Duet 2Wifi Board: 3 Z-Axis configuration create problem
939
    R006
    We are using duet2 wifi board and we add 3 motor for Z-axis as per image
    Problem: When we move Z axis motor, Automatically Y Axis motor rotate slightly due to noise on the channel
    We have configured Z axis motor in different combination as listed below
    1. We have add z axis motor on 50 pin expansion connector
      E_5 for Z1
      E_6 for Z2
      E_7 for Z3
    Observation: Same as above, When we move Z axis motor, Automatically Y Axis motor rotate slightly due to noise as observed on DSO also.
    1. We moved z axis motor on 50 pin expansion connector
      On board Z driver for Z1
      E_5 for Z2
      E_6 for Z3
    Observation: Same as above, When we move Z axis motor, Automatically Y Axis motor rotate slightly due to noise . (Single pulse/spike signal causes the Y motor to rotate).
    1. We also tried with Z axis 3 motor connected to Z , Y and X axis on board connection
      Z axis - Z1
      Y axis - Z2
      X axis - Z3
      E_5 for X axis
      E_6 for Y axis
    In this case , When we move Z axis motor, There is no noise in any motor.
    But In this case X and Y axis didn't move at all and we didn't find any signal at step or dir pin with respect to GND.
    When we run Z homing There is no noise in Y axis.
    But When we use move command we observe noise in Y Axis motor.
    1. We also tried to change to a different duet 2 wifi board, the result is same.
    @dc42 ,@Phaedrux
    Please give us some solution for above problem. Is it a problem with the board?
    And why do the XY motors don't run with E_5 & E_6 channels while Z does?
      Are your motor wires running alongside each other?
      What are the motor models?
      undefined 1 Reply Last reply 20 Feb 2024, 05:51 Reply Quote 0
        R006 @Phaedrux
        @Phaedrux
        Here is your answer inline,
        Are your motor wires running alongside each other? - NO
        We have used shielded wire and it's separate from each other.
        Motor model : Motion king stepper motor 17H2A9425 2.5 Amp 1.8 degree
          Please share your config.g and homing files as well as the output of sending M122 and M98 P"config.g" in the gcode console.
          Can you provide a photo of your wiring setup?
          undefined undefined 2 Replies Last reply 20 Feb 2024, 06:08 Reply Quote 0
            R006 @Phaedrux
            @Phaedrux
            Actually we have set table top setup for testing purpose.
            We have connect motor to board and display only.
            and still we get noise in Y axis motor.
            config
            M569 P0 S1
            M569 P1 S1
            M569 P2 S1
            M569 P3 S1
            M569 P4 S1
            M569 P5 S1
            M584 X0 Y1 Z2:3:4 E5
            M350 X16 Y16 I0
            M350 Z16 E16 I1
            M92 X80.00 Y80.00 Z2133.33 E932.00
            M566 X600.00 Y600.00 Z300.00 E600.00
            M203 X8400.00 Y8400.00 Z1800.00 E6000.00
            M201 X2500.00 Y2500.00 Z30.00 E250.00
            M906 X2000 Y2000 Z1800 E800 I30
            M84 S30
            M574 X1 S1 P"xstop"
            M574 Y1 S1 P"ystop"
            M574 Z1 S1 P"zstop+e0_stop+e1_stop"
            ; Bed Heater
            M308 S0 P"bedtemp" Y"thermistor" T100000 B4138
            M950 H0 C"bedheat" T0
            M307 H0 B0 S1.00
            M140 H0
            M143 H0 S105
            ; Extuder Heater
            M308 S1 P"e0temp" Y"pt1000"
            M950 H1 C"e0heat" T1
            M307 H1 B0 S1.00
            M143 H1 S320
            homeall
            G91
            G1 H2 Z5 F6000
            G1 H1 X-305 Y-305 F1800
            G1 H2 X5 Y5 F6000
            G1 H1 X-305 Y-305 F600
            G1 H1 Z305 F500
            G1 H2 Z-5 F500
