    Duet Web Control 2.0.0-RC5
    Duet Web Control
    23
    87
    10.4k
    • gtj0undefined
      gtj0 @chrishamm
      @chrishamm said in Duet Web Control 2.0.0-RC4:
      @dragonn See the other thread
      @gtj0 Thanks for the note, I'll change that again
      Thanks!
      • SupraGuyundefined
        SupraGuy
        @chrishamm Any change related to the issue where the Z jog buttons could only be used once with a manual probe while doing a G30 action? (For me, this is the only issue that I'd identified with RC3.)
        Lead screw driven printer, powered by Duet 2 Wifi
        MPCNC powered by Duet 2 Wifi
        CoreXY printer driven by Duet 3 6HC
        LowRider CNC powered by Duet 2 Wifi
        chrishammundefined 1 Reply Last reply Reply Quote 1
        • chrishammundefined
          chrishamm administrators @SupraGuy
          @supraguy No it's still the same code. I tested the jog controls using a simple M291 message box before I released RC4 and it worked nicely there but I was not aware you were using a different kind of message box.
          I'll remove the spinners from all the move buttons in RC5 just to be sure.
          Duet software engineer
          • SupraGuyundefined
            SupraGuy
            @chrishamm Alas. Well, it didn't seem to pose a problem using the move axis buttons in the main control, only with the G30 probe, which has the unfortunate property of being where I might want to make several very small adjustments.
            Well, I'll update to RC4 anyway.
            • wilrikerundefined
              wilriker @chrishamm
              @chrishamm The issue did not appear when using a M291 directly but only if the jog button dialog appears as part of the Z sensor being configured as "none" and movement was required, i.e. for all bed compensation or Z height measuring methods.
              Manuel
              My Tool Collection
              • garyd9undefined
                garyd9 @chrishamm
                @chrishamm Thank you. Your hard work and careful attention to the needs (and whims) of users is sincerely appreciated.
                • samlogan87undefined
                  samlogan87
                  @chrishamm I just installed the latest Web Control. I really like it. It has a nice layout.
                  One thing I noticed however is when you are running a Macro and it is showing the loading Icon, the size of it seems to be slightly larger than the box around the macro that is running. Not sure if that is meant to happen, but I personally don't think it looks quite right.
                  Other than that i haven't seen anything yet.
                  Kind Regards,
                  Sam
                  Custom Core-XY
                  • pkosundefined
                    pkos
                    This is awesome. I absolutely love it. Thank you very much for your amazing work!
                    One question (tiny). Do you plan on maybe giving us either an option to easily change font colors?
                    I have a slight problems with colors it seems, because the dark theme makes a lot of text almost invisible to me - especially in gcode file selector and like here, for example with fans.
                    The blue fades too much into gray for me and I can't see what's written.
                    Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
                      samlogan87
                      Sorry another thing, I have the print running at the moment. On my laptop which I sent the g code file through on, the active bed and nozzle temp are showing. When I access it via my phone, it says the active temp is zero not what it is actually running. It seems that it is not pulling that data through. It also says in a pop up that it cannot maintain a connection with the printer even though the position values are changing and you can see the temp moving ever so slightly as the pid control is working.
                      Custom Core-XY
                      • pkosundefined
                        pkos
                        So yeah, I have to get back to this too sadly.
                        Every layer change, I get:
                        Failed to maintain connection to printer.local
                        Cannot set property 'firstLayerHeight' of undefined
                        My guess is this is attached to the problem with Slic3r PE 1.42.0 new way of storing metadata about the print that the newest Duet firmware doesn't always support yet.
                        I guess that because of this error also, I don't get any visibility into layer progression on the charts.
                        Going back to the old firmware immediately fixes that and while I still don't get information about which layer the printer is on - at least I can see progression on the chart.
                        deckingmanundefined anraf1001undefined 2 Replies Last reply Reply Quote 0
                          deckingman @pkos
                          @pkos Unfortunately, Prusa version of Slic3R is becoming more and more biased towards it being used with Prusa firmware and every release sees this integration becoming tighter and tighter.
                          So should we expect RepRap firmware to be changed to support a specific slicer? To my mind, the slicer should be firmware agnostic but Prusa Slic3R has started doing things differently.
