Duet 2 Wifi 3 Heater control using bed output + messed up tools
I suspect the firmware is confused because it is not a complete configuration.
Maybe you can describe what you want to do.
As I understand it, you only want to control 3 heaters? -
Yes i want to control just 3 different heaters (all for an extruder/hotend), one from the bed output on the duet. two others from the regular E outputs.
and all with 3 different sensors - PT100 on the duet aswellThen i want to map the 3 sensors and heaters to heater 1 2 and 3 , but it keeps turning up as they are mixed up, or one of them on the bed heater output...
Looking something like this:
M308 S0 P"spi.cs3" Y"rtd-max31865" ; configure sensor 0 as PT100 on pin spi.cs3
M950 H0 C"bedheat" T0 ; create nozzle heater output on bedheat and map it to sensor 0
M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H0 S280 ; set temperature limit for heater 0 to 120CM308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
M143 H1 S280 ; set temperature limit for heater 1 to 280CM308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 2 as thermocouple via CS pin spi.cs2
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H2 S280 ; set temperature limit for heater 2 to 280CI am quite confused of the P1, P2 and how to configure them to the correct "tool" in the dwc and duet display - so i am sure my heaters match etc.
M563 P1 H0 F0 ; define tool 1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0CM563 P2 H1 F0 ; define tool 2
G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0CM563 P3 H2 F0 ; define tool 3
G10 P3 X0 Y0 Z0 ; set tool 3 axis offsets
G10 P3 R0 S0 ; set initial tool 3 active and standby temperatures to 0C -
@mikep91
The tool count starts with 0.
So P0 Is tool1 -
Also make sure your firmware is update and that DWC version matches. You should also update your paneldue firmware.
Paneldue is up to 1.25 now this was updated and works great!
Looking at the PT100 - which side is spi.cs1 & which side is spi.cs2? when i plug another one on top - i suppose that becomes spi.cs3&4?
The sides have silk screen labels of RTD1 and RTD2.
And yes when you stack two of them the next ones are spi.cs3 & 4. -
@mikep91 said in Duet 2 Wifi 3 Heater control using bed output + messed up tools:
Should probably update to the 3.x firmware there as well.
The 1.25 works on 2x setups with only 2 heaters - I am only having problems assigning the heaters on the 3rd setup that needs 3 heaters.
Could a problem be that i start up by assigning H0? Looking at the duet display - i am using the 3 marked heaters. - e0heat - e1heat and H3 "bedheat"
Why are you using the expansion header? Why not the actual bed heater output?
It is for controlling a 3 heater hotend (Dyze Pulsar)
Therefor I am turning off the bed heater - but my tool mapping seems to be wrong so i keep getting the 3rd temperature on the bed heater output instead of a 3rd tool - and at the same time I'm get them mismatched somehow....
Will do some wiring checks and numbering of wires tomorrow hopefully sort it up.
Am not using heated bed - so I know I should do a H-1 to turn it off. but the mapping seems to go on that tool
Are you using a heated bed, or not?
No - not controlled off the DUET - duet is only supposed to be controlling 3 heaters in one hotend
Elaborated in answer above
If you're not using a bed heater you can use the output for your 3rd extruder heater, then you don't need to use the expansion headers, which aren't really intended to be used directly by a heater.
If you don't define a bed heater you don't need a H-1 to disable it.
Makes sense and would be alot better as the connections on the expansion is quite poor compared to the bed and extruder connections.
How would the M command look for mapping the 3rd heater to the bed instead of the expansion?
M308 S1 P"spi.cs3" Y"rtd-max31865" ;
M950 H1 C"bedheat" T0 ;
M307 H1 B0 S1.00 ;
M143 H1 S280 ;Something like this - whilst not using H-1 to cancel it out?
So if I understand your setup, and I'm not sure that I do, you'd have something like this for a single tool, using 3 heaters together, and no bed heater, with PT100 temp sensors.
; Heaters M140 H-1 ; disable heated bed (overrides default heater mapping) M308 S0 P"spi.cs1" Y"rtd-max31865" ; configure sensor 0 as PT100 on pin spi.cs1 M950 H0 C"bedheat" T0 ; create nozzle heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H0 S280 ; set temperature limit for heater 0 to 280C M308 S1 P"spi.cs2" Y"rtd-max31865" ; configure sensor 1 as PT100 on pin spi.cs2 M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C M308 S2 P"spi.cs3" Y"rtd-max31865" ; configure sensor 2 as PT100 on pin spi.cs3 M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H2 S280 ; set temperature limit for heater 2 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H0:1:2 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H0:1:2 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Miscellaneous T0 ; select first tool -
Yeah im sorry for being not very precise - I am using a pellet hotend on a robotic arm, so the duet is only to control the heaters. But it has 3 heat zones - so i would need individual control of each heat zone mapped to a specific sensor.
Would this give me 3 individual heaters to control on the duet display?
I will do a test first thing tomorrow morning with this - thank you!
Does the Duet even need to know it's a tool? If it's only doing heater control and no motion planning I think you could leave out the tool and fan definition.
No it does not actually - i thought these commands were what gave me temp control on the display
Hello again Phaedrux -
When testing out the config you posted yesterday.
When setting the temperature on the display - I am getting the error "wrong tool"...
How would i correct the tool allocations?
I can turn them on using macros and M commands but not on the display....
Cheers
I have three sensors attached both in the DUET and in the code.
However when launching this CONFIG below- I can only see 2 in the DWC --->
When using a completely 2nd code (for another robot with only 2 heaters) I can see all three - however then they are mapped wrong as this only uses 2 heaters outputs.
M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 0 as PT100 on pin spi.cs1
M950 H1 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0
M143 H1 S280 ; set temperature limit for heater 0 to 120CM308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 1 as PT100 on pin spi.cs2
M950 H2 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
M143 H2 S280 ; set temperature limit for heater 1 to 280CM308 S3 P"spi.cs3" Y"rtd-max31865" ; configure sensor 1 as PT100 on pin spi.cs2
M950 H3 C"bedheat" T2 ; create nozzle heater output on e1heat and map it to sensor 1
M307 H3 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H3 S280 ; set temperature limit for heater 1 to 280CM570 H1 P10 T100 ; An anomaly on heater 1 must persist for 10 seconds, and must be greater or less than 100C from the setpoint, to raise a heater fault.
M570 H2 P10 T100 ; An anomaly on heater 1 must persist for 10 seconds, and must be greater or less than 100C from the setpoint, to raise a heater fault.; Fans
M563 P1 D0 H1 F0 ; define tool 2
G10 P1 X0 Y0 Z0 ; set tool 2 axis offsets
G10 P1 R0 S0 ; set initial tool 0 active and standby temperatures to 0CM563 P2 H2 F0 ; define tool 1
G10 P2 X0 Y0 Z0 ; set tool 1 axis offsets
G10 P2 R0 S0 ; set initial tool 1 active and standby temperatures to 0CM563 P3 H3 F0 ; define tool 1
G10 P3 X0 Y0 Z0 ; set tool 1 axis offsets
G10 P3 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
