    Sovol SV08 Multiple Motion System Upgrade.
    My Duet controlled machine
    8
    239
    26.7k
    • dwuk3dundefined
      dwuk3d
      SV08 Double Gantry INDX option - with middle tool rack having independent Z
      Tools can be moved between front and rear gantry.
      Parallel Printing and Parallel tool changes
      A bit messy - but probably what I might end up with -
      INDX on 2 heads on both gantries - with IDEX too - using existing SOVOL heads, with option to offload both IDEX heads when not needed.
      So this is making me think I will probably still do a tool changer upgrade on my printer if I complete the 4 head stage before INDX becomes available.
      Some estimates of tool change/colour change times
      INDX tool change is about 17 seconds in total including reheat and priming.
      XL based on PrusaSlicer about 14 seconds (3 secs quicker).
      Doing the same thing with Bambu Studio and an H2D - Intra Nozzle total change times seem to be estimated at 11.7 seconds (about 5.3 secs quicker). IDEX times likely to be similar
      If you move all swaps to the same Nozzle then Bambu Studio estimates 76secs for a normal Multiplexing filament change.
      Doing the same thing for an X1C comes out as 95 seconds per change -
      An MK4 with MMU3 using the same method is estimating at 67 seconds per change.
      Dual Gantry parallel INDX or Stealtchanger tool changes could be as quick as sub-second - and faster than Ratrig toolshift..
      Parallel printing could then reduce single colour printing by appx 40% on dual gantry for some larger models, and by over 70% for symmetrical models on quad head printer.
      • dwuk3dundefined
        dwuk3d
        Don't really understand what is happening with my NEMA8 motor.
        It started working pretty well with the slower speeds, and I created a sort of test bed - and it lifted 500g quite happily.
        Then it stopped working - it might be electronic, the motor, or my mechanical design - I might be over constraining the bolt
        Lead Screw Nema11 now arrived - the lead screw is a bit long - 50mm - but will try that - with the coupler for the lead screw not too constrained if I get any trouble.
        This motor is rated at 1.0A - will be interesting to see how more powerful it is.
        Nema 11 installed - sticks up more than it really needs to - might chop off the lead screw, or try and source one with shorter screw - but managing to lift 500g and the extruder so far
        F93E6250-4A40-4BCA-AD5C-B23C2B821331.jpeg Screenshot 2025-03-29 at 22.44.30.png
        • dwuk3dundefined
          dwuk3d
          Simplified Dual IDEX belt routing.
          Decided it will be easier to put one 'Ratrig Hybrid' Y Axis motor above (for rear gantry) and below (for front gantry).
          It will mean that the bed needs to be raised up a bit - due to the height of the bottom motor - but this will be needed eventually anyway when I move
          to an occasionally moving bed.
          Will have to redesign the extruder carriage belt couplings so that there is room one of the belts to fit through.
          583EBB6F-833B-4DB7-8D5A-D5D0EA364865.png 7EE20091-82B1-4C7D-8760-483BBC791185.png
          I think this should work well for the front gantry in particular as the belt fix point will be very near the Y axis rail carriage.
          For the rear gantry they are further away - as the fix point is at the top - so there might be a slight pendulum effect.
          Setup will be mirrored on the other side - could I suppose swap the top and bottom couplings - but I guess it will be better to keep both sides of each gantry the same.
          • o_lampeundefined
            o_lampe @dwuk3d
            @dwuk3d said in Sovol SV08 Multiple Motion System Upgrade.:
            Their internal magnets might have degraded due to overheating? I noticed the same on some NEMA14 pancakes I used to use for extruders. They survived only when I reduced their rated current by 50%.
            I replaced them with brushless gimbal motors and a selfmade simpleFOC-interface and the problem was gone.Torque/weight ratio improved a lot, too.
            dwuk3dundefined 1 Reply Last reply Reply Quote 0
            • dwuk3dundefined
              dwuk3d @o_lampe
              @o_lampe Thanks - looks interesting - especially the gearing you have added.
              I would like to investigate adding some nylon or metal gears if I can source some suitable ones.
              I haven't really investigated driving normal motors from Duet - but it would be useful to be able to try something like your motors if I can control them ok with GCODE.
              I switched away from servo's partly as they didn't play well with parallel gcode processing.
              I'm wondering whether the type of Servo Motors that BambuLab have started using in the H2D extruder and AMS2 might be of use.
              I guess the ideal solution would involve some sort of close loop feedback and temperature monitoring.
              Think I will at least put some speed and reliability testing in my Macros - I think I should be able to home the ZHopper AXIS, do a few up and down movements and check the home point hasn't drifted due to missed steps.
