    Alternatives to E3D V6?
    36
    3.9k
    • DocTruckerundefined
      DocTrucker @oliof
      @oliof said in Alternatives to E3D V6?:
      You can also look at MicroSwiss hotends. Creality uses a clone on (most of) their printers, and I am printing quite successfully with that.
      Processed material, temp, and rough flowrate either average or peak?
      I should have been a little more specific. I am using PLA and PETG at the moment but looking to move into PA and PC as my machines improve. Therefore process temps of 300-350 are likely to be needed.
      • oliofundefined
        oliof
        In that case the Merlin hotend is right out. MicroSwiss has a fullmetal variant plus plated nozzles for different material, but I've only looked into that passingly as I am far off printing PA or PC.
        • Dougal1957undefined
          Dougal1957 @DocTrucker
          @doctrucker said in Alternatives to E3D V6?:
          @dougal1957 Yeah, a brief search has shown me E3D are not at the expensive end of the specrum for companies designing and selling hotends.
          Subject title suitably adjusted! I may just have to delay introducing the other hotend for a while longer! 😄
          Yeah I know what you mean I am thinking of getting one as well but it would have to be the Mosquito Magnum version which in the UK is £185 bare on top of that you need a High spec 50W heater cartridge A Temp sensor to handle the high temps and a suitable nozzle
          So if you say 12 for a PT100 25 or so for a Nozzle X 30 wish for a heater cartridge and an amount for the fan I reckon I would pretty soon be in the 250-300 range for a hotted (and that is using non Mosquito parts for some of it as well) but at least they use the std ish sort of V6 nozzles. 713Maker at least does a conversion unit to convert it to a screw mount to suit the Smart Effector.
          The minimum for a nozzle IMHO would be either the slice engineering coated one or the E3D V6 nozzle-X
          Doug
          • tech-ratonundefined
            tech-raton
            There is also the all in one. French made...
            https://www.hotends.fr/fr/home/50-hotend-all-in-one-evo.html
            • dasquiddiundefined
              dasquiddi
              There's one i have seen a review of a hotend that is considered for high end Plastics
              Review from C.R.T -> https://www.youtube.com/watch?v=3Agbt8etzPM
              Website -> https://dyzedesign.com/
                There's the original jhead folks: https://hotends.com/
                The newer designs look fantastic from what I saw at MRRF.
                • JamesMundefined
                  JamesM
                  Here's another one that is high temp capable to throw in the mix...direct drive though
                  https://micron-eme.com/products/high-temperature-cobra-1-75mm-extruder-up-to-400-degrees-c
                    Phaedrux Moderator @JamesM
                    @jamesm said in Alternatives to E3D V6?:
                    $500USD?!
                    • mrehorstdmdundefined
                      mrehorstdmd
                      I've been using this XCR3D hot-end for about a year and it has been working great. The cheap fan that came with it didn't last at 50C enclosure temperature (replaced with Sunon fan), but unlike the E3D V6, the fan mounts on an aluminum bracket screwed to the heatsink. It doesn't rotate, and can't come into contact with the heater block and melt like the E3D fan mount usually does. The heatbreak is held in place with a set screw, not threading into the heatsink, so it never comes loose during printing like the E3D v6 heatbreak did to me on several occasions.
                      I wrote a more detailed review here.
                        DocTrucker @mrehorstdmd
                        @mrehorstdmd said in Alternatives to E3D V6?:
                        I recently had some issues with dimensionsl errors on their drawings of their hotend assembly and requested they update thrir notes too:
                        I'd advise an update on the notes too.
                        Exisiting:
                        NOTE: THE BLOCK CAN BE MOUNTED EITHER WAY ROUND.
                        NOTE: THE DUCT CAN BE MOUNTED EITHER WAY UP.
                        Add:
                        NOTE: DO NOT POINT NOZZLE BLOCK TOWARDS THE FAN SHROUD WHEN THE FAN HOLDER IS OFFSET DOWN.
                        They must've been aware of the issue, I've had second hand genuine units that have obviously been toasted by being assembled with the shroud too close to the block.
                          DocTrucker
                          Thanks for all the suggestions so far. I'll record them all!
                            DocTrucker @Phaedrux
                            @phaedrux I was having issues getting onto their website yesterday, but all seems fine today. Odd.
                              mrehorstdmd
                              In simple finger tests, I find that the two bottom fins of the E3D heatsink seem to be dissipating all the heat and the rest never really get warm (at least at block temperature of 240C). I suspect the entire upper half of the heatsink is there mainly to allow room for the fan to be mounted. I never got a chance to take a picture of it with a thermal camera.