            G1 H1 Z305 F500
            G90
            G92 Z300
            homex
            G91 ; relative positioning
            G1 H1 X-305 F1800 ; move quickly to X axis endstop and stop there (first pass)
            G1 H2 X5 F6000 ; go back a few mm
            G1 H1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
            G1 H2 Z-5 F6000 ; lower Z again
            G90
            homey
            G1 H1 Y-305 F1800 ; move quickly to Y axis endstop and stop there (first pass)
            G1 H2 Y5 F6000 ; go back a few mm
            G1 H1 Y-305 F360 ; move slowly to Y axis endstop once more (second pass)
            G90
            homez
            G1 H2 Z5 F500 ; lift Z relative to current position
            G1 H1 Z305 F500 ; move Z up until the endstop is triggered
            G1 H2 Z-5 F500
            G1 H1 Z305 F500
            G90
            G92 Z305 ; set Z position to axis maximum (you may want to adjust this)
            undefined 1 Reply Last reply 20 Feb 2024, 17:06 Reply Quote 0
              Phaedrux Moderator @Phaedrux
              @Phaedrux said in Duet 2Wifi Board: 3 Z-Axis configuration create problem:
              undefined 1 Reply Last reply 21 Feb 2024, 05:16 Reply Quote 0
                T3P3Tony administrators @R006
                @R006 are you using a Duex5?
                undefined 1 Reply Last reply 21 Feb 2024, 04:26 Reply Quote 0
                  R006 @T3P3Tony
                  @T3P3Tony no
                  undefined 1 Reply Last reply 21 Feb 2024, 06:53 Reply Quote 0
                    R006 @Phaedrux
                    @Phaedrux
                    M112
                    2024-02-21 10:04:42 [debug] RepRapFirmware for Duet 2 WiFi/Ethernet MOD. By STPL version 3.4.0beta3 (2023-08-17 14:30:25) running on Duet WiFi 1.02 or later
                    2024-02-21 10:04:42 [debug] Board ID: 08DLM-996RU-N8PS0-6J9F8-3SN6M-KVVMR
                    2024-02-21 10:04:42 [debug] Used output buffers: 3 of 24 (24 max)
                    2024-02-21 10:04:42 [debug] === RTOS ===
                    2024-02-21 10:04:42 [debug] Static ram: 23940
                    2024-02-21 10:04:42 [debug] Dynamic ram: 75676 of which 0 recycled
                    2024-02-21 10:04:42 [debug] Never used RAM 9248, free system stack 100 words
                    2024-02-21 10:04:42 [debug] Tasks:
                    2024-02-21 10:04:42 [debug] NETWORK(ready,14.0%,199)
                    2024-02-21 10:04:42 [debug] HEAT(notifyWait,0.0%,140)
                    2024-02-21 10:04:42 [debug] Move(notifyWait,1.0%,297)
                    2024-02-21 10:04:42 [debug] MAIN(running,84.9%,317)
                    2024-02-21 10:04:42 [debug] IDLE(ready,0.0%,29)
                    2024-02-21 10:04:42 [debug] , total 100.0%
                    Owned mutexes:
                    2024-02-21 10:04:42 [debug] Aux(MAIN)
                    2024-02-21 10:04:42 [debug] === Platform ===
                    2024-02-21 10:04:42 [debug] Last reset 22:16:10 ago, cause: power up
                    2024-02-21 10:04:42 [debug] Last software reset time unknown, reason: User, GCodes spinning, available RAM 11928, slot 1
                    2024-02-21 10:04:42 [debug] Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                    2024-02-21 10:04:42 [debug] Error status: 0x0c
                    2024-02-21 10:04:42 [debug] Aux0 errors 0,0,0
                    2024-02-21 10:04:42 [debug] Step timer max interval 0
                    2024-02-21 10:04:42 [debug] MCU temperature: min 30.0, current 30.3, max 30.7
                    2024-02-21 10:04:42 [debug] Supply voltage: min 23.8, current 24.3, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                    2024-02-21 10:04:42 [debug] Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/14/0, gc cycles 0