              Could also I guess use the same method to find the maximum move speeds up and down, plus also use the same method on my U & V axis with their optical end stops.
              So far in my first steps my Nema11 seems to be able to handle F1000 moves up - which look pretty fast.
              • dwuk3dundefined
                dwuk3d
                Nema11 seems to be able to handle F1900 on a 1mm pitch lead screw - which is faster than I expected.
                Started to get a bit warm at end of test - so probably shouldn't push it that hard - will probably limit this ZHopper to F500 or F1000
                Test sequence was:
                I homed A.
                Then lifted it 0.2 slowly (F100)
                Then lifted it at the test rate 1mm
                Then lowered it slowly (F100) back to the end stop using G1 H4 - to check how far it had drifted.
                Then G92 A0 - to reset end stop - and repeat.
                5 times for each federate
                31/03/2025, 09:34:54 rate 2000 max pos 0.033 average 0.0107500 total 0.054
                31/03/2025, 09:34:49 rate 1900 max pos 0.015 average 0.0075000 total 0.038
                31/03/2025, 09:34:44 rate 1800 max pos 0.015 average 0.0068750 total 0.034
                31/03/2025, 09:34:38 rate 1700 max pos 0.014 average 0.0044375 total 0.022
                31/03/2025, 09:34:33 rate 1600 max pos 0.010 average 0.0045625 total 0.023
                31/03/2025, 09:34:28 rate 1500 max pos 0.014 average 0.0034375 total 0.017
                31/03/2025, 09:34:22 rate 1400 max pos 0.004 average 0.0018125 total 0.009
                31/03/2025, 09:34:17 rate 1300 max pos 0.006 average 0.0039375 total 0.020
                31/03/2025, 09:34:12 rate 1200 max pos 0.008 average 0.0050000 total 0.025
                31/03/2025, 09:34:06 rate 1100 max pos 0.008 average 0.0030000 total 0.015
                31/03/2025, 09:34:01 rate 1000 max pos 0.004 average 0.0023125 total 0.012
                31/03/2025, 09:33:55 rate 900 max pos 0.002 average 0.0006250 total 0.003
                31/03/2025, 09:33:50 rate 800 max pos 0.003 average 0.0023750 total 0.012
                31/03/2025, 09:33:44 rate 700 max pos 0.005 average 0.0023125 total 0.012
                31/03/2025, 09:33:39 rate 600 max pos 0.010 average 0.0057500 total 0.029
                31/03/2025, 09:33:33 rate 500 max pos 0.002 average 0.0010000 total 0.005
                31/03/2025, 09:33:27 rate 400 max pos 0.003 average 0.0013750 total 0.007
                31/03/2025, 09:33:22 rate 300 max pos 0.007 average 0.0036250 total 0.018
                31/03/2025, 09:33:15 M98 P"0:/macros/Speed TestA.g"
                rate 200 max pos 0.014 average 0.0061875 total 0.031
                Test Macro
                ;Speed TestA.g
                M98 P"homeA.g"
                M400
                G91
                var maxV = 0
                var totalV = 0
                var count = 0
                var rate = 200
                while var.rate <= 2000
                    while iterations < 5
                        G1 A0.2 F100
                        M400
                        G1 A1 F{var.rate}
                        G1 H4 A-2 F100
                        M400
                        var pos = abs(move.axes[5].machinePosition)
                        if var.pos > var.maxV
                            set var.maxV = var.pos
                        set var.totalV = var.totalV + var.pos
                        set var.count = var.count + 1
                        G92 A0
                        if var.pos > 0.1
                            break
                    echo "rate",{var.rate},"max pos",{var.maxV},"average",{var.totalV}/{var.count},"total",{var.totalV}
                    if var.maxV > 0.1
                        break
                    set var.rate = var.rate + 100
                    set var.maxV = 0
                    set var.totalV = 0
                    set var.count = 0
                Config
                ; Smart Drivers
                M569 P0.0 S1 D2 ; driver 0.0 goes forwards (Z axis)
                M569 P0.1 S1 D2 ; driver 0.1 goes forwards (Z axis)
                M569 P0.2 S0 D2 ; driver 0.2 goes backwards (Z axis)
                M569 P0.3 S1 D2 ; driver 0.3 goes forwards (X axis)
                M569 P0.4 S0 D2 ; driver 0.4 goes backwards (Y axis)
                M569 P1.3 S1 D2 ; driver 0.5 goes backwards (Z axis) - changed to 1.3 forwards
                ;M569 P1.0 S0 D3 V2000 ; driver 1.0 goes backwards (U axis)
                ;M569 P1.1 S0 D3 V2000 ; driver 1.1 goes backwards (V axis)
                M569 P1.0 S0 D2; driver 1.0 goes backwards (U axis)
                M569 P1.1 S0 D2 ; driver 1.1 goes backwards (V axis)
