    Pay for config / json files for my corexy printer build.
    67
    5.7k
    • Stevoundefined
      Stevo @Phaedrux
      @phaedrux should I swap around the x and “move slowly” commands ? Towards the end of the file
        That will depend if the end stops will still be lined up or not. If you need to get Y homed first to line up X, is the switch contact area large enough to trigger 5mm away? If it's still going to miss, you can switch the order of the second X and Y moves so that it moves Y first.
        You can copy and paste each line of the macro into the gcode console to execute it one at a time for testing to make sure it actually works.
        Stevoundefined 1 Reply Last reply Reply Quote 0
        • Stevoundefined
          Stevo @Phaedrux
          @phaedrux thank you very much like that
          • DanLundefined
            DanL
            @stevo said in Pay for config / json files for my corexy printer build.:
            ; generated by RepRapFirmware Configuration Tool v2 on Wed Jun 26 2019 19:39:28 GMT+0100 (BST)
            G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
            G1 R1 X0 Y0 ; go back to the last print move
            M83 ; relative extruder moves
            G1 E10 F3600 ; extrude 10mm of filament
            More of a question than a suggestion....
            Theway I read the above is that 10mm of filament will be deposited on top of the last print position. Shouldn't the extrude filament command be first...as a priming step....then move the extruder to the last position to start printing again?
            This is a really helpful thread...thanks!
            DanL
            • Stevoundefined
              Stevo
              Evening,
              I have done the final wire up and fitted the BLTouch and both X and Y limits.
              Been editing the files to get me to where I am as follows,
              When I turn on the printer the BL touch deploys and retracts twice and then lights up red self test ?
              I can then hit the home all and the y axis will home firstly then followed by the x axis homing after this has completed the print head moves to the centre of the printbed which then starts to rise but the probe does nothing in regards to the homing of the z axis.
              I realise I have not put the offsets in for the BLTouch just wanted to get an understanding of how the z homing should work.
              Have wired BLTouch as per be true 3d link
              Would appreciate a pointer please.
              ; generated by RepRapFirmware Configuration Tool v2 on Tue Jul 23 2019 21:10:42 GMT+0100 (BST)
              M669 K1 ; Select CoreXY mode
              M550 P"WILE E COYOTE" ; Set machine name
              M552 S1 ; Enable network
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              M569 P0 S1 ; Physical drive 0 goes forwards
              M569 P1 S1 ; Physical drive 1 goes forwards
              M569 P2 S0 ; Physical drive 2 goes backwards
              M569 P3 S1 ; Physical drive 3 goes forwards
              M92 X80.00 Y80.00 Z1600.00 E420.00 ; Set steps per mm
              M566 X900.00 Y900.00 Z30.00 E2400 ; Set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z144.00 E1200.00 ; Set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
              M906 X800.00 Y800.00 Z2000.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X-220 Y-220 Z0 S1 ; Set axis minima
              M208 X220 Y220 Z660 S0 ; Set axis maxima
              M574 X1 Y1 S0 ; Set active low and disabled endstops
              M574 Z1 S2 ; Define Z to use Probe. Home to Min.
              M558 P5 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. Not using on XY, but using it on Z.
