Nonlinear extrusion
I started a thread about this last year. It got kind of sidetracked so I decided to start a new post with the hopes that maybe we could try to have a thread where we can compile the most current information, best practices, and how to use it.
This is assuming people are actually using it. Based on my last post it doesn't seem like something that is used a lot which I find surprising especially when it comes to things like TPU and other softer filaments that can benefit greatly from nonlinear extrusion.
If it is not being used I expect that is probably because information on use is really hard to find, vague, confusing, and I'm not even fully convinced there is a calculator or easy way to get useful numbers.
I think having a known to work calculator would be huge. Or even better if there was something built into DWC that would be amazing.I have read through a ton of threads, I have tried the calculators I could find but have had very mixed results with trying different values.
Is anyone using this successfully? What calculations, calculator, or solutions are you using to come up with your values?
Even more importantly I would love to know if Duet can give us more information on exactly how it is implemented and how we are supposed to use it because in all the threads I have read I'm not even sure Duet support understands how it works or if it is even working properly.
Has this even been proven out by Duet developers? If so can they give us a little more guidance on how to properly use it? -
@yoshimitsuspeed
If you use the Magnetic FIlament Monitor from Duet3d you can try to use my improved automatic calibration macro for NLE by @AndyE3D
https://forum.duet3d.com/post/347692the public version of mine is only working in the latest firmware 3.6 in standalone mode / and not working in SBC mode.
@yoshimitsuspeed A calculator and a standardized test of some sort would be great. I eventually got it to work with my pellet extruder. It's not perfect, but it helps. I recommend starting at your lowest possible speed, calibrate your esteps with your favorite method, then repeat that test at your fastest speed, and a few in between to plot a trendline. I was not able to get it to work with my esteps calibrated at max speed and going backwards.
Here's my thread where I was trying to figure it out: https://forum.duet3d.com/topic/37013/speed-affects-extrusion-rate-with-pellet-extruder -
LOL I was so proud of myself for updating to a stable release from an RC I had been running and now I might be jumping straight back to a new RC.
I have been meaning to install my filament monitor for ages so maybe this will finally be the inspiration to do so.
I will check out your thread.I would still love to see information consolidated here on how this feature is supposed to be used without that. I think it would be much more popular if it was made easy to use.
Thanks for your option though. I will look into it more.
Thanks for the info and especially thanks for confirming my experience in that the esteps need to be changed massively to have any hope of making this work.
My extruder is supposed to be set around 680 steps/mm but as soon as I apply any NLE it will massively over extrude at lower speeds so I end up reducing steps/mm down to like 625 to avoid low speed over extrusion but then end up needing massive multipliers to get the high end back to where it needs to be and that seems to result in some unpredictable outcomes.This is part of what makes me think that this has never actually been implemented properly on the back end. I don't know whether this is in the Duet implementation or Rep Rap, or whether any effort has gotten the concept working properly.
But if without NLE I am getting proper extrusion at super low speed at say 670steps/mm, then I should be able to start there with my NLE. The fact that I need to lower it to 625 means either the implementation or my calculator isn't working properly.On that topic I have modified the calculator I am using to go to the volumetric flow rates I need so maybe that messed something up, even though if the formula I am using is correct it should calculate for any flow rate.
I also read something last night in a thread that said you need to start the graph where you see flow deviate from 100.
In my graph I have been starting my graph at close to zero. WIth say 0.1mm/s at 100% then scaling down as flow rate increases. So it might be an interesting test to start at say 2mm/s at 100 then curve up from there. But I also read something that it will mess up the calculator if you move the range.Either way it still suggests that either NLE isn't implemented properly, or that the calculator isn't working properly. Because if I have 0.1mm/s at 100 and 4mm/s at 99.5 then I should still be getting correct extrusion at low rates +- 0.5% not +5%.
This is why I think we really need some guidance from Duet on how this is supposed to be used and I think an official calculator with instructions on how to use it would be huge.
As an update in my calculator I changed it from starting at 0.1mm/s at 100% with very small changes in value on the low end, to starting at 4mm/S at 100% with larger changes in value up to the same numbers at the top and the A and B numbers are virtually identical so I don't think this would change anything.
@yoshimitsuspeed I don't know if I would say that it's not implemented properly because I did eventually get it to work. But it took me a lot of reading forum posts and mistakes to get it to work.