                M569 P1.4 S0 D2 ; Z-hopper 2
                M569 P0.5 S1 D2 ; Z-hopper 1
                M569 P121.0 S0 D2 ; driver 121.0 goes backwards (extruder 0)
                M569 P122.0 S0 D2 ; driver 122.0 goes backwards (extruder 1)
                ; Motor Idle Current Reduction
                M906 I30 ; set motor current idle factor
                M84 S30 ; set motor current idle timeout
                ; Axes
                M584 X0.3 Y0.4 Z0.1:0.2:0.0:1.3 U1.0 V1.1 A1.4 B0.5; set axis mapping
                M350 X16 Y16 Z16 U16 V16 A16 B16  I1 ; configure microstepping with interpolation
                M906 X800 Y800 Z800 U800 V800 A750 B150 ; set axis driver currents
                ; A - 1.8 degree, 0.7mm pitch - 200*16/0.7 = 4571
                ; A - 1.8 degree, 1mm pitch - 200*16 = 3200
                M92 X80 Y80 Z533.33 U80 V80 A3200 B629  ; configure steps per mm
                if exists(global.vMin) == false
                    global vMin = 120
                    global vMax = 340
                    global yMin = -5
                    global yMax = 210
                M208 X-5:310 Y-5:210 Z0:300 U27:350 V120:340 A0:3 B0:3  ; set minimum and maximum axis limits
                M566 X540 Y540 Z12 U540 V540 A300 B300 ; set maximum instantaneous speed changes (mm/min)
                M203 X10000 Y10000 Z720 U10000 V10000 A2000 B200  ; set maximum speeds (mm/min)
                M201 X10000 Y10000 Z500 U10000 V10000 A2000 B20  ; set accelerations (mm/s^2)
                • o_lampeundefined
                  o_lampe @dwuk3d
                  These spur gears were printed with a resin printer using anycubic's tough resin. They don't last for ages, but I can print a whole bunch at once.
                  There are a few user on this board using simpleFOC with it's GCode-compliant step/dir interface.
                  It's a bit of a learning curve to get used to it's PID behaviour... Their development & documentation status isn't as professional as Duet3D's, yet.
                  In the past, I've tagged some threads with sFOC or simpleFOC if you are interested.
                  • dwuk3dundefined
                    dwuk3d
                    NEMA11 seems to be working quite well.
                    Made some good progress over the last few days on
                    1. Reliable Z height from the two gantries. I switched back to just using the induction probes for now - as using Induction plus tap was getting too confusing.
                    2. trep.g and tpost.g macros - that include heating up, head cleaning and priming.
                    3. Tidying up of macro's so hopefully they work in both multi and single threaded modes.
                    Basic IDEX things like head cleaning and priming are quite a challenge - so I am trying to get them as reliable as possible before attempting some proper multi colour and parallel prints.
                    • dwuk3dundefined
                      dwuk3d
                      New build plan - based on INDX - which I think looks a lot less complicated than my previous attempt
                      Phase 1 - Dual Gantry, Multi Motion System - current phase - still working on refining macro's and reliability.
                      Phase 2 - Dual Idex on rear gantry only (3 heads) - CoreXYUVW - Still a good testing point for additional kinematics, and avoids the need for motors at the bottom front.
                      Phase 3 - Occasionally moving bed - to allow for bigger prints, and for all heads to access full Y extent of bed.
                      Phase 4 - Nozzle Changer - with INDX on front gantry
                      Print types
                      1. Small single colour - using just INDX head on front gantry
                      2. Big Single colour - parallel printing with all 3 heads
                      3. Small multi colour - Most common 2 colours in rear heads, plus 2 of the INDX slots - most colour changes would then be cross gantry parallel changes - so almost instant
                      4. Big multi colour - As Small multi colour - but with some parallel printing too.
                      5. Duplicate prints - - up to 3x speed for single colour using all 3 heads
                      Phase 5 - Only if enough benefits seen from IDEX - Add 4th head - as IDEX on Front Gantry, possibly with stealth changer offload ability for fast non IDEX printing.
                      Phase 4 - AMS - ideally finding a way to connect Bambu Lab AMSs - if not some sort of MMU solution - which will need more Mini5s
                        droftarts administrators @dwuk3d
                        @dwuk3d
                        For a moment, it looked like you were going to mount a second INDX on the back of the front gantry!
