    Duet 2 Wifi 3 Heater control using bed output + messed up tools
    1.4k
    • DIY-O-Sphereundefined
      DIY-O-Sphere @mikep91
      @mikep91
      You are mapping heater1 to the bed....
      (UTC+1)
      mikep91undefined 1 Reply Last reply Reply Quote 0
      • mikep91undefined
        mikep91 @DIY-O-Sphere
        Yes I need to use the "bedheat" output to heat up my 3rd heater as the two other heater outputs is used.
        However I am mismatching sensors, tools and heaters somehow in my config, so nothing aligns up :(!
        • mikep91undefined
          mikep91 @mikep91
          @mikep91
          This one bedheater shows 101c but that doesnt show anywhere in my DWC - vise versa
          DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
            @mikep91
            M140 H-1                                   ; disable heated bed (overrides default heater mapping)
            M308 S0 P"spi.cs3" Y"rtd-max31865"          ; configure sensor 0 as PT100 on pin spi.cs3
            M950 H0 C"bedheat" T0                      ; create nozzle heater output on bedheat and map it to sensor 0
            M307 H0 B0 S1.00                            ; disable bang-bang mode for heater  and set PWM limit
            M143 H0 S120                                ; set temperature limit for heater 0 to 120C
            M308 S1 P"spi.cs1" Y"rtd-max31865"  ; configure sensor 1 as thermocouple via CS pin spi.cs1
            M950 H1 C"e0heat" T1                        ; create nozzle heater output on e0heat and map it to sensor 1
            M307 H1 B0 S1.00                            ; disable bang-bang mode for heater  and set PWM limit
            M143 H1 S280                                ; set temperature limit for heater 1 to 280C
            M308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 2 as thermocouple via CS pin spi.cs2
            M950 H2 C"e1heat" T2                        ; create nozzle heater output on e1heat and map it to sensor 2
            M307 H2 B0 S1.00                            ; disable bang-bang mode for heater  and set PWM limit
            M143 H2 S280                                ; set temperature limit for heater 2 to 280C
            M563 P0 H0 F0                               ; define tool 1
            G10 P0 X0 Y0 Z0                             ; set tool 1 axis offsets
            G10 P0 R0 S0                                ; set initial tool 1 active and standby temperatures to 0C
            M563 P1 H1 F0                               ; define tool 2
            G10 P1 X0 Y0 Z0                             ; set tool 2 axis offsets
            G10 P1 R0 S0                                ; set initial tool 2 active and standby temperatures to 0C
            M563 P2 H2 F0                               ; define tool 3
            G10 P2 X0 Y0 Z0                             ; set tool 3 axis offsets
            G10 P2 R0 S0                                ; set initial tool 3 active and standby temperatures to 0C
            Try that
            (UTC+1)
            • mikep91undefined
              @DIY-O-Sphere
              Does not work properly either.
              I think maybe my heaters, sensors & tools is mismatching somehow.
              When i PID turned heater 3 it didnt heat properly either.
                @mikep91
                I suspect the firmware is confused because it is not a complete configuration.
                Maybe you can describe what you want to do.
                As I understand it, you only want to control 3 heaters?
                (UTC+1)
                • mikep91undefined
                  @DIY-O-Sphere
                  Yes i want to control just 3 different heaters (all for an extruder/hotend), one from the bed output on the duet. two others from the regular E outputs.
                  and all with 3 different sensors - PT100 on the duet aswell
                  Then i want to map the 3 sensors and heaters to heater 1 2 and 3 , but it keeps turning up as they are mixed up, or one of them on the bed heater output...
                  Looking something like this:
                  M143 H0 S280 ; set temperature limit for heater 0 to 120C
                  I am quite confused of the P1, P2 and how to configure them to the correct "tool" in the dwc and duet display - so i am sure my heaters match etc.
                  M563 P1 H0 F0 ; define tool 1
                  M563 P2 H1 F0 ; define tool 2
                  G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
                  G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
                  M563 P3 H2 F0 ; define tool 3
                  G10 P3 X0 Y0 Z0 ; set tool 3 axis offsets
                  G10 P3 R0 S0 ; set initial tool 3 active and standby temperatures to 0C
                    @mikep91
                    The tool count starts with 0.