                    2024-02-21 10:04:42 [debug] Driver 0: position 42246, ok, SG min/max not available
                    2024-02-21 10:04:42 [debug] Driver 1: position 38649, ok, SG min/max not available
                    2024-02-21 10:04:42 [debug] Driver 2: position 14123, standstill, SG min/max not available
                    2024-02-21 10:04:42 [debug] Driver 3: position 0, standstill, SG min/max not available
                    2024-02-21 10:04:42 [debug] Driver 4: position 0, standstill, SG min/max not available
                    2024-02-21 10:04:42 [debug] Driver 5: position 0
                    2024-02-21 10:04:42 [debug] Driver 6: position 0
                    2024-02-21 10:04:42 [debug] Driver 7: position 0
                    2024-02-21 10:04:42 [debug] Driver 8: position 0
                    2024-02-21 10:04:42 [debug] Driver 9: position 0
                    2024-02-21 10:04:42 [debug] Driver 10: position 0
                    2024-02-21 10:04:42 [debug] Driver 11: position 0
                    2024-02-21 10:04:42 [debug] Date/time:
                    2024-02-21 10:04:42 [debug] 2024-02-21 10:04:42
                    2024-02-21 10:04:42 [debug] Cache data hit count 4294967295
                    2024-02-21 10:04:42 [debug] Slowest loop: 8.19ms; fastest: 0.18ms
                    2024-02-21 10:04:42 [debug] I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0
                    2024-02-21 10:04:42 [debug] === Storage ===
                    Free file entries: 8
                    2024-02-21 10:04:42 [debug] SD card 0 detected, interface speed: 20.0MBytes/sec
                    2024-02-21 10:04:42 [debug] SD card longest read time 2.0ms, write time 1.0ms, max retries 0
                    2024-02-21 10:04:42 [debug] === Move ===
                    DMs created 83, segments created 15, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                    2024-02-21 10:04:42 [debug] === MainDDARing ===
                    Scheduled moves 14329, completed moves 14324, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                    2024-02-21 10:04:42 [debug] === AuxDDARing ===
                    2024-02-21 10:04:42 [debug] === Heat ===
                    Bed heaters =
                    2024-02-21 10:04:42 [debug] 0
                    2024-02-21 10:04:42 [debug] -1
                    2024-02-21 10:04:42 [debug] , chamberHeaters =
                    2024-02-21 10:04:42 [debug] Heater 0 is on, I-accum = 0.2
                    2024-02-21 10:04:42 [debug] Heater 1 is on, I-accum = 0.4
                    2024-02-21 10:04:42 [debug] === GCodes ===
                    2024-02-21 10:04:42 [debug] Segments left: 1
                    2024-02-21 10:04:42 [debug] Movement lock held by null
                    2024-02-21 10:04:42 [debug] HTTP is idle in state(s) 0
                    2024-02-21 10:04:42 [debug] Telnet is idle in state(s) 0
                    2024-02-21 10:04:42 [debug] File is doing "G1 X264.039 Y247.89 E1.1394" in state(s) 0
                    2024-02-21 10:04:42 [debug] USB is idle in state(s) 0
                    2024-02-21 10:04:42 [debug] Aux is ready with "M122" in state(s) 0
                    2024-02-21 10:04:42 [debug] Trigger is idle in state(s) 0
                    2024-02-21 10:04:42 [debug] Queue is idle in state(s) 0
                    2024-02-21 10:04:42 [debug] LCD is idle in state(s) 0
                    2024-02-21 10:04:42 [debug] Daemon is idle in state(s) 0
                    2024-02-21 10:04:42 [debug] Autopause is idle in state(s) 0
                    2024-02-21 10:04:42 [debug] Code queue is empty
                    2024-02-21 10:04:42 [debug] === Filament sensors ===
                    2024-02-21 10:04:42 [debug] Extruder 0 sensor: ok
