    Core-XY based on Rat Rig V-Core and Duet 2 Ethernet
    My Duet controlled machine
    15
    176
    27.0k
    • Scachiundefined
      Scachi @snoozer
      @snoozer I am currently building a rat rig V-Core too , did you flip your belts somewhere to run on the smooth belt side on the idlers ? Looks like there isn't enough space to twist them anywhere.
      snoozerundefined 2 Replies Last reply Reply Quote 0
      • snoozerundefined
        snoozer @Scachi
        @scachi
        no I have not flipped them over anywhere, the smooth side is not running on the idlers everywhere, just on the inner idlers on the X gantry.
        Regards
        Jan
        Regards Jan
        My Printers:
        #1 Prusa i3 MK3 kit all stock (Retired)
        #2 Rat Rig V-Core Core-XY (Almost finished but fully usable)
        My Experiments:
        https://www.thingiverse.com/snoozer17/designs
        • snoozerundefined
          snoozer
          Here a couple more links to Thingiverse with my bed spring mount and the strain relieve for the bed heater wires (Fusion 360 links included).
          https://www.thingiverse.com/thing:3636671
          https://www.thingiverse.com/thing:3636679
          Also a box for the PSU I use till I have my mains AC bed heater.
          https://a360.co/2VL0WOC
          Consider these quick and dirty designs, I am all about functional, not "nice looking".
          Have FuN!
          Jan
          Regards Jan
          My Printers:
          My Experiments:
          • snoozerundefined
            snoozer @Scachi
            @scachi I have read that people dislike running the teeth on plain idler. I can imagine on a very small diameter idler that could be an issue but the idlers in the V-Core are pretty big actually. Once I get printing I shall be on the lookout for issues I guess.
            Jan
            Regards Jan
            My Printers:
            My Experiments:
            Scachiundefined 1 Reply Last reply Reply Quote 0
            • Scachiundefined
              Scachi @snoozer
              @snoozer
              Yes, I guess it would be fine. I finished building the printer today. Runs smooth during a short test without printing. I am waiting for some 24v parts to arrive before I can start printing/the real fun.
              snoozerundefined 1 Reply Last reply Reply Quote 0
              • snoozerundefined
                snoozer @Scachi
                @scachi what is your plan regarding the print surface and bed ? Will you use the aluminium plate that came with it ? Wil you use a z-probe and if yes what kind ?
                Jan
                Regards Jan
                My Printers:
                My Experiments:
                • Scachiundefined
                  Scachi @snoozer
                  @snoozer Thank you for sharing your models, I will print your "Bed Heater Strain Relieve" as a real print test then.
                  I have a thick and heavy (2kg) aluminium bed from my old printer that I am using now on this one. It has a magnetic sheet / switch plate system attached. I use some thin sheet of gfk as a print surface. Worked fine on my old printer.
                  For the Z probe I am using some more parts from my old printer, a precision piezo (screw mount version), my x carriage:
                  https://www.thingiverse.com/thing:3637202
                  • snoozerundefined
                    snoozer
                    I have the temporary PSU mounted to the frame now. It is actually not bad so far, the fan is temp controlled and even with the bed heating for hours it only gets hand warm and the fan is pretty quiet.
                    The macro is also done now to move all axis out of the way quick for easy access to the print bed. Using a Z max endstop for that.
                    Here is the content of my macro
                    ; Move-Clear.g
                    ; Move axis out of the way to get maximum possible room for access to print
                    M574 Z2 S1          ; Set active high endstops at the HIGH end of X
                    G91                 ; Relative positioning
                    G1 S1 Z+320 F2000   ; Move bed down until the endstop is triggered (1st pass)
                    G1 Z-3 F2000        ; go back a few mm
                    G1 X250 Y270 F30000 ; Move the hotend out of the way but leave Z-probe above bed
                    G1 S1 Z+20 F100     ; move bed down until the endstop is triggered (2nd pass)
                    G92 Z305            ; set Z position to axis maximum
                    M574 Z1 S2          ; Set endstops controlled by probe
                    G90                 ; absolute positioning
                    I am not clear how I can show code here in this forum as fixed width text.......
