    1LC TOOLBOARD v1.1. Accelerometer fail
    accelerometer filament sensor toolboard
    • Isaac Lópezundefined
      Isaac López
      I have a 1LC toolboard v1.1 with firmware 3.5.0-RC.1 connected to a DUET3 MB6HC.
      The input shaping addon show this error when trying to record a motion profile. "Error: Failed to start accelerometer data collection: INT1 error"
      I read this happens beacuse this revision of the board have a missing diode. Its posible to solder this diode and what reference is needed?
      I have another error with my filament switch sensor connected to the board, when i try to activate it the board resets all the time. Is it possible that this error also has some relationship with the diode? This is the command i use to activate the sensor: M591 D0 P1 C"121.io1.in" S1
      • chrishammundefined
        chrishamm administrators @Isaac López
        @Isaac-López Please share your full config.g here.
        Duet software engineer
        Isaac Lópezundefined 1 Reply Last reply Reply Quote 0
          Isaac López
          This is my config.g.
          The error message when the firmware resets because the filament sensor configuration is "DCS has been stoped"
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 05 2020 18:14:45 GMT+0200 (hora de verano de Europa central)
          M80 C"pson"											  ; Turns on the ATX power supply
          G90                                                   ; send absolute coordinates...
          M83                                                   ; ...but relative extruder moves
          M550 P"Duet 3"                                        ; set printer name
          M669 K1                                               ; select CoreXY mode
          G4 S1   											  ; wait for expansion boards to start
          M955 P121.0 I10                                       ; Configure Accelerometer
          M569 P0.0 S1                                          ; physical drive 0.0 goes forwards
          M569 P0.1 S1                                          ; physical drive 0.1 goes forwards
          M569 P0.2 S0                                          ; physical drive 0.2 goes forwards
          M569 P0.3 S1                                          ; physical drive 0.3 goes forwards
          M569 P0.4 S0										  ; physical drive 0.4 goes forwards
          M569 P121.0 S0								          ; physical drive 121.0 goes forwards
          M584 X0.1 Y0.0 Z0.2:0.4 E121.0                        ; set drive mapping
          M671 X-63:368 Y0:0 S5 			  	   	              ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
          M350 X16 Y16 Z16 E16 I1                               ; configure microstepping with interpolation
          M92 X100.00 Y100.00 Z400.00 E655                      ; set steps per mm
          M566 X500.00 Y500.00 Z24.00 E600.00                   ; set maximum instantaneous speed changes (mm/min)
          M203 X25000.00 Y25000.00 Z1200.00 E7200.00            ; set maximum speeds (mm/min)
          M201 X20000.00 Y20000.00 Z300.00 E800.00              ; set maximum accelerations (mm/s^2)
          M204 P8000 T14000									  ; set printing and travel accelerations
          M906 X1200 Y1200 Z1200 I30                            ; set XYZ motor currents (mA) and motor idle factor in per cent
          M906 E1200 I10                                        ; set Extruder motor currents (mA) and motor idle factor in per cent
          M84 S30                                               ; Set idle timeout
          ; Pressure advance
          M572 D0 S0.035   									  ; Pressure advance
          ; Linear Compensation
          ;M592 D0 A0.015 B0.0012 L0.2				          ;
          ; Dynamic Acceleration Adjustment
          M593 P"zvd" F25
          M208 X-9 Y0 Z0 S1                                     ; set axis minima
          M208 X320 Y310 Z350 S0                                ; set axis maxima
          M574 X1 S1 P"121.io2.in"                              ; configure active-high endstop for high end on X via pin io3.in
          M574 Y2 S1 P"io2.in"                                  ; configure active-high endstop for high end on Y via pin io2.in
          M574 Z1 S2                                            ; configure Z-probe endstop for low end on Z
          ;Sensorless homing config
          ;M915 X  S3 R0 F0
          M950 S0 C"121.io0.out"                                    ; create servo pin 0 for BLTouch
          M558 P9 C"121.io0.in" H3 F300 T20000                      ; set Z probe type to bltouch and the dive height + speeds
          G31  P25 X-25 Y-15 Z1.6                                   ; set Z probe trigger value, offset and trigger height (+valor +bajo)
          M557 X30:270 Y30:270 P6:6                                 ; define mesh grid
          M308 S0 P"temp0" Y"thermistor" T100000 B3950              ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out0" T0                                        ; create bed heater output on out0 and map it to sensor 0
          M307 H0 B0 S1.00 A140.1 C400.1 D6.8 V24.2                 ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                                   ; map heated bed to heater 0
          M143 H0 S130                                              ; set temperature limit for heater 0 to 130C
          M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
          M950 H1 C"121.out0" T1                                    ; create nozzle heater output on out1 and map it to sensor 1
          M307 H1 B0 R2.434 C196.7:173.0 D4.89 S1.00 V25.2          ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S280                                              ; set temperature limit for heater 0 to 280C
          M950 F0 C"121.out1" Q500                                  ; create fan 0 on pin out7 and set its frequency
          M106 C"Layer" P0 S0 H-1                                   ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"121.out2" Q500                                  ; create fan 1 on pin out8 and set its frequency
          M106 P1 S1 H1 T55                                         ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"out9" Q500                                      ; create fan 2 on pin out6 and set its frequency
          M106 C"Filtro" P2 S0 H-1                                  ; set fan 2 value. Thermostatic control is turned off
          M563 P0 S"EVA2" D0 H1 F0                    	          ; define tool 0
          G10 P0 X0 Y0 Z0                                           ; set tool 0 axis offsets
          G10 P0 R0 S0                                              ; set initial tool 0 active and standby temperatures to 0C
          ;Filament Sensor
          M564 H0         									      ;Allow Moving Axes Without Homing
          M575 P1 S1 B57600                                         ; enable support for PanelDue
          M575 P2 S1 B57600                                         ; enable support for Neopixels
          M911 S20 R21 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"        ; set voltage thresholds and actions to run on power
          T0													      ; select first tool
            Isaac López @chrishamm
            @chrishamm The filament monitor is working fine with the new firmware 3.5.RC2, but the accelerometer continue showing the same error. My config.g is posted above.
              droftarts administrators @Isaac López
              @Isaac-López
              The boards were modified during production by
              • the INT output of the accelerometer is no longer connected to PA19 of the microcontroller;
              • INT is instead connected through a silicon diode to PA00.
              To do this yourself, you need a 1N4148W (SOD123 package) diode. Then, on the toolboard:
              • Cut the trace between the PA19_sel pads
              • Solder the diode between PA19_sel pad and the PA0 pad.
              • The end with the stripe goes to the PA19 pad.
              A couple of pictures:
              (source: https://forum.duet3d.com/post/232831)
              (source: 'Revision v1.1' tab here https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Toolboard_1LC#dimensions)
                Isaac López @droftarts
                @droftarts said in 1LC TOOLBOARD v1.1. Accelerometer fail:
                1N4148W
                Thanks for the information, I will buy the diode and solder it, I hope this will solve the problem.
