    Panel Due stopped working
    4.1k
    • elmoretundefined
      elmoret
      Check also that you haven't erased the PanelDue firmware.
      • brianundefined
        brian
        I checked for voltage on the duet board and there was 0.8 volts. So purchased a new tft and that didnt solve the problem, so purchased a new panel due and that works except the graphics are upside down or reversed. What do i need to do to set that right.
        As a side note the old panel due/tft was constantly blinking no matter what i did would start blinking. This new one is not doing that and looks very stable, just not the right way around.
        Thanks in advance so your support.
          There is a button in the settings page to invert the display. That should get it right way round for you.
          • brianundefined
            brian
            thx Phaedrux, that worked, had to use a mirror to read it but it worked!
              dc42 administrators @brian
              @brian said in Panel Due stopped working:
              Your new PanelDue controller probably came programmed for the 5" display. If you run the 5" firmware on the 7" display, the colours are wrong and I think the display is the wrong way round too (as you found out). So if you want to get the colours right, you will need to upload the 7" firmware to it.
              • brianundefined
                brian
                Yes you are right, it is the wrong color. can i assume some of the functions also wont work, eg i cant set z to 0 using G92 Z=0?
                Also looking for instructions to update the firmware (for panel due) but cant find so far.
                  Phaedrux Moderator @brian
                  @brian Instructions are here: https://miscsolutions.wordpress.com/paneldue/
                  • brianundefined
                    brian
                    Yes thanks, i finally found them and successfully uploaded the firmware but...
                    now when the tft displays the menu (after several tedious seconds of the logo displaying) there are no boxes under the hotend icon so i cannot set the temp. Also trying to print via the sd card produces no results.
                    when the tft first lights, i can see the boxes under the hotend for a split second then it disappears. there are boxes under the hotbed icon.
                    Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      @brian are you sure you have the right firmware for your controller?
                      • brianundefined
                        brian
                        Ok, i down loaded the nologo version and it works,
                        • brianundefined
                          brian
                          wait, once plugged into duet, it no longer shows the the boxes
                          • brianundefined
                            brian
                            yes i have the 3.0a controller and downloaded the v3-7.0-nologo.bin
                            • Patundefined
                              Pat
                              Hi.
                              My Panel Due stopped working after an update.
                              Updated using bossa (writing and verifying were successful) and now the screen is black.
                              I have to connect it multiple times to get it recognised, and i still can write and verify, but no matter which firmware i try, it doesnt work.
                                I think either you don't have any tools defined in config.g, or the Duet firmware version you are running is too old for the PanelDue firmware you have installed.
                                  dc42 administrators @Pat
                                  @pat said in Panel Due stopped working:
                                  Hi.
                                  Are you quite certain that you have chosen the correct firmware? Which version PanelDue do you have, and what TFT panel?
                                  brianundefined Patundefined 2 Replies Last reply Reply Quote 0
                                  • brianundefined
                                    brian @dc42
                                    @dc42 The panel due is v3.0a and the 7" tft i just purchase a few days before the new panel due and i downloaded the v3-7.0-nologo.bin. Checking the tft setup shows at the top of the screen "Panel Due firmware version 1.21.3(13b1)"
                                    The duet wifi is v1.0 and firmware is 1.19 beta 7.
                                    As for the config.g, it is the same as before and has worked for many months.
                                    M563 P0 D0 H1 ; Define tool 0
                                      @brian is there a reason to stick on 1.19 beta 7? Might be a good time to do a backup and try upgrading to 2.0
                                      brianundefined 2 Replies Last reply Reply Quote 0
                                      • brianundefined
                                        brian @Phaedrux
                                        @phaedrux no reason, in fact i thought i had upgraded. i'll try again.
                                        • brianundefined
                                          brian @Phaedrux
                                          @phaedrux actually there are so many now i dont know which is which. I have duet wifi v1. There is no reference to that, just v2 and the earlier versions 0.85. Then there is SAM, no idea what that is. I assume i want reprap as my printer is a Cartesian.
                                            I'd start by trying duet2combined, wifi server, web control, and the IAP files. You can drag and drop them all into the DWC settings page and they should update. You may need to redo the duet2combined on its own after the other files have updated.
                                            brianundefined 1 Reply Last reply Reply Quote 0