                        • dwuk3dundefined
                          dwuk3d @droftarts
                          @droftarts haven't ruled out anything yet about the direction of heads on gantries - but I hadn't thought of opposite directions on the same gantry.
                          Thinking about it - it might actually make the belt routing a bit simpler as have a linear on each side - as the belts wouldn't need to cross the linear rail carriages.
                          • dwuk3dundefined
                            dwuk3d
                            Been working today on tidying up probing and tool change macros which is proving quite difficult.
                            I'm currently on 3.5.4
                            B144E24C-AB13-4785-95BC-65DBCBD47283_4_5005_c.jpeg Screenshot 2025-04-03 at 22.01.19.png
                            Biggest issue I am having is with occasional 'Tool is in use or Axis is in use messages' - the biggest problem with these are that they don't stop execution so a) It can cause head clashes and b) They are quick tricky to track down.
                            I got a surprising tool temperature requirement - absolute zero - which I need to try and track down the cause.
                            UPDATE: Solved this issue - I had missed out the S on my M568 - so just had 0 - handy to know for the future.
                            Also I am getting some quite strange behaviour with the U and Z axis - where sometimes when I do a Z move down it seems to also move U left (probably to where X currently is).
                            If I then move Z up again and U right - it goes a lot further than I am asking - presumably back to its proper position.
                            It's interesting seeing the head move in 45 degrees - but it is messing up my probing.
                            See <<< on line 74 in here for the place where it does the strange move.
                            Update - Solved - I removed all T0 and T1 commands from alignment/homing/cleaning sequences and that seems to have stopped the odd behaviour.
                            It left the possibility of parts of the macro's being multi threaded by replacing all T0,T1's with M596.1 T0/T1 - which will still do the tool switches when needed.
                            ;AlignUVZ.g
                            if exists(global.ballProbeX) == false
                                abort "XY alignment not found"
                            G90
                            G1 Z50 F10000
                            T0
                            G1 X30 Y30 F20000
                            M400
                            M98 P"0:/macros/FindProbeUV.g"
                            M574 Z1 S2 K3; Set Z to Ball Probe
                            G1 H4 Z{global.zHit-1} F300
                            if sensors.probes[3].value[0] = 0
                                echo "Probe not found"
                                break
                            ;G1 U204 V149 F10000
                            T1
                            ; Find basic Z position
                            var Zpos = {50,49,48,48,48}
                            var Zrate = {300,200,100,100,100}
                            var Upos = {10,8,8,8,8}
                            var Vpos = {10,8,8,8,8}
                            var UVrate = {1000,800,300,300,300}
                            var prev = false
                            var pVM = 0
                            var pUM = 0
                            var VM=0
                            var UM=0
                            while iterations < 2
                                G90
                                G1 Z{var.Zpos[iterations]} F300
                                G91
                                G1 H4 Z-12 F{var.Zrate[iterations]}
                                ;echo "Z", {move.axes[2].userPosition}
                                var ZP = move.axes[2].userPosition
                                G1 Z5 F5000
                                M574 Z1 S2 K0; configure Z axis endstop
                                ; Now find U middle
                                G91
                                G1 U{0-var.Upos[iterations]} F5000
                                G90
                                G1 Z{var.ZP-0.2} F300
                                G91
                                M574 U1 S2 K3 ; Configure U axis with Z ball probe
                                G1 H4 U+10 F{var.UVrate[iterations]}
                                ;echo "X1", {move.axes[0].userPosition}
                                M400
                                var U1 = move.axes[3].userPosition
                                G1 Z5 F300
                                G1 U{var.Upos[iterations]}  F5000
                                G1 Z-5 ; <<< Strange move - where it also moves U back
                                M400
                                G1 H4 U-10 F{var.UVrate[iterations]}
                                ;echo "X2", {move.axes[0].userPosition}
                                M400
                                var U2 = move.axes[3].userPosition
                                G1 Z5
                                G90
                                set var.UM = (var.U1+var.U2)/2
                                ;echo "XM", {var.XM}
                                G1 U{var.UM}
                                M574 U2 P"!122.io0.in" S1 ; configure U axis endstop
                                ; Now V
                                G91
                                G1 V{0-var.Vpos[iterations]} F5000
                                G1 Z-5 F300
                                M574 V1 S2 K3
                                G1 H4 V+10 F{var.UVrate[iterations]}
                                ;echo "Y1", {move.axes[1].userPosition}
                                M400
                                var V1 = move.axes[4].userPosition
                                G1 Z5 F300
                                G1 V{var.Vpos[iterations]} F5000
