    Duet 3 Scanning Z probe
    88
    6.0k
    • R4ffersundefined
      R4ffers
      @dc42 are there any drawings available please? I'd like to look at making a mount.
      Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
        deckingman @jens55
        @jens55 said in Duet 3 Scanning Z probe:
        @deckingman said in Duet 3 Scanning Z probe:
        As I understand it, your probe will measure the topmost surface of a metallic sheet, so anything on top of that must follow any contours of the underlying metal sheet for the readings to be valid.
        .... and this is exactly why I have issues with this kind of probe. In early days I installed a sheet of PEI on a glass plate for my printing surface and found out that at higher bed temperatures (IIRC at around approx 90C and higher) the glue sheet lets go and the PEI starts to curl up at the edges. In addition to that, getting an approximation of the surface by scanning the metal underneath does not catch PEI surface irregularities or, more importantly, the occasional air bubble between PEI and glass.
        I assume, but have not tested, that both of these issues do not apply to PEI that is directly deposited on spring steel.
        The other reason I am still printing on glass is cost - a PEI coated spring steel system can be relatively expensive and is subject to nicks, scrapes or damage from a printhead crash. Setting wrong parameters and getting the print stuck too well on the PEI and you can peel the PEI off the steel substrate.
        Float glass is cheap and readily available when you start getting divots on it from too strong adhesion.
        I tend to agree - but with caveats. I have to say that I have no problems using 6mm float glass and I still have the original 3 sheets that I bought several years ago. I do however use 3DLac so some other form of removable print surface might be useful. As you say, powder coated PEI would be preferable to adhesive sheet. But regardless of that, a scanning probe might be useful for tramming the XY gantry with regard to the bed and also for checking the flatness of the (underlying) plate. Any high spots could be scraped or lapped out. That is the approach that I personally would want to take, rather than using software compensation with the inevitable lead screw wear that would result. But that's just me. I've done these measurements before with a DTi but it's a tedious process. So a scanning probe might still be a useful tool, even if the print surface itself is rigid.
          T3P3Tony administrators @R4ffers
          @R4ffers https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Scanning_Z_Probe#dimensions
          R4ffersundefined 1 Reply Last reply Reply Quote 1
          • R4ffersundefined
            R4ffers @T3P3Tony
            @T3P3Tony thankyou
              @R4ffers the STEP file will go up at some point in the next week or so as well.
              zaptaundefined 1 Reply Last reply Reply Quote 2
              • gtj0undefined
                gtj0
                Hmmm. From the video it looks like the probe has to be mounted "flat" in reference to the bed surface which makes sense but would take up a bit of space. Not that 25mm is a lot but it's "something" . Now if it were a bit bigger, and the center of the coil were open, the hole might be big enough to stick a nozzle through. šŸ™‚
                Also any limits on the length of the flat FFC cable? My tool platform is very light and I'd prefer not to place the control board on it.
                dc42undefined droftartsundefined 2 Replies Last reply Reply Quote 0
                • zaptaundefined
                  zapta @T3P3Tony
                  @T3P3Tony, does the sensor require 'magnetic clearance' around or above it?
                  Also, is it affected if using individual embedded magnets to hold the removeable bed sheet? (vs adhesive magmatic sheet which has a more uniform static magnetic force).
                  Notepadundefined 1 Reply Last reply Reply Quote 0
                  • Notepadundefined
                    Notepad @zapta
                    @zapta said in Duet 3 Scanning Z probe:
                    Yes, I believe so.
                    The real bamboo printer manufacturer
                      dc42 administrators @gtj0
                      @gtj0 you can use different size coils, you just need to adjust the number of turns to get the inductance to be around 16uH. Larger coils can work at greater distances to the bed, while smaller coils provide greater XY resolution.
                      The FFC cable can be longer than the one we supply, as long as it is secured so that its capacitance to ground doesn't change as the head moves. However the board should be mounted on the tool head. It's very light.
                      @zapta we found that when using small coil we were able to detect the magnets under the bed, but not when using the larger coils the we are shipping. Preferably, choose the mesh to avoid the magnets. The sense coil should not be mounted very close to large metal parts on the hot end.
                        droftarts administrators @gtj0
                        @gtj0 On the stand at Formnext we also had a development coil board with a hole through the middle. The idea with that one is that you could mount it on the end of a BLTouch, and the BLTouch could probe through the hole in the centre of the coil. Not sure if it has actually been tested, but could then be packaged with the BLTouch.
                        • R4ffersundefined
                          R4ffers
                          Just thinking out loud here, but what if you had a coil mounted upside down next to the bed. Use that one to scan the nozzle. Mount one on the toolhead for scanning the bed. That way it wouldn't matter if anything was stuck to the nozzle. Would it be accurate enough to set Z height that way?
                            @R4ffers I mentioned this in the blog post AFAIR - potentially useful, especially for multi axis printing where the bed autocalibration solution we have right now in Open5X relies on electrical contact. I have not had a chance to do experimentation yet. I may well require a different coil size and possibly more than one coil.
                            o_lampeundefined jlipavsky79undefined 2 Replies Last reply Reply Quote 1
                            • o_lampeundefined
                              o_lampe @T3P3Tony
                              @T3P3Tony said in Duet 3 Scanning Z probe:
                              I thought the same, because otherwise the adjustment-macro would only know the nozzle is off, but not in which direction.
                              Fullsize metal detectors often have two or three overlapping coils. Wouldn't be a big issue to make a PCB with three layers on one side, I guess.
                              • gtj0undefined
                                gtj0
                                Folks have been talking about magnets but what about a bed heater? I've got a 500x500x6.5mm aluminum bed with a full coverage 1600 watt heater on the bottom and PrintBite on top. As the probe passes over the heater wires, especially if they're energized (not to mention with PWM active), is there going to be an issue? I would think that 6.5mm of aluminum would help to dampen any variance but I'm curious if that was tested.
                                • fcwiltundefined
                                  fcwilt @gtj0
                                  @gtj0
                                  There is an option to turn off bed heaters during probing.
                                  Reference M558 parameter B
                                  Bn If 1, turn off all heaters while probing, default (B0) leaves heaters on.
                                  gtj0undefined 1 Reply Last reply Reply Quote 1
                                  • gtj0undefined
                                    gtj0 @fcwilt
                                    @fcwilt said in Duet 3 Scanning Z probe:
                                    @gtj0
                                    Ah yeah, I forgot about that. I never used it because probing currently takes long enough that, even with all that mass, the bed cools down a bit during the probe with the heater off. Shouldn't be an issue at this speed though, and de-energized, the wires aren't going to make a difference through 6.5mm of aluminum.
                                      @gtj0 as far as I’m aware, the SZP is not affected by bed heaters. I’m pretty sure @dc42 told me that at the show.
                                      • zaptaundefined
                                        zapta
                                        Here is an idea, a Klicky like probe that first picks a switch for a reference Z data and then a coil for fast scanning of the entire bed.
                                        (Don't ask me how to do that).
                                        • o_lampeundefined
                                          o_lampe @zapta
                                          @zapta I guess you could have a combination of switch and analog sensor in one housing. That would eliminate the time for double tool-pickup.
                                          Just have to config the zprobe to be digital for the first probe point, then switch over to the analog sensor.
                                          • zaptaundefined
                                            zapta @o_lampe
                                            @o_lampe, when the switch is pressed, it can change the characteristics of the sensor, e.g. disconnect it. This way there is not need to switch sensors. Just an idea.