              G31 P25 X0 Y-25.3 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height
              M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
              M558 P9 H5 F100 T2000 ; Set Z probe type to bltouch and the dive height + speeds
              G31 X0 Y0 Z0 P25 ; Set Z probe trigger value, offset and trigger height
              M557 X220:220 Y-220:220 S20 ; Define mesh grid
              ; BLTouch - Heaters
              M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
              M140 H-1 ; Disable heated bed
              M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
              M106 P0 S0 I0 F500 H-1 C ; Part cooling fan
              M563 P0 D0 H1 ; Define tool 0
              T0 ; Select first tool
              ; homeall.g
              ; called to home all axes
              G91 ; relative positioning
              G1 Z15 F6000 S2 ; lift Z relative to current position
              G1 S1 Y-445 F1800 ; move quickly to Y axis endstop and stop there (first pass)
              G1 Y5 F6000 ; go back a few mm
              G1 S1 Y-445 F360 ; move slowly to Y axis endstop once more (second pass)
              G1 S1 X-445 F1800 ; move quickly to X axis endstop and stop there (first pass)
              G1 X5 F6000 ; go back a few mm
              G1 S1 X-445 F360 ; move slowly to X axis endstop once more (second pass)
              G90 ; absolute positioning
              G1 X0 Y0 F6000 ; go to first bed probe point and home Z
              ;G91 ; relative positioning
              ;G1 S2 Z15 F100 ; lift Z relative to current position
              ;G90 ; absolute positioning
              ; homez.g
              ; called to home the Z axis
              G30 ; Do a single probe to home our Z axis
              G90 ; Make sure we are in absolute mode
              G1 Z10 F6000 ; Rapidly move the Z axis to Z=10.
              ; homex.g
              ; called to home the X axis
              G1 Z-15 F6000 S2 ; lower Z again
              ; homey.g
              ; called to home the Y axis
              ; deployprobe.g
              ; called to deploy a physical Z probe
              M280 P3 S10 I1
              ; retractprobe.g
              ; called to retract a physical Z probe
              M280 P3 S90 I1
                Phaedrux Moderator @Stevo
                ; BLTouch - Heaters
                You've got a few commands duplicated there. You should probably clean those up to prevent future confusion.
                It would seem you are using 0,0 as bed center? Just checking.
                ; homez.g
                You may want to add a G1 X Y move before the G30 to place the probe in the same location as you do in homeall for consistency, unless you have different plans for using homez alone in certain situations. That's valid, but just be aware that G28 and G28 Z will give you very different results.
                ; BLTouch - Heaters
                ; deployprobe.g
                M280 P3 S10 I1
                You're unbinding heater pin 7, but then you're targeting servo 3 in your deploy and retract commands. I think this is the reason the probe isn't doing anything. If you are actually using pin 7, then change the servo commands to be P7 instead of P3.
                Did you test the deploy and retract macros? What happens if you send M401 and M402? (should be deploy and retract)
                Use this procedure for safely testing your probe. https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                • Stevoundefined
                  Stevo @Phaedrux
                  @phaedrux Thank you for the help as always much appreciated!
                  Will report back once I have sorted my mess out lol.
                  • Stevoundefined
                    Stevo
                    Evening all,
                    Now have signs of life from the BL touch on hitting the home button the bed lowers 15mm the y axis then homes followed by the x axis homing and then the printhead moves to the middle of the machine and deploys the probe and upon touching the bed and retracting the table lowers 15mm again.
                    Its a little hit and miss as sometimes when I turn the machine on the bl will just flash red and will not deploy at the z axis homing stage.
                    If I actually deploy the prove manually after one of these instances but prior to powering the machine on everything seems to be ok ?
                    G31 P25 X0 Y-25.3 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                    M558 P9 H15 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
                    G31 P500 X32 Y2 Z2.5 ; Set Z probe trigger value, offset and trigger height
                    M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    ; homeall.g
                    ; homex.g
                    ; homey.g
                    ; homez.g
                    G1 X0 Y0 F6000 ; go to first probe point
                      Some people add a command to reset the BLTouch out of an error state, before using it for probing. You can add this command in homez.g and homeall.g (before the G30 command), and if you wish in bed.g. It's an M280 command but I forget the details. You may need a short G4 delay command after it, to make sure that the reset happens before the firmware tries to deploy the probe.
                        Try adding this to the end of your config.g to clear any BLTouch errors and retract the pin just in case.
                        ; BLTOUCH PREP
                        G4 S1
                        M280 P7 S160 I1 		; Alarm Release and Push-Pin UP just in case it's in alarm and deployed
                        G4 S1
                        M402				; Retract probe just in case it's down
                        You've still got some probe settings duplicated in the endstops and zprobe section.
