    RepRapFirmware 3.6.0-alpha.2 for Duet main boards available
    Beta Firmware
    14
    83
    6.6k
    • Notepadundefined
      Notepad
      New tranche of tests completed,
      The first and most important is the new baseline for 3.6.A2+3
      Duet 2 3.6.a2+3 no arc weld x16microsteps.txt
      This completed without any issues, the output benchy is identical to A2+2 and the motor chirping is none existent (no chirping detected in A2+2 either). Thankfully the PanelDue is now functional so I can confirm the changes to the serial output has worked with no complications.
      Further testing to no ones surprise shows x256 and x128 microstepping failed to complete, and failed in the same code 3 error as in A2+0
      Duet 2 3.6.a2+3 no arc weld x128microsteps.txt
      Duet 2 3.6.a2+3 no arc weld x256microsteps.txt
      The motors sounded awful during this, and the prints failed within 10 layers of starting.
      Interestingly, in A2+2 I was able to get a successful print out of x128 microstepping, which was not possible in A2+3. I wonder if the fixed serial connection put extra load onto the MCU and caused it to fail.
      As I have confirmed that between A2+2 and A2+3 at x16 microsteps with interpolation are pretty much identical, I have resliced the test print file to increase accelerations from 5k->10k, and jerk values 10->14. The goal is to put as much strain on the MCU as possible to try and find any failure cases.
      If the test print was made back in 3.5.2, this print would look absolutely awful and highly risk layer shifts. With A2+3 the print was basically flawless with an average print speed of 220mm/s. The motors also sounded slightly quieter when compared to 3.5.2, though I expect this is because of the smoother transitions in corners not exciting the frame instead of directly being motor noise.
      Duet 2 3.6.a2+3 no arc weld x16microsteps 10kaccel14Jerk.txt
      The last test I have completed is the same increased speeds as before, however with pressure advance disabled. I wanted to remove any possibility that PA could be slowing the machines XY movements down, and at the same time I can test if PA is doing anything (spoiler, it is working)
      Duet 2 3.6.a2+3 no arc weld x16microsteps 10kaccel14Jerk noPA.txt
      Both these higher speed / more aggressive prints performed flawlessly. there was no weird noises, and as you can see with the photos, Pressure advance seems to be working effectively.
      My next test will be focused on finding a new PA value, as my gut feeling is PA has become more effective, thus my original PA value of 0.022 can be reduced.
      After this I intend to focus on 16x microstepping and using alternative input shaping methods and cancelation frequencies to see if specific values (i.e ultra low frequencies with complex shapers) might cause issues.
      Interestingly I have not noticed any z-probe hanging akin to @Exerqtor has mentioned, the behaviour of my bed and gantry levelling using an inductive probe feels identical to normal.
      The real bamboo printer manufacturer
      1 Reply Last reply Reply Quote 5
      • Notepadundefined
        Notepad
        After a quick investigation on PA, it does appear to be much more effective. Key word is 'appears'. Due to the new input shaper causing cornering artefacts (which from now on I will reference as smoothing) this aids in reducing the amount of pressure advance required. More on this later.
        The main thing I have tested in this batch is the behaviour of the different input shapers available. I did so by cutting down the original print file into a smaller 10mm slice so the parts can be printed quicker. The slice was chosen to be at the bottom of the original file as this is where most print errors occurred, which coincides with the most amount of long arcing movements. Print speeds and aggression stayed the same.
        Duet 2 3.6.a2+3 16xmicro 10kA 14J MZV 51hz.txt
        Duet 2 3.6.a2+3 16xmicro 10kA 14J EI3 51hz.txt
        Duet 2 3.6.a2+3 16xmicro 10kA 14J EI2 51hz.txt
        Duet 2 3.6.a2+3 16xmicro 10kA 14J zvddd 51hz.txt
        Duet 2 3.6.a2+3 16xmicro 10kA 14J zvd 51hz.txt
        Over all, the prints performed exactly as expected, and all passed without any issues.
