    Issues with pressure advance since RRF 3.4
    308
    37.9k
    • gloomyandyundefined
      gloomyandy @oliof
      @oliof Can't resist taking this thread slightly more off topic! How did you select the Jerk speed for the V-Minion? Did you use any test prints to help? I seem to remember it has a big impact on how curves get printed...
      • Notepadundefined
        Notepad @oliof
        @oliof
        I currently am running a jerk of 1000mm/min with accelerations of 4000 mm/s/s Using a Hemera XS with a volcano style hotend.
        I used to run by the theory of low jerk high acceleration (J of 500mm/min and 7000mm/s/s) but im now just trying everything in order to isolate the issue
        Edit: I should say I am only experiencing this issue on larger nozzles. On a 0.4mm nozzle the issue is imperceptible enough to not be an issue, but on a 0.6mm nozzle the issue is exceptionally bad.
        The real bamboo printer manufacturer
          deckingman
          You apply pressure at one end which forces a viscous fluid out of a restricted orifice. Just like a 3D printer extruder. You'll learn a lot about how the flow of a viscous fluid out of a small orifice reacts (or rather hardly reacts) to changes in pressure on the input and how difficult it is to get that flow rate to match the rate to change of movement of the nozzle through space.
          Personally, I get best results by keeping the filament flow rate as near constant as possible which essentially means low(ish) acceleration and high(ish) jerk and using pretty much the same speed for all move types.
          • oliofundefined
            oliof @gloomyandy
            @gloomyandy re:jerk -- I increased it until I got skipping on the motion system, then backed off by 20%. It seems to be a good approach that gets me into a "usable, not too low" range.
            @deckingman I had issues with too low acceleration causing print head inertia to be a factor on corner performance. So I tend to aim for low-ish jerk and higher acceleration.
              gloomyandy
              @Notepad Are the jerk and acceleration figures you are quoting for the extruder, the movement axis or both?
              @deckingman A similar question really what are the actual jerk/acceleration figures you have settled on both for the various axis and the extruder?
              deckingmanundefined Notepadundefined 3 Replies Last reply Reply Quote 0
                deckingman @gloomyandy
                @gloomyandy I'll get back to you with my actual settings next time I'm at my computer. But given that any print move at any point in time runs at the slowest of XY or E (because they have the synchronised) then extruder jerk will only apply if it's so low that it will slow down X and/or Y. If extruder jerk is not applied to the start of a move, then it won't apply to retractions either, so I can't off hand think of any situation where extruder jerk does apply unless it's so low that it effectively overrides the X or Y axis jerk. For that reason, I set it silly high so that it won't override my X and Y jerk.
                  @gloomyandy With regard to jerk (instantaneous speed change), I look at it like this. If we didn't have it (or it was set to zero) then every move would start at zero speed, accelerate up to the print speed (if the move was long enough) then decelerate to zero speed before commencing the next move. Clearly this would be problematic with short segmented moves such as curves. Therefore it kind of follows that in order to print curves at the same speed as straight lines, the instantaneous speed change should be set to the same as the print speed. So in theory, if we want to print at (say) 60mm/sec, then jerk should be set to 3600 (mm/minute). But in practice, that seems to be too high and also (visually) speed around circular perimeters seems to be the same as the speed on long straight moves with much lower jerk settings. So something is amiss with my logic or the application of jerk. Are we sure that the units for M566 are mm/minute as per the documentation and not mm/sec?
                  gloomyandyundefined 1 Reply Last reply Reply Quote 0
                    gloomyandy @deckingman
                    @deckingman I think there is an error in your logic here. In the case of a curve the two movement vectors are relatively close to each other (they typically will have a shallow angle between them), so the actual delta change in speed of the X and Y component (lets keep things simple and assume easy kinematics), will be much less than jumping to full speed. Your example is true in the case of a 90 degree corner.
                    deckingmanundefined 2 Replies Last reply Reply Quote 0
                      @gloomyandy I'm sure you are right in that the angle between line segments plays a part. The description of M566 states (quote) ....
                      "The model files and GCode files used by repraps generally render circles and other curves shapes as a sequence of straight line segments. If the motors were not allowed any instantaneous speed change, they would have to come to a stop at the junction between each pair of line segments. By allowing a certain amount of instantaneous speed change, printing speed can be maintained when the angle between the two line segments is small enough."