                                G1 Z-5 F300
                                G1 H4 V-10 F{var.UVrate[iterations]}
                                ;echo "Y2", {move.axes[1].userPosition}
                                M400
                                var V2 = move.axes[4].userPosition
                                set var.VM = (var.V1 + var.V2) / 2
                                echo "UM", {var.UM},"VM", {var.VM},"ZP", {var.ZP},"---U1,2",{var.U1},{var.U2},"--V1,2",{var.V1},{var.V2}
                                if (var.prev == true)
                                    echo "variation U:",{var.pUM-var.UM}, "V:", {var.pVM-var.VM}
                                set var.pVM = var.VM
                                set var.pUM = var.UM
                                set var.prev = true
                                G1 Z5 F300
                                G90
                                G1 U{var.UM} V{var.VM} F2000
                                M574 V2 P"io4.in" S1 ; U Axis optical
                            G91
                            G1 H4 Z-5
                            var Z1 = move.axes[2].machinePosition
                            echo "z1",{var.Z1}
                            G1 Z5 F1000
                            G1 U4 F10000
                            G1 H4 Z-10
                            var Z2 = move.axes[2].machinePosition
                            echo "z2",{var.Z2}
                            G1 Z5 F1000
                            if var.Z1-var.Z2 < 1
                                echo "z1,z2",{var.Z1},{var.Z2}
                                abort "possible issue with UV alignment"
                            G90
                            var adjust = var.UM - global.ballProbeX
                            echo "adjusting U",{global.ballProbeX - var.UM},"V",{global.ballProbeY - var.VM}
                            G92 U{global.ballProbeX} V{global.ballProbeY}
                            if exists(global.UVAdjusted) == false
                                global UVAdjusted = true
                            I have written a little wrapper macro form M596 - M596.1 - which a) Has the ability for M596's to be switched off, and be allows the tool to be specified instead of the motion system.
                            NB/ At present my tools and motion systems are swapped round - i.e. T0 is in motion system 1, and T1 in ms 0 - This was due to issues I was having when I have a servo on T1 (UV axis) - so I may well swap them back around at some point.
                            ;M596.1,g
                            ;M596.1 P-1  ; Ignore M596.1 commands until P-2
                            if exists(global.M596_stat) == false
                                global M596_stat = -1
                            if exists(param.P)
                                if param.P < 0
                                    set global.M596_stat = param.P
                                else
                                    if global.M596_stat == -2
                                        M596 P{param.P}
                            if exists(param.T) && global.M596_stat == -2
                                if param.T == 0
                                    M596 P1
                                    T0
                                else
                                    M596 P0
                                    T1
                            if exists(param.Z) && global.M596_stat == -2
                                    M596 P0
                                    T1
                            • dwuk3dundefined
                              dwuk3d
                              Ball probe Auto Alignment getting fairly good.
                              Images of nozzle as was found by printer with no manual adjustment or head movements.
                              The alignment isn't perfectly on the centre of the nozzles in the camera because I can't guarantee the XY offset between the camera and ball probe - due to the swing out movement based on a servo - which might be a slightly different angle every time.
                              Checking with the camera I am getting a 0.1mm variation in the X/U axis, and 0.7mm in the Y/V axis.
                              Not sure if this a consistent difference or whether it varies.
                              Not sure if this is dirty nozzles, nozzle shape irregularity or RRF Ball Probe macros' or just the sort of error you might get with a ball probe vs camera.
                              My XY Axis is still on sensorless end stops - so will be interesting to see what difference it makes swapping between sensorless and optical end stops in keeping alignment across reboots.
                              • o_lampeundefined
                                o_lampe
                                I think I just had a bright moment regarding z-hop: Re-purposing Rc-car servo savers could be the answer to more torque and accuracy, whilst still be backlash-free.
                                I tried to find a good picture to show how they work and came up with this:
                                Twisting the servo arm while the output-side is fixed to the tool head would be translated to vertical lift (or drop if you want to use gravity to your advance).
                                They usually come with an adjustable spring which isn't shown here.
                                • dwuk3dundefined
                                  dwuk3d @o_lampe
                                  @o_lampe said in Sovol SV08 Multiple Motion System Upgrade.:
                                  Rc-car servo savers
                                  Thanks - are you suggesting having this attached to a non geared stepper motor, or a servo or somehow attaching it to the lead screw to translate big linear movements into smaller more powerful ones?
                                  The final Nema8 I ordered just arrived and its a non lead screw 34 high vs most of the others which were 24 - so hopefully a bit more powerful.
