    Indirect (bearing) laser filament monitor concept
    Filament Monitor
    26
    109
    8482
    • brunofporto
      brunofporto last edited by
      I designed a new casing for the Duet3D Laser Filament Monitor to hold two bearings with a compliant mechanism spring to try indirect reading of filament extrusion. The sensor will read the bearing surface instead of the filament and I hope this should end the issues with different filament colors and types.
      I'll test print it today and if it works I'll publish the files as soon as possible.
      siblues 1 Reply Last reply Reply Quote 8
      • timcurtis67
        timcurtis67 last edited by
        It looks really good. I'll be following this one.
        I've been running the filament housing turned at a 10 degree angle with mixed results so far.
        • Synapsis
          Synapsis last edited by
          Same here as tim, bought my filament monitor time back but still hadn't decided how to mount it, this looks good.
          • brunofporto
            Finish printing... And realized that I lost my small bearings..... 😞
            I stored at some safe place to not lose it and now I do not remember where 😂😬
            PuterPro 1 Reply Last reply Reply Quote 1
            • brunofporto
              I'll release the current design for those who have a 693ZZ bearing at hand and want to test and redesign it for the F623ZZ bearings that I have spares.
              • PuterPro
                PuterPro @brunofporto last edited by
                @brunofporto said in Indirect (bearing) laser filament monitor concept:
                What the heck are you doing in my house??!?? 😂
                This is great thinking outside the box (well, maybe INSIDE the box).
                LOVE THIS!
                Don't have that sensor, but if this works it gives me a reason to have one. Well done.
                brunofporto 1 Reply Last reply Reply Quote 0
                • brunofporto
                  brunofporto last edited by brunofporto
                  If you have the Duet3D LAser Filament Monitor and a pair of 693ZZ bearings here is the prototype.
                  https://www.thingiverse.com/thing:3558691
                  I'll redesign it for the F623ZZ 😄
                  • brunofporto
                    brunofporto @PuterPro last edited by
                    @puterpro Pretty sure I'll find them when they are not needed anymore 😂 😂
                    • Adrian52
                      Adrian52 last edited by
                      Have done a test print of the 693zz version in pla. alt text
                      As you can see, the jaw tends to drop somewhat when the filament goes through. Do you think it needs some extra support? - maybe a plate that goes on the bottom? Or perhaps it would be better in petg? For my printing, I think the 4mm slots for the bearings could do with a tiny bit more tolerance. Great idea though - I am about to order a laser monitor on the strength of it.
                      brunofporto 1 Reply Last reply Reply Quote 2
                      • johnjohn1990
                        johnjohn1990 last edited by
                        this looks very good 🙂
                        do you have any tests to show the difference? 🙂 might put this on my printer if its actually working good 🙂
                        • brunofporto
                          brunofporto @Adrian52 last edited by
                          @adrian52 It was supposed to work like that! 😄 The spring is integrated.
                          Does it deform permanently or it comes back nicely to the original position? When you pull the filament can you see the bearings moving?
                          Adrian52 1 Reply Last reply Reply Quote 0
                          • brunofporto
                            brunofporto @johnjohn1990 last edited by
                            @johnjohn1990 Still not tested... I lost my bearings and now I am designing for the F623ZZ that I have here.
                            cabal2000 1 Reply Last reply Reply Quote 0
                            • pkos
                              pkos last edited by
                              I wonder... how much work would it be to give this a go with the 608ZZ?
                              Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
                              • Adrian52
                                Adrian52 @brunofporto last edited by
                                @brunofporto the bearing moves ok, but it feels like the jaw is having to move too far, overstretching a little past the point where it would spring back strongly.
                                • brunofporto
                                  @adrian52 Thanks!
                                  • Adrian52
                                    @brunofporto realised later that one of the bearings was not fully seated, so your bearing gap may well be right. Still need a bit of tolerance for the outer part of the bearing, and I suspect that the jaw spring may need to be a bit thicker. Will try again - thanks for the design.
                                    • Adrian52
                                      Those changes seem to work OK
                                      I used 0.1mm gap on each side of the bearings, and added 1mm to the base of the jaw to make the spring stronger. I didn't have room for washers, but the bearings rotate quite freely.
                                      • siblues
                                        siblues @brunofporto last edited by
                                        @brunofporto How is the sensor working out for everyone after this modification?
                                        pkos 1 Reply Last reply Reply Quote 0
                                        • claustro
                                          claustro last edited by
                                          Thank you for sharing with us.
                                          I have a magnetic sensor from about 1 year and it works flawlessly.
                                          I don't know if laser costs less of magnetic, but the need of a bearing system in the laser sensor affect the simplicity of this device reducing or annulling the advantages over the magnetic one.
                                          IMHO
                                          good idea anyway
                                          • pkos
                                            pkos @siblues last edited by
                                            @brunofporto
                                            I haven't really tested it yet after the initial test runs.
                                            In my case, the range was always between 1% and 25%. So not really usable. I have loads of the 693ZZ now, so can experiment. I'll try to paint it over with a sharpie and see what that will do.
                                            Another thing is that I had to enlarge the cutout for the bearing. My bearing is exactly 4mm and the gap is the same. There's no way washers will fit in there along with the bearing.
                                            brunofporto 1 Reply Last reply Reply Quote 1
                                            • brunofporto
                                              brunofporto @pkos last edited by
                                              @pkos We can test some bearing surface coverings and treatments - like heat shrink tube of a way to make the surface of the bearing rough.
                                              Adrian52 1 Reply Last reply Reply Quote 1
                                              • Adrian52
                                                @brunofporto I finally got a sensor, and have fitted it. It seems to be working OK, although giving high percentages - 103 minimum, 147 average, 203 max, on a roughly 3000mm print. I have made the following changes to the design
                                                1. The cutout for the board components needed an extra 1mm - maybe because I have the v2 sensor?
                                                2. The jaw bearing is lowered by 0.3mm. The hinge only bends a little, but enough to grip the filament
                                                3. The ptfe tube slot is widened to 4mm diameter. I was finding the filament was sticking because of compression of the tube. I also made 3 narrow cutouts 4.2 mm diameter in the slot to make the inside ridged - the tube seems to hold quite firmly without occluding the bore
                                                4. I think I already mentioned giving 0.1mm clearance for the bearings, and 1mm extra for the hinge
                                                5. I roughened the outside of the upper bearing with an emery board - feels a bit more grippy, and maybe seen better by the sensor?
                                                  this is what it looks like
                                                I could post my changes on thingiverse, but didn't want to steal your thunder
                                                Will update as I get more experience with it.
                                                3dmntbighker 1 Reply Last reply Reply Quote 1
                                                  @adrian52 said in Indirect (bearing) laser filament monitor concept:
                                                  I think you have the new version laser filament monitor, that's why the movement percentages are so high. Firmware versions 2.03beta and 3.0beta recognise the newer version and give the correct percentages.
                                                  • Adrian52
                                                    Adrian52 @dc42 last edited by
                                                    @dc42 I'm actually on 2.03beta3 (2019-03-25b6)
                                                      dc42 administrators @Adrian52 last edited by dc42
                                                      When you send M591 D0, does the response include the sensor version?