                    2024-02-21 10:04:42 [debug] === Network ===
                    2024-02-21 10:04:42 [debug] Slowest loop: 201.09ms; fastest: 0.07ms
                    2024-02-21 10:04:42 [debug] Responder states:
                    2024-02-21 10:04:42 [debug] HTTP(0)
                    2024-02-21 10:04:42 [debug] FTP(0)
                    2024-02-21 10:04:42 [debug] Telnet(0), 0 sessions
                    2024-02-21 10:04:42 [debug] HTTP sessions: 1 of 8
                    2024-02-21 10:04:42 [debug] - WiFi -
                    Network state is active
                    2024-02-21 10:04:42 [debug] WiFi module is connected to access point
                    2024-02-21 10:04:42 [debug] Failed messages: pending 0, notready 0, noresp 1
                    2024-02-21 10:04:42 [debug] WiFi firmware version 1.27
                    2024-02-21 10:04:42 [debug] WiFi MAC address 48:3f:da:a6:ee:20
                    2024-02-21 10:04:42 [debug] WiFi Vcc 3.42, reset reason Power up
                    2024-02-21 10:04:42 [debug] WiFi flash size 2097152, free heap 26032
                    2024-02-21 10:04:42 [debug] WiFi IP address 192.168.0.101
                    2024-02-21 10:04:42 [debug] WiFi signal strength -69dBm, mode 802.11n, reconnections 0, sleep mode modem
                    2024-02-21 10:04:42 [debug] Clock register 00002002
                    2024-02-21 10:04:42 [debug] Socket states:
                    M98 P"config.g"
                    2024-02-21 10:07:14 [debug] WiFi module stopped
                    2024-02-21 10:07:14 [debug] HTTP is enabled on port 80
                    2024-02-21 10:07:14 [debug] FTP is disabled
                    2024-02-21 10:07:14 [debug] TELNET is disabled
                    2024-02-21 10:08:13 [debug] Done printing file
                    2024-02-21 10:08:13 [warn] Cancelled printing file 1:/gcodes/new/20-2/300_50 cube_acc500_j5_ps_100.gcode, print time was 7h 47m
                    2024-02-21 10:08:13 [warn] Error: G0/G1: insufficient axes homed
                    2024-02-21 10:08:13 [info] G10 P0 X0 Y0 Z0
                    2024-02-21 10:08:13 [info] G10 P0 R0 S0
                    2024-02-21 10:08:13 [warn] Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 767C
                    2024-02-21 10:08:13 [info] G10 L2 P1 X0.00 Y0.00 Z0.00
                    2024-02-21 10:08:13 [info] G10 L2 P2 X0.00 Y0.00 Z0.00
                    2024-02-21 10:08:13 [info] G10 L2 P3 X0.00 Y0.00 Z0.00
                    2024-02-21 10:08:13 [info] G10 L2 P4 X0.00 Y0.00 Z0.00
                    2024-02-21 10:08:13 [info] G10 L2 P5 X0.00 Y0.00 Z0.00
                    2024-02-21 10:08:13 [info] G10 L2 P6 X0.00 Y0.00 Z0.00
                    2024-02-21 10:08:13 [info] G10 L2 P7 X0.00 Y0.00 Z0.00
                    2024-02-21 10:08:13 [info] G10 L2 P8 X0.00 Y0.00 Z0.00
                    2024-02-21 10:08:13 [info] G10 L2 P9 X0.00 Y0.00 Z0.00
                    2024-02-21 10:08:13 [info] Event logging stopped
                    2024-02-21 10:08:13 [info] Event logging started at level debug
                    2024-02-21 10:08:13 [info] Running: Duet WiFi 1.02 or later: 3.4.0beta3 (2023-08-17 14:30:24)
                    2024-02-21 10:08:13 [debug] STPL-INFD300 - Print your imagination!
                      @R006 so what external drivers are you using on the expansion header for the motors you are connecting there.
                      Also a note you are using custom RRF, have you tested with stock RRF?
                      undefined 2 Replies Last reply 21 Feb 2024, 07:06 Reply Quote 0
                        R006 @T3P3Tony
                        @T3P3Tony
                        external driver: Motion king stepper motor drive model no. 2L415B
                        yes we have tested with stock RRF.
