    Duet 3 Scanning Z probe
    88
    6.0k
    • Notepadundefined
      Notepad @fcwilt
      @fcwilt
      Nope, thats on me, My wording skills are pretty poor at times.
      I probe before every print because I want to reduce any risk of an imperfect first level. A failed print because I tried to save 4 minutes in skipping a probe sequence just isn't worth it IMO.
      And when you take a step back and look at the average time to complete a print (say 4 hours) the probing time is literally only 1% of the total time. So I'm happy to do the probing before every print.
      But on the flip side of the coin, from a user experience aspect, the initial wait for 4 minutes just feels sluggishly slow, especially when doing really small prints (say less than 1 hour) the probing time just eats at the mind as I wait for it to complete.
      my feelings are juxtaposed between happy with what I currently have, but also disappointed by the completely acceptable 4 minutes it takes.
      What I am definitely looking forward to is the ability to do increase resolution height maps without any time impact. And after using a beacon probe, it does become a tipping point where once you have experienced those speeds, you never really can look at the slower methods the same.
      Hope that makes more sense.
      • fcwiltundefined
        fcwilt @Notepad
        @Notepad
        Sounds good to me.
        I'm going to get one just to work with it BUT I don't know that I will undertake the work involved to re-design the tool mounts for my five printers (all different) IF a "traditional" Z probe is still required.
        I don't currently use any 1LC boards but if they were updated to include the scanning probe then I would certainly explore a re-design of my tool mounts,
        If I went that way I would, sadly, be forced to upgrade the two of my printers that are using Duet 2 boards. I mean who wants the latest and greatest hardware?
        I'm sure the wife would understand. 😁
        Still thinking on it.
        zaptaundefined 1 Reply Last reply Reply Quote 1
        • zaptaundefined
          zapta @fcwilt
          @fcwilt said in Duet 3 Scanning Z probe:
          Start the conversation with her printer.
            A Former User @droftarts
            This post is deleted!
            • o_lampeundefined o_lampe referenced this topic
              @Herve_Smith I think it's a case of damned if we release early, and equally damned if we wait until we've spent a lot more time characterising the behaviour when the probe used as the sole Z reference.
              We've spent a lot of time testing the scanning function, to the point where we know it works well. So we've released a product that is definitely useful to many owners of existing machines that already have a good way of establishing Z=0, and probably capable of being the sole Z probe in some (but perhaps not all) machines with metallic bed plates.
              We know that inductive sensors are temperature-sensitive, and we know that in some cases at least it is practical to compensate for the change in behaviour with temperature. So we've included a thermistor right on the coil so that we can compensate for changes in coil temperature. This might not even be necessary - it may be that the change in bed resistance with temperature is the primary cause of temperature sensitivity, in which case compensating for bed temperature will be more appropriate. Or it could be that in some machines we will need to compensate for both bed and coil temperature. Currently RRF can only compensate a Z probe for one temperature, but we can extend that if necessary.
              This is a case where community input is so important, because the community has a much wider range of machines than we do. If we were to state that on a particular machine with a particular make of bed plate it is possible to use the scanning probe as the only Z reference, how useful would that really be, given that we can't guarantee that users with other machines and different bed plates will have equally good results?
              Machines vary enormously, and on some of them (e.g. machines with a heated chamber), it may be that sufficiently accurate temperature compensation will never be possible. In these cases, if mesh bed compensation is required then it it still useful to have a fast scanning probe even if a separate contact-based Z=0 reference must be provided.
              fcwiltundefined 1 Reply Last reply Reply Quote 3
              • fcwiltundefined
                fcwilt @dc42
                Thanks for the comprehensive reply.
                Thoughts:
                • could you design a 1LC board with the scanning Z probe? I would be far more inclined to re-design my tool mounts to use a 1LC board like that.
                • you guys are smart - really smart - design a very small "contact Z probe" and sell the whole package 1LC with scanning probe and contact probe. I would definitely go for that.
                  droftarts administrators @fcwilt
                  @fcwilt The new Roto toolboard already has a scanning Z probe on it, and is a bit smaller than a 1LC (more details to come). You may also prefer the connectors on it!
                  • fcwiltundefined
                    fcwilt @droftarts
                    @droftarts
                    Is this an E3D product?
                    If so, what is the timeline?
                    Thanks much.
                      @fcwilt We designed it for E3D, and it fits on their new Revo Roto extruder https://e3d-online.com/pages/revo-roto-landing-page, which is tiny. But it is available separately too. https://www.duet3d.com/Duet3RotoToolboard
                      Revo nozzle, coil for scanning Z probe next to it, and standard connectors for E3D components around the edge of the board. For mounting, it mirrors the two screws that hold the board on the other side of the extruder.
