    6XD I/O >> Issue solved
    5.4k
      dc42 administrators @tecno
      @tecno you only need the Enable connections to the drivers if you want the Duet to be able to turn off the motor current. If you leave them disconnected, the motors will be energized whenever power is applied to the drivers.
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @dc42
        @droftarts
        Just finished cable from 8 LED circular strip from
        Ali DC5V WS2812B Led Ring 5050 RGB Individul AddressabIe Round Lights Module 3Pin Black White PCB 8 16 24 35 45 Pixels BuiIt-in IC
        Only one led lights up so my question is my settings OK?
        M950 E0 C"led" Q3000000
        M150 E0 R255 P128 S20 F1
        Cheers
        Bengt
          droftarts administrators @tecno
          @tecno In M150, the F parameter tells the firmware what to do next:
          Fn Following command action. F0 (default) means this is the last command for the LED strip, so the next M150 command starts at the beginning of the strip. F1 means further M150 commands for the remainder of the strip follow this one.
          So you need F0 to finish and send the command, eg:
          M150 E0 R255 P128 S20 F0
          This should set LED string 0 (E0) to 255 Red (R255) at brightness 128 (P128), 20 LEDs (S20 you only have 8 but doesn't matter) and no more commands (F0).
          If the first LED is getting stuck on red or another colour, or you can't control any of the LEDs, what firmware version are you using?
          • tecnoundefined
            tecno @droftarts
            @droftarts
            Duet Web Control 3.5.1
            Yes it is stuck on one LED no color change
              @tecno RepRapFirmware 3.5.1 as well? Please update to 3.5.3 (RRF and DWC) and test, there have been some fixes for LEDs. https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.3
              This was a fix in 3.5.2:
              [Duet 3 MB6HC] [Duet 3 MB6XD] When a Neopixel LED strip was configured on a part other than the LED port, the first LED in the strip sometimes had the wrong colour (issue 996). This was a new bug in RRF 3.5.0.
              It could also be the M950 Q parameter. We say:
              The Qnn parameter sets the LED clock frequency. This is 4x the bit rate. Most datasheets for LEDs (at least SK6812 and WS2812B based LEDs) suggest a maximum data rate of 800Kbps, so 800000 * 4 = 3200000. The default of 3000000 appears to work well with most LEDs.
              So try M950 E0 C"led" Q3200000, and M950 E0 C"led" Q2800000, but after you have updated the firmware.
              Also, check your wiring!
              • tecnoundefined
                tecno @droftarts
                @droftarts
                Wires OK
                Same lonly LED
                Sanity check
                  @tecno I've just tested it on a 6HC, on RRF 3.5.1, and it's working for a 7-segment LED strip. All light up correctly. The fix in 3.5.2 was if you were using IO ports for LEDs. I don't have a 6XD to test, but it should be exactly the same as 6HC.
                  Can you send M115 and post the response?
                  Can you post a picture of the other side of the neopixel ring?
                  Also, I'm not sure using the uninsulated wire as the high frequency data line is a good idea! Most likely it has higher resistance than a 'normal' wire, and may not be transmitting the signal effectively. Use a different wire.
                  • tecnoundefined
                    tecno @droftarts
                    @droftarts
                    m115
                    FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6XD FIRMWARE_VERSION: 3.5.3 ELECTRONICS: Duet 3 MB6XD v1.01 FIRMWARE_DATE: 2024-09-18 11:27:56
                    This cable is a HQ Audio twisted pair with foil shield. Change White to shield.
                      @tecno Ah, that looks like an RGBW ring. Try
                      M950 E0 C"led" Q3000000 T2
                      M950 T2 tells RRF that it's RGBW, not RGB.
                      • tecnoundefined
                        tecno @droftarts
                        @droftarts
                        Same same
                        Will change LED ring to one with black PCB board. This a job for torrow ๐Ÿ˜‰
                        • tecnoundefined
                          tecno @tecno
                          @droftarts
                          Morning Ian,
                          Changed LED strip and only 1 of 8 is working on this one too.
                          Any suggestions?
                          Cheers
                          Bengt
                            @tecno I've just tested both RGB and RGBW LEDs on my 6HC, both worked without issue. I've asked someone with a 6XD to test.
                            Can you post a link to the white LED ring you bought? And post a picture of the current wiring?
                            • tecnoundefined
                              tecno @droftarts
                              @droftarts
                              https://vi.aliexpress.com/item/1005002313192735.html?spm=a2g0o.order_list.order_list_main.11.364b1802NFG3VP&gatewayAdapt=glo2vnm
                              Both white and ยดblach PCB 8 LEDS
                              Wiring https://forum.duet3d.com/post/345489
                              gloomyandyundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                              • gloomyandyundefined
                                gloomyandy @tecno
                                @tecno Shouldn't the control signal be going to d0 and not to d1?
                                • tecnoundefined
                                  tecno @gloomyandy
                                  @gloomyandy
                                  As I understand is 6XD D0 out goes to Di in.
                                  gloomyandyundefined 1 Reply Last reply Reply Quote 0
                                    @tecno Those do look like RGB LEDs, looking closer. Though they should light up, just with the wrong colours, if you put the wrong T parameter in M950.
                                    I thought you said you had changed the wire over? @tecno said in 6XD I/O >> Issue solved:
                                    On each LED, there is a corner 'notch' to indicate which pin is GND. Can you check continuity of GND, DI and 5V from the LED pins to the connector?
                                    @gloomyandy It's DI for Digital In, DO is Digital Out, where it passes the signal on to the next one. Mine are labelled and wired like that.
                                      gloomyandy @tecno
                                      @tecno This has nothing to do with the 6XD I'm talking about the pads on the LED ring, there is a D0 and a D1. Your wiring here: https://forum.duet3d.com/post/345489 shows it going to D1 I think it should go to D0. It seems very odd to me to have the input labelled D1 and the output labelled D0.
                                        gloomyandy @gloomyandy
                                        Ah yes that may be Din and Dout I suppose. Oh well good luck!
                                        • tecnoundefined
                                          tecno @gloomyandy
                                          @droftarts
                                          So now I changed White to signal and Shield is now 5V
                                          So now we are getting closer ๐Ÿ™‚
                                            @tecno Okay, so now use:
                                            M950 E0 C"led" Q3000000 T1
                                            ie change T2 to T1
                                            I expect that bare 'earth' wire had too much capacitance to transmit the signal. Now you're using the bare wire for 5V, so easier to create a short. Same goes for using that wire for GND. I'd replace the wiring with individually insulated wires, ie 3-core wire. If you don't have 3-core wire, use left-over stepper motor wire, that's about the right gauge for LEDs.