I would recommend testing at a wide range of speeds, especially speeds slower and faster than you ever plan to use. I noticed my trendline was rather linear after I threw out the data at both extremes of the inverted bell curve. At extremely low speeds, the nozzle oozes more than it extrudes, and while I didn't test it, I would imagine at extremely high speeds, extruder motor torque becomes an issue.
At least with a pellet extruder, the screw is the most efficient at its slowest (useful) speed.
Here's how I did it: I had a test model that was exactly two beads wide, and large enough to give the extruder screw time to spin up and pressurize. At the slowest speed I measured and adjusted the esteps until the beads had the same width as the slicer says it should be, using a simple linear ratio. Note this estep value will be different than it was before. Don't forget to change it back if you turn off non-linear extrusion.
I then increased the speed in increments, and printed the same test model for each speed, and measured the widths. Note that they should be decreasing as the speed increases. With the esteps calibrated at the slowest speed, divide it by the measured widths at different speeds. This gives you the new required multiplier at each increased speed.
Example with fake numbers:
Speed | width | correction factor
100 | 8 | (8/8) = 1
200 | 7 | (8/7) = 1.14
300 | 6 | (8/6) = 1.33
400 | 5 | (8/5) = 1.6
Graph the correction factor vs the speed in Excel and plot a trendline. Mine was pretty linear so I excluded the squared coefficient (B). On my trendline, the A coefficient was about 0.005 and the y-intercept was ALMOST 1 - which is correct.
Now you can go back and verify your work by comparing your old linear extrusion esteps at a medium speed to the non-linear esteps by multiplying them:
(non-linear esteps) * Bv^2 + Av + 1
They should be close to the same. -
@p8blr
I say it doesn't seem to be implemented properly because the estep values that work without it are not remotely close to the estep values to work with it.To highlight a big problem with this. If I am getting good enough results with a specific filament to run without NLE I should be able to do so. Then if say I am running TPU and need to run an aggressive NLE I should be able to add that to my TPU Gcode to enable NLE.
But when NLE esteps doesn't work properly at low volumetric extrusion until I get down to 625 steps/mm but I need 670 steps/mm to print without NLE enabled then it IMO isn't implemented properly.
I have found the "slippage" rate to be more of an increasing rate curve which mathematically it should be. The amount of resistance being squared or cubed, or something as you try to push more filament through.
So for example this is one of my most aggressive TPU curves which up to 4mm/s doesn't require much correction but up at 12 it requires much more correction per mm/s increase. Which would be expected by fluid dynamics and all that.With that said it shouldn't be 64%/ If I tried to do a static extrusion test it would be much higher but I think what we are seeing is the compounding of NLE and whatever is causing me to need to reduce the esteps.
At the 680 steps/mm my extruder is specced at I would get much closer to nominal extrusion at 12mm/s but with NLE active I would then get massive over extrusion at 1mm/s. So then I turn esteps down to 625 and get acceptable extrusion at 1mm/s, but then need to crank the multiplier up massively at 12mm/s.I have also found that around and below 70% things seem to go real weird too. So trying to get a good result across the full range is very hard. Especially when I need to turn my esteps down so much just to get it to work at all.
I'm not quite sure I follow the excel you show as you seem to have a 4th order polynomial and an exponential plot, but no 2nd order polynomial (quadratic) which is what NLE actually uses.
However, one thing that is clear is that you need ~1.56x more extrusion at your max speed than min speed you tested (100/64). First question: is that really true?
Second, what NLE command do you actually have, and have you specified an L parameter? NLE is limited to a maximum factor of 1+L, and L defaults to 0.2. If you haven't specified one, you won't be getting anywhere near the amount of NLE you need at higher speeds (1.2 is a lot less than 1.56). My guess is this is why you are having issues with your e-steps as anything above ~7mm/s would not get enough NLE based on your excel.
Link to the docs for ref, but I guess you've already been there!
https://docs.duet3d.com/User_manual/Reference/Gcodes#m592-configure-nonlinear-extrusion -
@engikeneer
This math is beyond me.
This is a calculator someone or some people developed I got off this forum. There is at least one other but this one seemed to be the most commonly used and most developed so it is what I have been using.These are the values to be entered for A and B
"However, one thing that is clear is that you need ~1.56x more extrusion at your max speed than min speed you tested (100/64). First question: is that really true?"
I never had much luck with the static extrusion test. Plus it isn't super accurate since the restriction during printing is different.
So I have just started adjusting the curve based on over/under extrusion at various flow rates while printing.
As I explained above the math on this curve isn't accurate to actual rates because we have to lower Esteps just to get it remotely working properly.
