    Firmware 2.02 Release candidate 3 now available
    Firmware installation
    31
    104
    15.7k
    • Adrian52undefined
      Adrian52 @Adrian52
      @adrian52 previous version dwc seems to work fine with rc3
      • pro3dundefined
        pro3d @Phaedrux
        @phaedrux
        Did you test M600 yet?
        Does it have pause and park feature or does this have to be macros on the side?
        /Roy
        Valkyrie DIY High Temp 3D Printer
        R&D - Engineering Designer - Viking 3D Printers
        https://vkingprinter.com/
        • stewwyundefined
          stewwy
          Had a problem with the 1.22.4 web interface:
          Uploading a file the first time using the upload&print button was fine.
          However if I upload it again with the same filename, having made some slicer settings, and having paused and canceled the original it usually failed the re-upload.
          Just retrying with 1.22.3 and it works fine
            Phaedrux Moderator @pro3d
            @pro3d it will run pause.g by default or filament-swap.g if present. So you have to customize the macro to your needs.
            • k3lagundefined
              k3lag
              @dc42 updated to 2.02rc3 and dwc 1.22.4-b1. Since upgrading whenever I scroll down in DWC it automatically scrolls back up a couple seconds later. Very irritating. I'm using Safari 12.0. This hasn't been a problem with any previous version. It seems to print fine however.
              dc42undefined Dougal1957undefined zerspaner_gerdundefined fmaundefined paulowiskundefined 5 Replies Last reply Reply Quote 0
                dc42 administrators @k3lag
                @k3lag said in Firmware 2.02 Release candidate 3 now available:
                Which version of DWC were you using previously?
                • Dougal1957undefined
                  Dougal1957 @k3lag
                  @k3lag I can't reproduce this in Safari 12.0 it appears just fine to me tho I normally use Chrome.
                  Doug
                  • zerspaner_gerdundefined
                    zerspaner_gerd @k3lag
                    I have that too (with Chrome).
                    It depends on the screen size, I noticed.
                    Here are two pictures see scroll bar
                    jump back (100%)
                    scrolling works (110%)
                    But I already had it with the previous version DWC 1.22.1
                    Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                    • k3lagundefined
                      k3lag
                      I was using 1.22 and never noticed a problem. I reverted back to 1.22.3 and it behaved the same as the .4b1. However, I figured out that it is related to 'scaling' the web page. If I use the buttons in my browser to either shrink or enlarge the page the problem occurs. It does not occur if it's not being scaled. It appears others have seen the same thing in other browsers. I don't have this problem with any other web pages that I've noticed.
                      • BlueDustundefined
                        BlueDust @Adrian52
                        @adrian52 I also see that the Print Again is missing, and it is super annoying. I keep testing the same parts after making small adjustments, pause, cancel, print again etc... And this got annoying the first time I printed after updating the firmware and web interface.
                        Fun, that 3 letter word with "u" in the middle.
                          I've seen an error message on the PanelDue console that hasn't shown up in the Gcode console.
                          Wifi reported error: incomplete write wifi reported error: incomplete write It shows up twice like that.
                          It happened once while trying to download a gcode file from the DWC. The download failed in the browser as well.
                          Then it happened again uploading a Gcode file. But the gcode file seems to have uploaded correctly.
                          When I saw the error message I checked the DWC console which was up and running but nothing was there.
                          I then ran a M122 to see the diagnostics and the DWC reloaded and the printer paused for a second mid print and then carried on. When the DWC reloaded I ran M122 again. This time it worked. But doesn't seem to show anything amiss. Nothing was logged to the PanelDue console.
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC3(RTOS) running on Duet WiFi 1.02 or later
                          Board ID: 08DDM-9FAM2-LW4SD-6JKF0-3SN6N-T2ZBY
                          Used output buffers: 1 of 20 (20 max)
                          Static ram: 28532
                          Dynamic ram: 98720 of which 12 recycled
                          Exception stack ram used: 512
                          Never used ram: 3296
                          Tasks: NETWORK(ready,328) HEAT(blocked,1184) MAIN(running,3484)
                          Owned mutexes:
                          Last reset 02:13:18 ago, cause: power up
                          Last software reset at 2018-10-15 13:21, reason: User, spinning module GCodes, available RAM 3480 bytes (slot 0)
                          Error status: 4
                          Free file entries: 9
                          MCU temperature: min 44.5, current 44.9, max 45.3
                          Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0
                          Driver 0: ok, SG min/max 0/1007
                          Driver 1: ok, SG min/max 0/254
                          Driver 2: standstill, SG min/max 0/222
                          Driver 3: ok, SG min/max 0/240
                          Date/time: 2018-10-21 16:43:25
                          Slowest loop: 4.63ms; fastest: 0.07ms
                          Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 150, MinFreeDm: 150, MaxWait: 0ms, Underruns: 0, 0
                          Scheduled moves: 191830, completed moves: 191800
                          Bed compensation in use: mesh
                          Heater 0 is on, I-accum = 0.2
                          Heater 1 is on, I-accum = 0.4
                          Segments left: 1
                          Stack records: 3 allocated, 0 in use
                          Movement lock held by null
                          http is idle in state(s) 0
                          telnet is idle in state(s) 0
                          file is doing "G1 X186.602 Y122.915 E0.08193" in state(s) 0
                          serial is idle in state(s) 0
                          aux is idle in state(s) 0
                          daemon is idle in state(s) 0
                          queue is idle in state(s) 0
                          Code queue is empty.