        There was one print which did get a Code 3 error, and the main difference was I changed the input shaper type mid printer (after the first layer). This might be an edge case senario but it is interesting that the only time I manually change the input shaper type mid print via inserting custom gcode in the slicer, is the one time it fails. It is also interesting that it didnt fail instantly, it was able to process about 5 seconds more of the print job before the print failed on one of the curved sections.
        Duet 2 3.6.a2+3 16xmicro 10kA 14J MZV 51hz fail.txt
        After this initial fail, I decided on updating the config.g itself and restarting the mainboard to be the best course of action.
        Stacking the print jobs from previous, gives a great example of the input shaper aggression against the amount of smoothing which the input shaper applies.
        In order from top to bottom:
        MZV, ZVD, ZVDDD, EI2, EI3
        P1086725.JPG P1086723.JPG P1086721.JPG P1086719.JPG P1086717.JPG P1086715.JPG
        The effect of the smoothing is very noticableon the benchy's rear text and the orca slicer logo.
        This also leads me to the conclusion that pressure advance should be calibrated to the type of input shaper used, as more aggressive input shapers require lower values of PA for the same clarity.
        I personally use EI2 as my go to shaper of choice. and at 51hz I was able to lower my PA value from 0.0225 to 0.0085, which in-turn also sped up my overall print speeds without sacrificing any quality.
        One final test I completed (no pictures sadly) is using MZV on an extremely low frequency which would normally never be used in actual machines, in hopes to overload the MSU.
        The output print quality was decent, however showed massive amount of smoothing almost 10x worse than EI3 in the previous tests.
        This leads me to the conclusion that the input shaper should only be used on frequencies above 40hz, and the lower the frequency you go, the simpler the input shaper should be used. I.E dont use EI3 over MZV at 30Hz.
        Duet 2 3.6.a2+3 16xmicro 10kA 14J MZV 20hz.txt
        I am starting to run out of things to test on my dedicated test machine, so I have selected a handful(8) of print farm machines which i have deployed 3.6.A2+3 on to. So far the output has been a marked improvement in print quality. No known errors or issues has appeared yet.
        Any advice on specific areas I should focus my testing onto would be much appreciated. if not my next batch will be all the input shaper types at very low and very high frequencies.
        o_lampeundefined 1 Reply Last reply Reply Quote 7
        • o_lampeundefined
          o_lampe @Notepad
          @Notepad https://forum.duet3d.com/assets/uploads/files/1721499165580-p1086721.jpg
          In this picture you can see the uppermost layers show a bit of meltdown on the Ei2 Y-part.
          I blame it on very short layer time and the filament got too hot?
          Wouldn't printing at too high temp also explain the smoothing?
          Notepadundefined 1 Reply Last reply Reply Quote 0
          • Notepadundefined
            Notepad @o_lampe
            @o_lampe AH, I probably should have mentioned, in the Y section at the top, I use pliers to grip the printed model to pull it off my bed. Im too lazy to take the PEI off or let it cool down so when I grip it causes those indentations.
            Exerqtorundefined 1 Reply Last reply Reply Quote 1
            • Exerqtorundefined
              Exerqtor @Notepad
              I've done some more testing and tuning as well, both PA, Acceleration & Jerk has gotten some adjustments. This new approach to input shapiny is REALLY a huge improvement!
              I'll upload some pictures once i get home, but i at least was able to shave down PA to 0.0075s from 0.0450s ,acceleration to 3000mm/s2 from 2500mm/s2 & upped the jerk to 7mm/s (i can't remember the Jerk values so i'll update those with the pics later). I also turned up the printspeed with 50mm/s across the board.
              Here is the "PA-tower" results with a range from 0-0.05s, before i had to run 0.045s PA to get the same result as I get with 0.0072s now.
              The printer sounds happier, and the surface quality in the prints is better than ever. Gread job @dc42 & and others who contributed!😁
              Proschi3Dundefined 1 Reply Last reply Reply Quote 4
              • Proschi3Dundefined
                Proschi3D @Exerqtor
                I have also tested the firmware and am very satisfied with the improved quality. I haven’t been able to make any fine adjustments yet, but I have increased the speed by 50mm/s as well.