                    Thanks @phaedrux, fixed that now.
                    Jan
                    Regards Jan
                    My Printers:
                    My Experiments:
                      Phaedrux Moderator @snoozer
                      @snoozer said in Core-XY based on Rat Rig V-Core and Duet 2 Ethernet:
                      https://commonmark.org/help/
                      • snoozerundefined
                        snoozer @Phaedrux
                        @phaedrux Thanks for that !!!
                        Regards Jan
                        My Printers:
                        My Experiments:
                        • snoozerundefined
                          snoozer
                          This cheap sh** spring steel bed is killing me. Its warped and so flimsy that it wont lay flat. The magnets I have are not strong enough to hold it down through the aluminium bed. I was impressed with the trigger height difference, never thought it made such a difference. The aluminium bed alone was 0.38 mm with the steel sheet its 1.78 mm.
                          Jan
                          Regards Jan
                          My Printers:
                          My Experiments:
                          • Scachiundefined
                            Scachi @snoozer
                            @snoozer
                            Your springs mounted to adjust the bed will cause it to bend too as it isn't located at a good position. The screw should better be inside of the spring I think.
                            My aluminium bed is 8mm thick
                            • snoozerundefined
                              snoozer @Scachi
                              @scachi, this is a temp setup only. The springs cause minimal deflection, its the spring steel sheet having issues. The proper bed I get will be somewhere between 6-8mm and the bolts will pass through the springs then on a 3-point mount. Once my piezo probe has arrived I will try glass and also keep looking for a PEI coated proper spring steel sheet.
                              PS: Just tried printing now....... I am not getting anywhere with this sheet. I'd say I repurpose that as spatula or what ever...... I check if I can somehow use the Prusa sheet, that's at least in shape.
                              Regards Jan
                              My Printers:
                              My Experiments:
                              • snoozerundefined
                                snoozer
                                Got my VERY first layers down now. Took me some time to finally acknowledge the the low cost Spring Steel Sheet was a waste of money. Its way to thin and wont lay flat at all. So I have used the PEI surface from the Prusa and clamped it down in a crude way.
                                I now have a trigger height of 2.12 mm. I was surprised by that. Here is how I figured that out.
                                I heated the bed to 65 degree.
                                M564 S0 ;Disable limits
                                Then I jogged the bed to just clamp a piece of paper under the nozzle
                                G92 Z0 ;Set Z=0
                                G1 Z10 ;Move Z away a bit
                                G30 S-1 ;Lower Z till probe triggers
                                The Z reading I would use in the config.g, homex.g and homeall.g as trigger height. Then I ran Auto Bed Compensation and the print after.
                                Here a short clip of the machine printing:
                                https://youtu.be/5rnSY7tANSQ
                                And here the result without ANY tuning done at all, just as it came out 1st time.
                                I have to look into another matter now with an Ethernet Switch, done what I wanted to do for today. I am looking into fine tuning tomorrow and also figure out a part cooling fan mount.
                                Jan
                                Regards Jan
                                My Printers:
                                My Experiments:
                                • snoozerundefined
                                  snoozer
                                  I have tried for a number of hours now to get it level as much as I can. The curve in the middle is just a combination of the Prusa sheet and the non presence of magnets I suppose.
                                  The auto compensation works real well, the 1st layers now look better and better. Still have no part fan, only had 12V fans around and apparently a buck converter is a bad idea on the PWM output. Have a couple of 24V on order now.
                                  I am well happy so far how this turned out. Really well made Kit the V-Core and Duet 2 is a delight so far.
                                  Jan
                                  Regards Jan
                                  My Printers:
                                  My Experiments:
                                    The buck converter supplied a 12v input to the vfan pin which powers the fans. The duet switches PWM on the negative side.
