    Leveling the bed...
    4.1k
      Phaedrux Moderator @TLeTourneau
      @tletourneau said in Leveling the bed...:
      I am now getting random Z probe readings not consistent errors. I'm trying to figure that out now.
      The errors were already there (as shown in your height map) they are being reported now because of the M558 A5 S0.005 I had you add. A5 means it will try and probe up to 5 times until it gets two readings that are within 0.005 of the trigger height. If it can't get an agreed value it reports the error.
      So something is not right with your probe. Is it a genuine BLTouch or a clone? You can take the pin out by removing the set screw at the top of the probe. Check it for dirt or damage. Clean it with alcohol. reinstall it and try again.
      TLeTourneauundefined 1 Reply Last reply Reply Quote 0
      • TLeTourneauundefined
        TLeTourneau @Phaedrux
        @phaedrux It's a genuine Bltouch, I checked the SN on the website when I received it.
        https://www.amazon.com/gp/product/B07GVCX74T/ref=od_aui_detailpages00?ie=UTF8&psc=1
        I'll clean the pin and see if that helps.
        I want to thank everyone for the help, I really appreciate it.
        Thanks,
        Tom
        TronXY X5S-500 (CoerXY)
        Duet 2 Ethernet v1.04
        Firmware Version: 2.02(RTOS) (2018-12-24b1)
        Web Interface Version: 1.22.6
        7" PanelDue
        E3D V6 Clone
        MOSFET's for hot end
        1000w Keenovo with SSR for heat bed
        dc42 Mini IR Sensor or BLTouch
        • JoergS5undefined
          JoergS5 @TLeTourneau
          @tletourneau Instead of anti backlash screws you can try to loose one of the steppers, so it can self adjust and there is no tension between spindle - bed frame- spindle, but the stepper is not allowed to rotate. Analog to the idea of fixed bearing - loose bearing.
          The screw in front on the left seems to be bent, maybe from heating the bed, temperature expansion and this can lead to bed bending also.
          The best article I know how to design a heat bed is: https://drmrehorst.blogspot.com/2017/07/ultra-megamax-dominator-3d-printer-bed.html
            Have you actually tried a test print to see how flat the bed actually is?
            Something like this is a good way to test.
            0_1542493718946_bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
              @phaedrux not yet, I wanted to get a good bed compensation first but I'll try to do a print. I want to test the new hot end. 🙂
              I did order a borosilicate plate for it, would this work as an interface between the glass and the bed?
              https://www.amazon.com/gp/product/B06XG4QV1X/ref=crt_ewc_title_dp_2?ie=UTF8&psc=1&smid=A30U07HIVF5QFE
              Thanks,
              Tom
              7" PanelDue
              E3D V6 Clone
                The nice part about an actual print is that it takes the probe completely out of the equation and let's you visualize the bed surface without abstraction.
                If you use that STL I posted and tweak your slicer settings so that each line is made up of two extrusion lines you'll be able to tell easily where on the bed is too low or two high.
                • mikebridgeundefined
                  mikebridge
                  on my tronxy x5s with the same issue (appearing to 'arc up' in the middle of the bed when the bed should be showing a slight sag), it was overtightened screws for the smooth rods on either side of the Z motors, that was enough to pull the y axis 2020 into a sag in the middle.
                  edit: i should have read the entire thread before responding, seems you already addressed this and have moved on to another issue.
                  375x360x415 CoreXY DuetWifi + Duex5
                  24v 600w, E3D Chimera, Zesty Nimble CC, BLTouch, X&Y linear rails, dual Z motors
                    TLeTourneau @mikebridge
                    @mikebridge said in Leveling the bed...:
                    I appreciate the reply though! I've determined in the interim that my bed is warped and the most recent mesh map aligns with what my machinist level shows. As I don't necessarily want to replace the bed I have ordered a 330x330x3mm piece of borosilicate glass and a 500x500x0.5mm high temp silicone rubber sheet to put between the bed and the glass. Hopefully that will help with that part.
                    For the Z probe, I get the consistency errors when I have it set to a sensitivity of between 0.005mm and 0.011mm. It seems fine at 0.012mm. I have cleaned it as recommended with no change and have reached out to the vendor for assistance. Until then 0.012 will have to be sufficient. 🙂
                    I will be running the recommended test print shortly, I'm just trying to figure out how to set Simplify3D so that each line is made up of two extrusion lines.
                    Thanks,
                    Tom
                    7" PanelDue
                    E3D V6 Clone
                      TLeTourneau
                      Latest run with the sensitivity set to 0.013mm, it completed at that setting.
                      Thanks,
                      Tom
                      7" PanelDue
                      E3D V6 Clone
                        So I ran the STL and the bed is all over the place. Beyond the sensitivity issues I'm having with the BLTouch my bed is definitely... wavey... I'll see how the borosilicate sheet with the silicone interface works. Although I see the benefit of changing the build platform I want to try the glass first.