So as I said above to get my low extrusion rates not over extruding I need to adjust Esteps from around 680 to 625, then to prevent under extrusion at higher flow rates I need to make that up.
So 680/625 is 8.8% Add that to the 64 = 73 and that is probably pretty close to what the "slippage" would be.
Also this goes past what I would be printing at. So I might actually be printing at like 10mm/s and going to 12 just to continue the curve past what I need and likely past what would print well although I haven't dialed this filament too much.So realistically more like 10mm/s and "slippage" probably being more like 20%.
Oh yeah and yes I did learn a long time ago to use L.
I assume 1 is the highest value but it doesn't exactly clarify in the documentation. I have tried higher values like 10 and it seems to accept them but I never noticed any difference with values higher than 1. -
Well I still really hope someone from Duet will post in this thread to give some clarification on how this feature is supposed to work and ideally I would really love to see an official Duet calculator that we can know the math is good and compatible with the way it is programmed to work.
Unless I am missing something I also would almost consider the fact that we need to turn esteps way down to prevent over extrusion at lower rates, and that at least in my experience need to add that back to the multiplier to get acceptable extrusion at higher rates should technically be considered a bug or issue either with how it is implemented or the calculators that we are using.With that said having read here and also at least one other person in another thread having experienced this issue of needing to turn their esteps down has helped me. At least I don't feel like I am gaslighting myself if others are experiencing the same. So I went back to my old settings with esteps turned down from the manufacturers recommended 680ish to 625 and have my hard filaments dialed back in to where I would say it is running better across a range than without NLE but I need to do a little more testing.
One thing I experienced in the past and reconfirmed running that aggressive TPU profile in the pic above is that once you go below something like 70% it does seem to actually reduce flow. Now in theory we shouldn't need to go below that or it's probably a sign of pushing filament too hard anyway but it does suggest something is going on in the math either in Duet code or the calculator. Running a harder TPU starting with that profile above and under extruding, then throwing in my settings for something like 80% as the lowest and the extrusion rate in the print increasing significantly.
@droftarts @Phaedrux either of you able to help here?
@yoshimitsuspeed sorry I've been away so not able to look into the calculations etc. First thing they ask will be FW and hardware and maybe to see your config file in case there's anything unexpected there (low e jerk etc that might impact etc). You are right that a 'standard calculation sheet' and a method to tune NLE would be good (similar to how we have for pressure advance).
Fundamentally, the process should be:
- calibrate e steps for your chosen filament at a low speed (e.g. 1mm/s extrusion) with NLE off
- run a series of tests where you increase the extrusion rate and measure the level of under extrusion, but keeping as many other things constant as possible
- plug numbers into the calculator and work out your parameters
- rerun your tests with NLE enabled and confirm that it is working as expected
- trial in actual prints
Personally I'd say that the best method would be the static extrusion test (e.g. pebbles) and then weighing them. If you do dynamic (moving) printing, then you may end up against head acceleration and other speed effects, unless you do a simple line at a single set speed and just increase the line width accordingly, but that seems unlikely to be sensible/viable over the range of feedrates you'd want to do.
I can imagine you'd want to repeat this (and your estep calibration!) For different filament types as the drive gear will always dig more into a softer material.One extra thing... I think some of your issue may be down to your parameters you are setting. If you calculate the NLE rate you get at 5mm/s (reasonably high rate, but not crazy) then you get an NLE factor of about 1, so no impact at all. Maybe try plugging in the numbers and see what you're actually asking it to do? The maths is really simple so don't be afraid of it!
@engikeneer @yoshimitsuspeed The linear extrusion calculation is here in the code (3.6-dev branch) https://github.com/Duet3D/RepRapFirmware/blob/85432634695d00506d63d0055d65027d6dc3cb9f/src/Movement/DDA.cpp#L1740
So you can check that it's being calculated the way you think it should be calculated, ie
The amount of extrusion requested is multiplied by (1 + min(L, Av + Bv^2)) where v is the requested extrusion speed (calculated from the actual speed at which the move will take place) in mm/sec.
(The calculation is rewritten in the firmware as (1 + min(L, (A + Bv)^2)), but the result is the same.)
I don't see any limitation that would cause a difference when the steps/mm increases; I would think this is probably related to something else you have set. It's worth pointing out that NLE is applied along with many other factors that affect the motion/extrusion system, eg speed, acceleration, jerk, input shaping, pressure advance, etc etc. Also note that NLE is not applied to extruder-only moves, ie moves without XYZ movement.