                      • fcwiltundefined
                        fcwilt @droftarts
                        @droftarts
                        Thanks much.
                        I have signed up to get emails.com
                        Notepadundefined 1 Reply Last reply Reply Quote 0
                        • Notepadundefined
                          Notepad @fcwilt
                            deckingman
                            @dc42 @droftarts @T3P3Tony. On the basis that you would like feedback from the wider community, and a range of different machines, if you want to loan me one, I'd be happy to graft it onto my machine and run some tests. It's currently fitted with a Bondtech LGX Ace / Slice engineering Mosquito and I use the nozzle itself as a Z endstop via a hinged mount and two brass plates that form a switch. That arrangement is extremely repeatable and AFAIK, not at all temperature sensitive so would be a good comparison to see if your scanning probe can be used as a Z probe. I can also print edge to edge (400mm X 400mm) without mesh compensation so having a height map might shut down the naysayers who keep telling me that isn't possible (despite multiple videos showing otherwise). Anyway, the offer is on the table.....
                              dc42 administrators @deckingman
                              @deckingman thanks, we would certainly value your input. Do you print direct on a metallic bed? You will need to install the latest 3.5.0-rc1+ firmware; is that OK?
                                deckingman @dc42
                                @dc42 said in Duet 3 Scanning Z probe:
                                Ref the build plate - not at the moment but that will change. I'm currently printing on 6mm thick glass but intend to try some sort of PEI sheet. Glass has worked well for me but I tire of using 3DLac and times move on. As I understand it, your probe will measure the topmost surface of a metallic sheet, so anything on top of that must follow any contours of the underlying metal sheet for the readings to be valid. By "metallic", do you mean ferrous metal or will it work with aluminium? I'm thinking along the lines of sticking PEI directly onto the aluminium plate but no purchase decision has yet been made so I could use steel backed PEI or some such.
                                Ref the firmware, I don't mind trying a release candidate as long as I can revert back to the stable version. I envisage making a new aluminium rear carriage plate which will accommodate the new tool board and probe as a well as a part cooling solution that I'm working on. So by the time I've done all that, the firmware might be stable in any case.
                                dc42undefined jens55undefined 2 Replies Last reply Reply Quote 0
                                  @deckingman the tests we have done have been on flexible magnetic steel plates, but aluminium should work too. As you run your machine in standalone mode you can revert easily to firmware 3.4.6 but of course you will lose the scanning probe functionality (which I know you don't actually need anyway). It would probably be OK to leave DWC at version 3.5.x.
                                  Let us know when you have made a decision on the bed surface.
                                  • jens55undefined
                                    jens55 @deckingman
                                    @deckingman said in Duet 3 Scanning Z probe:
                                    .... and this is exactly why I have issues with this kind of probe. In early days I installed a sheet of PEI on a glass plate for my printing surface and found out that at higher bed temperatures (IIRC at around approx 90C and higher) the glue sheet lets go and the PEI starts to curl up at the edges. In addition to that, getting an approximation of the surface by scanning the metal underneath does not catch PEI surface irregularities or, more importantly, the occasional air bubble between PEI and glass.
                                    I assume, but have not tested, that both of these issues do not apply to PEI that is directly deposited on spring steel.
                                    The other reason I am still printing on glass is cost - a PEI coated spring steel system can be relatively expensive and is subject to nicks, scrapes or damage from a printhead crash. Setting wrong parameters and getting the print stuck too well on the PEI and you can peel the PEI off the steel substrate.
                                    Float glass is cheap and readily available when you start getting divots on it from too strong adhesion.
                                    • R4ffersundefined
                                      R4ffers
                                      @dc42 are there any drawings available please? I'd like to look at making a mount.
                                      Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
                                        deckingman @jens55
                                        @jens55 said in Duet 3 Scanning Z probe:
                                        I tend to agree - but with caveats. I have to say that I have no problems using 6mm float glass and I still have the original 3 sheets that I bought several years ago. I do however use 3DLac so some other form of removable print surface might be useful. As you say, powder coated PEI would be preferable to adhesive sheet. But regardless of that, a scanning probe might be useful for tramming the XY gantry with regard to the bed and also for checking the flatness of the (underlying) plate. Any high spots could be scraped or lapped out. That is the approach that I personally would want to take, rather than using software compensation with the inevitable lead screw wear that would result. But that's just me. I've done these measurements before with a DTi but it's a tedious process. So a scanning probe might still be a useful tool, even if the print surface itself is rigid.
                                          T3P3Tony administrators @R4ffers
                                          @R4ffers https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Scanning_Z_Probe#dimensions
                                          R4ffersundefined 1 Reply Last reply Reply Quote 1
                                          • R4ffersundefined
                                            R4ffers @T3P3Tony
                                            @T3P3Tony thankyou