                        Thanks,
                        Tom
                        7" PanelDue
                        E3D V6 Clone
                          I'm not surprised it's wavy. I asked before, but maybe you missed it, have you tried only using 3 of the 6 bed fasteners? Is the bed plate stiff enough to allow for that? Those 6 bolts are torque the plate every which way. Only 3 points are needed to define a flat plane.
                          With the bolt pattern like this
                          1......2......3
                          4......5......6
                          I would remove bolts 2, 4, and 6. Then use bolt 1 to set the reference height of Z0 with the nozzle, and then adjust bolts 3 and 5 to meet the nozzle.
                          This may not be feasible if the plate flexes too much under its own weight, or if the plate itself is truly warped even when not under competing tension from the bolts.
                          You can verify the repeatability of your probe by redoing the G30 S-1 test several times, manually resetting the probe to just touch the bed and resetting Z0 between each attempt. 0.013 is a lot worse variability than you should be getting with the BLtouch obviously, but I'd still like to know what actual trigger height values you get. Is there any pattern or consistency to it at all? If not, then possibly a bunk probe or something else mechanical going on that's interfering.
                            @phaedrux said in Leveling the bed...:
                            1......2......3
                            4......5......6
                            I tried changing the screw layout but the bed had quit a bit of flex in it when I did that.
                            I have no problem running the G30 S-1 repeatedly but I am not certain how to reset Z0 between each attempt. For some reason my search abilities seem to be lacking today...
                            Also, although I am not certain, I think the Bltouch issue could be being influenced by a wiring issue, I noticed that when I moved some wires above my hot end the Bltouch went into an error state. I'm going to order some JST SM connectors to see if that helps. I've wanted to do quick connects on the hot end anyway so this may help.
                            Thanks again for all of your help!
                            Thanks,
                            Tom
                            7" PanelDue
                            E3D V6 Clone
                              @tletourneau to reset between the g30 s-1 you can move the nozzle down to touch the bed. If you can't get it low enough you can use G92 Z5 to trick the firmware ii bro thinking it's actually higher than it is, allowing you to move it down more. Then when it's just touching the bed, send G92 Z0 to tell the firmware you're at z0 and then do g30 s-1 again.
                                @phaedrux I don't know how but I think my bed may lift up a bit (.30) on a power cycle.
                                The process I used is: power on the machine, input the G92 X20 Y20 Z20 so I can leave the head in the same spot, set the bed to have a light drag on a piece of 20lb paper and run the G92 Z0 and then the G30 S-1. Once I do that it gives me the reading and puts the Bltouch in an error state that I can't seem to recover from regardless of the M280 I try (I've tried M280 P7 S160 and M280 H7 S160 to no avail, my sensor is on heater 7). So I take down the reading, set the Z to 0 (when I run the G30 S-1 it adds the value to Z) and move the bed down 5mm. I then power cycle input the G92 X20 Y20 Z20 and move Z -5 which should put the bed in the same position it was in previously however when I do that the paper no longer slips between the nozzle and bed. I have to lower the bed .3mm for the paper to slide between the nozzle and bed again. If I could get the Bltouch to reset it would be less of an issue but as it is I have doubt about the accuracy of the data set gathered. That being said, here are the iterations I got running the tests.
                                -.580
                                -.608
                                -.615
                                -.605
                                -.615
                                As mentioned given my inability to ensure that Z was physically the same distance from the bed for each iteration I am not certain of the value of the data.
                                I am open to any other suggestions regarding testing the sensor and ensuring that my bed is not somehow changing position on its own. I am starting to get a bit frustrated but I realized this is one of the pitfalls to an inexpensive DIY 3D printer.
                                Thanks,
                                Tom
                                7" PanelDue
                                E3D V6 Clone
                                  It wouldn't be unheard of for the bed to change shape during a heating cycle, but I don't know why it would change just from power up.
                                  Are you starting with a G31 Z0 value?
                                    G31 Z0
                                    I am fairly certain that I had set the Z offset to 0, I will verify the G31 entry when I get home from work. While I can not change the bed at this time I would like to see if I can at least stiffen the bed, perhaps using 1/2" or 1" aluminum angle stock along the beds perimeter. I did order anti-backlash nuts for the lead screws and have found an improved mount that is supposed to help with Z wobble on the Tronxy X5S. I may look at swapping out the linear flange bearings also, the ones that came with the printer are plastic and I am wondering if a higher quality bearing may help.
                                    Thanks,
                                    Tom
                                    7" PanelDue
                                    E3D V6 Clone
                                      Have you done any research on Tronxy specific places about how others have improved the bed situation?
                                        TLeTourneau
                                        Yes, I have found a bracket that people have said help with Z wobble that I will try to print out and install. There are a few other things that people have tried that they have indicated resolve the issue(s) with the Z axis on the X5S. I am planning on doing those methodically over the next few days so if I do resolve it I can post to perhaps help others that may have similar issues.
