    rfm - RepRapFirmware FileManager [duetbackup successor]
    83
    10.3k
    • 3mmundefined
      3mm
      Hi wilriker,
      I hate to sound stupid, but how do I use it? Where do I put the files? And how do I access it? My system is Windaze 7 PC and a DUET-EtherNet controller.
      Thanks in advance...3mm
      There are 10 types of people: Those who understand binary and those who don't.
      • gtj0undefined
        gtj0 @wilriker
        @wilriker
        Yep, -removeLocal now works.
        You can't specify the remote directory as 0:/ any more though. Not sure if this is intentional or not.
        $ ./rfm backup -domain duet0 /tmp/duet0 0:/
        2019/07/30 05:49:53 Fetching filelist for 0:/0:
        2019/07/30 05:49:53 Directory not found
        Doesn't matter to me, not sure if it's matter to others.
        wilrikerundefined 2 Replies Last reply Reply Quote 0
        • wilrikerundefined
          wilriker @3mm
          @3mm You download the release for your operating system. For Windows that would be rfm-windows_amd64.zip. Then you unpack that to a location of your choice. It is a command-line tool so you have to open cmd and navigate to the directory where you unpacked rfm to (alternatively: in Explorer right click while holding shift in the directory where rfm.exe is located - this should provide a context-menu entry to open a command line in this directory).
          There you can simply run
          rfm help
          to get an overview and the available sub-commands. With
          rfm help <subcommand>
          you can see individual parameters of each sub-command.
          Manuel
          My Tool Collection
          3mmundefined 1 Reply Last reply Reply Quote 0
          • wilrikerundefined
            wilriker @gtj0
            @gtj0 said in rfm - RepRapFirmware FileManager [duetbackup successor]:
            @wilriker
            No, that's a bug. 🤦 I'll look into that.
            Manuel
            My Tool Collection
            • wilrikerundefined
              wilriker @gtj0
              @gtj0 Found it and fixed it.
              Release v1.1.0-RC3
              This can be found as usual on GitHub Releases page.
              Another bug fix. There was a regression introduced in v1.1.0-RC1 where it was no longer possible to specify the root directory of the SD card as 0:/. This is fixed in this release.
              Also this release candidate is intended to be the last one before final release of this version.
              Manuel
              My Tool Collection
              • 3mmundefined
                3mm @wilriker
                @wilriker
                Thank you very much!
                3mm
                • wilrikerundefined
                  wilriker
                  Arch User Repository Package
                  For Arch Linux users: I have submitted a package to install rfm via AUR: https://aur.archlinux.org/packages/rfm/
                  This is available for x86_64, arm, armv6h, armv7h and aarch64.
                  Manuel
                  My Tool Collection
                  • wilrikerundefined
                    wilriker
                    Release v1.1.0
                    v1.1.0 has existed Release Candidate stage and is now available at GitHub Releases page or via Arch User Repository.
                    Reiterating the changes:
                    This release implements the persisting of -exclude parameter values in rfm.toml. These parameters will be persisted separately for backup and upload command so they do not confuse each other.
                    A new keyword reset has been added as a recognized value for the -exclude parameter to delete all persisted excludes for the current command, i.e.
                    rfm backup -exclude reset ...
                    will remove all persisted excludes for the backup command. Further -exclude parameter after that (even in the same command) will add new excludes.
                    Note that order is relevant, i.e.
                    rfm backup -exclude 0:/gcodes -exclude reset backup-dir 0:/
                    will backup everything in 0:/ since the given exclude for 0:/gcodes was reset by the following -exclude reset parameter.
                    Bug Fixes
                    • -removeLocal was broken for files (working for directories though)
                    • Sub-command upload would fail most of the times (this was fixed between RC3 and this version)
                    Manuel
                    My Tool Collection
                    • fmaundefined
                      fma
                      I'm trying to use your script, but I always get 'invalid character '<' looking for beginning of value' error. What am I doing wrong?
                      I'm using the amd64 version...
                      Thanks.
                      Frédéric
                      • wilrikerundefined
                        wilriker @fma
                        @fma This happens if the Duet responded with an HTML error page instead of a JSON error. I've seen this happen more often recently but so far have not found the cause.
                        Are you using the latest v1.1.0 final release above?
                        Also which sub-command does this happen for? Also you can use the parameter -debug to see the actual response coming from the Duet. This might give a hint what's going wrong.
                        Manuel
                        My Tool Collection
                        • fmaundefined
                          fma
                          Yes, I'm using the final release.
                          The error happens with all commands, and -debug does not give much info:
                          ./rfm ls 0:/ -debug
                          0::
                          2019/08/18 12:52:40 invalid character '<' looking for beginning of value
                          BTW, does it require a specific version of RRF? Im' running 2.02RC2...
                          Frédéric
                          • wilrikerundefined
                            wilriker @fma
                            @fma It should work with any version of RRF. Though the -debug parameter has to come before the location to list (in this case) or more general: before any parameter that does not have its own -something prefix.
                            Manuel
                            My Tool Collection
                            • fmaundefined
                              fma
                              My bad, I made a mistake in the device name! All seems to work fine 🙂
                              Thanks for your help.
                              Frédéric
                              • wilrikerundefined
                                wilriker @fma
                                @fma I'm glad it was that simple. 🙂
                                Manuel
                                My Tool Collection
                                • wilrikerundefined
                                  wilriker
                                  Release v1.1.1
                                  v1.1.1 has been release and can be found at GitHub Releases page.
                                  Changes
                                  • New -debug option to output the HTTP requests being sent to RRF
                                  • Add CRC32 checksum as HTTP header to file uploads (supported by RRF 2.04RC3 and newer).
                                  Manuel
                                  My Tool Collection
                                  • PaulHewundefined
                                    PaulHew
                                    This post is deleted!
                                    • PCRundefined
                                      PCR
                                      @wilriker Is it possibble to upload a file and start the print?
                                      Best
                                      • wilrikerundefined
                                        wilriker @PCR
                                        @PCR No, this is not a feature of rfm. It was and is intended to manage files on the SD card but not further interaction with the RepRapFirmware.
                                        Manuel
                                        My Tool Collection
                                        • PCRundefined
                                          PCR
                                          Ah OK. Thank you! BTW will it work with an DUET3 with a PI?
                                          Best
                                          • wilrikerundefined
                                            wilriker @PCR
                                            @PCR said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                                            No, it won't because in that setup the files are located on the RPi and for Linux there are much better file managers than I could ever come up with. 😉
                                            Manuel
                                            My Tool Collection
