    Duet3D PCB delta printer effector sneak preview
    53
    367
    77.6k
    • Zesty_Lykleundefined
      Zesty_Lykle
      OK, that will work.
      Then I can clamp the adapter on top of that and lock the PTFE tube in, without need for the collet.
      Lykle
      Design, make and enjoy life
      Co Creator of the Zesty Nimble
      • loicundefined
        loic
        @Dougal1957:
        The PCB Effector with Nimble and mounting adaptor plus custom E3D V6 comes in at 159 grammes.
        Don't know how the Flex would fit TBH the mounting for the custom heatsink is 3x M3 holes on a 18mm PCD which would be tight.
        http://i1014.photobucket.com/albums/af270/dougal1957/DSC_0117_zps5zgaq1gs.jpg
        Right time to go put it back on the printer
        Doug
        where is the fan for the print piece?
        we need one to have good quality print.
        i agree the nimble is top notch but if i need to buy everything i will have for 280e only for the head..110euro for arm+rod kit+ 60euro for pcb+100 with shpping cost for nimble..it s a lot expansive
        it s almost the price for my anycubic i3 mega only for parts..
        • Dougal1957undefined
          Dougal1957
          I hav'nt included the part fan as I use the Berdair system
          • DjDemonDundefined
            DjDemonD
            That's a nice feature being able to disconnect it easily, due to the magnets and the electrical couplings used. Is there one connector for the whole effector, or multiple connectors?
            www.precisionpiezo.co.uk
              Zesty_Lykle
              OK, new adapter is available.
              This adapter is mounted onto the PCB using 6.6 mm tall standoffs. The PCB has 3 holes of 2.9 mm diameter and the adapter has space for 3 M2.5 bolts that go through the standoffs.
              The bottom of the adapter sits on top of the hot end and has a 4mm opening that is 5 mm deep. This hole is for the PTFE tube. It locks the tube into the hot end, so that there is no need for the collet.
              edit: corrected the standoff length.
              https://www.thingiverse.com/thing:2453322
              Lykle
              • jannisjundefined
                jannisj
                @dc42:
                Bear in mind that to use the Nimble with the production effector, you will need a different adaptor compared to the prototype that Doug used. The new heatsink doesn't come with the threaded collar that the old one did, instead there is a shorter threaded section and a M12 fine pitch half nut and washer. OTOH the effector now has 3 additional 2.9mm holes at 120 degree intervals on a 17mm radius.
                Damn, I ordered the adapter from shapeways last weekend..
                Hopefully they are able to cancel the order
                -Jannis
                • jannisjundefined
                  jannisj
                  @Zesty_Lykle:
                  This adapter is mounted onto the PCB using 7.4 mm tall standoffs. The PCB has 3 holes of 2.9 mm diameter and the adapter has space for 3 M2.5 bolts that go through the standoffs.
                  Will this be available from shapeways too?
                  I ordered the Nimble today (and already got the tracking number)
                  -Jannis
                    Dougal1957
                    DJ there are 2 connectors on it a 8 way single row for thesensors etc and a 3x2 for heater fan and thermistors/temp sensor it took me about 3 minutes to take it of the machine for the photo
                    • oleeundefined
                      olee
                      Hello. It's my first message in this forum but I has been reading it for a few month. Sorry for my english it's not my native language. I'm going to build my first delta 3D printer based on David's Kossel XL. I've got almost all main mechanical parts: extrusions, buildplate, heater, stepper motors etc. Now I'm waiting for the PCB effector to order it with electronics (Duet an so on). On the way to me is the Nimble extruder which I want to pair with the effector. Reading this thread I got sure that the adaptor from shapeways allow me to do that (obviously can't print it myself). But now I see that I need a new version of the adaptor. So it is a question. Can I order this new adaptor from shapeways right now or should I wait some time before this version will be available there? Thanks in advance.
                      Oleg
                        Dougal1957
                        Yes
                        https://www.shapeways.com/product/62MB3QZJ7/nimble-mount-base-for-smart-effector?optionId=62810434
                        • oleeundefined
                          olee
                          @Dougal1957:
                          Yes
                          That is a new one is the same as the old adaptor except it needs to use 7.4mm stands that I should make by myself?
                            Dougal1957
                            it is quite a bit different to the old one although it may look the same and the stand offs can be purchased tho wether you will get 7.4 mm ones I am not sure but 10 would do you would just have to extend the PTFE Tube a bit further I think check ebay for standoffs.
                            Found some 8mm long ones here http://www.ebay.co.uk/itm/M3-M4-M5-M6-M8-Nylon-plastic-spacers-standoff-washers/282477022050?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D20140122125356%26meid%3D757a377c307d47cf806cde39a5736fa8%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D272505748740 you will also need some m2.5 screws and nuts probably around 20mm long screws should do I think
                            • oleeundefined
                              olee
                              @Dougal1957:
                              Thank you! It is just not obvious that the link points to a new version of adaptor as it looks much the same as the old one that I was ready to order before read las posts in this thread. So I will order this right now and if I got it right I can use standard bronze or plastic standoffs that used for PCB mounting. Thanks one more!
                              Oleg
                                Dougal1957
                                just hold off for a bit Lykle is still working on it with input from me as well.
                                He is adding the standoffs as part of the print we just need to get the hight correct first?
                                • oleeundefined
                                  olee
                                  I think M3 screws make the job better. 2.9mm hole diameter is exact size of external dia of M3 thread so it seems that David chose this size for precize positioning with M3 screws, IMHO.
                                    Dougal1957
                                    the fact that the PTFE Tube is locked in the bottom of the adaptor should locate it adequately
                                      Zesty_Lykle
                                      OK, after some work, and a nice discussion with Doug, I have wrapped up the design for the adapter.
                                      It now features a nice set of integrated legs, 6.6 mm long as we want to make sure we do not bend the PCB when mounting the adapter. No idea if it will hinder the working of the sensor embedded in the PCB.
                                      So the Shapeways model is now complete and ready.
                                      The Thingiverse page holds the 2 models, the legless one and the legged one. (If you look at the adapter standing there you will realise why I am calling it the Grand Piano adapter)
                                      Shapeways http://shpws.me/OPLc
                                      Thingiverse https://www.thingiverse.com/thing:2453322
                                      Lykle
                                      • oleeundefined
                                        olee
                                        @Dougal1957:
                                        Precision could not be much. BTW I ordered the adaptor and it could be seen small feet on bottom of the adaptor onat the picture on the order status page. So it's possiblly no standoffs are needed.
                                          Dougal1957
                                          yes indeed that is correct precise mount is important but the tube will locate it centrally anyway.
                                          • oleeundefined
                                            olee
                                            @Dougal1957:
                                            OK, you won. Your advices help me make another step building my delta so thanks anyway.