                                        Thanks,
                                        Tom
                                        7" PanelDue
                                        E3D V6 Clone
                                          TLeTourneau
                                          Just an update, I think I figured out my issue resetting the BLTouch. I was doing a M280 P7 S160 and I needed to do a M280 P7 S160 I1 because I am using the heater 7 connection without an expansion board connected. My readings are still odd, here is what I am doing: The process I used is: power on the machine, input the G92 X20 Y20 Z20 so I can leave the head in the same spot, set the bed to have a light drag on a piece of 20lb paper and run the G92 Z0 and then the G30 S-1. The G30 S-1 command seems to raise the bed at the end, should it? That might make it hard to achieve repeatable results.
                                          I've installed anti-backlash nuts on the bed and a 330x330x3mm borosilicate glass plate with an interface between the glass and the bed of a sheet of 0.5mm high temp silicone rubber.
                                          Here are the results:
                                          BLTouch on glass:
                                          -0.598
                                          -0.610
                                          -0.587
                                          -0.645
                                          -0.582
                                          BLTouch with blue painters tape on glass:
                                          -0.585
                                          -0.605
                                          -0.600
                                          -0.600
                                          -0.587
                                          -0.600
                                          I entered the following commands between each iteration:
                                          G92 Z0
                                          G30 S-1
                                          M280 P7 S160 I1
                                          Again, I noticed the bed raising after the probe took it's reading whenever the G30 S-1 was executed.
                                          I am including my config file in case that helps:
                                          ; generated by RepRapFirmware Configuration Tool v2 on Fri Nov 16 2018 15:16:22 GMT-0600 (Central Standard Time)
                                          G90                                                ; Send absolute coordinates...
                                          M83                                                ; ...but relative extruder moves
                                          M667 S1                                            ; Select CoreXY mode
                                          M550 P"Tronxy X5S"                                 ; Set machine name
                                          M552 P192.168.0.95 S1                              ; Enable network and set IP address
                                          M553 P255.255.255.0                                ; Set netmask
                                          M554 P192.168.0.1                                  ; Set gateway
                                          M586 P0 S1                                         ; Enable HTTP
                                          M586 P1 S0                                         ; Disable FTP
                                          M586 P2 S0                                         ; Disable Telnet
                                          M569 P0 S1                                         ; Drive 0 goes forwards
                                          M569 P1 S1                                         ; Drive 1 goes forwards
                                          M569 P2 S0                                         ; Drive 2 goes backwards
                                          M569 P3 S0                                         ; Drive 3 goes backwards
                                          M350 X16 Y16 Z16 E16 I1                            ; Configure microstepping with interpolation
                                          M92 X80.00 Y80.00 Z400.00 E98.00                   ; Set steps per mm
                                          M566 X600.00 Y600.00 Z12.00 E120.00                ; Set maximum instantaneous speed changes (mm/min)
                                          M203 X18000.00 Y18000.00 Z180.00 E1500.00          ; Set maximum speeds (mm/min)
                                          M201 X3000.00 Y3000.00 Z100.00 E10000.00           ; Set accelerations (mm/s^2)
                                          M906 X1100.00 Y1100.00 Z1100.00 E1100.00 I30       ; Set motor currents (mA) and motor idle factor in per cent
                                          M84 S30                                            ; Set idle timeout
                                          M208 X0 Y0 Z0 S1                                   ; Set axis minima
                                          M208 X330 Y330 Z400 S0                             ; Set axis maxima
                                          M574 X1 Y1 S0                                      ; Set active low endstops
                                          M574 Z1 S2                                         ; Set endstops controlled by probe
                                          M307 H7 A-1 C-1 D-1                                ; Disable heater on PWM channel for BLTouch
                                          M558 P9 H5 F100 T6000 A5 R0.3 S0.005 B1            ; Set Z probe type to bltouch and the dive height + speeds
                                          G31 P25 X-42 Y-4 Z0                                ; Set Z probe trigger value, offset and trigger height
                                          M557 X15:315 Y20:315 S20                           ; Define mesh grid
                                          M307 H0 B0 S1.00                                   ; Disable bang-bang mode for the bed heater and set PWM limit
                                          M305 P0 T100000 B4138 R4700                        ; Set thermistor + ADC parameters for heater 0
                                          M143 H0 S120                                       ; Set temperature limit for heater 0 to 120C
                                          M305 P1 T100000 B4138 R4700                        ; Set thermistor + ADC parameters for heater 1
                                          M143 H1 S280                                       ; Set temperature limit for heater 1 to 280C
                                          M106 P0 S0.3 I0 F500 H-1                           ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                          M106 P1 S1 I0 F500 H1 T45                          ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                          M106 P2 S1 I0 F500 H1 T45                          ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                          M563 P0 D0 H1                                      ; Define tool 0
                                          G10 P0 X0 Y0 Z0                                    ; Set tool 0 axis offsets
                                          G10 P0 R0 S0                                       ; Set initial tool 0 active and standby temperatures to 0C
                                          ; Automatic power saving
                                          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                                          ; Custom settings
                                          M591 D0 P1 C3 S0
                                          I'm going to run a mesh grid and see what I get, I've set the sensitivity back to 0.005.
                                          Thanks,
                                          Tom
                                          7" PanelDue
                                          E3D V6 Clone
                                            I don't suppose you could post a video showing the behaviour of the probe?
