    Multiple motion system
    69
    2.6k
      dc42 administrators @Alva
      @Alva I have just put a 6HC build at the same location.
      Alvaundefined 1 Reply Last reply Reply Quote 0
      • Alvaundefined
        Alva @dc42
        @dc42 Thank you , I will check it out
          T3P3Tony administrators @Alva
          @Alva please can you confirm if you have tested this.
          • Alvaundefined
            Alva @T3P3Tony
            @T3P3Tony Hello sorry, i haven't checked it out. The 6HC board i have is bit different from the original version. So i need to build it differently. I am actually waiting for the beta 3 version of the firmware now.
              @Alva you could try 3.6.0-beta.2+5 at https://www.dropbox.com/scl/fo/1l1t3h52jkapaszdpcruz/AOWakD9qTwZ2HRnV7N3vVvQ?rlkey=42ehcpbas7rwgz6z1318mbceh&dl=0 if you like. Use it with care because the changes in it are quite substantial. You may wish to reduce motors currents until you are happy that it behaves correctly. See https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-360-beta3-in-preparation for important changes.
              Alvaundefined 2 Replies Last reply Reply Quote 0
              • Alvaundefined
                Alva @dc42
                @dc42 Thank you. I will try it out and let you know the status.
                • Alvaundefined
                  Alva @dc42
                  @dc42 g binary "0:/firmware/Duet3_SDiap32_MB6HC.bin" not found , in the drop box this file is not available
                    droftarts administrators @Alva
                    @Alva Get the "Duet3_SDiap32_MB6HC.bin" file individually from here: https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.1
                    Otherwise it's in the zip file download in most releases, eg in "Duet2and3Firmware-3.5.4.zip" here https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.4
                    • Alvaundefined
                      Alva @droftarts
                      @droftarts thank you. got it.
                      • Alvaundefined
                        Alva @Alva
                        @Alva Tested the second motion system with the new version 3.6.0.beta2 + 5, but i am getting the error shows in the picture below:
                        tried gcode :
                        set global.daemonStop = true ; stopped the daemon
                        M118 S{"starting to move"}
                        G90
                        set global.daemonStop = false ; activated the daemon which only use U axis
                        G1 X0 Y0
                        M400 S1
                        G91
                        G1 X100 Y100 F200
                        M400 S1
                        G90
                        M118 S{"move done"}
                        M99
                        daemon.g :
                        ; File Name: 		/sys/daemon.g
                        if(!exists(global.daemonStop))
                        	global daemonStop = false	; Set to 1 to stop the daemon.g, it can be use to upload a new daemon.g file
                        while( global.daemonStop == false )
                            if(state.status== "processing")
                                G91
                                M596 P1
                                G1 U5 F300
                                M596
                            G4 P0
                        M99; Exit; File Name: 		/sys/daemon.g
                        • Alvaundefined
                          Alva @Alva
                          @Alva U axis was trying to use only in the second motion system. so motion system 0 and motion system 1 are not able to execute simultaneously.
                          • Alvaundefined
                            Alva @Alva
                            @Alva i have tried the same with the 3.6.0.beta2 +3 it worked as intended
                            Alvaundefined 1 Reply Last reply Reply Quote 1
                            • Alvaundefined
                              Alva @Alva
                                @Alva We're going to release 3.6.0-beta.3 in a couple of days, please retest when we release that.
                                • Alvaundefined
                                  Alva @droftarts
                                  @droftarts Sure will do. Thank you.
                                  T3P3Tonyundefined 1 Reply Last reply Reply Quote -1
                                    @Alva it's released:
                                    https://forum.duet3d.com/topic/37289/software-version-3-6-0-beta-3-now-available
                                    Testing is appreciated 🙏
                                    • o_lampeundefined
                                      o_lampe
                                      My understanding of the dual gcode stream is: you can open two gcode files at the same time and have a daemon.g running in the background?
                                      At the same time you'd have to split the config.g into two portions.
                                      Maybe put the U-axis specific lines in the startcode of the second stream?
                                      • Alvaundefined
                                        Alva @T3P3Tony
                                        @T3P3Tony Tested the above mentioned testing procedure and got the same error as 3.6.0.beta2 + 5.
                                        • Alvaundefined
                                          Alva @o_lampe
                                          @o_lampe My requirement is to utilize the unused axes during printing, with their movement controlled via daemon.g and triggered by a flag. My understanding of multiple motion systems is that the unused axes should be accessible to the other motion system. However, the error I am encountering indicates that the unused axes are still being treated as part of the motion system responsible for the print job.
                                          • Alvaundefined
                                            Alva @Alva
                                            Any updates about this topic? My observation is 3.6.0-beta2+3 worked , but after that it is broken. Thank you