                      So if we knew how the algorithm worked, then maybe we can determine that the optimum jerk value would be the lowest value which maintains the print speed around a segmented curve? The question is, how many segments or more precisely the angle between them. Thoughts?
                        @gloomyandy So by way of a bit of additional data, I've just run a couple of simple prints. On the basis that I wanted a large angle between segments but not 90 degrees, I made a 200mm diameter, 5 sided hollow "cylinder" with 3mm thick walls. Sliced at 80mm/sec with 3 perimeters (inside and out) that gives 6 perimeter lines using a 0.5m nozzle with no other infill. Then I printed it and played around with M566 on the fly. My default is 1500 for X and Y and that's what I started with. Going higher leads to an audible "clunk" on direction change. This could be more problematic for less robust printer designs. Going lower does have an impact on speed but it's subtle. DWC doesn't update all that fast but I could detect the odd value for top speed which was lower than 80. No such low values could be detected at 1500 Jerk and above.
                        So maybe that's one strategy for setting jerk. Print a large 5 sided hollow "cylinder" and increase jerk until the machine "clunks", then back off a bit.
                        As promised, these are the values that work best for me on my machine/
                        M566 X1500 Y1500 Z300 E3600
                        M201 X1000 Y1000 Z300 E6000
                        M203 X21000 Y21000 Z780 E9000
                        gloomyandyundefined edspedundefined 2 Replies Last reply Reply Quote 3
                          @deckingman Interesting! Was the clunk during the printing of the "curve" (rather than at one end)? How much lower did you need to go before you saw a noticeable drop in speed?
                          From my (rather vague) recollection of school geometry the length of the "sides" does not impact the angle but the number of "sides" does. With 5 sides the angle will be 72degrees with 10 "sides" it would be 36degrees. I'd expect you to be able to use a lower jerk for similar results with a 10 sided object.
                          If the jerk setting is too low such that the target speed can't be maintained then the length of the sides will start to have an impact as that will (eventually) determine the maximum speed that can be reached between each "corner".
                          I wonder if a test print which had a large number of "sides" at the base and reduced that number as the height increased would provide a useful insight into how this works on a particular printer?
                          Maybe we should start a new thread to continue this discussion?
                          • edspedundefined
                            edsped @deckingman
                            @deckingman So if I'm looking at this correctly your settings are counter to the high accel low jerk recommendations for proper PA input shaping given elsewhere? I thought, for the CoreXY at least Jerk should have been somewhere around 300 mm/min.
                            Notepadundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                            • Notepadundefined
                              Notepad @gloomyandy
                              @gloomyandy said in Issues with pressure advance since RRF 3.4:
                              Those were in relation to extruder jerk and accel settings.
                              For printing I generally use the following: 130d1621-9f27-489a-9100-f11d98466d4a-image.png
                              For the actual requested print speeds, the issue is identical if asking for 40mm/s or 300mm/s. As for the printers Jerk and Accel values, these were determined by vibrational analysis and reinforced with real world ABX testing on a unified test print - so I am confident in saying the printer is behaving as intended, isolating the problem to either the extruder, the extrusion control algorithm, or the nozzle flow in general.
                              I should say, this isnt isolated to one machine, I currently have 5 similar machines behaving the same, and it only becomes apparent on the 0.6mm nozzles and above.
                              edspedundefined oliofundefined 2 Replies Last reply Reply Quote 0
                              • Notepadundefined
                                Notepad @edsped
                                @edsped Jerk depends on the printers rigidity, If your printer can do X jerk without it inducing vibrations or warp, then you need to go up to that value but no further.
                                I have identified a weird behaviour with RRF and low jerk, but I believe this will be resolved once IS is done on small line segments.
                                  No the "clunk" was at the intersection of the two segments. i.e. where the direction changed. I didn't actually notice any adverse effects on the print quality but clearly a near instantaneous change of direction for a moving mass is going to sound "clunky". Bear in mind that a 200mm dia pentagon has longish sides (so big segments) and also my "all metal" gantry is on the heavy side. I did go silly high (up to 6000 jerk) and while the "clunk" was more audibly pronounced, I couldn't really detect any difference in overall speed.
