    Best lead screw - ball bearing mount system
    3D Printing General Chat
    13
    42
    5.2k
    • claustroundefined
      claustro @deckingman
      @deckingman
      I am trying to use your Z rail configuration with only 2 carriage in a diagonal disposition .
      If you talking about the plastic tee plate , the one that fix the 2020 that support the 2 front lead screws, I am going to switch to aluminum one as soon I 'll have my CNC running . ( it will be my first easy test with aluminum 🙂 )
      I have a dial gauge and I surely check what you suggest.
        deckingman @claustro
        @claustro For info, here is how I mounted my lead screw blocks.
        So each block is supported on two 2020 extrusions. One might be OK but check for deflection.
        • claustroundefined
          claustro
          I have 2 spare 2040 peaces I can always copy your design in case I'll find some flex
          • claustroundefined
            claustro
            I changed the setup following your tips this is the result.
            Now I have to choose if make a bed leveled by lead screws or by another set of screws only for the bed.
              @claustro That looks very familiar ☺
              claustroundefined 1 Reply Last reply Reply Quote 0
              • claustroundefined
                @deckingman eh eh 🙂
                • claustroundefined
                  claustro
                  I am thinking to change my setup.
                  with only one bearing when I tension the belt the shaft tend to be dragged towards the centre, creating tension on the lead screw, for this reason I am making another support for another ball bearing under the previous one fixed on the other side of the vslot. The 4cm distance between the 2 bearing should improve the stiffness of the system.
                  • claustroundefined
                    claustro
                    this is what I did
                    • bondusundefined
                      bondus
                      I have had issues with the z-axis due to that the 8mm hole on the pulleys are slightly oversized. Advertised 8mm, real world 8.07mm. And the lead screws tend to be slightly undersized, typically 7.9mm. This may lead to that the pulley is mounted at a slight angle causing massive z-banding. With an 8mm pitch screw it is not very visible, but with a 1.5mm pitch screw it certainly is.
                      The nice screw @claustro has should solve that problem. Where did you find such a screw?
                      My goto screw-peddler offers them with a machined 5mm end, I'm very tempted to get one of those.
                      @sinned6915 said in Best lead screw - ball bearing mount system:
                      Proper design would be to use a pair of angular contact bearings that bear on a shoulder, but those are $$$
                      $5 a piece on ali, seems to be good quality. A bit scary with an open bearing.
                      Edit: Typo
                      • sinned6915undefined
                        sinned6915
                        @bondus - what bearing is that? you have piqued my curiosity.
                        looking at my printer now, i realize that i might have left out and important bit- i used a shaft collar on there too between the pulley and the thrust bearing-
                        https://www.mcmaster.com/6655k54
                        and i think
                        https://www.mcmaster.com/6157k32
                        • bondusundefined
                          bondus
                          @sinned6915. Clamping shaft collar, should get a straighter clamp than with a set screw, I need to get some of those.
                          The bearing is a 798C, 15 degree angle bearing. Mochu has their own shop on ali, lots of specialized bearings. I have bought many bearings from them, they are good.
                          • Denisundefined
                            Denis
                            I got the best results with this solution (assuming that the Chinese friends inserting the axis exactly) 0_1560873439748_2019-06-18_18-54-56.png
                            • Vetiundefined
                              Veti @Denis
                              yes the sfu1204 are working nicely on my printer as well.
                              no play and very rid-git. you might even be able to use them without linear guides.
                              • claustroundefined
                                claustro
                                @bondus said in Best lead screw - ball bearing mount system:
                                I am not a native english speaker so maybe I am l misunderstanding something.
                                My lead screw is a regular 2mm pitch Chinese lead screw and it is connected with a 8mm to 8 mm coupler with a 8mm shaft.
                                I am having quite difficult aligning perfectly the lead screws but I think that it will not affect a lot the Z if the bed is correctly fixed in X and Y ( with V slot wheels in my case).
                                I can't understand the shaft collar and 15 degree angle bearing. What would be the advantages over thrust bearing and regular ball bearing like I did?
                                • bondusundefined
                                  bondus
                                  @claustro said in Best lead screw - ball bearing mount system:
                                  I realize now that your picture above shows the screw and shaft, without the coupler mounted.
                                  A shaft collar: 0_1561311157196_e173d6c3-8b04-4cbc-a76f-4198429aa4e8-image.png
                                  An angular bearing is very similar to a regular deep groove, but the surfaces the balls contact are at a slight angle. They can take axial load, in one direction, and radial load. They seem to be a specialist bearing only available with tight tolerances and a high price.
                                  • gnydickundefined
                                    gnydick @claustro
                                    @claustro Came across this, Instead of an intricate belt path, I just put 4 motors under my bed, one at each corner. Works lovely because it's super strong now as well.
