    Wire to wire connectors
    18
    5.8k
    • Rommieundefined
      Rommie
      Could always try these
      http://shop.rc-electronic.com/WING-AND-FUSELAGE-CONNECTORS/ROOKIE-LINE/Wing-connectors-8pin-plug-socket-2-pairs.htm?shop=k_emcotec_e&a=article&ProdNr=A85310&p=3726
      I may look at these myself would make wireing much better
      • briangilbertundefined
        briangilbert
        Any thought on 15 pin D type connectors? having trouble finding datasheets too if they would handle 40watt hot-end at 24v (1.6amp by my calculation).. cable run approx 1m.
        I was planning to use these so that I can remove whole effector to swap in another one if need
        Co-creator of the Zesty Nimble direct drive extruder
        • Aussiephilundefined
          Aussiephil
          @briangilbert:
          3M show 1A http://www.mouser.com/ds/2/1/ts0234-247014.pdf however OMRON show 3A http://www.mouser.com/ds/2/307/XM3-L_XM2-L_XM4K_XM4L_1212-348835.pdf
          The greater issue may be that D-Sub in general are specced for 26AWG or 28AWG wiring and this in my personal view is way to thinโ€ฆ... ๐Ÿ™‚ mind you i have wired D-Sub's with heavier wire in the distant past ๐Ÿ™‚
          Cheers
          Phil
            briangilbert
            A friend at my hackerspace reports pumping 15amp through single pins on 15Pin D connectors.. so I think the 1.6amp for a hotend will be ok, I've put them on the outside of the plug so that heat doesn't build up tho..
              T3P3Tony administrators
              The Mendel90 by the brilliant nophead used D type connectors for hotend etc:
              http://hydraraptor.blogspot.co.uk/2011/12/mendel90-extruder.html?m=1
              We copied this design on the Think3dPrint3d laser cut mendel90. The D type connectors work well and are particularly suited to flat ribbon cable as they come in IDC versions.
                briangilbert
                Considering I've already used the connector, glad to hear this ๐Ÿ™‚
                  Aussiephil
                  @briangilbert:
                  A friend at my hackerspace reports pumping 15amp through single pins on 15Pin D connectors.. .
                  mmm maybe that is not a good reason to copy him and whilst I'm trying to be polite I call a steaming pile of BS from him.
                  if he did it itโ€ฆ. is so far outside of even safe margins for the connector rating to even be considered vaguely safe at 15A for any extended periods.
                  We have a huge range of "designed for the task" quick connectors for power which the heater wires should use at the very least.
                  Cheers
                  Phil
                    briangilbert
                    @aussiephil
                    Normally I would say yes, but I believe him in this case.. either way I'm not planning to over-rate by anywhere near that in my case..
                    • ShadowXundefined
                      ShadowX
                      The D-sub pins are safely rated to 3A. Test have shown the temperature rises approximately 12C at 3A. You can pump more current through them, but the temperature may approach unsafe levels.
                      The easiest way to route high current is to use small compact battery connectors for RC applications. There are lots of different types such as Deans, Molex, JST, Tamiya, Futaba etc and they are rated for high currents due to the design. These connectors have a lot more surface contact between the male and female pins and some are gold plated to reduce oxidation which increases electrical resistance. I use the Deans connector for my hot end and it is very compact and can handle the current without problems.
                      • ShadowXundefined
                        ShadowX
                        Examples:
                        Deans:
                        Others:
                        • ShadowXundefined
                          ShadowX
                          For the lower current connections such as PT100, you can use a JST style 2.54 connector pin. There are different types from 2 pins to 20 pins and they have a locking feature to prevent accidental demates. There is no point in routing the PT100 and hot end on same connector unless you split the hot end into multiple pins to reduce the current through each pin. If the connector is rated for high current, it would be large, and vice versa for smaller connector. You always way to keep the high current connection on a different connector.