                                  Well you have to look hard to notice the drop in speed but basically anything less than 1500 jerk did have an effect. 1500 mm/jerk is 25 mm/sec and I was printing at 80mm sec. In theory one would expect the move to decelerate to the jerk speed, then change direction but that's clearly not what happens - even with a biggish change in direction of 72 degrees.
                                  I tried 5, 6 8 and 12 sided "cylinders". I can't say that I could detect any difference and there was still a very slight drop in overall speed with a 12 sided "cylinder" and with jerk values lower than 1500 (which is surprising).
                                  I'd have thought that acceleration would have a much bigger impact on attaining target speed.
                                  I use OpenScad so to do a 5 sided "cylinder", I used $fn =5 which sets the number of segments. But there is another variable that I've never played with which is $fs. That sets the segment size. So if made a cone with fixed $fs insteda of $fn, then in theory it should have a large number of segments at the base reducing as the height increases. I might give that a go some time.
                                  We do seem to have hijacked this thread.
                                    deckingman @edsped
                                    @edsped said in Issues with pressure advance since RRF 3.4:
                                    Dunno. I don't get ringing so I don't really have a need to use input shaping. Maybe it's my approach of trying to maintain as near constant speed as possible or maybe it's just having a very rigid but somewhat heavy hot end assembly. I did have a play around with the accelerometer built into my tool board but the graphs don't give me any defined frequency peak that I could use as a centre frequency. Such peaks as there are seem to be at around 30, 50 and 90 Hz but they are low in amplitude and difficult to discern.
                                      @gloomyandy So here is a bit more data. If in doubt - do the maths I always say. Starting with the formula v=u+at where v=initial velocity, u= final velocity, a=acceleration and t=time, we can rearrange that to give t=(v-u)/a. So with the print above at 80mm/sec, if it did indeed decelerate at 1000mm/sec^2 from 80mm/sec to the jerk speed of 25 (1500mm/minute) then the time it takes would be 0.055 seconds for that phase. Then we have the change of direction followed by an acceleration at the same rate from 25 to 80 mm/sec. So the total deceleration/acceleration phase takes (0.55 x 2 = ) 0.11 seconds. That would explain why it's difficult to detect and change in overall speed. We can also calculate the distance travelled which worked out at 2.8875 mm - again difficult to spot by eye.
                                      Now it gets interesting. If we change the final velocity to zero (i.e. no jerk) then the time it takes decelerate from 80mm/sec to zero speed at 1000mm/sec^2 is 0.08 seconds (as opposed to 0.055 with 1500 mm/minute jerk) so 0.16 seconds for both the accel and decel phases.
                                      So the impact on print speed will only be apparent where there are a large number of segments. If we assume our cylinder had 360 segments (one per degree) and also assuming that each segment is long enough to reach the desired speed, then the time "lost" decelerating and accelerating would be (360 * 0.16 = ) 57.6 seconds. Whereas with jerk set to 1500 (25mm/sec) then the time "lost" becomes (360 * 0.11 = ) 39.6 seconds. As an aside, it has been mentioned that jerk should be set to circa 300 which would be 5mm/sec giving the "time lost" as 54 seconds which isn't much different to having no jerk at all.
                                      Now, there are other factors at play because I mentioned that the distance travelled was 2.8875 mm to go from 80mm/sec to 25mm/sec at 1000mm/sec^2. With my 200mm diameter cylinder, 360 segments would each have a length of 1.745mm so they would be too short and 80mm/sec wouldn't be achieved. We'd need to drop the number of segments to around 110. So using the above calculations but with 110 segments, the "time lost" would be 12.1 seconds with jerk at 1500 (25mm/sec) and 17.6 seconds with zero jerk.
                                      Finally, the circumference of a circle 200mm in diameter is circa 628mm. Printing 628 mm at 80mm/sec should take 7.855 seconds if it was a pure X or Y move. If we add the "time lost", we get 19.9 seconds with 1500 jerk or 25.5 with zero jerk so roughly 28% faster for one circumference but it's very much acceleration dependent.
