    Core-XY based on Rat Rig V-Core and Duet 2 Ethernet
    My Duet controlled machine
    15
    176
    27.6k
    • snoozerundefined
      snoozer @deckingman
      @deckingman I try to avoid the need of support from above if I can. The idea is that I can have a full acrylic made hood on top without any further obstructions to keep the heat in but easy access if needed. Sure If I find no other way I can also make a support frame on top. Re wiring, I am nowhere near to a final setup yet but I have added a spare 4 core cable with Dupont connectors just in case, so I don't have to rip it apart for everything I like to test.
      Are you actually using shielded cable on your machine ? Just wondering if you had issues with noise from the stepper motors and probes etc ? The cables that came with the motors are non shielded which I actually don't like so much.
      Jan
      Regards Jan
      My Printers:
      #1 Prusa i3 MK3 kit all stock (Retired)
      #2 Rat Rig V-Core Core-XY (Almost finished but fully usable)
      My Experiments:
      https://www.thingiverse.com/snoozer17/designs
        deckingman @snoozer
        @snoozer said in Core-XY based on Rat Rig V-Core and Duet 2 Ethernet:
        No and No - (with a couple of caveats). I twist the motor wires but they are unshielded. I'm not sure of the source but I used to get a noisy signal when I used a PT100 on my bed. Not much but enough that the temperature reading had about +_ 0.5 degree "oscillation" in the signal. However, this happened regardless of whether the motors were moving or not so I doubt that the motors were the cause. Changing the PT100 to a simple thermistor fixed the problem.
        • snoozerundefined
          snoozer
          On my ToDo list I now have:
          This WE
          • Macro for Z-Max
          • Part cooling
          • PSU Mount
          • Temporary fix bad spring steel surface
          Following Weeks
          • Piezo Probe
          • Wiring harness support
          • Tooling Plate Alu Bed
          • 230V AC Heater with Solid State Relay
          • Bed heater insulation (thermal)
          • Push buttons to call macros (Fast to Z-Max, Home XY, Home Z, Load and unload filament, E-Stop
          Regards Jan
          My Printers:
          My Experiments:
          Scachiundefined 1 Reply Last reply Reply Quote 0
          • Scachiundefined
            Scachi @snoozer
            @snoozer I am currently building a rat rig V-Core too , did you flip your belts somewhere to run on the smooth belt side on the idlers ? Looks like there isn't enough space to twist them anywhere.
            snoozerundefined 2 Replies Last reply Reply Quote 0
            • snoozerundefined
              snoozer @Scachi
              @scachi
              no I have not flipped them over anywhere, the smooth side is not running on the idlers everywhere, just on the inner idlers on the X gantry.
              Regards
              Jan
              Regards Jan
              My Printers:
              My Experiments:
              • snoozerundefined
                snoozer
                Here a couple more links to Thingiverse with my bed spring mount and the strain relieve for the bed heater wires (Fusion 360 links included).
                https://www.thingiverse.com/thing:3636671
                https://www.thingiverse.com/thing:3636679
                Also a box for the PSU I use till I have my mains AC bed heater.
                https://a360.co/2VL0WOC
                Consider these quick and dirty designs, I am all about functional, not "nice looking".
                Have FuN!
                Jan
                Regards Jan
                My Printers:
                My Experiments:
                • snoozerundefined
                  snoozer @Scachi
                  @scachi I have read that people dislike running the teeth on plain idler. I can imagine on a very small diameter idler that could be an issue but the idlers in the V-Core are pretty big actually. Once I get printing I shall be on the lookout for issues I guess.
                  Jan
                  Regards Jan
                  My Printers:
                  My Experiments:
                  • Scachiundefined
                    Scachi @snoozer
                    @snoozer
                    Yes, I guess it would be fine. I finished building the printer today. Runs smooth during a short test without printing. I am waiting for some 24v parts to arrive before I can start printing/the real fun.
                    snoozerundefined 1 Reply Last reply Reply Quote 0
                    • snoozerundefined
                      snoozer @Scachi
                      @scachi what is your plan regarding the print surface and bed ? Will you use the aluminium plate that came with it ? Wil you use a z-probe and if yes what kind ?
                      Jan
                      Regards Jan
                      My Printers:
                      My Experiments:
                      • Scachiundefined
                        Scachi @snoozer
                        @snoozer Thank you for sharing your models, I will print your "Bed Heater Strain Relieve" as a real print test then.
                        I have a thick and heavy (2kg) aluminium bed from my old printer that I am using now on this one. It has a magnetic sheet / switch plate system attached. I use some thin sheet of gfk as a print surface. Worked fine on my old printer.
                        For the Z probe I am using some more parts from my old printer, a precision piezo (screw mount version), my x carriage:
                        https://www.thingiverse.com/thing:3637202
                        • snoozerundefined
                          snoozer
                          I have the temporary PSU mounted to the frame now. It is actually not bad so far, the fan is temp controlled and even with the bed heating for hours it only gets hand warm and the fan is pretty quiet.