                                    • snoozerundefined
                                      snoozer
                                      To late now, I have 24V fans ordered now from Radionics, they will arrive at work before I am back home here on Thursday. Cant do anything till then anyway, at work for the duration. But thanks for the tip, much appreciated.
                                      Jan
                                      Regards Jan
                                      My Printers:
                                      My Experiments:
                                      • snoozerundefined
                                        snoozer
                                        @deckingman, I ask you cause you seem to have a lot of knowledge when it comes to practical mechanical engineering. I am still not all that clear how I go about fixing glass and flex plate surfaces to a aluminium print bed. I have settled for 340x340 in size but thickness I am not yet clear. Given is a rather large bed I would almost think 15mm but is that realistic to get heated ? For a glass plate I think I would have 4 holes on the sides with knurled M6 or M5 bolts to clamp down an aluminium angle to hold it down. For spring steel I was thinking to make a pattern of holes, example a 5.5mm hole and a M3 thread in the center to have round countersunk magnets bolted to the plate BUT flush with the surface or even 0.5mm below. Do you think the stainless M3 bolts for the magnets and the magnets as such would cause warping of the aluminium plate when heated due to different expansion of aluminium and stainless bolts ? Would the hole pattern itself cause significant warping when heating ?
                                        Its a lot f questions, but given the price and work involved I'd rather get this right the 1st time. I am even thinking of sending a CAD file to a factory, Weerg for example can make such a plate for approx 450 Eur including all the magnet pattern (25 holes and center holes with M3 thread etc.).
                                        Jan
                                        Regards Jan
                                        My Printers:
                                        My Experiments:
                                          deckingman @snoozer
                                          @snoozer My preference is to have removable build surfaces. Mostly because it allows me to slide one out as soon as a print is finished, then slide another one in so that I can start printing again without waiting for the bed to cool down and heat right up again. For my 400mm x 400mm bed I use 10mm thick aluminium tooling plate but in hind site, 8mm thick would have been sufficient and would warm up faster. On top of that, I use 6mm float glass (un-toughened). I choose glass because it's flat (as long as you don't get it toughened) and relatively cheap. 6mm thick is surprisingly difficult to break. I use 3D lac on the glass because it "just works". I can lay the first layer down at normal print speed - generally 90mm/sec but have managed 300mm/sec and I've never seen anyone lay a first layer down at anything like that speed using any other print surface. Oh and it allows me to print things like this on end https://www.youtube.com/watch?v=vG1WqijJ634&t=63s
                                          To hold the glass in place, I use a couple of thumb bolts with washers that screw into Tee nuts in the bed frame. Then I use some aluminium angle from front to back, with a couple of vertical slots that line up with the thumb bolts. I cut the aluminium angle down along it's length to form just a small lip where it holds the glass. I just press down on the aluminium angle and tighten the thumb bolts to hold the glass in place. To release the glass, I simply slacken the bolts an slide it out forwards. Here is a picture of the side view (without glass). The aluminium build plate was painted matt black because I used to have an IR probe (but hat doesn't play nicely with 3D Lac).
                                          I have no experience of using sprint steel (have no need of it), so can't comment on how best to fix it.
                                          HTH
                                            A Former User
                                            I'm doing the same on a smaller scale 150x150mm; but magnets seems to be stuck in customs so can't say much about how it'll work.
                                            Since aluminium spread the heat quite well I had enough space between my heating traces to embed 3x3 grid of 6x20 pockets from the underside and still have a perfectly uniform temperature on top (measured with thermal camera and masking tape)
                                            For the glass I'm hoping to use magnets as well, use diamond annular cutters or hole saws to make a series of overlapping cuts to make up a shallow pocket to embed something for the magnets to attract to. Waiting to try out the steel first before I start messing with the glass
                                            Havent decided on registration yet, pins, edge, just the magnets, idk,