                          dc42undefined Martin1454undefined ctilley79undefined 3 Replies Last reply Reply Quote 0
                            dc42 administrators @deckingman
                            @deckingman said in Duet Web Control 2.0.0-RC4:
                            True; but:
                            is a bug. RRF/DWC should not error out if the information wasn't found in the GCode file.
                            • Martin1454undefined
                              Martin1454 @deckingman
                              God dammit.... Changed from S3D to Slic3r PE due to S3D being to slow on devlopment, and now I might have to go to Cura? -.- Well, might be worth to try it with the new GUI.
                              • pkosundefined
                                pkos
                                I'm kinda looking forward to Pathio being the next big thing (way too feature starved at this point, but love the concept), or maybe, if S3D 5.0 is amazing - stick with that. I can't stand Cura 🙂
                                I chose Slic3r PE for my prints right now to get the strongest possible parts for a new HEVO, while not rattling the printer to bits with honeycomb. Gyroid is way easier on the printer.
                                  Thanks for your feedback so far.
                                  @samlogan87 Are you using any kind of scaling in your browser? It looks good to me on both Windows and Linux at 100%
                                  @pkos I'll expand theming support in the future but for now it is limited to internal changes. Would it help to make the links in the file lists look like the other cells (e.g. black in the normal theme and white in the dark theme)? Perhaps I could change the font colors of the fan selectors to white in the dark theme too.
                                  Thanks for reporting the disconnect problem, I'll release another RC shortly which is going to fix it.
                                  @deckingman As long as Slic3r PE generates proper G-code I see no reason why it would become incompatible to RRF.
                                  pkosundefined samlogan87undefined 2 Replies Last reply Reply Quote 0
                                  • pkosundefined
                                    pkos @chrishamm
                                    @chrishamm I like the idea of the blue to set it aside from regular text.
                                    I am wondering if maybe making it a way lighter blue - so the contrast between the text and the background is bigger - would help blind people like your's truly 🙂
                                    • mudcruzrundefined
                                      mudcruzr
                                      I see the same error:
                                      And I'm using Cura (3.6.0)
                                        deckingman @Martin1454
                                        @martin1454 said in Duet Web Control 2.0.0-RC4:
                                        I use the latest dev build of Slic3R (non Prusa) https://dl.slic3r.org/dev/
                                        It seems to be more actively developed than it used to be.
                                        I've just downloaded the latest version although I haven't yet had time to play with it. My other version of 1.3.1 dev was dated June. This one is dated 10th Feb this year. New things I've noticed at first glance are:
                                        "Use adaptive slicing" - automatically determine layer heights by the object topology instead of using a static value.
                                        "Match horizontal surfaces"
                                        "Minimum shell thickness" - Alternative method of configuring perimeters - additional perimeters and/or solid top bottom layers as necessary.
                                        "Fill gaps"
                                        A huge number of new options for generating support material.
                                        Print server upload - can be set to Octoprint or Duet.
                                        Also tick boxes for:
                                        "Use set and Wait Gcode extruder" and "Use set and wait Gcode bed"
                                        And it doesn't override configured acceleration settings and so forth, the way that PE does. And multi colour/material printing is still more "generic" rather than being biased towards using a Prusa style MMU.
                                        For my particular usage case, non PE Slic3R is still by far the best slicer (but I do use mixing hot ends).
                                        • fmaundefined
                                          fma
                                          Mmm, I will give a try to Slic3r non-PE...
                                          About slicer and firmware, it becomes hard to define where the first should end, and where second should start. A lot of ideas for improvement need that both evolve together (for example, canceling an objet when printing multiple objects at the same time). In another topic, Ian said he defines temperatures on firmware side, while another guy prefers defining them in the slicer... There are more and more overlapping features.
                                          As E3D adopted Duet boards for their tool changer machine, and as they started to develop a slicer themselves, it may be a nice opportunity to have coherent devs between slicer and firmware 🙂
                                          Frédéric
                                          • DaveAundefined
                                            DaveA
                                            Just want to confirm the "cannot set property "first layerheight of undefined'" and disconnect issue. This is a file sliced with the latest S3D version 4.1.1.
