    Duet Polargraph
    My Duet controlled machine
    997
      jay_s_uk @droftarts
      @droftarts nice write up. I'm looking forward to seeing some of the prints from drawingbotv3
      • o_lampeundefined
        o_lampe @droftarts
        @droftarts Awesome work, my hero!
        So the accuracy lies in the details, like a constant angle at the motor pulley, but a varying angle at the effector. That's why my build was off the track for so much.
        OTOH, I was happy with my belt tensioning system, using no weights but a BLDC motor in torque mode. Also good for horizontal use cases.
        In your case, I'd add rollers for the belt guides, as they might add friction and disturb smooth motion. The fish hooks look pretty flimsy, too as do the wings of the effector. But that's the original Makelangelo design.
        I'm intrigued to try it again, especially now with your very helpful drawing. To know, what's what helps a lot to derive the right numbers for the kinematics.
        PS: I'm currently watching lots of woodworking videos on YT and they always need a lot of time to sketch up their cutting lines and such.
        A "strap-on" version of such plotter (as we discussed in the maslow thread) would be a huge help as they often have their plans in DXF format anyway.
        • droftartsundefined droftarts referenced this topic
          droftarts administrators @o_lampe
          @o_lampe said in Duet Polargraph:
          To make the triangles work, the line from the anchor point to the effector centre really needs to be as close as possible to being in a straight line. Otherwise you're going to get an error. The motor standoff that the belt runs around is only 5.8mm in diameter. I chose the point at 45° as the pivot point, which is roughly at the point the belt touches when the gondola is at the centre of the area, ie X0 Y0. As the gondola moves to the limits, the anchor point does move, but only about 0.8mm in the 'significant' direction. The 'less significant' direction error is around 1.5mm, but has less effect on the calculations, as it is the long side of the triangle.
          Close up of the 'C' anchor (top left motor). The arrow points to the pivot point on the 5.8mm standoff:
          I think it would be easy to 'do the math' to account for the anchor point movement, and it's possible that other firmwares already do that. I haven't looked at the Makelangelo code (it uses it's own branch of Marlin). Putting the motor centre as the initial anchor point, with the radius of the motor pulley, and the direction of rotation, it could be calculated and adjusted for.
          Where you set X0 Y0, and making sure you accurately home to that point, so the anchor points are accurate, is also important.
          That's cool. Maybe four BLDC motors in torque mode would be a better way to spool the cable/belt if you built something with a motor at each corner.
          Adding rollers would make the diameter of the pivot point bigger, and increase the error. The back of the belt is sliding on the standoff, which is printed in PLA, so without much weight on the gondola, I think it's fine.
          The effector wings are printed flat, so are actually pretty strong. The hooks are also printed with the layer lines along the hook, so should be okay. I did break one putting the belt in, but it had warped off the bed anyway, so was too tight. That did break across a layer line. Generally pretty happy with the printed parts, nothing I'd change.
          • o_lampeundefined
            o_lampe
            @droftarts I was noticed, you've edited a post, but couldn't find any big news.
            Did you add the drawings lately?
            THX
            Olaf
              @o_lampe No, I just updated a link that I got wrong in the first post, to the motor mount. I'm updating it a little (moving it off the big board, onto a smaller bar like the original Makelangelo, to make it more portable) and fixing a couple of bits (the servo had broken loose), as I'm taking it to SMRRF in Manchester this weekend. Changing the motor mounts to make them shorter, too.
              What drawings do you want?
              • o_lampeundefined
                o_lampe @droftarts
                @droftarts said in Duet Polargraph:
                No need for drawings, I was talking about the drawings you made with it. Didn't remember seeing the dragon before.
                Good luck in Manchester
                Olaf
                  Polargraph Update...
                  I took the Polargraph to SMRRF 2024 in Manchester last weekend. As it was mounted on a large MDF sheet, and I was travelling by train, this required a little bit of re-engineering. I re-mounted it on a strip of MDF, the same width as the original piece (so I didn't have to change the config), and updated the motor mounts so the belts hang closer to the wall, as there was now a step down from the motors to the drawing surface. I also did a nice Voronoi case for Duet boards (produced the Voronoi in Inkscape, which I spent far to long playing around with, see https://youtu.be/0fzJdGRzjf8 then extruded that in Fusion 360), but of course that was invisible as it was behind the Duet!
