    My multi input, multi material, mixing hot end
    My Duet controlled machine
    12
    32
    3.0k
    • brunofportoundefined
      brunofporto @deckingman
      @deckingman Amazing 😄 Will follow. There should be some pressure losses within the mixing chamber that I am curious to the effects!
        deckingman @mrehorstdmd
        @mrehorstdmd That's an impressive 3D print ☺
          deckingman
          I've just posted Part 2 here if anyone is interested https://somei3deas.wordpress.com/2019/06/13/my-modular-multi-input-multi-material-mixing-hot-end-part-2/
          T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 2
            T3P3Tony administrators @deckingman
            @deckingman is the design really too compact to use e3d heatbreaks to save you quite a bit of effort?
              dc42 administrators @deckingman
              Nice write-up!
              I think E3D heat breaks would save you a lot of effort, if you can find a way to get round the problem that both ends are threaded. Maybe you can screw an aluminium sleeve onto the bottom thread. It could be worth asking E3D whether they can make you some heat breaks with one of the threads left off, since they may be interested in your research. The top end could screw directly into an aluminium block with a water cooling hole running through it, so no need for a water tank on the hot end at all.
              There are also other types of threaded heat breaks that can be screwed into both the heater block and the heatsink without needing to rotate either. For example, this one https://www.amazon.com/Bowden-Extruder-Throat-Heatbreak-3-00mm/dp/B07G99G5MB.
              Regarding the filament inlet spacing, what's the reason for putting the BMGs on the outside and the extruder stepper motors on the inside, instead of the reverse? Is it because you sometimes need to dismantle the BMGs to deal with filament issues?
                @deckingman to add to what @dc42 has said e3d have single end threaded heatsinks for use on the Chimera etc: see "whats in the box" here:
                https://e3d-online.com/chimera
                  deckingman @dc42
                  @dc42 said in My multi input, multi material, mixing hot end:
                  Mostly that but also fitting them in the first place. The screws go through the extruder body into the motor so if two extruders face each other, it's impossible. Having said that, maybe I could fix each set of 3 onto a plate, then somehow slot or bolt that plate into place. If I needed to dis-assemble one extruder, I'd have to remove the plate with all three but that wouldn't be the end of the world. It's only a partial solution to the problem though - there would still be a significant offset in X if not so much in Y, but if the inputs to the hot end were angled, it might work. I do have a bit of a concern about heat with those 6 motors being in such close proximity to each other, so having the motors on the outside would be advantageous in that respect.
                  Ref heat breaks, certainly "off the shelf" ones will save me a lot of heartache. As well as the E3D variant, I was very taken by what the inventor (if that's the word) of the Zatsit printer was doing. Also the Slice engineering Mosquito seemed to be a very efficient heat break design. If I could adapt my design to use either of those, and if either of those companies would supply me just the heat breaks, that's another option.
                  Lots to think about............
                  • Martin1454undefined
                    Martin1454
                    Im really looking foward to see how it turns out 🙂 - The "maze mixing" design sounds interresting!
                      deckingman @Martin1454
                      @martin1454 There are a few untested ideas that ultimately might not work. I've set the bar quite high trying to do multi-material as well as mixing so in the end, I might have to make some sort of compromise. But for now, I'll leave the bar where it is and keep on trying.
                      • fmaundefined
                        fma
                        Did anyone aready try to inject ink in the melted zone to color the filament? It should be easier to mix CMYB inks rather than PLA...
                        Frédéric
                          deckingman @fma
                          @fma said in My multi input, multi material, mixing hot end:
                          Kind of. IIRC, that was something that Adrian Bowyer or one of his students was looking into. If you look at the firmware, you'll see this https://duet3d.dozuki.com/Wiki/Gcode#Section_M578_Fire_inkjet_bits. It seems to have died a death so maybe there were some problems that couldbn't be overcome.
                          • wilrikerundefined
                            wilriker @deckingman
                            @deckingman said in My multi input, multi material, mixing hot end:
                            Ref heat breaks [...] Also the Slice engineering Mosquito seemed to be a very efficient heat break design. If I could adapt my design to use either of those, and if either of those companies would supply me just the heat breaks, that's another option.
                            At least Slice Engineering sells the heatbreak as spare parts: https://www.sliceengineering.com/shop/heat-break
                            Manuel
                            My Tool Collection
                              deckingman @wilriker
                              @wilriker said in My multi input, multi material, mixing hot end:
                              ahh, thanks for that.
                              Edit- £35 USD a pop and I need 6! That's an expensive experiment.
                              • wilrikerundefined
                                @deckingman I never said they where cheap. 😁
                                EDIT: But for test you could start with one.
                                Manuel
                                My Tool Collection
                                  True. Or I could try making something similar. Looks like a copper heat sink, copper nut with (probably) Titanium tube swaged in between. hmmmm........
                                    Phaedrux Moderator @deckingman
                                    I think DiVinci sells a proprietary printer that uses inkjet coloring.
                                    • fmaundefined
                                      fma
                                      Mu suggestion was to inject the ink in the melted chamber, not on the printed part.
                                      But It may be difficult to maintain pressure, and it may mess up the print process...
                                      Frédéric
                                        deckingman @fma
                                        @fma I don't know what the boiling point of printer ink is, but I'll bet it would likely just vaporise if you tried to inject it into the melt chamber at circa 200 deg C.
                                        3DOesteundefined 1 Reply Last reply Reply Quote 0
                                          You'd think some of the pigment or dye might survive. What do they use to color the filament itself?
                                            deckingman @Phaedrux
                                            @phaedrux said in My multi input, multi material, mixing hot end:
                                            I believe coloured pellets go into the mix but I'm not sure.