                          === Network ===
                          Slowest loop: 182.79ms; fastest: 0.08ms
                          HTTP sessions: 1 of 8
                          - WiFi -
                          Network state is running
                          WiFi firmware version 1.21
                          WiFi MAC address 5c:cf:7f:ef:4a:74
                          WiFi Vcc 3.31, reset reason Turned on by main processor
                          WiFi flash size 4194304, free heap 13216
                          WiFi IP address 10.10.0.63
                          WiFi signal strength -40dBm, reconnections 0, sleep mode modem
                          Socket states: 0 2 0 0 0 0 0 0
                          === Expansion ===
                          • Synapsisundefined
                            Synapsis
                            I have been using it without any real problem but a funny one.
                            While I was connected I had to turn my router off. When the router was back online the duet reconnected but the web interface would not connect again, even after a refresh of the page. I closed the browser and reopened it, but nothing it would not connect to the duet.
                            I had to turn the duet off then on and all was back to normal.
                            • timcurtis67undefined
                              timcurtis67
                              If you have a panel due try sending an M552 S1to restart the Wifi.
                              See https://duet3d.dozuki.com/Wiki/GCode#Section_M552_Set_IP_address_enable_disable_network_interface
                              • chrishammundefined
                                chrishamm administrators @Adrian52
                                @adrian52 Thanks for the note, I'll fix this shortly.
                                @k3lag I'm afraid I cannot reproduce this. I tried it on Firefox (Win+Linux), Edge and Safari (OS X) but it never scrolls up for me. Can you check if the toggling the option "Always show info area and menu" on the Settings makes a difference?
                                Edit: There you go - v1.22.4 is now official: https://github.com/chrishamm/DuetWebControl/releases/tag/1.22.4
                                Duet software engineer
                                k3lagundefined 1 Reply Last reply Reply Quote 0
                                • k3lagundefined
                                  k3lag @chrishamm
                                  I can't duplicate now either. It was consistent for a few days now suddenly it seems fine. I'll let you know if the problem returns and I'll pay attention to any change in circumstances that may cause it.
                                  • k3lagundefined
                                    k3lag @k3lag
                                    It just started doing it again and I noticed what's going on but I don't know why. My printers name on the network is "bigbox.local". If the URL in address bar is "bigbox.local" it does not exhibit the problem. Somehow the URL is changing to "bigbox.local." (notice the "." at the end) and when it is that way it scrolls back to the top after scrolling down. I'm not sure where the extra "." is coming from. If I manually put the "." on the end when it's working correctly the behavior will start as well. For some reason the extra "." is getting added to the end of URL on its own somehow.
                                    • BlueDustundefined
                                      BlueDust
                                      Z Baby Stepping doesn't seem to work any more.
                                      I just updated DWC to 1.22.4 to see if that would fix it, and it did not.
                                      Current version
                                      Firmware Electronics: Duet Ethernet 1.02 or later
                                      Firmware Version: 2.02RC3(RTOS) (2018-10-17b2)
                                      Web Interface Version: 1.22.4
                                      Is anyone else having this problem?
                                      garyd9undefined 1 Reply Last reply Reply Quote 0
                                      • garyd9undefined
                                        garyd9 @BlueDust
                                        @bluedust said in Firmware 2.02 Release candidate 3 now available:
                                        It seems to be working for me from both the 1.22.4 DWC (that was just put out today) and from the PanelDue 1.22 released a couple days ago. (It's annoying from the Paneldue due to the "response" popups, but it seems to work.)
                                        What symptoms are you seeing that suggest it's not working?
                                        BlueDustundefined 1 Reply Last reply Reply Quote 0
                                        • claustroundefined
                                          claustro
                                          M557 now supports a P parameter to set the number of X and Y points, as an alternative to using the S parameter to set the spacing
                                          So I can write M557 X30:260 Y15:245 P9
                                          Instead M557 X30:260 Y15:245 S57.5
                                          and the firrmware automatically calculate probe point spacing right?
                                          i
                                            dc42 administrators @claustro
                                            @claustro said in Firmware 2.02 Release candidate 3 now available:
                                            i
                                            Yes, that's correct.
                                            Googliolaundefined 1 Reply Last reply Reply Quote 0