                Love my Duet 3 Mini.
                https://www.instagram.com/proschi3d
                https://youtube.com/@proschi3d
                https://www.proschi3d.de
                • Notepadundefined
                  Notepad
                  Small behaviour test. Acceleration vs smoothing amount.
                  As a follow on from the PA test, PA should be dialed in once a set aggressiveness is chosen. A printer that is more aggressive with higher jerk and acceleration will require less PA as there is less of an impulse of pressure inside the nozzle as the printer changes directions and speeds.
                  One of the risks of higher aggression accelerations and jerk values is the amount of smoothing the input shaper applies can lead to lower tolerances, which is especially noticeable in corners intending to be sharp.
                  Using an IS profile like MZV and ZVD, these appear to have the least amount of aggression based smoothing.
                  Im not sure how the forum will handle the compression of these pictures (originally 9k photos). The test prints increase in acceleration in the thousands based on the number for that section. 1->10, 12, and 15. In ZVD the printer started to show some ringing artefacts at 8k acceleration mark, but even up to the 15k mark, there didnt appear to be any gap forming in the half moon segments. The over extrusion caused by no PA being enabled did show that at higher accelerations that less PA will be required.
                  For the EI2 test, it is immediately obvious that the amount of over extrusion due to the lack of PA is greatly reduced, this is probably due to the printer being more aggressive with the smoothing of the geometry causing the over extrusion amount to be mitigated and thus hidden.
                  While the printed part shows no sign of ringing, what does become visible after the 8k acceleration point is the half moon segments do start to separate and thus the tolerance quality of the part does deviate from the intended shape.
                  ( I have rewritten this section 4 times already as it just reads like word soup, so bear with me)
                  This does open up a new choice for printer setting optimisations in terms of optimisation methodology.
                  I personally require very accurate tolerancing, so my current print profiles were optimised to produce accurate parts with FW3.5.2.
                  With 3.6.A2+3 and the improvement of the input shaper, I am able to increase my accelerations and jerk values whilst maintaining the same tolerance level.
                  Accel 3400 -> 6800
                  Jerk 8 ->12
                  PA 0.0225 -> 0.0085
                  It is important to note that the previous settings on 3.5.2 was also the hard maximum as any more and the printer risks layer shifting. This risk seems completely bypassed in 3.6.A2+3 as the printer can handle the higher aggression with ease.
                  I can also push the printer even faster if I throw perfect tolerances out of the window. I have been able to test accelerations up to 16,000 and Jerk values up to 16mm/s.
                  This means for prints of a more artistic nature that do not require high engineering level tolerancing even higher speeds are available.
                  Of the 8 machines currently deployed with 3.6.A2+3 none have had any failures or show any signs of input shaping oddities. One printers extruder behaviour does sound weird when pausing however it almost appears like the bug with 3.5.2 (where insertion of filament after retracting in a pause being doubled) might be the cause. This bug behaviour has not been tested in this version specifically so take it with a grain of salt.
                  Edit, Tested the same with jerk values from 5->30, Same behaviour of smoothing when the print gets more agressive, and less PA is required. a good value for me at 8000accel seems to be 10jerk to maintain detail
                  Exerqtorundefined 1 Reply Last reply Reply Quote 6
                  • Exerqtorundefined
                    Exerqtor @Notepad
                    Today i managed to do a print that the new inputshaping couldn't help!
                    I printed a model with some 0.4mm debossed 7mm tall text on sides of the model the text was "HALDEN PK" (with the "PLAY" font if anyone want to try and it's rinting pretty bad between "N P" and after the "K".
                    I'll take some pictutes and post this evening!
                    Here is the results:
                    Print settings:
                    • Outer wall acceleration : 3000mm/s2.
                    • Inner wall acceleration: 5000mm/s2.
                    • Outer & inner wall jerk: 7mm/s.
                    • Outer wall speed: 120mm/s.
                    • Inner wall speed: 200mm/s.