                  When I got to Manchester, @T3P3Tony insisted that I update it from the old, white PCB prototype Duet 2 WiFi, to a Duet 3 Mini 5+. This induced some headaches, as I eventually realised the comments in the config.g relating to anchor positions and motors was not correct in the original version. I have updated the config.g first post in this thread so it is now correct. I also removed the endstops, intending to make homing sensorless, but didn't get around to that, and just ended up homing manually. It was mounted on a white board, so easy to wipe off the board and draw something else. I'm sure that says something about the impermanence yet repeatability of art...
                  Apart from that, it ran smoothly for the weekend. It mostly drew things I'd created before, but I eventually got around to doing a couple of new things. There was a bit of an Andy Warhol/art theme (there were some impressive Hueforge prints), so I used DrawingBot to produce some of my own:
                  Here's the Voronoi case. Let me know if you want the stl.
                  T3P3Tonyundefined oliofundefined 2 Replies Last reply Reply Quote 5
                    T3P3Tony administrators @droftarts
                    @droftarts really fun to have it at SMRRF. Next stop pen changing?
                    • oliofundefined
                      oliof @droftarts
                      @droftarts that looks fun. Please share the case.
                        droftarts administrators @oliof
                        @oliof said in Duet Polargraph:
                        Here you go: Duet 3 Mini 5+ case.stl
                        It fits a Mini 5+ Ethernet or WiFi. I had to hack a bit out of the side around the WiFi module to get the Duet 2 WiFi to fit. Makes quite a nice bench test enclosure, though it's more of a board carrier than a full case. Doesn't use too much filament, so prints quite fast. Also mounting holes are for M3x8mm. I probably should have made the sides a tighter fit on the board, there's a 3mm gap all around between the board and side.
                        I printed two, and put the Mini 5+ Ethernet in it that runs a demonstration closed loop linear axis, with a M23CL. Now it can sit on top of metal things without shorting out! We found out that our little server PC (that was collecting the data from the closed loop axis and displaying it in Graphana) had a metal band around the edge the hard way, fortunately no damage.
                        • o_lampeundefined
                          o_lampe @T3P3Tony
                          @T3P3Tony said in Duet Polargraph:
                          I guess the hard part of that is: keeping the unused feltpen tips fresh without drying out. (A wipe-zone is not an option, unless it's outside of the actual drawing area)
                          I imagine a revolver-like parking device which holds the pens and covers the tips.
                          Electromagnets would hold/release the pens instead of a clamping screw.
                          Is reversing the e-magnets polarity an option with Duets heater ports? (required to attract/repell a neodym magnet)
                          i-draw-monkeysundefined 1 Reply Last reply Reply Quote 0
                          • i-draw-monkeysundefined
                            i-draw-monkeys @o_lampe
                            @o_lampe kids' markers are your friend. I've left "Medium felt-tip pen STABILO power" markers (I'd post link but can't yet) without cap for months and they still write
                            droftartsundefined 1 Reply Last reply Reply Quote 5
                              droftarts administrators @i-draw-monkeys
                              @i-draw-monkeys said in Duet Polargraph:
                              You need a minimum reputation of 2 to be able to post links. I've given you one upvote, one to go!
                              Thanks for the hint about kid's marker pens, too. Funnily enough, my daughter has exactly this set... https://www.stabilo.com/uk/medium-felt-tip-pen-stabilo-power/280-24-01
                              Whiteboard marker pens might be different, though, haven't checked.
                              • o_lampeundefined
                                o_lampe @droftarts
                                @droftarts I think whiteboards are a good base for testing, but you want to have a permanent drawing on paper once in a while.
                                Over at the "maslow" thread we even talked about technical drawings on wooden panels (cutting lines and laser markings). Even drywall could be an option (very thursty surface, they might need different pens)
                                A portable "strap-on" version could be useful on many construction sites. (where to put electric and water-cutouts)
                                  @o_lampe this was just for the show, to make it transportable. Using the whiteboard was convenient for demonstration purposes. Now it’s back home, I’m going to mount it to the wall, and see how it draws then. In the past, the board it was mounted on was always laid back a few degrees, which may both help and hinder drawing, by increasing the pressure on the pen.
                                  It’s still not very precise, least accurate at the limits of its range by 1-2mm perhaps. I need to tune the speeds and accelerations a bit more, but we did find at the show that some low frequency, broad band input shaping helped with belt wobble a bit.
                                  I could mount two more motors at the bottom, if I went back to using a full sheet board, but then I’d have to deal with winding the belts/cables onto a spool, and redesign the gondola to have 4 arms. 3 points would limit the drawing area.
                                  It may be that something like the original CoreXY ‘Bot of the Cloth’ would make a better, more accurate, portable plotter. https://corexy.com/botofthecloth/index.html