                              Even if you position it properly, the E3D fan mount doesn't usually stay there long. It can rotate even from the small pull of the fan wires or when bumped when you remove prints from the bed.
                              I'm not a fan of the mounting system that seems to have become standard. The round barrel has no anti rotation features and in the Titan extruder it can rotate relatively easily, The Bondtech BMG extruder seems to clamp it tightly enough to prevent rotation. Why anyone would design something like this without at least one flat face to prevent rotation I'll never understand. It reminds me of using 4 screws to level print beds - an early design mistake that is still being propagated.
                              DocTruckerundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                              • bricorundefined
                                bricor
                                For the price, quality and options E3D is hard to beat. Its not a sales pitch, I tried to move away from E3D, long story for another day.
                                Originally I felt the pricing was high considering all the knock offs. Well I learned there is a huge difference with E3D quality and it justifys the price.
                                There is consistancy in the product, making troubleshooting easier and reducing failures. (unless you forget to plug in the hotend fan, lesson learned)
                                Plus resolving any issue is straightfoward, sometimes a pain but routine over time.
                                When outfitted with a copper block, nozzle x and PT100 it is quite a robust workhorse with few limitations. Pricing is still near half any other option that seems comparible. I’d really like to try another solution but can’t justify the cost difference. Id rather purxhase anoher DUET Wifi with a hotend at that cost. That I can justify (if I had the dough thai is).
                                As mentioned above the clip on fan isnt the best solution. I found that integrating the shroud for the heatsink with the mount yeilds better results. Also, there should be no issues with the heatsink spinning in the mount, even when using printed mounts. That too needs to be adressed in the mount design.
                                  @mrehorstdmd yes, you would have thought flats would be the intuative solution to the problem. E3Ds fix has been to move to a screw in mount. Fine for mounting in machined or precision moulded parts but a further step away from working well with printed hotend mounts.
                                  Regarding the groove mount I'm not sure where it originated. It seems to be an informal thing with a degree of variation between different suppliers versions. I tend to ensure a 0.5mm CAD gap between my clamp part and base and so far that has not failed to grant a tight clamp.
                                  With the fan mount rotated so the offset is upward, moving the fan away from the heater block it is easy enough to ensure the fan is trapped and can't rotate much.
                                    DocTrucker @bricor
                                    @bricor said in Alternatives to E3D V6?:
                                    Firstly this is not knocking E3D or their V6 product at all. I've got a number of machines and I don't want my knowledge to be limited to a single manufacturers products.
                                    ...but yes agree that price comparisons to cloned and east asian products are dangerous.
                                    You have the similar issues when trying to justify why component x costs an order of manitude more than a mass manufactured part of similar size to J Bloggs who's just realised 3D Printing may be the ideal solution to making the prototype widget for that product that will make their fortune.
                                    • bricorundefined
                                      bricor
                                      Good luck in your quest. I’d like to see more options, options that have proven, significant advantages. And at twice rhe price it has to be revolutionary. As much as I would like to evaluate the comparable otions, I can only rely on the opinions of others that have written or posted videos, nothing I’ve researched has justified any further persuit. I’m hopeful that something is coming in the near future.
                                        DocTrucker @bricor
                                        @bricor ok the 500 US dollars end of the market is too expensive for me (particually when import considerations and potential CE issues are brought into the mix) but as a community I feel we need to be careful to avoid loosing viable competitors for any specific element of our systems.
                                        As soon as order quantities becomes significant enough manufacturing can outsourced to cheaper countries. With big order quantities significant quality control and penalties can be imposed on the manufacturers. This results in a good product which has the fraction of the cost of locally manufactured products - which will be what new market entrants will be most likely to do.
                                        Edit: Fully appreciate cost drivers though. Many if my genuine E3D V6s are second hand.
                                          DocTrucker
                                          No reports from Dyze Design products? I think they were the only non E3D hotend maker at the UK TCT 2018?
                                          Scachiundefined 1 Reply Last reply Reply Quote 0
                                          • Scachiundefined
                                            Scachi @DocTrucker
                                            @doctrucker I have been using two DyzEnd-X successfully on my previous printer. Printed ABS,PLA,PETG with it. I had a genuine e3d v6 installed before and the print quality improved a bit, but that might be caused by having tuned the pid more carefully than I did with the e3d or because of the e3d already lost quality because of high usage and some crashes into the bed.
                                            I stopped using them when I changed to a bowden system. With the DyzEnd using bowden the filament often get stuck because of to much retraction I think and using the e3d I had no problems.
                                            Is anyone of you successfully using a full metal one of any brand with a long bowden tube (70-80cm) and high retraction (4-6mm) without issues ?