                    • Pressure advance: 0.0072s.
                    Tbh. the artifacts look more pressure advance related than input shaping. But anyways i guess it's something worth having a look at.
                    o_lampeundefined Notepadundefined 2 Replies Last reply Reply Quote 0
                    • o_lampeundefined
                      o_lampe @Exerqtor
                      @Exerqtor Which IS algo did you use and does it look better with rrf 3.5.x?
                      Exerqtorundefined 1 Reply Last reply Reply Quote 0
                      • Exerqtorundefined
                        Exerqtor @o_lampe
                        @o_lampe said in RepRapFirmware 3.6.0-alpha.2 for Duet main boards available:
                        It's using ZVD and a 40.5Hz center frequency, forgot to mention that. I haven't tried reverting to 3.5 tbh!
                          dc42 administrators @Exerqtor
                          @Exerqtor those artefacts don't looks like ringing to me. They may or may not be related to PA as you suggest. I suggest you try printing that piece of the print with IS and/or PA disabled, to see what effect it has on those artefacts.
                          • Exerqtorundefined
                            Exerqtor @dc42
                            @dc42 I'll try without PA first and see how that fairs ☺️
                              droftarts administrators @Exerqtor
                              @Exerqtor You should definitely retune PA with the new IS implementation, if you haven't.
                              • N3XT3Dundefined
                                N3XT3D
                                I have tested the new version and I have to say it really is a huge improvement. For me, it's the best and most important update so far. My printer is heavy and has quite a high mass that is being moved. Now I can increase the acceleration and jerk with higher print speeds and a much better surface as a result. The printer used to make a lot of noise, especially when changing direction quickly (contours of figures etc.), which is no longer the case. In short, my printer now finally prints the way I always imagined it would, in terms of speed, noise and quality. Thank you for the release and the work involved.
                                • Exerqtorundefined
                                  Exerqtor @droftarts
                                  @droftarts said in RepRapFirmware 3.6.0-alpha.2 for Duet main boards available:
                                  Oh i have 😅 Went from 0.045 too 0.0072 lol
                                  • balajiramaniundefined
                                    balajiramani
                                    I just tried this on the delta that I have and during calibration, the effector is crashing into the bed. After reverting back to 3.5.2, calibration works fine.
                                    Here is a video of the crash.
                                    Here is config.g
                                    ; Setup some global variables
                                    global power_fail_retract = 2   ;  Retract 2mm when power fails
                                    ; Communication and general
                                    M550 P"BigDelta"				        ; Machine name and Netbios name (can be anything you like)
                                    M551 Preprap                        	; Machine password (used for FTP)
                                    M552 S1					                ; Enable WiFi. Disabled for setup and testing. Enable once set up on your network.
                                    ; Enable telnet
                                    M586 S1 P2
                                    ; Debugging
                                    M111 S0                                 ; Debug off
                                    M929 P"eventlog.txt" S1                 ; Start logging to file eventlog.txt
                                    M555 P2                           	    ; Set output to look like Marlin
                                    G21                                 	; Work in millimetres
                                    G90                                	    ; Send absolute coordinates...