                          The macro is also done now to move all axis out of the way quick for easy access to the print bed. Using a Z max endstop for that.
                          Here is the content of my macro
                          ; Move-Clear.g
                          ; Move axis out of the way to get maximum possible room for access to print
                          M574 Z2 S1          ; Set active high endstops at the HIGH end of X
                          G91                 ; Relative positioning
                          G1 S1 Z+320 F2000   ; Move bed down until the endstop is triggered (1st pass)
                          G1 Z-3 F2000        ; go back a few mm
                          G1 X250 Y270 F30000 ; Move the hotend out of the way but leave Z-probe above bed
                          G1 S1 Z+20 F100     ; move bed down until the endstop is triggered (2nd pass)
                          G92 Z305            ; set Z position to axis maximum
                          M574 Z1 S2          ; Set endstops controlled by probe
                          G90                 ; absolute positioning
                          I am not clear how I can show code here in this forum as fixed width text.......
                          Thanks @phaedrux, fixed that now.
                          Jan
                          Regards Jan
                          My Printers:
                          My Experiments:
                            Phaedrux Moderator @snoozer
                            https://commonmark.org/help/
                            • snoozerundefined
                              snoozer @Phaedrux
                              @phaedrux Thanks for that !!!
                              Regards Jan
                              My Printers:
                              My Experiments:
                              • snoozerundefined
                                snoozer
                                This cheap sh** spring steel bed is killing me. Its warped and so flimsy that it wont lay flat. The magnets I have are not strong enough to hold it down through the aluminium bed. I was impressed with the trigger height difference, never thought it made such a difference. The aluminium bed alone was 0.38 mm with the steel sheet its 1.78 mm.
                                Jan
                                Regards Jan
                                My Printers:
                                My Experiments:
                                • Scachiundefined
                                  Scachi @snoozer
                                  @snoozer
                                  Your springs mounted to adjust the bed will cause it to bend too as it isn't located at a good position. The screw should better be inside of the spring I think.
                                  My aluminium bed is 8mm thick
                                  • snoozerundefined
                                    snoozer @Scachi
                                    @scachi, this is a temp setup only. The springs cause minimal deflection, its the spring steel sheet having issues. The proper bed I get will be somewhere between 6-8mm and the bolts will pass through the springs then on a 3-point mount. Once my piezo probe has arrived I will try glass and also keep looking for a PEI coated proper spring steel sheet.
                                    PS: Just tried printing now....... I am not getting anywhere with this sheet. I'd say I repurpose that as spatula or what ever...... I check if I can somehow use the Prusa sheet, that's at least in shape.
                                    Regards Jan
                                    My Printers:
                                    My Experiments:
                                    • snoozerundefined
                                      snoozer
                                      Got my VERY first layers down now. Took me some time to finally acknowledge the the low cost Spring Steel Sheet was a waste of money. Its way to thin and wont lay flat at all. So I have used the PEI surface from the Prusa and clamped it down in a crude way.
                                      I now have a trigger height of 2.12 mm. I was surprised by that. Here is how I figured that out.
                                      I heated the bed to 65 degree.
                                      M564 S0 ;Disable limits
                                      Then I jogged the bed to just clamp a piece of paper under the nozzle
                                      G92 Z0 ;Set Z=0
                                      G1 Z10 ;Move Z away a bit
                                      G30 S-1 ;Lower Z till probe triggers
                                      The Z reading I would use in the config.g, homex.g and homeall.g as trigger height. Then I ran Auto Bed Compensation and the print after.
                                      Here a short clip of the machine printing:
                                      https://youtu.be/5rnSY7tANSQ
                                      And here the result without ANY tuning done at all, just as it came out 1st time.
                                      I have to look into another matter now with an Ethernet Switch, done what I wanted to do for today. I am looking into fine tuning tomorrow and also figure out a part cooling fan mount.
                                      Jan
                                      Regards Jan
                                      My Printers:
                                      My Experiments:
                                      • snoozerundefined
                                        snoozer
                                        I have tried for a number of hours now to get it level as much as I can. The curve in the middle is just a combination of the Prusa sheet and the non presence of magnets I suppose.
                                        The auto compensation works real well, the 1st layers now look better and better. Still have no part fan, only had 12V fans around and apparently a buck converter is a bad idea on the PWM output. Have a couple of 24V on order now.
                                        I am well happy so far how this turned out. Really well made Kit the V-Core and Duet 2 is a delight so far.
                                        Jan
                                        Regards Jan
                                        My Printers:
                                        My Experiments:
                                          The buck converter supplied a 12v input to the vfan pin which powers the fans. The duet switches PWM on the negative side.
                                          • snoozerundefined
                                            snoozer
                                            To late now, I have 24V fans ordered now from Radionics, they will arrive at work before I am back home here on Thursday. Cant do anything till then anyway, at work for the duration. But thanks for the tip, much appreciated.
                                            Jan
                                            Regards Jan
                                            My Printers:
                                            My Experiments:
