    Duet 2 Wifi 3 Heater control using bed output + messed up tools
    1.4k
    • mikep91undefined
      mikep91 @Phaedrux
      @Phaedrux
      The 1.25 works on 2x setups with only 2 heaters - I am only having problems assigning the heaters on the 3rd setup that needs 3 heaters.
      Could a problem be that i start up by assigning H0? Looking at the duet display - i am using the 3 marked heaters. - e0heat - e1heat and H3 "bedheat"
        Why are you using the expansion header? Why not the actual bed heater output?
        mikep91undefined 1 Reply Last reply Reply Quote 0
        • mikep91undefined
          mikep91 @Phaedrux
          @Phaedrux
          It is for controlling a 3 heater hotend (Dyze Pulsar)
          Therefor I am turning off the bed heater - but my tool mapping seems to be wrong so i keep getting the 3rd temperature on the bed heater output instead of a 3rd tool - and at the same time I'm get them mismatched somehow....
          Will do some wiring checks and numbering of wires tomorrow hopefully sort it up.
          Am not using heated bed - so I know I should do a H-1 to turn it off. but the mapping seems to go on that tool
            Are you using a heated bed, or not?
            • mikep91undefined
              mikep91 @Phaedrux
              @Phaedrux
              No - not controlled off the DUET - duet is only supposed to be controlling 3 heaters in one hotend
              Elaborated in answer above
                Phaedrux Moderator @mikep91
                @mikep91 said in Duet 2 Wifi 3 Heater control using bed output + messed up tools:
                If you're not using a bed heater you can use the output for your 3rd extruder heater, then you don't need to use the expansion headers, which aren't really intended to be used directly by a heater.
                If you don't define a bed heater you don't need a H-1 to disable it.
                • mikep91undefined
                  mikep91 @Phaedrux
                  @Phaedrux
                  Makes sense and would be alot better as the connections on the expansion is quite poor compared to the bed and extruder connections.
                  How would the M command look for mapping the 3rd heater to the bed instead of the expansion?
                  M308 S1 P"spi.cs3" Y"rtd-max31865" ;
                  M950 H1 C"bedheat" T0 ;
                  M307 H1 B0 S1.00 ;
                  M143 H1 S280 ;
                  Something like this - whilst not using H-1 to cancel it out?
                    So if I understand your setup, and I'm not sure that I do, you'd have something like this for a single tool, using 3 heaters together, and no bed heater, with PT100 temp sensors.
                    M140 H-1                                ; disable heated bed (overrides default heater mapping)
                    M308 S0 P"spi.cs1" Y"rtd-max31865"      ; configure sensor 0 as PT100 on pin spi.cs1
                    M950 H0 C"bedheat" T0                   ; create nozzle heater output on bedheat and map it to sensor 0
                    M307 H0 B0 S1.00                        ; disable bang-bang mode for heater  and set PWM limit
                    M143 H0 S280                            ; set temperature limit for heater 0 to 280C
                    M308 S1 P"spi.cs2" Y"rtd-max31865"      ; configure sensor 1 as PT100 on pin spi.cs2
                    M950 H1 C"e0heat" T1                    ; create nozzle heater output on e0heat and map it to sensor 1
                    M307 H1 B0 S1.00                        ; disable bang-bang mode for heater  and set PWM limit
                    M143 H1 S280                            ; set temperature limit for heater 1 to 280C
                    M308 S2 P"spi.cs3" Y"rtd-max31865"      ; configure sensor 2 as PT100 on pin spi.cs3
                    M950 H2 C"e1heat" T2                    ; create nozzle heater output on e1heat and map it to sensor 2
                    M307 H2 B0 S1.00                        ; disable bang-bang mode for heater  and set PWM limit
                    M143 H2 S280                            ; set temperature limit for heater 2 to 280C
                    M950 F0 C"fan0" Q500                    ; create fan 0 on pin fan0 and set its frequency
                    M106 P0 S0 H-1                          ; set fan 0 value. Thermostatic control is turned off
                    M950 F1 C"fan1" Q500                    ; create fan 1 on pin fan1 and set its frequency
                    M106 P1 S1 H0:1:2 T45                   ; set fan 1 value. Thermostatic control is turned on
                    M563 P0 D0 H0:1:2 F0                    ; define tool 0
                    G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
                    G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
                    T0                                      ; select first tool
                    • mikep91undefined
                      mikep91 @Phaedrux
                      @Phaedrux
                      Yeah im sorry for being not very precise - I am using a pellet hotend on a robotic arm, so the duet is only to control the heaters. But it has 3 heat zones - so i would need individual control of each heat zone mapped to a specific sensor.
                      Would this give me 3 individual heaters to control on the duet display?
                      I will do a test first thing tomorrow morning with this - thank you!
                        Does the Duet even need to know it's a tool? If it's only doing heater control and no motion planning I think you could leave out the tool and fan definition.
                        mikep91undefined 2 Replies Last reply Reply Quote 0
                        • mikep91undefined
                          mikep91 @Phaedrux
                          @Phaedrux
                          No it does not actually - i thought these commands were what gave me temp control on the display
                          • mikep91undefined
                            mikep91 @Phaedrux
                            @Phaedrux
                            Hello again Phaedrux -
                            When testing out the config you posted yesterday.
                            When setting the temperature on the display - I am getting the error "wrong tool"...
                            How would i correct the tool allocations?
                            I can turn them on using macros and M commands but not on the display....
                            Cheers
                            • mikep91undefined
                              mikep91 @mikep91
                              @mikep91
                              I have three sensors attached both in the DUET and in the code.
                              However when launching this CONFIG below- I can only see 2 in the DWC --->
                              When using a completely 2nd code (for another robot with only 2 heaters) I can see all three - however then they are mapped wrong as this only uses 2 heaters outputs.
