    Connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?
    30
    3.8k
    • CrazyCreatorundefined
      CrazyCreator
      I have bought a Duet Wifi v1.04 and would like to continue using my existing Lerdge Power Monitoring module.
      Can I connect a Lerdge Power Monitoring Module to the Duet Wifi v1.04?
      I mean this Modul: https://www.banggood.com/Lerdge-3D-Printer-Power-Monitoring-Module-Continued-to-Play-Printing-Automatically-Put-off-p-1328145.html?admitad_uid=fad9d51316ed24ef0e20a4a7af11915c&utm_content=90289&tagtag_uid=fad9d51316ed24ef0e20a4a7af11915c&cur_warehouse=CN
      http://www.crazycreatorcube.com
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
      • A Former User?
        A Former User
        Probably compatible with this https://duet3d.dozuki.com/Wiki/Power_Wiring#Section_Controlling_the_external_power_supply
        But since they don't provide any documentation, or release the sources for their more than likely RepRap forked firmware I cannot say for sure. Maybe someone else has already tried?
        However if it is compatible with the Duet documentation, then you need a separate 5V supply as outlined in the wiki.
        Edit: would maybe look at Makerbase MKS PWC V2.0 instead, they're about equally shady but has 5v supply and signaling seems to be compatible.
          CrazyCreator
          Hmmmmm ... So it says: Try it.
          Unfortunately, I do not really know anything about electronics and really only understand the absolute principles.
          I also have the MKS PWC 2.0 here. How would you have to wire that?
          Do I have to wire this as stated in the description for the MKS PWC, or do I have to pay attention to something here? The 5V voltage described in the wiki disappears when using the MKS PWC module?
          • A Former User?
            A Former User
            Should be able to use the diagram here
            https://github.com/makerbase-mks/MKS-TFT/issues/112
            S1 on PWC to PS_ON on duet. (and 5v/gnd of course)
            And for the resume wire S0 to a free input on the Duet and follow
            https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure
            gomines created this issue in makerbase-mks/MKS-TFT
            closed MKS PWC (Auto-Off) + SBase #112
            • A Former User?
              A Former User
              Although don't know if the 5V/0.6A provided by the MKS PWC unit is sufficient for the Duet.
              This may shed some light on that:
              https://forum.duet3d.com/post/35264
                CrazyCreator
                First: You mean the Wiring from the first posting?
                This: https://user-images.githubusercontent.com/35586270/36057698-87f482dc-0df0-11e8-983e-dbaf89b09f5a.png
                Second:
                What mean: (and 5V/gnd ofc)?
                I don't understand the "ofc"
                And Last:
                I can use this wiring for the rest:
                • A Former User?
                  A Former User
                  Yeah, it has the S1 and S0 labels on the MKS PWC, they are the PS_ON output and PowerLoss input signals respectively.
                    CrazyCreator
                    Ok ... I read and hope I understand 🙂
                    For the rest of wiring I can use this picture too:
                    I know the picture is for the MKS Gen 1.4, but I mean the routing for the other cables
                    CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
                    • thweundefined
                      thwe
                      if your goal is:
                      • 24v supply on / off via gcode or dwc
                      • emergency stop switch
                      • reset
                      try this:
                      You only need : example for a opto low-level trigger-relay
                      Thomas
                      • Stephen6309undefined
                        Stephen6309 @CrazyCreator
                        @crazycreator Duet is able to resume after a power loss, if you set it up: https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure
                        For powering on/off: https://duet3d.dozuki.com/Wiki/Power_Wiring and
                          CrazyCreator @CrazyCreator
                          @thwe and @Stephen6309
                          My only concern is to have a 16mm button on the front of the printer, with this I want to turn on the printer.
                          If I can turn off the printer with this button, that would be nice, but it is not necessary. I can do that also via web interface
                          • ediikundefined
                            ediik
                            If anybody came accross the same thing 😃 i got a solution. now the baord turns ON with the front button.
                            Sidenote: it does not matter where you get the 5v from. The pins from the main extension ports are allready if use on my board (bltouch).
                            Meltexundefined 1 Reply Last reply Reply Quote 0
                              CrazyCreator
                              how locks your config.g now
                              ediikundefined 1 Reply Last reply Reply Quote 0
                              • ediikundefined
                                ediik @CrazyCreator
                                @CrazyCreator it does not matter. The lerdge board simply gets 5v from the duet and stays on for the time it has 5v connected. No cdg changes necessary. 🙂
                                  CrazyCreator
                                  ok ... I would test it
                                  • Meltexundefined
                                    Meltex @ediik
                                    @ediik Hi! I came across this thing. 🙂 One question - why don't you use PS_ON signal for controlling Lerdge power module?
                                    • ediikundefined
                                      ediik @Meltex
                                      @Meltex hi sorry for late reply. i honestly dont know how to wire it up the right way.
                                      • bitminterundefined
                                        bitminter
                                        Don’t feel bad this module has beaten me as well for time being. I went to the solid state relay setup as highlighted above and was much simpler to get going with the same button. But... I really would like to figure this out too at some point lol.
                                          bitminter
                                          Little correction, for me, it’s the Makerbase MKS PWC V2.0 module. No matter what I tried, just couldn’t get it to work.
                                          • Richygoatundefined
                                            Richygoat
                                            Hello, did anybody the Lerdge Power Modul to work with the Duet. I want to try the same thing. Have a Lerdge Power Modul laying around here. What does the PS_ON pin on the Duet exactly? Act it like a 5v on and off switch?
