    Help me ID this heatbreak?
    3D Printing General Chat
    1.1k
    • Blacksheep99undefined
      Blacksheep99
      Hi, I need to replace this hearbreak but can’t find a compatible replacement. It seems to be a E3D V6 however it’s shorter. Hopefully someone could advise and link me to a replacement. Thanks
      https://photos.app.goo.gl/j1rzTwyVYbwhRVsh7
      • 3DPMicroundefined
        3DPMicro
        E3d V6 is the same thread size on both sides. M6x1 or 1.25. I don't recall
        Yours appears to have 2 different thread diameters
        Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
        Cataundefined zaptaundefined 2 Replies Last reply Reply Quote 0
        • Cataundefined
          Cata @3DPMicro
          @3dpmicro said in Help me ID this heatbreak?:
          Have you ever seen a e3d v6?
          • zaptaundefined
            zapta @3DPMicro
            @3dpmicro, I think that E3D V6 are M6 on the lower end and M7 on the upper end. There should be open source dimensions somewhere.
            • DocTruckerundefined
              DocTrucker
              The original poster has indicated their part is (over 4mm) too short for an E3D V6 heat break.
              https://e3d-online.dozuki.com/Item/V6_Heat_Break
                DocTrucker
                ...also not V5.
                https://wiki.e3d-online.com/E3D-v5_Documentation
                • Vetiundefined
                  Veti
                  can you post a picture of the entire hotend assembly?
                    Blacksheep99
                    More photos added to the first link showing the other hot end parts. Thanks all
                    • Vetiundefined
                      Veti
                      that seems like a custom part.
                      how is the radiator part attached to the carriage? you might be able to replace it with a standard v6.
                        Blacksheep99
                        That was my fear. Not sure if I'm honest. I'd have to try taking it apart. The problem is I can't access the FW so any change to the nozzle position/height will be a problem.
                        I should add I've bought a replacement nozzle and it was a V6 clone which worked/fitted perfectly.
                          A Former User
                          The block looks like its bigger than "normal"; maybe look into fitting a regular v6 heat break + v6 block and see if the over all length is close enough?
                            Blacksheep99
                            I’ll measure up tonight. See if that could be an option.
                            • zaptaundefined
                              zapta @Blacksheep99
                              @blacksheep99 said in Help me ID this heatbreak?:
                              What kind of Z homing do you have? You may be able to adjust the Z height my moving the endstop or shim the moving part that activates it. Upgrading to common parts will make your life easier.
                              Blacksheep99undefined 1 Reply Last reply Reply Quote 0
                                Blacksheep99 @zapta
                                @zapta said in Help me ID this heatbreak?:
                                It’s a microswitch that probes the build plate in 5 locations. I considered the option you’ve proposed. Would need to look closer to see if that is possible. I’ve found a new hot end for £45 which is an expensive fix.
                                I have two printers and the other is in bits as I’m going to upgrade the control board to duet so ideally want this working until that is done then will consider the same with this printer.
                                Thanks for the suggestion
                                  Blacksheep99
                                  Just wondering if I’ve read your suggestion correctly now. It’s a Core-XY printer so the build plate lowers. Assume it’s a microswitch though