                                      I guess it's fair to say therefore that the higher the acceleration, the less need for jerk (because the "time lost" due to acceleration/deceleration will be less). Or rather the "time lost" could be the same with high acceleration/low jerk or low acceleration/high jerk. Of course, "time lost" isn't by any means the only factor that determines print quality but if you want to run near constant speed then low acceleration/high jerk is the way to go (in my humble opinion).
                                      Now I'll sit back and wait for the pedants to find the flaws in my maths or reasoning (of which there could be many)........
                                      • edspedundefined
                                        edsped @Notepad
                                        @Notepad I'll have to dig but my recollections is as low a jerk for X & Y as possible for IS to work properly. That number being somewhere in the neighborhood of 5 - 6 mm/s. I'm trying to follow my academic training and always use units to keep things clear. This was recently posted so I should be able to find a link to the thread when I'm home.
                                          @deckingman
                                          Let me have a go at explaining what I understand about how jerk is applied in RRF....
                                          First consider a set of moves
                                          G1 X10
                                          G1 X20
                                          G1 X30
                                          Let's assume the feedrate, and acceleration are such that the length of each move is enough for the target speed to be easily reached. So the simple case would give us three moves each of which accelerates(a), then cruises(c) at the target speed then decelerates(d) back to zero. so we would have
                                          a/c/d a/c/d a/c/d
                                          However RRF would like to make the overall motion as smooth and fast as it possibly can. This is pretty easy in this case as we can in effect cancel out some of the acceleration and deceleration phases and extend the cruise phases so then we get:
                                          a/c c c/d
                                          Which is a much smoother overall move. So far so good!
                                          We now need to look at what actually happens in a move like those above, let's assume we have a simple Cartesian motion system. With that system the above set of moves would have the X motor operating at the feedrate and the Y motor not moving. So 100% of the move speed is allocated to X and 0% to Y.
                                          Now suppose that instead of a set of simple moves along the same axis we are creating a shallow "curve" from a series of straight lines. The curve is such that the first move is 100% X 0% Y, the second move is 90% X and 10% Y (we will ignore later moves to keep things simple). Can we still smooth these moves out in some way? This is when jerk comes into the picture. Let's assume the feedrate is 100mm/s and that the jerk limit is set at 20mm/s (for both X and Y). So what we are saying is that the system is such that we can have an instantaneous change in speed so long as the change is less than the jerk limit. In this example at the join between the first move and the second the change in speed for X is -10mm/s ( a 10% reduction of speed from 100mm/s), for Y we have a +10mm/s change in speed (as it needs to go from 0mm/s to 10% of 100mm/s). In both cases these changes are below the jerk limit of 20mm/s so we can still merge them and maintain "smooth" motion (though the motors will see a jump in speed).
                                          If we have a sharper join between two of the moves such that the first move speed was 100% X and 0% Y but this time the second was 70% X and 30% Y then things become more interesting. Now we have a decrease in speed for X of -30mm/s and an increase in speed of Y of +30mm/s in both cases this exceeds our jerk limit, we need to adjust the speed at the join so we reduce our target velocity for the end of the first move to be 66.67mm/s (instead of 100mm/s). Now the jerk is 0.3*66.67 = 20mm/s so within our jerk limits. However because we have had to reduce the speed at the join we now need to have a deceleration section to the first part of the move and an acceleration to the second part of the move so our motion is no longer smooth.
                                          The above is a big simplification of what actually happens (in particular I've played very fast and loose with the % speed model, in reality this is a direction vector that is normalised) but I think it captures the basic mechanism. The key function in applying jerk is matchSpeeds see here: https://github.com/Duet3D/RepRapFirmware/blob/3.5-dev/src/Movement/DDA.cpp#L1249
                                          From the above I hope we can see that having low jerk and high acceleration will mean that there is less chance to smoothly join consecutive moves, instead you get a series of (in this case) fast decelerations and accelerations which is likely to make the motion noisy and induce vibration.
                                          What I'm not sure about is the impact of high jerk on things like IS, PA and retraction.
                                          SJIundefined deckingmanundefined 2 Replies Last reply Reply Quote 2
                                          • SJIundefined
                                            SJI @gloomyandy
                                            @gloomyandy
                                            Well written mate