                    So P0 Is tool1
                    (UTC+1)
                      Also make sure your firmware is update and that DWC version matches. You should also update your paneldue firmware.
                      • mikep91undefined
                        mikep91 @Phaedrux
                        @Phaedrux
                        Paneldue is up to 1.25 now this was updated and works great!
                        Looking at the PT100 - which side is spi.cs1 & which side is spi.cs2? when i plug another one on top - i suppose that becomes spi.cs3&4?
                          The sides have silk screen labels of RTD1 and RTD2.
                          And yes when you stack two of them the next ones are spi.cs3 & 4.
                            Phaedrux Moderator @mikep91
                            @mikep91 said in Duet 2 Wifi 3 Heater control using bed output + messed up tools:
                            Should probably update to the 3.x firmware there as well.
                            • mikep91undefined
                              mikep91 @Phaedrux
                              @Phaedrux
                              The 1.25 works on 2x setups with only 2 heaters - I am only having problems assigning the heaters on the 3rd setup that needs 3 heaters.
                              Could a problem be that i start up by assigning H0? Looking at the duet display - i am using the 3 marked heaters. - e0heat - e1heat and H3 "bedheat"
                                Why are you using the expansion header? Why not the actual bed heater output?
                                • mikep91undefined
                                  mikep91 @Phaedrux
                                  @Phaedrux
                                  It is for controlling a 3 heater hotend (Dyze Pulsar)
                                  Therefor I am turning off the bed heater - but my tool mapping seems to be wrong so i keep getting the 3rd temperature on the bed heater output instead of a 3rd tool - and at the same time I'm get them mismatched somehow....
                                  Will do some wiring checks and numbering of wires tomorrow hopefully sort it up.
                                  Am not using heated bed - so I know I should do a H-1 to turn it off. but the mapping seems to go on that tool
                                    Are you using a heated bed, or not?
                                    • mikep91undefined
                                      mikep91 @Phaedrux
                                      @Phaedrux
                                      No - not controlled off the DUET - duet is only supposed to be controlling 3 heaters in one hotend
                                      Elaborated in answer above
                                        If you're not using a bed heater you can use the output for your 3rd extruder heater, then you don't need to use the expansion headers, which aren't really intended to be used directly by a heater.
                                        If you don't define a bed heater you don't need a H-1 to disable it.
                                        • mikep91undefined
                                          mikep91 @Phaedrux
                                          @Phaedrux
                                          Makes sense and would be alot better as the connections on the expansion is quite poor compared to the bed and extruder connections.
                                          How would the M command look for mapping the 3rd heater to the bed instead of the expansion?
                                          M308 S1 P"spi.cs3" Y"rtd-max31865" ;
                                          M950 H1 C"bedheat" T0 ;
                                          M307 H1 B0 S1.00 ;
                                          M143 H1 S280 ;
                                          Something like this - whilst not using H-1 to cancel it out?
                                            So if I understand your setup, and I'm not sure that I do, you'd have something like this for a single tool, using 3 heaters together, and no bed heater, with PT100 temp sensors.
                                            M308 S0 P"spi.cs1" Y"rtd-max31865"      ; configure sensor 0 as PT100 on pin spi.cs1
                                            M143 H0 S280                            ; set temperature limit for heater 0 to 280C
                                            M308 S1 P"spi.cs2" Y"rtd-max31865"      ; configure sensor 1 as PT100 on pin spi.cs2
                                            M308 S2 P"spi.cs3" Y"rtd-max31865"      ; configure sensor 2 as PT100 on pin spi.cs3
                                            M950 F0 C"fan0" Q500                    ; create fan 0 on pin fan0 and set its frequency
                                            M106 P0 S0 H-1                          ; set fan 0 value. Thermostatic control is turned off
                                            M950 F1 C"fan1" Q500                    ; create fan 1 on pin fan1 and set its frequency
                                            M106 P1 S1 H0:1:2 T45                   ; set fan 1 value. Thermostatic control is turned on
                                            M563 P0 D0 H0:1:2 F0                    ; define tool 0
                                            G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
                                            G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
                                            T0                                      ; select first tool
