    Web interface AJAX timeouts
    40
    6.1k
    • elmoretundefined
      elmoret
      Same here, about one timeout related disconnect every 15 minutes. AJAX timeout set to 20s.
      • RCarlyleundefined
        RCarlyle
        Haven't had any timeouts yet tonight. Currently 36 minutes into a print.
        • RCarlyleundefined
          RCarlyle
          It's really weird that some nights I get the timeouts constantly, and some nights I make it 4+ hours without one.
          • elmoretundefined
            elmoret
            I'm seeing the same behavior here.
            • RCarlyleundefined
              RCarlyle
              Not sure what just happened, but I had an AJAX timeout in the middle of uploading a file, and the web interface lost the ability to upload files until I reloaded the interface page (in Chrome). When I clicked Upload & Print, it would open the file selection dialog, and then upon selecting the file nothing would happen. Persisted through power cycling the printer. Reloading the web page (which took ~20+ seconds) fixed it.
              • briangilbertundefined
                briangilbert
                This has just happened to me as well, except I was unable to reload the web interface without power cycling the duet
                Co-creator of the Zesty Nimble direct drive extruder
                • elmoretundefined
                  elmoret
                  The AJAX errors are really my only complaint at this point, everything else has been smooth sailing.
                  • roboduetundefined
                    roboduet
                    @RCarlyle:
                    Not sure that I'm right, but it seems like such long times with page reload caused by this: https://www.duet3d.com/forum/thread.php?pid=402#p402
                    • curieosundefined
                      curieos
                      I'm printing now but I keep getting timeouts. I got two in a row after restarting the same print (had to power cycle the printer both times) and then this one got a ways in before it timed out. The print is still going, but I need to reconnect to increase the temp by 5 degrees. Its been 25 minutes since the DC and I still can't connect.
                      She/Her
                      I work at a local 3D printing shop.
                      Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
                        T3P3Tony administrators
                        Nyl0cke, check out the resolution on this thread:
                        https://www.duet3d.com/forum/thread.php?id=38&p=2
                        It will be interesting to see what effect this has
                        • roboduetundefined
                          roboduet
                          Seems like this fix is only for static files (css/html/js) coming from Duet to browser. But not for dynamic ajax responses.
                          • curieosundefined
                            curieos
                            Yeah I'm also still getting a lot of errors. About the same amount, maybe more but its a small sample size so it might be coincidence.
                            She/Her
                              1. Those of you who are getting Ajax disconnects: is the Error Reason at the bottom of the box always given as timeout?
                              2. If you ever find that you can't reconnect after a disconnect, please try the following if possible:
                              A. Close the browser tab, open a new one and try to connect in that.
                              B. If that doesn't work, use Pronterface or PanelDue to send M552 S0 followed by M552 S1 to restart the wifi module. Then try to connect.
                              C. If that doesn't work, run M122 from Pronterface and see what the number of free buffers is.
                              • curieosundefined
                                curieos
                                Yes for me. I canceled the print I had going (had a mechanical problem I had to fix) and I updated the web server and now I can't keep connected for more than a couple minutes it seems. its been anywhere between 30 seconds to 8 minutes right now.
                                I'll try what you said when it happens again
                                She/Her
                                • pjr3Dundefined
                                  pjr3D
                                  1. It certainly is for me.
                                    • A. Connect from another browser instance (machine) works but is slow
                                  B. Hasn't been necessary yet and I have no paneldue on this machine
                                  C. Will try next time if I can't reconnect
                                  Seems to be worse after I went from wired-wifi connection to wifi-wifi after I moved my laptop. Upload speeds dropped to ~250k (even seen 30-40k on smallish files!).
                                  Hope you can find a fix for timeouts as well as speed.
                                  • curieosundefined
                                    curieos
                                    Okay, If it disconnects I can not reconnect by opening a new tab and trying to connect. If I connect to the board via serial I can turn off the server and turn it back on and I can connect.
                                    I can leave it connected but I can't test while printing for a while, the mount I used for my hotend isn't working very well, the hotend is moving around in its mount (flying extruder) a good 3mm or so.
                                    I also tried reconnecting on a different computer to no avail.
                                    She/Her
                                    • mhackneyundefined
                                      mhackney
                                      I've been chasing timeout problems on my thread here too. I also can not reconnect after a timeout but can do things from PanelDue. When I first commissioned Duet WiFi using the installed firmware, it was up and running for well over 48 hrs with no time outs. I then attempted to install a custom DWC.bin (simple hack) and it has been disconnecting within 1 minute since and once disconnected, I can't stay connected. I copied and pasted all of the error dialogs and exactly what I did on my thread. I'm now going to go back and reinstall all of the original binaries and see what happens and do some network captures in wireshark.
                                      My 3D Printing blog: http://www.sublimelayers.com
                                      Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
                                      • elmoretundefined
                                        elmoret
                                        I think I've always been able to reconnect without power cycling. Maybe once did I have to, otherwise a reload of the page or clicking the connect button worked.
                                        Have not upgraded to the recently released firmware though.
                                        • mhackneyundefined
                                          mhackney
                                          I've reverted back to the pre-production firmware that shipped with the board and when I disconnect now, I have to reset or turn off/on wifi in order to reconnect. But, once connected it always disconnects quickly afterwards (1-60 seconds or so).
                                          • curieosundefined
                                            curieos
                                            I was having connection issues with the original firmware shipped (had to restart the board or wifi interface, or there was a time or two where I waited an hour and it was working again), but only after a couple hours normally. The issues became more frequent with the newer firmwares for me, but I'm not sure if its actually because of the newer firmwares, since hackney has tried downgrading to the shipped firmwares with the same issues.
                                            She/Her