                                    M83                                 	; ...but relative extruder moves
                                    ; Axis and motor configuration
                                    M569 P0 S0				; Drive 0 goes backwards
                                    M569 P1 S0				; Drive 1 goes backwards
                                    M569 P2 S0				; Drive 2 goes backwards
                                    M569 P3 S0				; Drive 3 goes backwards
                                    ; Assign extruder drive
                                    M584 E3
                                    ; Set homing switch config
                                    M574 X2 S1 P"!xstop"        ; Set homing switch configuration on S1 = high-end, active-low
                                    M574 Y2 S1 P"!ystop"        ; Set homing switch configuration on S1 = high-end, active-low
                                    M574 Z2 S1 P"!zstop"        ; Set homing switch configuration on S1 = high-end, active-low
                                    ; Set it as a linear delta
                                    M669 K3
                                    ; Setup paneldue 5i
                                    M575 P1 S1 B57600
                                    M665 R215.062 L395.317:395.475:395.433 B160 H374.050		; set delta radius, diagonal rod length, printable radius and homed height
                                    M666 X0 Y0 Z0				; put your endstop adjustments here, or let auto calibration find them
                                    M350 X16 Y16 Z16 E16 I1    	; Set 16x microstepping with interpolation
                                    M92 X200 Y200 Z200			; Set axis steps/mm
                                    M906 X1400 Y1400 Z1400 E1400 I60	; Set motor currents (mA) and increase idle current to 60%
                                    M84 S60                             ; Set idle timeout
                                    M201 X12000 Y12000 Z2000 E10000        ; Accelerations (mm/s^2)
                                    M203 X30000 Y30000 Z5000 E3600		; Maximum speeds (mm/min)
                                    ;M566 X900 Y900 Z300 E3600 P1		; Maximum instant speed changes mm/minute
                                    M566 X300 Y300 Z300 E450 P1         ; Maximum instant speed changes mm/minute
                                    M204 P6000 T6000                    ; Set acceleration for print and travel moves
                                    ; Configure Input shaping
                                    M593 P"zvdd" F45
                                    ; Thermistors
                                    M308 S0 P"bed_temp" Y"thermistor" T100000 B3950 R4700 H30 L0	; Put your own H and/or L values here to set the bed thermistor ADC correction
                                    M308 S1 P"e0_temp" Y"thermistor" T100000 B3950 R4700 H30 L0	; 100K NTC
                                    ;M308 S1 P"e0_temp" Y"thermistor" T100000 B4658 C6.5338987554e-08 ; 104-NT Aliexpress thermistor
                                    M950 H0 C"bed_heat" T0      ; Set up H0 as the bed heater using T0 as the sensor
                                    M950 H1 C"e0_heat" T1       ; Set up H1 as the extruder heater using T1 as the sensor
                                    M140 H0                     ; Map H0 as the bed heater
                                    ; Set temperature excursion warnings
                                    M570 H0 P20
                                    M570 H1 P20
                                    M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as thermistor on pin e1temp for left stepper
                                    M308 S4	Y"drivers"  A"Drivers"  ; configure sensor 4 as temperature warning and overheat flags on the TMC2660 on Duet
                                    M912 P0 S-3.5               ; Calibrate MCU temp
                                    ; Fan definitions
                                    M950 F0 C"fan0"
                                    M950 F1 C"fan1"
                                    M950 F2 C"fan2"
                                    ; Thermostatic fan on 1 for cooling the hotend
                                    M106 P1 T50 H1
                                    ; Thermostatic fan on 2 for cooling the board
                                    M106 P2 H3:4 L.3 X1 B0.3 T35:70 ; set fan 2 value
                                    ; Tool definitions
                                    M563 P0 D0 H1                       	; Define tool 0
                                    G10 P0 S0 R0                        	; Set tool 0 operating and standby temperatures
                                    ;M92 E1392								; Based on https://www.thingiverse.com/thing:1359717; 2023/01/06
                                    M92 E1077.1646                          ; This is the new value for the hobb-goblin extruder.  03/07/2023
                                    ;M92 E319.2005                           ; Set extruder steps per mm.  This is for the MK8 gear
                                    ; Z probe and compensation definition
                                    M558 P8 C"^!zprobe.in" R0.4 H4 F1200 T6000 A5 S0.01	; Z probe is a piezo sensor
                                    G31 X0 Y0 Z-0.08 P100			; Set the zprobe height and threshold
                                    M557 R150 S20				; Probe within a radius of 150mm and mesh spacing of 20
                                    M376 H5                     ; Taper off bed compensation after 5mm
                                    ; Configure power failure and resume
                                    M911 S21.0 R23.0 P"G91 M83 G1 Z3 E{-global.power_fail_retract} F1000" ; Relative movement and extrusion.  Move head up and retract 2mm filament.