                                  The Lead Screw Nema 11 still seems to be working quite well in my probing and Z offset tests - but haven't actually tried doing some proper printing with lots of Z Hopping yet. It is noticeably quicker than the tiny linear stepper that I had on the other axis - and I think will end up being quicker the geared belt driven Z Axis of the SV08
                                  The good news with my current 3 rather than 4 headed next step is at least it means one less Z hopper motor to buy.
                                  Shame I bought the 4th Extruder/ 1LC board and 2nd Mini5 - as I think I might be able to get away with the 16 drivers available on the 6HC, Mini5+, plus 3x1LC
                                  Glad I haven't done to termination removal drill out on the Mini5+ board yet.
                                  • dwuk3dundefined
                                    dwuk3d
                                    Work progressing on dual colour printing - example of auto alignment (it looked fairly good on the camera so I didn't adjust it at all).
                                    Also made an extremely useful discovery about pre-heating - Orca Slicer (and probably PrusaSlicer and Bambu Studio supports it).
                                    Example below with 2 seconds specified. - see 5th line down.
                                    This will be very useful - because I can fairly easily change the G10 Pre-heats to be a macro call with a post processor - which can they do:
                                    1. More intelligent pre-heating based on the actual amount the inactive extruder has cooled - perhaps with some feedback to see how long it actually takes to reheat.
                                    2. Do the priming in parallel - so that as soon as in this example T0 has completed T1 can then start immediately printing - with hopefully almost no delay.
                                    G1 X131.54 Y141.994 E.34619
                                    G1 X131.54 Y142.652 E.02497
                                    M73 P23 R1
                                    G1 X137.336 Y148.448 E.31089
                                    G10 S220 P1 ; preheat T1 time: 2s
                                    G1 X136.677 Y148.448 E.02497
                                    G1 X131.54 Y143.31 E.27558
                                    G1 X131.54 Y143.968 E.02497
                                    G1 X136.019 Y148.448 E.24028
                                    G1 X135.361 Y148.448 E.02497
                                    G1 X131.54 Y144.627 E.20497
                                    M73 P24 R1
                                    G1 X131.54 Y145.285 E.02497
                                    G1 X134.703 Y148.448 E.16966
                                    G1 X134.044 Y148.448 E.02497
                                    G1 X131.54 Y145.943 E.13436
                                    G1 X131.54 Y146.601 E.02497
                                    G1 X133.386 Y148.448 E.09905
                                    G1 X132.728 Y148.448 E.02497
                                    M73 P25 R1
                                    G1 X131.54 Y147.259 E.06375
                                    G1 X131.54 Y147.918 E.02497
                                    G1 X132.275 Y148.654 E.03947
                                    ; stop printing object Cube id:0 copy 0
                                    ; printing object Cube id:1 copy 0
                                    ; stop printing object Cube id:1 copy 0
                                    G10 ; retract
                                    ; filament end gcode
                                    M106 P3 S0
                                    G10 S215 P0 ; set nozzle temperature ;cooldown
                                    ;M98 P"0:/macros/changeFilament.g" A previous_extruder  B new_filament_temp  L layer_num  N next_extruder   F first_layer_temperature1
                                    M98 P"0:/macros/changeFilament.g" A0 B220 L0  N1  F220
                                    M106 S0
                                    T1
                                    ; Filament gcode
                                    G10 S220 P1 ; set nozzle temperature
                                    • dwuk3dundefined
                                      dwuk3d
                                      Simple post processing script created
                                      #!/usr/bin/python3
                                      # preheat - simple script to change all G10 & G11 commands to .1 versions - so that they run a Macro in RRF
                                      # Based on example from Bobs Notebook. - https://projects.ttlexceeded.com/3dprinting_prusaslicer_post-processing.html
                                      import sys
                                      import re
                                      import os
                                      sourceFile=sys.argv[1]
                                      # Read the ENTIRE g-code file into memory
                                      with open(sourceFile, "r") as f:
                                          lines = f.readlines()
                                      destFile = sourceFile
                                      os.rename(sourceFile,sourceFile+".preheat.bak")
                                      count = 0
                                      with open(destFile, "w") as of:
                                          for lIndex in range(len(lines)):
                                              oline = lines[lIndex]
                                              # Parse gcode line
                                              if oline.startswith("G10 ") and "X0 " not in oline:
                                                  oline = oline.replace("G10 ","G10.1 ")
                                                  if "preheat" in oline:
                                                      oline = oline.replace("G10.1 ","G10.1 Q1 ")
                                                  count += 1
                                                  of.write(oline);
                                              elif oline.startswith("G11 "):
                                                  oline = oline.replace("G11 ","G11.1 ")
                                                  count += 1
                                                  of.write(oline);
                                              else:
                                                  # Write original line
                                                  of.write(oline)
                                          of.write(";****\n;****preheat " + str(count) + " lines changed\n")
                                      of.close()
                                      f.close()
                                      Results - changing G10's all to G10.1 (except G10's with lots of AXIS parameters in).