                        undefined 1 Reply Last reply 21 Feb 2024, 08:02 Reply Quote 0
                          droftarts administrators @R006
                          @R006 is it a genuine Duet3D board? Which version of RRF did you test with? Try 3.4.6 https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.6
                          undefined 1 Reply Last reply 21 Feb 2024, 09:49 Reply Quote 0
                            R006 @droftarts
                            @droftarts
                            yes it is.
                            i tried with 3.4.4 & 3.4.6 RRF version standard RRF.
                            I even tried to configure 2 motor in Z with same configuration, but again on Z movement, Y axis gets some random pulse.
                            Tried with 3 different duet 2 WIFI boards and observed this problem repeatedly, when the Z travel more then 5-10 mm then Y motor rotates intermittently, due to some random pulse signals on it,
                            Could you please try at your end, by configuring 3 different Z motors, oneY and one X, run 4 stepper motors with just the board? (temporarily just mark Z0, Y0 X0 using G92 & move Z axis by 5mm, then Y axis gets some pulse? IF you hold the motor shaft, you might feel it. You can also monitor the Y axis pins on DSO to see this.
                            NOTE: External driver was only used for Extruder. I was using onboard drivers for axes.
                              R006 @T3P3Tony
                              @T3P3Tony @Phaedrux @dc42
                              I am waiting for your response.
                              gloomyandyundefined 1 Reply Last reply 22 Feb 2024, 08:40 Reply Quote 0
                              • gloomyandyundefined
                                gloomyandy @R006
                                @R006 It might help if you post a picture of the board showing how you have the motors connected.
                                undefined 1 Reply Last reply 22 Feb 2024, 11:24 Reply Quote 0
                                  R006 @gloomyandy
                                  @gloomyandy
                                  gloomyandyundefined undefined 2 Replies Last reply 22 Feb 2024, 17:14 Reply Quote 0
                                    gloomyandy @R006
                                    @R006 Di you have a higher resolution version, it is hard to see what you have connected to the board in that picture.
                                    undefined 1 Reply Last reply 23 Feb 2024, 05:12 Reply Quote 0
                                      @R006 in your config.g, you haven’t specified any timing for your external drivers, set by M569 Txx:xx:xx:xx parameter. I think this may be causing a problem, as it will be using the default timing of ‘fast’, which is only suitable for the on-board drivers. The high frequency of these steps, and the high step rate you have set for Z (M92 Z2133.33) may be causing the interference. Try:
                                      M569 P5 S1 T5:5:10:10
                                      And similar for any other external driver.
                                      undefined 1 Reply Last reply 23 Feb 2024, 05:10 Reply Quote 0
                                        R006 @droftarts
                                        @droftarts , @dc42 , @T3P3Tony
                                        hey,
                                        i tried as per your suggestion but problem remains same. Please find detailed observations as per trials:
                                        with onboard drivers connected for all axes:
                                        1. I have 4 boards, and all of them with latest or old software have same behaviour.
                                        2. Somehow on while moving Z, Y axis gets some pulse.
                                        3. If i interchange the driver of X& Y, from P0 , P1 respectively to P1, P0, even then the noise appears only on the Y channel.
                                        4. The problem is some intermittent pulse that generates only on Y channel when declared. If i make P0 & P1 as X, then noise does not appear.
                                        5. It appears only if the Zmove is > 5mm .
                                        6. This noise does not generate when we HOME Z, but move Z at the same homing speed, the problem appears.
                                        with XY via external driver:
                                        7) When we use SPI-> external driver-> with suggested timing parameters, the probelms still exists.
                                        I have tried many things, Can you please check this once in the boards with you ? Somewhere a pulse is generated for the Y axis only when z moves.
                                        Is there anywhere in code where i can look for the problem ?
                                        ***What can be the possible causes for such behaviour?***bolded text
                                          R006 @gloomyandy
                                          @gloomyandy
                                          can't upload original file because the original file size is more and giving error while upload it
                                          undefined 1 Reply Last reply 23 Feb 2024, 07:54 Reply Quote 0
                                          6 out of 29
