Very strange behavior, CoreXY with external drivers
yes, i did, x and z go together and i can´t find a shortcut...
i also tried to redirect z to drive 8 or 9. Same behavior... -
Do any other motors move when you command the Y motor?
Please check that you really do have +5V on the common 5V feed to the + inputs of the stepper drivers.
no other motors affected by moving Y.
the Voltage at the + inputs of the drivers is 4.56 V -
meanwhile i tested another driver for z-motor (have more of them as spare) and also testet to set the
config to cartesian kinematiks. No luck, always x/z move together.... I´m frustrated.... -
thank you, for your help, i´m just about cabling the printer. i can test it, when everything else is running.
Are you sure that the power to your external stepper drivers is stable? I am wondering whether when they are driving the motors, the voltage could be dropping.
i test that... but i think so, cause i serve 5V to the board with a extern 50W power supply
testet, konstant 4.45V. I take the 5V from the breakout board. Should i take it from the main board?
Or direct of the power supply? -
@capricorn, I mean the main power to your external stepper drivers - 12V, 24V, 36V or whatever you are using.
@capricorn said in Very strange behavior, CoreXY with external drivers:
how do you wire the two power supplies? i think the negative needs to be connected between the two, but i am not 100% sure.
konstant 41V motors driving , i´m using a 600W power supply
i dont think 41v is supported
https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply
The Duet 2 (Wifi and Ethernet) work with a VIN supply of between 11V and 25V
@veti
i don´t think so.... -
this is the power for the external motor drivers, not to the duet2
please draw a diagram. this is getting confusing.
including all power supplies and the wires between them.
@veti
that´s easy.12V and 5V go to the duet2
41V go to the external motor drivers -
and how are the power supplies connected to each other?
this are 3 different power supplies. one end each to 220V the other end to the 5v/12v input duet2 and 41v to the motor drivers. No direct connection (except 220V) between them.
see this for the wiring of the duex
https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiringthe entire wiring is about avoiding current flow between gnd connections.
and in your case you have several non connected gnd connections.
not suitable for me, because i have no duex2 oder duex5 board. i have the duet2 ethernet and the expansion breakout bord. the breakout board is only connected by the 50Pin connector