                                      M73 P23 R1
                                      G10.1 Q1 S220 P1 ; preheat T1 time: 2s
                                      M73 P24 R1
                                      M73 P25 R1
                                      G10.1 ; retract
                                      M106 P3 S0
                                      G10.1 S215 P0 ; set nozzle temperature ;cooldown
                                      M106 S0
                                      T1
                                      ; Filament gcode
                                      ;****preheat 21 lines changed
                                      Now I just need to write the G10.1.g macro - to do the preheating and parallel priming.
                                      • dwuk3dundefined
                                        dwuk3d
                                        Parallel colour changes more or less working.
                                        I used Orca Slicer to send 17 second pre-heating G10's
                                        The preheat G10 comes in the opposite motion system to the one that needs the colour change to kick off.
                                        So I used a loop within the next motion system to wait for the target temperature to change.- by checking heat.heaters[].active, and checking for temperature reached by looping around and checking sensors.analog[].lastReading.
                                        Then once temperature reached I kicked off the priming, and then have a M598 just after the priming, but before the printing - so that the printer waits until the other motion system has finished it's work - before starting with the new colour.
                                        The eventual aim would be to tune the preheat, and introduce a precisely timed delay so that the priming of the next colour finishes exactly when the other colour finishes.
                                        For the SV08 heaters will need a longer preheat period - and will change the preheat to a tiny amount - so that I can pick up the change.
                                        Will then depending on the current temperature either wait a bit, or kick of preheating straight away - with the heat up time calculated to leave exactly enough time for priming to be completed at exactly the same time as the other colour finishes printing.,
                                        so that ideally the M598 at the end is pretty much instant.
                                        NB/. This way of working is only for small multi colour / multi material models. For bigger objects, where there is room on the print bed for both print heads to be printing at the same time, much more use of the RRF Multi Motion System capabilities will be made.
                                        Short demo video here
                                        https://youtu.be/Qn1SG_vc8X8
                                        • dwuk3dundefined
                                          dwuk3d
                                          Better demo of parallel colour/material changes - some changes as quick as 2 seconds.
                                          Still more work to do - but synchronisation getting closer.
                                          Using preheat G10's to kicking off the Pre Heat, delay, final heat, priming, tool change.
                                          Demo here.
                                          https://youtu.be/uk7KTCqrujg
                                          Tool change macro getting pretty complicated....
                                          ;changeFilament.g
                                          ;M98 P"0:/macros/changeFilament.g" A{previous_extruder} B{new_filament_temp} L{layer_num} F{first_layer_temperature} N{next_extruder} H{first_layer_height}
                                          echo {state.thisInput},"changeFilament"
                                          if exists(global.primeLayer) == false
                                              global primeLayer = {-2,-2}
                                          ;if exists(param.A) && param.A == 0
                                          ;    M98.1 A"parkXY.g"
                                          ;if exists(param.A) && param.A == 1
                                             ; M98.1 A"parkUV.g"
                                          if exists(param.H)
                                              G1 Z{param.H} F500
                                          if exists(param.N) && param.N == 0
                                              M596.1 P1
                                              T0
                                              echo {state.thisInput},"step 0 - wait for 200",{sensors.analog[param.N+1].lastReading}
                                              while heat.heaters[1].active < 200
                                                  G4 P500
                                                  ;echo {state.thisInput},"step 0 - wait for 200",{sensors.analog[param.N+1].lastReading}
                                              ;echo {state.thisInput},"M116 P1 from ",{sensors.analog[param.N+1].lastReading}," to 200"
                                              ;var start = state.upTime
                                              ;M116 P{param.N}
                                              ;echo {state.thisInput},"step 1 heat up time",{floor(state.upTime-var.start)},"s"
                                              ;**** Calculate delay
                                              var delayT = global.preHeatT
                                              echo {state.thisInput},"delayT initial",var.delayT
                                              if exists(param.L) && param.L <= 0
                                                  if global.primeLayer[param.N] < param.L
                                                      set var.delayT = var.delayT - global.primeTime0*2
                                              if exists(param.L) && param.L > 0 && global.primeLayer[param.N] < param.L
                                              echo {state.thisInput},"delayT with prime",var.delayT
                                              ; post delay heatup
                                              var lastR = sensors.analog[param.N+1].lastReading
                                              if var.lastR < 200
                                                  set var.delayT = var.delayT - ((220-200)/global.degSec)
                                                  if (200-var.lastR)/global.degSec > var.delayT
                                                      set var.delayT = var.delayT - ((200-var.lastR)/global.degSec - var.delayT)
                                              echo {state.thisInput},"delayT with heatup",var.delayT
