    Requested speed is not reached
    6.2k
    • deckingmanundefined
      deckingman @PuddingBaer91
      @puddingbaer91 I say again that none of my 5 Bondtech BMGs make that noise. You said above that "there should be nothing loose" but have you actually taken it apart and checked?
      Edit. The only reason why reducing "jerk" helps the sound is that it effectively reduces pressure advance so either don't use pressure advance at all or fix the problem with the extruder.
      • PuddingBaer91undefined
        PuddingBaer91
        Could you please Share a Video of your running Extruder? I de assemled my bondtech 100 Times also because switching Stepper Motor it seems all perfekt. Also the other Extruder (ultimaker Clone) Made These Sounds...it also makes this Sound with pressure advance = 0.1
        Edit: i bought a bondtech BMG Clone to Check If Mine was faulty...
          @puddingbaer91 said in Requested speed is not reached:
          Taken just a few minutes ago and uploaded to my google drive folder.
          https://drive.google.com/file/d/1oEaL72FOPDlCzU3uTm2UajcCdYBtXVWL/view?usp=sharing
            PuddingBaer91
            thank you this is what i expect from my extruder 🐶
            May i found the problem:
            https://photos.app.goo.gl/Krb1Pd1MatLy46S57
            look closely to the metal gears. I tightened the screw to max and loosen it till it is possible to move the plastic gear (just a little bit. As you can see the spring is on block (compressed fully). The gears are slipping 😤 if i loosen the srew much more this will also happen. I think this is not normal or what do you think?
            • Vetiundefined
              Veti
              have you tightened the grub screw on the gear with the white gear?
                PuddingBaer91
                yes checked that. Here is also a video with cover (second bearing) mounted.
                https://photos.app.goo.gl/PoWPArpmCjFiu4kH7
                metal gears still slipping
                deckingmanundefined 1 Reply Last reply Reply Quote 1
                • Vetiundefined
                  Veti
                  take the one with the white gear apart and post a picture of the shaft and the grub screw.
                    @puddingbaer91 AFAIK that white gear is a press fit onto the shaft and it looks like it might be slipping. Take it apart and clamp the shaft firmly, then see if you can move that gear. It's likely to get worse the longer you print because of the heat conduction from the motor which will soften the plastic and /or make it expand more than the shaft. If that is the case, then you could try a it of epoxy adhesive or contact Bondtech and see if you can get new gear/shaft assembly (but make sure that is the problem first).
                    Edit - looks like we weer both typing at the same time.
                      PuddingBaer91
                      Commando Back, talked with bondtech Support and they told me it is designed for using with Filament loaded. Then they doesn't Slip. Reassemled and If i Turn the White Gear fast Back and forth by hand with Filament loaded There ist absolutely No Bad Sound. So i will try it again. If it is Not better i will do a Print without bondtech Extruder to Gear only Extruder stepper
                      • Vetiundefined
                        Veti
                        the white gear and and bondtech gear should never turn separately, even if there is no filament loaded.
                          PuddingBaer91
                          i tried again but the same sound. So i unmounted the bondtech bmg and printed without it. The sound comes from the motor because it is skipping steps or something other is wrong with them.
                          If i hold the motor shaft while printing lines without big speed changes i can't fix the shaft by hand. While fast and often print speed changes (infill) i easily can fix the motor shaft by hand also can turn the shaft in each direction by hand in spite of motor is working.
                          I tried 3 motors (ACT, original tronxy and original e3d pencake) but all three acting the same. Also lowered the current of xyz to 800mA and let the extruder at 85% current but no change (may it's a little harder to fix the shaft)
                          Do you know whats going wrong here?
                          It's a 12V system with 360W power supply
                            @puddingbaer91 If you run M122 while it's printing, what is the reported voltage?
                              PuddingBaer91
                              @deckingman said in Requested speed is not reached:
                              M122
                              Supply voltage: min 11.7, current 11.8, max 11.9, under voltage events: 0, over voltage events: 0, power good: yes
                                Do you have any other motors to test with?
                                  PuddingBaer91
                                  I have more tronxy Motors... But don't think the 3 i tested all faulty
                                    PuddingBaer91
                                    I Ordered 24V Power supply and other 24V stuff. What steppers do you recommend?
                                    Are the e3d high Torque steppers good?
                                    https://www.makerdise.com/high-torque-axes-motor.html
                                    For Extruder i found a short stepper from bondtech with Data Like in the recommendations but the Rated current is lower than 1.2A. What do you think?
                                    https://www.bondtech.se/en/product/nema17-pancake-stepper-25mm
                                    @deckingman What Motors you are using? In your Video i saw short Motors Like the bondtech one
                                      These https://www.omc-stepperonline.com/nema-17-stepper-motor/nema-17-bipolar-18deg-18ncm-255ozin-07a-29v-42x42x25mm-4-wires-17hs10-0704s.html?mfp=183-body-length-mm[25]
                                      Although the data sheets that I have ( 5 of them) all state the holding torque to be 1.8Kg.cm which is more like 17 or 18 N.cm whereas those that I linked to are the same in every respect, including the SKU number, but the quoted holding torque is 13N.cm. I suspect that web site might be wrong because 13N/cm is also the quoted holding torque for the shorter 20mm motors. These are 25mm long so I'd expect the holding torque to be higher and I remember the reason I bought them was because there was 30% more torque for only 5mm more length.
                                      PuddingBaer91undefined 1 Reply Last reply Reply Quote 0
                                        PuddingBaer91 @deckingman
                                        Thank you. Looks good but i Wonder because in the duet wiki is written that the Stepper should have inductance lower than 4mH and current should between 1,2A and 2A. Your Motor and also bondtech Stepper have 5.5mH inductance and only 0.7A.
                                        But Like in your Video it works 😄
                                        @dc42 What do you mean?
                                          @puddingbaer91 The wiki also states that lower inductance means that you can run faster before the torque drops off. Unless you have a very highly geared extruder such as a Zesty Nimble or some such, then the extruder(s) run much slower than the X and Y axis motors. So inductance is far less important for extruders such as the Bondtech.
                                            ah okay thank you. And what about the very low current of 0.7A? Or is it because it's one phase and we have to multiply by 4 so we get 2.8A?