                              M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 0 as PT100 on pin spi.cs1
                              M950 H1 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0
                              M143 H1 S280 ; set temperature limit for heater 0 to 120C
                              M308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 1 as PT100 on pin spi.cs2
                              M950 H2 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
                              M143 H2 S280 ; set temperature limit for heater 1 to 280C
                              M308 S3 P"spi.cs3" Y"rtd-max31865" ; configure sensor 1 as PT100 on pin spi.cs2
                              M950 H3 C"bedheat" T2 ; create nozzle heater output on e1heat and map it to sensor 1
                              M307 H3 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                              M143 H3 S280 ; set temperature limit for heater 1 to 280C
                              M570 H1 P10 T100 ; An anomaly on heater 1 must persist for 10 seconds, and must be greater or less than 100C from the setpoint, to raise a heater fault.
                              M570 H2 P10 T100 ; An anomaly on heater 1 must persist for 10 seconds, and must be greater or less than 100C from the setpoint, to raise a heater fault.
                              M563 P1 D0 H1 F0 ; define tool 2
                              G10 P1 X0 Y0 Z0 ; set tool 2 axis offsets
                              G10 P1 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
                              M563 P2 H2 F0 ; define tool 1
                              G10 P2 X0 Y0 Z0 ; set tool 1 axis offsets
                              G10 P2 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
                              M563 P3 H3 F0 ; define tool 1
                              G10 P3 X0 Y0 Z0 ; set tool 1 axis offsets
                              G10 P3 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
                              • mikep91undefined
                                mikep91 @mikep91
                                @mikep91
                                IIT WORKS !!!! XD
                                Almost.......
                                Heater 1 and Heater 3 is mismatched - should i remap these in the software or on the duet?
                                config (2).g
                                I restarted the controller and now I am having no tools: :(........ either on the duet or in the DWC
                                • mikep91undefined
                                  mikep91 @mikep91
                                  @mikep91
                                  I had to map the heater 1 to the bed to get all 3 heaters to work... I am sure there is something wrong with my tools still.
                                  I can only set the temps via DWC - not on the board anymore - how would I go about changing this?
                                  M140 H1 ; disable heated bed (overrides default heater mapping)
                                  ;M308 S0 P"spi.cs1" Y"rtd-max31865" ; configure sensor 0 as PT100 on pin spi.cs1
                                  ;M950 H1 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0
                                  ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                                  ;M143 H1 S280 ; set temperature limit for heater 0 to 120C
                                  M950 H1 C"bedheat" T1 ; create nozzle heater output on e0heat and map it to sensor 0
                                  M950 H2 C"e0heat" T2 ; create nozzle heater output on e1heat and map it to sensor 1
                                  M950 H3 C"e1heat" T3 ; create nozzle heater output on e1heat and map it to sensor 1
                                  M570 H3 P10 T100 ; An anomaly on heater 1 must persist for 10 seconds, and must be greater or less than 100C from the setpoint, to raise a heater fault.
                                  ;M563 P0 D0 H0:1:2:3 F0 ; define tool 0
                                  ;G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets
                                  ;G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
                                  M563 P3 D0 H1 F0 ; define tool 2
                                  G10 P3 X0 Y0 Z0 ; set tool 2 axis offsets
                                  G10 P3 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
                                  M563 P1 H2 F0 ; define tool 1
                                  M563 P2 H3 F0 ; define tool 1
                                    Is the Duet performing extrusion functions, or is that handled externally as well?
                                    It may be a better idea to define the heaters as something else, and not has tools at all.
                                    How closely coupled are the heaters? Does the heat from one affect the others, or are they more distinct zones?
                                    • mikep91undefined
                                      mikep91 @Phaedrux
                                      @Phaedrux
                                      That is handled externally aswell.
                                      The heat from different zones affect eachother.
                                      I will need to define the tools somehow - to be able to turn on the "tools" on the duet display.
                                      This setup works for a 2 heater control board:
                                      M563 P0 D0 H1 F0 ; define tool 2
                                      G10 P0 X0 Y0 Z0 ; set tool 2 axis offsets
                                        Instead of calling them tools maybe define them all as bed or chamber heaters.
                                        Perhaps @deckingman has some recommendations on dealing with multiple heaters on a single multi zone hotend?
                                          deckingman @Phaedrux
                                          @Phaedrux said in Duet 2 Wifi 3 Heater control using bed output + messed up tools:
                                          Saw my name mentioned. I can go through how I set up my 2 heat zone hot end but to save me reading this entire thread, what's the problem or issue that needs to be addressed?
                                          • mikep91undefined
                                            mikep91 @deckingman
                                            @Phaedrux If i define them all as BED i can only turn them all to the same temperature. I need to be able to put my top heater to IE. 190C- middle heater 210C and nozzle heater 230C - as an example.
                                            @deckingman
                                            Hi deckingman - thank you for jumping in.
                                            I am using a duet to control some different hotends. Some with 2 heaters and some with 3 heaters.
                                            I am having the problem that i cannot turn on my tools on my paneldue with my 3 heater system.
                                            I can turn them on in my DWC. But when I'm looking at the display of the 3 heater one: I dont have the option to toggle the tools on/off - I am 99,9% sure my tools is not defined properly....
                                            Not able to turn on tools: (3 heaters)
                                            Able to turn on tools: (2 heaters)
                                            On the one with 3 heaters; i have no option to turn on my tools.
                                            Config of 3 tools: - Only working on WIFI.
                                            Config of 2 tools: Works both on Wifi and on the paneldue:
                                            M143 H2 S280
                                            Hope this makes sense.
                                            Thank you!
