    6XD I/O >> Issue solved
    5.1k
    • tecnoundefined
      tecno @tecno
      New set of cables ready.
      tecnoundefined 1 Reply Last reply Reply Quote 1
      • tecnoundefined
        tecno @tecno
        @droftarts
        Hi Ian,
        All axis are now moving ๐Ÿ‘
        Happy camper here
        Bengt
          droftarts administrators @tecno
          @tecno Phew! Glad it's all working. Hopefully your faith in the 6XD is restored.
          Edit: You weren't tempted to wire in the enable signal as well?
          tecnoundefined 1 Reply Last reply Reply Quote 0
          • tecnoundefined
            tecno @droftarts
            @droftarts
            No need for enable as I see it. 6XD is a very nice controller.
            Now I have to sort out further I/O
              dc42 administrators @tecno
              @tecno you only need the Enable connections to the drivers if you want the Duet to be able to turn off the motor current. If you leave them disconnected, the motors will be energized whenever power is applied to the drivers.
              • tecnoundefined
                tecno @dc42
                @droftarts
                Just finished cable from 8 LED circular strip from
                Ali DC5V WS2812B Led Ring 5050 RGB Individul AddressabIe Round Lights Module 3Pin Black White PCB 8 16 24 35 45 Pixels BuiIt-in IC
                Only one led lights up so my question is my settings OK?
                M950 E0 C"led" Q3000000
                M150 E0 R255 P128 S20 F1
                Cheers
                Bengt
                  @tecno In M150, the F parameter tells the firmware what to do next:
                  Fn Following command action. F0 (default) means this is the last command for the LED strip, so the next M150 command starts at the beginning of the strip. F1 means further M150 commands for the remainder of the strip follow this one.
                  So you need F0 to finish and send the command, eg:
                  M150 E0 R255 P128 S20 F0
                  This should set LED string 0 (E0) to 255 Red (R255) at brightness 128 (P128), 20 LEDs (S20 you only have 8 but doesn't matter) and no more commands (F0).
                  If the first LED is getting stuck on red or another colour, or you can't control any of the LEDs, what firmware version are you using?
                  • tecnoundefined
                    tecno @droftarts
                    @droftarts
                    Duet Web Control 3.5.1
                    Yes it is stuck on one LED no color change
                      @tecno RepRapFirmware 3.5.1 as well? Please update to 3.5.3 (RRF and DWC) and test, there have been some fixes for LEDs. https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.3
                      This was a fix in 3.5.2:
                      [Duet 3 MB6HC] [Duet 3 MB6XD] When a Neopixel LED strip was configured on a part other than the LED port, the first LED in the strip sometimes had the wrong colour (issue 996). This was a new bug in RRF 3.5.0.
                      It could also be the M950 Q parameter. We say:
                      The Qnn parameter sets the LED clock frequency. This is 4x the bit rate. Most datasheets for LEDs (at least SK6812 and WS2812B based LEDs) suggest a maximum data rate of 800Kbps, so 800000 * 4 = 3200000. The default of 3000000 appears to work well with most LEDs.
                      So try M950 E0 C"led" Q3200000, and M950 E0 C"led" Q2800000, but after you have updated the firmware.
                      Also, check your wiring!
                      • tecnoundefined
                        tecno @droftarts
                        @droftarts
                        Wires OK
                        Same lonly LED
                        Sanity check
                          @tecno I've just tested it on a 6HC, on RRF 3.5.1, and it's working for a 7-segment LED strip. All light up correctly. The fix in 3.5.2 was if you were using IO ports for LEDs. I don't have a 6XD to test, but it should be exactly the same as 6HC.
                          Can you send M115 and post the response?
                          Can you post a picture of the other side of the neopixel ring?
                          Also, I'm not sure using the uninsulated wire as the high frequency data line is a good idea! Most likely it has higher resistance than a 'normal' wire, and may not be transmitting the signal effectively. Use a different wire.
                          • tecnoundefined
                            tecno @droftarts
                            @droftarts
                            m115
                            FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6XD FIRMWARE_VERSION: 3.5.3 ELECTRONICS: Duet 3 MB6XD v1.01 FIRMWARE_DATE: 2024-09-18 11:27:56
                            This cable is a HQ Audio twisted pair with foil shield. Change White to shield.
                              @tecno Ah, that looks like an RGBW ring. Try
                              M950 E0 C"led" Q3000000 T2
                              M950 T2 tells RRF that it's RGBW, not RGB.
                              • tecnoundefined
                                tecno @droftarts
                                @droftarts
                                Same same
                                Will change LED ring to one with black PCB board. This a job for torrow ๐Ÿ˜‰
                                • tecnoundefined
                                  tecno @tecno
                                  @droftarts
                                  Morning Ian,
                                  Changed LED strip and only 1 of 8 is working on this one too.
                                  Any suggestions?
                                  Cheers
                                  Bengt
                                    @tecno I've just tested both RGB and RGBW LEDs on my 6HC, both worked without issue. I've asked someone with a 6XD to test.
                                    Can you post a link to the white LED ring you bought? And post a picture of the current wiring?
                                    • tecnoundefined
                                      tecno @droftarts
                                      @droftarts
                                      https://vi.aliexpress.com/item/1005002313192735.html?spm=a2g0o.order_list.order_list_main.11.364b1802NFG3VP&gatewayAdapt=glo2vnm
                                      Both white and ยดblach PCB 8 LEDS
                                      Wiring https://forum.duet3d.com/post/345489
                                      gloomyandyundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                      • gloomyandyundefined
                                        gloomyandy @tecno
                                        @tecno Shouldn't the control signal be going to d0 and not to d1?
                                        • tecnoundefined
                                          tecno @gloomyandy
                                          @gloomyandy
                                          As I understand is 6XD D0 out goes to Di in.
                                          gloomyandyundefined 1 Reply Last reply Reply Quote 0
                                            @tecno Those do look like RGB LEDs, looking closer. Though they should light up, just with the wrong colours, if you put the wrong T parameter in M950.
                                            I thought you said you had changed the wire over? @tecno said in 6XD I/O >> Issue solved:
                                            On each LED, there is a corner 'notch' to indicate which pin is GND. Can you check continuity of GND, DI and 5V from the LED pins to the connector?
                                            @gloomyandy It's DI for Digital In, DO is Digital Out, where it passes the signal on to the next one. Mine are labelled and wired like that.