                                              ;set var.delayT = var.delayT - 1
                                              if var.delayT <= 0
                                                  echo {state.thisInput},"SYNC not enough time to parallel tool change",floor(-var.delayT*10+0.5)/10,"secs short"
                                              else
                                                  if  heat.heaters[2].active < 200
                                                      echo {state.thisInput},"SYNC - other motion system not active - so no need to wait"
                                                  else
                                                      echo {state.thisInput},"SYNC - wait for",floor(var.delayT*10+0.5)/10,"secs"
                                                      G4 P{floor(var.delayT*1000)}
                                              M568 P0 S220 R220
                                              ;echo {state.thisInput},"heat up step2"
                                              var start = state.upTime+state.msUpTime/1000
                                              var startReading = sensors.analog[param.N+1].lastReading
                                              echo {state.thisInput},"M116 P0 from ",{sensors.analog[param.N+1].lastReading}," to 220"
                                              M116 P0
                                              var delayFurther = false
                                              if heat.heaters[2].active > 199
                                                  set var.delayFurther = true
                                              while sensors.analog[param.N+1].lastReading < 219
                                                  M568 P0 S220 R220
                                                  G4 P500
                                              echo {state.thisInput},"step2 heat up time",{(state.upTime+state.msUpTime/1000-var.start)},"s",{sensors.analog[param.N+1].lastReading},"temp",{(sensors.analog[param.N+1].lastReading-var.startReading)/(state.upTime+state.msUpTime/1000-var.start)},"deg/sec"
                                                      M98.1 A"clean T0"
                                                      M801 X40 Y5 T0 S10  ; Prime
                                                      set global.primeLayer[param.N] =  param.L
                                              set global.T0Clean = false
                                              var timeC = state.upTime+state.msUpTime/1000
                                              while global.uvParked = false ; move.axes[4].machinePosition <290
                                                  G4 P500
                                                  M400
                                              echo {state.thisInput},"Waited for uv to be parked ",{state.upTime+state.msUpTime/1000-var.timeC},"secs"
                                              set global.xyParked = false
                                              echo {state.thisInput},"finished changeFilament"
                                          if exists(param.N) && param.N == 1
                                              M596.1 P0
                                              T1
                                              while heat.heaters[2].active < 200
                                                  G4 P500
                                              ;M116 P{param.N}
                                                      set var.delayT = var.delayT - global.primeTime1*2
                                              ; post delay heatup
                                              if var.lastR < 200
                                              if var.delayT <= 0
                                                  echo {state.thisInput},"SYNC not enough time to parallel tool change",-var.delayT,"secs short"
                                              else
                                                  else
                                                      echo {state.thisInput},"SYNC - wait for",var.delayT,"secs"
                                              M568 P1 S220 R220
                                              echo {state.thisInput},"M116 P1 from ",{sensors.analog[param.N+1].lastReading}," to 220"
                                              M116 P1
                                              while sensors.analog[param.N+1].lastReading < 220
                                                  M568 P1 S220 R220
                                                  G4 P500
                                              if heat.heaters[1].active > 199
                                                      M98.1 A"clean T1"
                                                      T1
                                                      M801 U50 V315 T1 S10 ; Prime
                                              set global.T1Clean = false
                                              ;echo {state.thisInput},"M598 started"
                                              ;M598
                                              ;M400
                                              ;echo {state.thisInput},"M598 waited for ",{state.upTime+state.msUpTime/1000-var.timeC},"secs"
                                              set var.timeC = state.upTime+state.msUpTime/1000
                                              while global.xyParked = false ; move.axes[1].machinePosition > 25
                                                  G4 P500
                                                  M400
                                              echo {state.thisInput},"waited for xy to be parked ",{state.upTime+state.msUpTime/1000-var.timeC},"secs"
                                              set global.uvParked = false
                                          • dwuk3dundefined
                                            dwuk3d
                                            Test post
                                            <table>
                                            <thead>
                                            <tr>
                                            <th>Header</th>
                                            <th>Another Header</th>
                                            </tr>
                                            </thead>
                                            <tbody>
                                            <tr>
                                            <td>field 1</td>
                                            <td>value one</td>
                                            </tr>
                                            </tbody>
                                            </table>
                                            # * bolded text