                        • Stevoundefined
                          Stevo
                          Thank you that's done the trick !
                          • Stevoundefined
                            Stevo
                            Evening all,
                            Just wanted to ask when the printer has finished its task how / where do I ask it to lower the bed and come back to the homing corner minima on x and y to cool print head down bearing in mind my origin is the centre of the build plate.
                            M104 S0 ;Turn off extruder heater
                            G91 ;Relative positioning
                            G1 Z 10 E-5 F300 ; Lower bed by 10mm and retract filament by 5mm
                            G1 S1 Y-150 X-150 F500 ;Move nozzle 150mm home direction out of the way of finished print.
                            M84 ;Motors off
                            G90 ;Absolute positioning
                            • zaptaundefined
                              zapta
                              Does this help? https://forum.duet3d.com/topic/6760/stop-g
                              • Stevoundefined
                                Stevo @zapta
                                @zapta thank you !
                                • Stevoundefined
                                  Stevo
                                  Evening all just wondered if one of you kind folk could cast an eye over my config file to see if it could be improved in any way please speeds and placement of codes within the file.
                                  As always your comments greatly received
                                  M550 P"CORE XY" ; Set machine name
                                  M92 X80.00 Y80.00 Z1600.00 E415.00 ; Set steps per mm
                                  G31 P25 X2 Y32 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                                  ; BLTOUCH PREP
                                  G4 S1
                                  G4 S1
                                  G31 P500 X32 Y2 Z0.96 ; Set Z probe trigger value, offset and trigger height
                                  ; BLTOUCH PREP
                                  G4 S1
                                  G4 S1
                                  • deckingmanundefined
                                    deckingman @Stevo
                                    @stevo If I was being really pedantic I'd say that you have disabled thermostatic mode for your part cooling fan (M106 P0 H-1) which is fine, but the comment after says "Thermostatic control is turned on" (should say "off").
                                    But I'm not feeling pedantic so I won't make that comment.
                                    Seriously, nothing leaps out as being obviously amiss. I think you are at the stage of playing around with things to see if the end result looks any better or can be printed faster without degrading quality. One good thing about Duet is that you can play around with things "one the fly".
                                    If you want, you can give your heaters and fans names for example such as "Hot end" rather than the default "heater 1" (M305 "S") or "Part fan" rather than "fan 0" (M106 "C").
                                    You could try firmware retraction (G10 /G11). It won't work any better than your slicer but you can play around with it "on the fly" which is a far easier way to tune the retraction settings.
                                    You could also play around with pressure advance (M572).
                                    • Stevoundefined
                                      Stevo
                                      Thank you for the input always appreciated !
                                      • Stevoundefined
                                        Stevo
                                        I have been tinkering with the driver speed settings in the config file only would this have any effect on the bltouch operation as when the x and y axis has homed and the head moves to the centre the bed raises a little before the bltouch has lowered the pin then changes its mind and lowers the bed.
                                        The bltouch then flashes red
                                          You can add a bit of a pause delay to the probe movements with M558 R0.5. This gives the BLTouch a half second chance to settle before starting to probe.
                                          • Stevoundefined
                                            Stevo
                                            Afternoon everyone,
                                            I wonder if I could seek some clarification please Part cooling fan and hot end fan operate as they should during the print apart from the part cooling fan not turning off when the print has finished which I'm guessing I need to add a line to my S3D end code this is what I have in the config g file .
                                            M106 P0 S0 I0 F500 H-1 ; Part cooling fan
                                            M106 P1 S1 I0 F500 H1 T35 ; Hot end fan set to come on and off at 35
                                            and S3D end code.
                                            M104 S0 ; extruder heater off
                                            G1 E-1 F300 ; retract the filament
                                            G1 Z15 F1000 S2 ; lift Z relative to current position
                                            G1 Y5 F1000 ; go back a few mm
                                            G1 X5 F1000 ; go back a few mm
                                            M84 ;steppers off
                                            G90 ;absolute positioning
