Solved NEW PROBLEM WITH 1LC CARD
@Gianluca said in NEW PROBLEM WITH 1LC CARD:
When turned on it flashes 3 quickly and then 5 quickly for 3 times, then the red LED is off.
3 times is normal after telling the board to update, it just means that board doesn't have any valid firmware on it. 5 times means the Duet main board reported that it didn't have the requested firmware. So as Ian says, download the file from Github and upload it to the Duet again.
@dc42 said in NEW PROBLEM WITH 1LC CARD:
Yes, that's exactly what I did last night, both in stand alone mode and in SBC, but the firmware doesn't load.
List of tests step by step:- downloaded the file Duet3Firmware_TOOL1LC.bin ver. 3.5.0 RC3 from Gitub
- copied the file into the firmware directory
- turned off the printer
- turned on the printer by holding down both buttons on the 1LC board for 5sec, then released. (I also tried 1 second and also keeping them pressed all the time)
Result: no firmware loaded, 1LC card always unusable.
If you give me a detailed procedure, I can try again...
Sorry for insisting, but I have a 1LC board that is stuck after trying to install a firmware provided by the Duet team.
Unfortunately factory reset using the two buttons doesn't work.
Should I throw the card in the trash? Is there anything else I can try? Is there a warranty for this type of problem?
Thank you -
Alternating 3 and 5 flashes then the main board should put a message in the DWC console saying that a firmware file was requested but not found. Check the DWC console while the 1LC is trying to load firmware and giving those flashes to see what it's requesting as missing.
@Phaedrux said in NEW PROBLEM WITH 1LC CARD:
Thank,you, this weekend I'll make further attempts and check the messages in the DWC console.
I will try again in both, SBC and stand alone mode.
In SBC mode, is it recommended to power up the toolboard after the system is already running? (in SBC mode, the boot is very long...) -
I'd say it would be best to test with as minimal a setup as possible, so try standalone.
SECOND 1LC CARD BRICKED AFTER UPDATE
This morning I updated the printer firmware to go from 3.5 RC3 to RC4 and also the second 1LC card is now unusable.
The update process stopped at 96% (see photos). After 30 min i have reboot the printer and now M122 B121 gives no response.
Can I get warranty assistance for at least (second) toolboard? I don't want to buy a third one!!
All attempts made to unlock the first toolboard did not work.
Thank you -
Is this the same can cable as before?
@Gianluca what happens if you connect just one of the non-functioning tool boards to the CAN bus and hold both buttons down while powering up? What sequence of LED flashes do you see on the tool board?
No, I have tried various canbus cables. I'm sure this isn't the problem.
I answer the questions by attaching videos.
VIDEO_1: startup in stand alone mode.
The beep at the end indicates boot completion.
link textVIDEO_2: startup in stand alone mode with reset 1LC.
link textVIDEO_3: startup in SBC mode.
link textVIDEO_4: startup in SBC mode with reset 1LC.
link textThe file "Duet3Firmware_TOOL1LC.bin" is present in both the firemware and SYS folders, both in the SD card (st. alone mode) and in the raspberry (SBC mode).
Unfortunately the toolboard reset procedure did not work with any attempts.
Before the toolboards were blocked, they worked fine, except for the "Can't turn heater 1 on while in fault state" error, that perhaps arose with the RC3 version.
Is it not possible to send the cards to load the firmware in your laboratory?
Thanks for the help, I really need it to get a usable printer again.
@Gianluca All the videos are marked as private, so I can't see them.
@droftarts said in NEW PROBLEM WITH 1LC CARD:
Sorry... Could you try now?
Have you seen the videos?
Can you help me get a working printer again?
Thank you -
@Gianluca can you remove everything from the toolboard so nothing is plugged in except the CAN and power connections?
I see you are using a 1LC v1.3
If you just have the one toolboard in the setup and its on the end of the CAN run, I would use the built in terminating resistor rather than have a resistor on the CAN connection
@jay_s_uk said in NEW PROBLEM WITH 1LC CARD:
Thanks, I'll try this too, just CAN and power connected.
No need to cut the track, if you look, there is the resistor on the CAN connector.
I have two v1.3 boards blocked by updates, one with the electrical track cut and one with the resistor. -
@Gianluca i was just suggesting remove all variables, but if you want to stick to the resistor thats fine
@Gianluca Hi, I have watched your videos, and also tested updating here on a v1.2a 1LC.
One thing I noticed is that if I disconnect the CAN cable, then I hold down the buttons and power up, I get an initial flash of the STATUS LED (like yours does), then let go of the buttons after a few seconds, I get a constant flashing on the red STATUS LED. I think the bootloader falls back to the firmware if it doesn't receive a response from the mainboard, but yours is then crashing. This makes me think that the firmware on your board is corrupted, and possibly stuck in a boot loop. However, pressing the two buttons on power up should allow it to request a new firmware, even if the current firmware is corrupt. Which makes me think there is a problem with the CAN cable, but it's possible there is some other fault with the board.
With the 1LC not finding a CAN connection, I think the main issue is with the CAN cable. Even with no firmware, or when pressing the buttons, you should still get a CAN connection. You said you replaced the cable, but to me it appears to still be a problem. Please try making a new cable. Do you have a working toolboard at the moment that you can test with?
Also, check your CAN termination. I see you have a resistor connected to the CAN connector on the toolboard, does that mean you have NOT soldered the CAN termination jumper on the back of the board? You shouldn't do both. We recommend bridging the CAN termination jumper on the back of the board, see https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Toolboard_1LC#terminating-resistor
If you stick with the resistor, make sure it is properly connected and providing resistance. Measure the resistance on the pins of the CAN cable connector.
I'm not sure what was causing the initial problem of the memory error, but hopefully we can get back to that.
I didn't solder the terminal, just to keep the board without any modifications...
@droftarts
First of all, thanks for your help, I hope to have a working printer again soon.I don't understand why in stand alone mode, the Status LED ( in both toolboards ) doesn't flash, while in SBC mode it does.
It would seem more logical to me to try to restore the firmware with the fastest boot (St. alone) and not waiting for the 30 seconds of the Raspberry (SBC).
In SBC, it seems that after the toolboard reset, the mainboard can give the firmware too late, only when the 1LC is no longer asking for it.Before the firmware update, both toolboards worked quite well, except for the "Expansion board 121 stopped sending status" error that was occasionally shown on the display. Printing was not interrupted.
In any case, making a new CAN cable costs nothing and I will do it right away.I also measure the resistance on the pins of the CAN cable connector, is actually working.
I'll report back as soon as all the tests have been done.