                                    M208 S1 Z-0.5				; set minimum Z
                                    T0					        ; select first hot end
                                    M501					    ; Load any config overrides
                                    Here is bed.g:
                                    M561						; clear any bed transform, otherwise homing may be at the wrong height
                                    M290 R0 S0			; Remove any baby stepping
                                    ; bed.g file for RepRapFirmware, generated by Escher3D calculator
                                    ; 16 points, 4 factors, probing radius: 150, probe offset (0, 0)
                                    ; If the printer hasn't been homed, home it
                                    if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                                      G28
                                    ; Probe the bed and do auto calibration
                                    G1 X0 Y0 Z10 F10000        ; go to just above the first probe point
                                    while true
                                      if iterations = 5
                                        abort "Too many auto calibration attempts"
                                      G30 P0 X0.00 Y150.00 Z-99999 H0
                                      if result != 0
                                        continue
                                      G30 P1 X96.42 Y114.91 Z-99999 H0
                                      if result != 0
                                        continue
                                      G30 P2 X147.72 Y26.05 Z-99999 H0
                                      if result != 0
                                        continue
                                      G30 P3 X129.90 Y-75.00 Z-99999 H0
                                      if result != 0
                                        continue
                                      G30 P4 X51.30 Y-140.95 Z-99999 H0
                                      if result != 0
                                        continue
                                      G30 P5 X-51.30 Y-140.95 Z-99999 H0
                                      if result != 0
                                        continue
                                      G30 P6 X-129.90 Y-75.00 Z-99999 H0
                                      if result != 0
                                        continue
                                      G30 P7 X-147.72 Y26.05 Z-99999 H0
                                      if result != 0
                                        continue
                                      G30 P8 X-96.42 Y114.91 Z-99999 H0
                                      if result != 0
                                        continue
                                      G30 P9 X0.00 Y75.00 Z-99999 H0
                                      if result != 0
                                        continue
                                      G30 P10 X64.95 Y37.50 Z-99999 H0
                                      if result != 0
                                        continue
                                      G30 P11 X64.95 Y-37.50 Z-99999 H0
                                      if result != 0
                                        continue
                                      G30 P12 X0.00 Y-75.00 Z-99999 H0
                                      if result != 0
                                        continue
                                      G30 P13 X-64.95 Y-37.50 Z-99999 H0
                                      if result != 0
                                        continue
                                      G30 P14 X-64.95 Y37.50 Z-99999 H0
                                      if result != 0
                                        continue
                                      G30 P15 X0 Y0 Z-99999 S6
                                      if result != 0
                                        continue
                                      if move.calibration.initial.deviation <= 0.03
                                        break
                                      echo "Repeating calibration because deviation is too high (" ^ move.calibration.initial.deviation ^ "mm)"
                                    ; end loop
                                    echo "Auto calibration successful, deviation", move.calibration.final.deviation ^ "mm"
                                    Exerqtorundefined balajiramaniundefined Notepadundefined 3 Replies Last reply Reply Quote 0
                                    • Exerqtorundefined
                                      Exerqtor @balajiramani
                                      Moved to new topic.
                                      @balajiramani
                                      Funny that you mention that.
                                      I've been doing roughly 24hours of printing on 3.6.0-a2+2 now without any notable issues, but when I'm about to start print this morning (a print finished in the middle of the night, and the printer has just stood idle since that) it's acting up/crashing into the bed.
                                      (The printer is a Voron Triden by the way.)
                                      I start a print from the office and waits for the printer to start homing, hear it homing XY and when it goes of to home Z I hear steppers just turning and turning, so I go out and check on the printer. Turns out the rear-center Z stepper is standing still(with the carriage roughtly about where it should be), while both the front Z steppers are still going in a downwards motion about halfway along the Z-axis (I have "WobbleX" on the z-axis).
                                      So I hit the E-stop and check out DWC and what it has to say about this:
                                      26.7.2024, 09:58:32	Emergency Stop! Reset the controller to continue.
                                                              Error: Failed to home axes Z
                                      26.7.2024, 09:58:32	Emergency stop, attemping to reconnect...