Indeed! @yoshimitsuspeed please post your config.g and response to M122, and any other relevant files. If the problems only surface during print jobs, make sure your slicer isn't emitting Gcode that overrides your config.g settings. And yes, we do understand how it works. Though my personal view is that it's a bit of a hack to try and get more performance from a hot end that is limiting flow.
@engikeneer said in Nonlinear extrusion:
I'll ask if there's any additional guidance we can supply, but largely the resources @yoshimitsuspeed has found cover it. As @yoshimitsuspeed pointed out, I don't think it's a widely used feature, so devoting resources to it is at the expense of other more pressing issues may not make sense.
You might also look at @timschneider's work on temperature feedforward (T and A parameters in M309), see https://forum.duet3d.com/topic/36364/feature-adaptive-feedforward-temperature-setpoint/, which may allow you to reduce the amount of NLE.
"The maths is really simple so don't be afraid of it!"
"So you can check that it's being calculated the way you think it should be calculated, ie"I just went over this with my partner who has an MBA and a pretty big maths background. Admittedly a while ago and out of practice but after probably a half hour of looking at this, talking about it, trying to figure out what all the variables mean, trying to figure out why we are intermixing polynomials and exponentials, etc, she said it would take a lot more time to even start to figure out how to check the calculator I have, create a calculator, check it against the firmware, or do much of anything with the information provided.
I can tell you for sure that I would have no chance of making anything from that equation without a lot more help.I don't know how popular this feature would be if it was stupid easy, but I can say that even if 9/10 people would use this if it was stupid easy the fact that it is the way it is right now would make all but a few give up or not even bother.
If you read through the threads about this it is mostly a bunch of people trying to hack their way to an answer and many still sounding unsure of whether they succeeded. Even the few calculators seem to have mixed opinions on which to use or if they even work properly.
I think while printing pressure is going to be a lot different than results from a static test. For that matter trying to print 0.8mm layer width at 0.1mm height is going to be a lot different than at a 0.3mm layer height and both should be significantly higher than just extruding into the air.
I will say if I didn't print a ton of TPU I could probably get things dialed in well enough with static testing but it was with TPU I started tweaking things mid print because static test settings just didn't get me much better results than without NLE. But issues with inconsitency have still left issues with NLE and struggling to get acceptable extrusion over a wide range of flow. Even more so if we throw in variable layer heights which goes beyond the capabilities of NLE or PA but an issue that would be great to see improved as well.
It is true that trying to make adjustments by watching a print creates a ton more variables and I would be hesitant to even try to walk someone through a methodology because it is a little like trying to fine tune chaos but it can be a useful tool if you notice you are consistently getting under/over extrusion at a given flow rate in different situations that likely eliminate pressure advance, and other things.
@droftarts
I can try to get config info at some point. With that said I have had these issues on four different machines, a Duet 2 wifi, Duet 3 mini, and Duet 3 6hc, many different Duet versions, probably at least 7 different extruders and with probably 3 being oribiter 2.0 and 2 being orbiter 3.0 starting with the manufacturers recommended settings and with all different setups showing the same behaviors."Though my personal view is that it's a bit of a hack to try and get more performance from a hot end that is limiting flow."
This seems like a pretty big over simplification.
Even if you manage to keep the filament at the lowest viscosity temp you will still increase pressure as you increase flow. The effects of this are pretty minimal for most filaments within typical ranges but can have a huge impact on soft filaments and I think possibly even some low friction filaments that might be more likely to slip.Printing TPU at 12+mm/s3 on a .6mm nozzle NLE is pretty critical if you have areas that need to slow down significantly.
I think it is awesome that feedforward temp control is being implemented. I will definitely be trying this out as soon as I get a chance and maybe this will help me get my TPU print speeds a little higher still while managing lower flow areas but even with perfect temp control I still think NLE will be pretty much necessary to print well from low flow areas to max build rates.
@yoshimitsuspeed please do the following:
- Tell us what firmware version you are using.
- Send
M592 D0 A0 B0
then command 100mm extrusion at 1mm/sec measure the amount of extrusion. I am assuming you are using extruder 0. - Send
M592 D0 A0.01 B0
then command 100mm extrusion at 1mm/sec measure the amount of extrusion. - Send
M592 D0 A0 B0.01
Do you want me to do this test with my estep settings as tuned without NLE, or the Estep settings I have found work best with NLE?
DWC 3.5.4I also assume I will need to do this test as a print move with some kind of XY motion to make M592 work right?
