple via CS pin spi.cs2
                  M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
                  M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                  M143 H2 S280 ; set temperature limit for heater 2 to 280C
                  M563 P0 H0 F0 ; define tool 1
                  G10 P0 X0 Y0 Z0 ; set tool 1 axis offsets
                  G10 P0 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
                  M563 P1 H1 F0 ; define tool 2
                  G10 P1 X0 Y0 Z0 ; set tool 2 axis offsets
                  G10 P1 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
                  M563 P2 H2 F0 ; define tool 3
                  G10 P2 X0 Y0 Z0 ; set tool 3 axis offsets
                  G10 P2 R0 S0 ; set initial tool 3 active and standby temperatures to 0C
                  Try that
                  (UTC+1)
                  undefined 1 Reply Last reply 7 Oct 2023, 15:37 Reply Quote 0
                    @DIY-O-Sphere
                    Does not work properly either.
                    I think maybe my heaters, sensors & tools is mismatching somehow.
                    When i PID turned heater 3 it didnt heat properly either.
                    undefined 1 Reply Last reply 7 Oct 2023, 16:05 Reply Quote 0
                      @mikep91
                      I suspect the firmware is confused because it is not a complete configuration.
                      Maybe you can describe what you want to do.
                      As I understand it, you only want to control 3 heaters?
                      (UTC+1)
                      undefined 1 Reply Last reply 7 Oct 2023, 16:24 Reply Quote 0
                        @DIY-O-Sphere
                        Yes i want to control just 3 different heaters (all for an extruder/hotend), one from the bed output on the duet. two others from the regular E outputs.
                        and all with 3 different sensors - PT100 on the duet aswell
                        Then i want to map the 3 sensors and heaters to heater 1 2 and 3 , but it keeps turning up as they are mixed up, or one of them on the bed heater output...
                        Looking something like this:
                        M143 H0 S280 ; set temperature limit for heater 0 to 120C
                        I am quite confused of the P1, P2 and how to configure them to the correct "tool" in the dwc and duet display - so i am sure my heaters match etc.
                        M563 P1 H0 F0 ; define tool 1
                        M563 P2 H1 F0 ; define tool 2
                        G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
                        G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
                        M563 P3 H2 F0 ; define tool 3
                        G10 P3 X0 Y0 Z0 ; set tool 3 axis offsets
                        G10 P3 R0 S0 ; set initial tool 3 active and standby temperatures to 0C
                        undefined 1 Reply Last reply 7 Oct 2023, 17:06 Reply Quote 0
                          @mikep91
                          The tool count starts with 0.
                          So P0 Is tool1
                          (UTC+1)
                            Also make sure your firmware is update and that DWC version matches. You should also update your paneldue firmware.
                            undefined 1 Reply Last reply 8 Oct 2023, 18:23 Reply Quote 0
                              mikep91 @Phaedrux
                              @Phaedrux
                              Paneldue is up to 1.25 now this was updated and works great!
                              Looking at the PT100 - which side is spi.cs1 & which side is spi.cs2? when i plug another one on top - i suppose that becomes spi.cs3&4?
                              Phaedruxundefined 1 Reply Last reply 8 Oct 2023, 18:26 Reply Quote 0
                                The sides have silk screen labels of RTD1 and RTD2.
                                And yes when you stack two of them the next ones are spi.cs3 & 4.
                                  Phaedrux Moderator @mikep91
                                  @mikep91 said in Duet 2 Wifi 3 Heater control using bed output + messed up tools:
                                  Should probably update to the 3.x firmware there as well.
                                  undefined 1 Reply Last reply 8 Oct 2023, 18:29 Reply Quote 0
                                    mikep91 @Phaedrux
                                    @Phaedrux
                                    The 1.25 works on 2x setups with only 2 heaters - I am only having problems assigning the heaters on the 3rd setup that needs 3 heaters.
                                    Could a problem be that i start up by assigning H0? Looking at the duet display - i am using the 3 marked heaters. - e0heat - e1heat and H3 "bedheat"
                                      Why are you using the expansion header? Why not the actual bed heater output?
                                      undefined 1 Reply Last reply 8 Oct 2023, 18:35 Reply Quote 0
                                        mikep91 @Phaedrux
                                        @Phaedrux
                                        It is for controlling a 3 heater hotend (Dyze Pulsar)
                                        Therefor I am turning off the bed heater - but my tool mapping seems to be wrong so i keep getting the 3rd temperature on the bed heater output instead of a 3rd tool - and at the same time I'm get them mismatched somehow....
                                        Will do some wiring checks and numbering of wires tomorrow hopefully sort it up.
                                        Am not using heated bed - so I know I should do a H-1 to turn it off. but the mapping seems to go on that tool
                                        Phaedruxundefined 1 Reply Last reply 8 Oct 2023, 18:40 Reply Quote 0
                                          Are you using a heated bed, or not?
                                          undefined 1 Reply Last reply 8 Oct 2023, 18:38 Reply Quote 0
                                          1 out of 40