                                      26.7.2024, 09:58:12	G28 Z
                                                              Warning: Driver 0.2 warning: phase A may be disconnected, phase B may be disconnected
                                      26.7.2024, 09:55:59	Error: G10: Probe was not triggered during probing move
                                                              Cancelled printing file 0:/gcodes/Automower/Rim_automower_305_0.2mm_ABS_0.4n_2h14m.gcode, print time was 0h 16m
                                                              Error: in file macro line 114: G1: insufficient axes homed
                                      26.7.2024, 09:53:33	Warning: Driver 0.2 warning: phase A may be disconnected, phase B may be disconnected
                                      26.7.2024, 09:51:07	Warning: Driver 0.2 warning: phase A may be disconnected, phase B may be disconnected
                                      26.7.2024, 09:49:20	Warning: Driver 0.2 warning: phase A may be disconnected, phase B may be disconnected
                                      26.7.2024, 09:39:45	M32 "0:/gcodes/Automower/Rim_automower_305_0.2mm_ABS_0.4n_2h14m.gcode"
                                                              File 0:/gcodes/Automower/Rim_automower_305_0.2mm_ABS_0.4n_2h14m.gcode selected for printing
                                      This all sounds somewhat odd since "Driver 0.2" is the one for the rear-center stepper, which don't seem to be doing anything weird.
                                      Anywho, I power down the printer and manually reset the two font axis & lock the bed. Then I flip the machine around to check the wiring which all looks good. But the machine back on it's feet, power up, remove the bed locks and home the printer: all seems fine. Ok? So I jog the printer through full Z motion min-max-min with Paneldue and all seems fine.
                                      Not seeing anything apparently borked I bring the bed up to heat again and attempt to run a tram routine (homing all axis, coarse tramming pass with 10mm dive height, then "n-number" of fine passes with 2mm dive height until the deviation is bellow 0.005mm). It runs the coarse pass, and ATTEMPTS to apply the initial adjustments:
                                      2024-07-26 10:15:06 [warn] Leadscrew adjustments made: -2.315 2.178 1.401, points used 3, (mean, deviation) before (0.660, 1.775) after (-0.000, 0.000)
                                      But for some reason the steppers don't move correctly so when it goes of with the second pass @ 2mm dive height it ends up scraping the nozzle allong the buildplate rather than hover 2mm above it (I've got Voron TAP, so it's not the biggest issue in the world with a slight "nozzle kiss" thankfully).
                                      At this point I of course slap the E-stop again and go over everything once more still without finding anything wrong. And again confirming full range of motion on the Z axis and rulling out phase/connection issues to the Z-steppers as far as I can understand.
                                      Try once more, and the exact same happens, and that's where I'm at now.
                                      Like I opened up with saying, I've done multible trams (restarted the printer a couple times and it trams the bed first print after each reboot), without issues during the roughly 24hours of print time I have on it with 3.6.0-a2+2.
                                      And that this happens with the printer standing idle after a print has finished is somewhat weird (roughly 3.5 hours between the night print finished and i tried starting a new one this monring).
                                        balajiramani @balajiramani
                                        I should add that this with a Duet 2 Wifi running 3.6.0-a2+3
                                        • Notepadundefined
                                          Notepad @Exerqtor
                                          @Exerqtor I think @dc42 is right. This looks like under extrusion to me from weird PA artifacts or possible retraction behaviours
                                          • Notepadundefined
                                            Notepad @balajiramani
                                            @balajiramani Do you think it would be possible to gather some diagnostic logs? I also use a Duet 2, but on a coreXY system, I would assume a delta has a higher amount of processing requirements So it would be interesting to see what's going on behind the hood.
                                            I personally use this process to gather the data:
                                            • Power cycle the printer
                                            • YAT USB connection
                                            • M122 as a baseline diagnostic
                                            • m111 p4 d1 b2048
                                            • Print till failure / untill not happy (Dont Estop, only cancel as you want to save the data from the printer)
                                            • M122 as a final diagnostic log
                                            • Estop
                                            • Save diaglog
                                            balajiramaniundefined 1 Reply Last reply Reply Quote 0
